[GRASS-SVN] r65835 - in grass/trunk/scripts/r.import: . testsuite testsuite/data
Tue Aug 4 15:15:16 PDT 2015
Author: annakrat
Date: 2015-08-04 15:15:16 -0700 (Tue, 04 Aug 2015)
New Revision: 65835
Added:
   grass/trunk/scripts/r.import/testsuite/
   grass/trunk/scripts/r.import/testsuite/data/
   grass/trunk/scripts/r.import/testsuite/data/data1.tif
   grass/trunk/scripts/r.import/testsuite/data/data2.asc
   grass/trunk/scripts/r.import/testsuite/data/data2.asc.aux.xml
   grass/trunk/scripts/r.import/testsuite/data/data2.prj
   grass/trunk/scripts/r.import/testsuite/test_r_import.py
r.import: add testsuite
Added: grass/trunk/scripts/r.import/testsuite/data/data1.tif
(Binary files differ)
Property changes on: grass/trunk/scripts/r.import/testsuite/data/data1.tif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass/trunk/scripts/r.import/testsuite/data/data2.asc
--- grass/trunk/scripts/r.import/testsuite/data/data2.asc	                        (rev 0)
+++ grass/trunk/scripts/r.import/testsuite/data/data2.asc	2015-08-04 22:15:16 UTC (rev 65835)
@@ -0,0 +1,9 @@
+ncols        4
+nrows        3
+xllcorner    1544385.000000000000
+yllcorner    1553655.000000000000
+cellsize     30.000000000000
+NODATA_value 255
+ 22 22 21 21
+ 22 22 22 21
+ 21 22 22 22
Added: grass/trunk/scripts/r.import/testsuite/data/data2.asc.aux.xml
--- grass/trunk/scripts/r.import/testsuite/data/data2.asc.aux.xml	                        (rev 0)
+++ grass/trunk/scripts/r.import/testsuite/data/data2.asc.aux.xml	2015-08-04 22:15:16 UTC (rev 65835)
@@ -0,0 +1,274 @@
+<PAMDataset>
+  <Metadata>
+    <MDI key="AREA_OR_POINT">Area</MDI>
+    <MDI key="DataType">Thematic</MDI>
+  </Metadata>
+  <PAMRasterBand band="1">
+    <ColorInterp>Palette</ColorInterp>
+    <ColorTable>
+      <Entry c1="0" c2="0" c3="0" c4="255" />
+      <Entry c1="0" c2="249" c3="0" c4="255" />
+      <Entry c1="71" c2="107" c3="160" c4="255" />
+      <Entry c1="209" c2="221" c3="249" c4="255" />
+      <Entry c1="221" c2="201" c3="201" c4="255" />
+      <Entry c1="216" c2="147" c3="130" c4="255" />
+      <Entry c1="237" c2="0" c3="0" c4="255" />
+      <Entry c1="170" c2="0" c3="0" c4="255" />
+      <Entry c1="178" c2="173" c3="163" c4="255" />
+      <Entry c1="249" c2="249" c3="249" c4="255" />
+      <Entry c1="104" c2="170" c3="99" c4="255" />
+      <Entry c1="28" c2="99" c3="48" c4="255" />
+      <Entry c1="181" c2="201" c3="142" c4="255" />
+      <Entry c1="165" c2="140" c3="48" c4="255" />
+      <Entry c1="204" c2="186" c3="124" c4="255" />
+      <Entry c1="226" c2="226" c3="193" c4="255" />
+      <Entry c1="201" c2="201" c3="119" c4="255" />
+      <Entry c1="153" c2="193" c3="71" c4="255" />
+      <Entry c1="119" c2="173" c3="147" c4="255" />
+      <Entry c1="219" c2="216" c3="60" c4="255" />
+      <Entry c1="170" c2="112" c3="40" c4="255" />
+      <Entry c1="186" c2="216" c3="234" c4="255" />
+      <Entry c1="181" c2="211" c3="229" c4="255" />
+      <Entry c1="112" c2="163" c3="186" c4="255" />
+    </ColorTable>
+    <Metadata>
+      <MDI key="RepresentationType">THEMATIC</MDI>
+      <MDI key="STATISTICS_MAXIMUM">22</MDI>
+      <MDI key="STATISTICS_MEAN">21.666666666667</MDI>
+      <MDI key="STATISTICS_MINIMUM">21</MDI>
+      <MDI key="STATISTICS_STDDEV">0.47140452079098</MDI>
+    </Metadata>
+  </PAMRasterBand>
+</PAMDataset>
Added: grass/trunk/scripts/r.import/testsuite/data/data2.prj
--- grass/trunk/scripts/r.import/testsuite/data/data2.prj	                        (rev 0)
+++ grass/trunk/scripts/r.import/testsuite/data/data2.prj	2015-08-04 22:15:16 UTC (rev 65835)
@@ -0,0 +1 @@
+PROJCS["Albers_Conical_Equal_Area",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Albers"],PARAMETER["standard_parallel_1",29.5],PARAMETER["standard_parallel_2",45.5],PARAMETER["latitude_of_origin",23],PARAMETER["central_meridian",-96],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["Meter",1]]
\ No newline at end of file
Added: grass/trunk/scripts/r.import/testsuite/test_r_import.py
--- grass/trunk/scripts/r.import/testsuite/test_r_import.py	                        (rev 0)
+++ grass/trunk/scripts/r.import/testsuite/test_r_import.py	2015-08-04 22:15:16 UTC (rev 65835)
@@ -0,0 +1,50 @@
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestRImportRegion(TestCase):
+    imported = 'test_r_import_imported'
+    @classmethod
+    def setUpClass(cls):
+        cls.runModule('g.region', raster='elevation')
+    def tearDown(cls):
+        """Remove imported map after each test method"""
+        cls.runModule('g.remove', flags='f', type='raster',
+                      name=cls.imported)
+    def test_import_estimate(self):
+        """Test e flag"""
+        self.assertModule('r.import', input='data/data2.asc', output=self.imported,
+                          resample='nearest', flags='e')
+        self.assertRasterDoesNotExist(name=self.imported)
+    def test_import_same_proj_tif(self):
+        """Import tif in same proj, default params"""
+        self.assertModule('r.import', input='data/data1.tif', output=self.imported,
+                          resample='bilinear')
+        reference = dict(north=223490, south=223390, east=636820, west=636710,
+                         nsres=10, ewres=10, datatype='FCELL')
+        self.assertRasterFitsInfo(raster=self.imported, reference=reference)
+    def test_import_asc_custom_res(self):
+        """Import ASC in different projection, with specified resolution"""
+                          resample='nearest', resolution='value', resolution_value=30)
+        reference = dict(rows=3, cols=4,
+                         nsres=30, ewres=30, datatype='CELL')
+        self.assertRasterFitsInfo(raster=self.imported, reference=reference, precision=1.1)
+    def test_import_asc_region_extent(self):
+        """Import ASC in different projection in specified region"""
+        self.runModule('g.region', raster='elevation', n=223655, s=223600)
+                          resample='nearest', extent='region', resolution='region')
+        reference = dict(north=223655, south=223600)
+        self.assertRasterFitsInfo(raster=self.imported, reference=reference, precision=1e-6)
+if __name__ == '__main__':
+    test()
