Author: gianluca
Date: 2015-08-05 14:18:44 -0700 (Wed, 05 Aug 2015)
New Revision: 65840
Added:
grass-addons/grass7/raster/r.mcda.topsis/
grass-addons/grass7/raster/r.mcda.topsis/Makefile
grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.html
grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.py
topsis addons - first implements
Added: grass-addons/grass7/raster/r.mcda.topsis/Makefile
--- grass-addons/grass7/raster/r.mcda.topsis/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.mcda.topsis/Makefile 2015-08-05 21:18:44 UTC (rev 65840)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.mcda.topsis
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.html
--- grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.html (rev 0)
+++ grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.html 2015-08-05 21:18:44 UTC (rev 65840)
@@ -0,0 +1,21 @@
+<h2>DESCRIPTION</h2>
+<em>r.mcda.topsis</em> implements the ideal point algorithms based on TOPSIS model and returns a raster map shown the ranking geospatial alternatives. The user has to provide the weight values and preference (gain or cost) directly
+<h2>NOTES</h2>
+<p> For bug please contact Gianluca Massei (g_mass at libero.it)</P>
+<h2>REFERENCE</h2>
+<ol>
+ <li><p>Hwang C. L. and Yoon K. Multiple Objective Decision Making Methods and Applications, A State-of-the-Art Survey.Springer - Verlag , 1981.</</ol>
+<h2>SEE ALSO</h2>
+<p><em>r.mcda.fuzzy, r.mcda.electre, r.mcda.roughset, r.to.drsa, r.in.drsa</em></P>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p>
+<i>Last changed: $Date: 2014-01-21 23:14:02 +0100 (mar, 21 gen 2014) $</i>
Added: grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.py
--- grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.py (rev 0)
+++ grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.py 2015-08-05 21:18:44 UTC (rev 65840)
@@ -0,0 +1,160 @@
+#!/usr/bin/env python
+# MODULE: r.mcda.topsis
+# AUTHOR: Gianluca Massei - Antonio Boggia
+# PURPOSE: Generate a MCDA map based on TOPSIS algorthm.
+# Based on Hwang C. L. and Yoon K. Multiple Objective Decision
+# Making Methods and Applications, A State-of-the-Art Survey .
+# Springer - Verlag , 1981.
+# COPYRIGHT: c) 2015 Gianluca Massei, Antonio Boggia and the GRASS
+# Development Team. This program is free software under the
+# GNU General PublicLicense (>=v2). Read the file COPYING
+# that comes with GRASS for details.
+#%Module
+#% description: Generates a MCDA map based on TOPSIS algorthm.
+#% keyword: raster
+#% keyword: Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: criteria
+#% type: string
+#% multiple: yes
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of criteria raster maps
+#% required: yes
+#%end
+#%option
+#% key: preferences
+#% type: string
+#% key_desc: character
+#% description: preference (gain,cost)
+#% required: yes
+#%end
+#%option
+#% key: weights
+#% type: double
+#% description: weights (w1,w2,...,wn)
+#% multiple: yes
+#% required: yes
+#%end
+#%option
+#% key: topsismap
+#% type: string
+#% gisprompt: new_file,cell,output
+#% description: Ranked raster map
+#% required: yes
+#%end
+import sys
+import grass.script as gscript
+#import grass.script.array as garray
+from time import time
+def standardizedNormalizedMatrix(attributes,weights): #step1 and step2
+ criteria=[]
+ for criterion,weight in zip(attributes,weights):
+ critPow="critPow=pow(%s,2)" % (criterion)
+ gscript.mapcalc(critPow,overwrite='True')
+ stats=gscript.parse_command("r.univar",map='critPow',flags='g')
+ nameMap="_%s" % criterion
+ mapalgebra="%s=(%s/sqrt(%s))*%s" % (nameMap,criterion,stats['sum'],weight)
+ gscript.mapcalc(mapalgebra,overwrite='True')
+ criteria.append(nameMap)
+ return criteria
+def idealPoints(criteria,preference): #step3
+ idelaPointsList=[]
+ for c,p in zip(criteria,preference):
+ stats=gscript.parse_command("r.univar",map=c,flags='g')
+ if p=="gain":
+ ip=float(stats['max'])
+ elif p=="cost":
+ ip=float(stats['min'])
+ else:
+ ip=-9999
+ print "warning! %s doesn't compliant" % p
+ idelaPointsList.append(ip)
+ return idelaPointsList
+def worstPoints(criteria,preference):
+ worstPointsList=[]
+ if p=="gain":
+ wp=float(stats['min'])
+ elif p=="cost":
+ wp=float(stats['max'])
+ else:
+ wp=-9999
+ worstPointsList.append(wp)
+ return worstPointsList
+def idealPointDistance(idelaPointsList,criteria): #step4a
+ distance=[]
+ i=0
+ for c,ip in zip(criteria,idelaPointsList):
+ mapname="tmap_%s" % i
+ mapalgebra1="%s=pow((%s-%s),2)" % (mapname,c,ip)
+ print mapalgebra1
+ gscript.mapcalc(mapalgebra1,overwrite='True')
+ distance.append(mapname)
+ i=i+1
+ mapalgebra2="IdealPointDistance=sqrt(%s)" % ("+".join(distance))
+ print mapalgebra2
+ gscript.mapcalc(mapalgebra2,overwrite='True')
+ gscript.run_command("g.remove", flags='f', type='raster', name=",".join(distance))
+ return 0
+def worstPointDistance(worstPointsList,criteria): #step4b
+ distance=[]
+ i=0
+ for c,wp in zip(criteria,worstPointsList):
+ mapalgebra1="%s=pow((%s-%s),2)" % (mapname,c,wp)
+ i=i+1
+ mapalgebra2="WorstPointDistance=sqrt(%s)" % ("+".join(distance))
+def relativeCloseness(): #step5
+ pass
+def main():
+ "main function for TOPSIS algorithm"
+ #try:
+ start=time()
+ attributes=options['criteria'].split(',')
+ preferences=options['preferences'].split(',')
+ weights=options['weights'].split(',')
+ topsismap = options['topsismap']
+ criteria=standardizedNormalizedMatrix(attributes,weights)
+ idelaPointsList=idealPoints(criteria,preferences)
+ worstPointsList=worstPoints(criteria,preferences)
+ idealPointDistance(idelaPointsList,criteria)
+ worstPointDistance(worstPointsList,criteria)
+ relativeCloseness()
+ gscript.run_command("g.remove", flags='f', type='raster', name=",".join(criteria))
+ end=time()
+ print "Time computing-> %.4f s" % (end-start)
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ main()
Property changes on: grass-addons/grass7/raster/r.mcda.topsis/r.mcda.topsis.py
___________________________________________________________________
Added: svn:executable
