[GRASS-SVN] r65844 - in grass/trunk: display/d.grid raster/r.grow.distance raster/r.param.scale raster/r.proj raster/r.topidx raster/r.viewshed scripts/r.grow vector/v.extract vector/v.kernel vector/v.proj
svn_grass at osgeo.org
Thu Aug 6 20:03:21 PDT 2015
Author: wenzeslaus
Date: 2015-08-06 20:03:21 -0700 (Thu, 06 Aug 2015)
New Revision: 65844
grass/trunk/display/d.grid/main.c
grass/trunk/raster/r.grow.distance/main.c
grass/trunk/raster/r.param.scale/interface.c
grass/trunk/raster/r.proj/main.c
grass/trunk/raster/r.topidx/main.c
grass/trunk/raster/r.viewshed/main.cpp
grass/trunk/scripts/r.grow/r.grow.py
grass/trunk/vector/v.extract/main.c
grass/trunk/vector/v.kernel/main.c
grass/trunk/vector/v.proj/main.c
add various keywords to modules
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/display/d.grid/main.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -50,6 +50,7 @@
module = G_define_module();
G_add_keyword(_("display"));
G_add_keyword(_("cartography"));
+ G_add_keyword(_("graticule"));
module->description =
_("Overlays a user-specified grid "
"in the active display frame on the graphics monitor.");
Modified: grass/trunk/raster/r.grow.distance/main.c
--- grass/trunk/raster/r.grow.distance/main.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/raster/r.grow.distance/main.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -150,6 +150,7 @@
G_add_keyword(_("raster"));
G_add_keyword(_("distance"));
+ G_add_keyword(_("proximity"));
_("Generates a raster map containing distances to nearest raster features.");
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/raster/r.param.scale/interface.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -53,6 +53,9 @@
G_add_keyword(_("geomorphology"));
+ G_add_keyword(_("terrain"));
+ G_add_keyword(_("elevation"));
+ G_add_keyword(_("landform"));
module->label = _("Extracts terrain parameters from a DEM.");
module->description = _("Uses a multi-scale approach"
" by taking fitting quadratic parameters to any size window (via least squares).");
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/raster/r.proj/main.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -144,6 +144,7 @@
G_add_keyword(_("projection"));
G_add_keyword(_("transformation"));
+ G_add_keyword(_("import"));
_("Re-projects a raster map from given location to the current location.");
Modified: grass/trunk/raster/r.topidx/main.c
--- grass/trunk/raster/r.topidx/main.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/raster/r.topidx/main.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -38,8 +38,9 @@
G_add_keyword(_("hydrology"));
+ G_add_keyword(_("wetness"));
- _("Creates a topographic index raster map from an elevation raster map.");
+ _("Creates a topographic index (wetness index) raster map from an elevation raster map.");
params.input = G_define_standard_option(G_OPT_R_ELEV);
params.input->key = "input";
Modified: grass/trunk/raster/r.viewshed/main.cpp
--- grass/trunk/raster/r.viewshed/main.cpp 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/raster/r.viewshed/main.cpp 2015-08-07 03:03:21 UTC (rev 65844)
@@ -115,6 +115,7 @@
G_add_keyword(_("viewshed"));
G_add_keyword(_("line of sight"));
+ G_add_keyword(_("LOS"));
module->label = _("Computes the viewshed of a point on an elevation raster map.");
module->description = _("Default format: NULL (invisible), vertical angle wrt viewpoint (visible).");
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/scripts/r.grow/r.grow.py 2015-08-07 03:03:21 UTC (rev 65844)
@@ -17,6 +17,8 @@
#%Module
#% description: Generates a raster map layer with contiguous areas grown by one cell.
#% keyword: raster
+#% keyword: distance
+#% keyword: proximity
#%end
#%flag
#% key: m
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/vector/v.extract/main.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -76,6 +76,8 @@
G_add_keyword(_("vector"));
G_add_keyword(_("extract"));
+ G_add_keyword(_("select"));
+ G_add_keyword(_("dissolve"));
_("Selects vector features from an existing vector map and "
"creates a new vector map containing only the selected features.");
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/vector/v.kernel/main.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -108,6 +108,9 @@
G_add_keyword(_("kernel density"));
+ G_add_keyword(_("point density"));
+ G_add_keyword(_("heatmap"));
+ G_add_keyword(_("hotspot"));
module->label =
_("Generates a raster density map from vector points map.");
module->description = _("Density is computed using a moving kernel. "
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c 2015-08-07 02:17:59 UTC (rev 65843)
+++ grass/trunk/vector/v.proj/main.c 2015-08-07 03:03:21 UTC (rev 65844)
@@ -67,6 +67,7 @@
module->description = _("Re-projects a vector map from one location to the current location.");
/* set up the options and flags for the command line parser */
