[GRASS-SVN] r65859 - grass/trunk/display/d.vect.thematic
svn_grass at osgeo.org
Sat Aug 8 07:15:17 PDT 2015
Author: neteler
Date: 2015-08-08 07:15:17 -0700 (Sat, 08 Aug 2015)
New Revision: 65859
grass/trunk/display/d.vect.thematic/d.vect.thematic.html
d.vect.thematic manual: example expanded (contributed by Vero Andreo)
Modified: grass/trunk/display/d.vect.thematic/d.vect.thematic.html
--- grass/trunk/display/d.vect.thematic/d.vect.thematic.html 2015-08-08 14:13:21 UTC (rev 65858)
+++ grass/trunk/display/d.vect.thematic/d.vect.thematic.html 2015-08-08 14:15:17 UTC (rev 65859)
@@ -51,6 +51,29 @@
nbclasses=5 colors=0:0:255,50:100:255,255:100:50,255:0:0,156:0:0
</pre></div>
+To actually draw the legend for the polygons in the graphical
+display, the procedure is:
+<div class="code"><pre>
+# first save legend instructions to a file
+d.vect.thematic -n map=communes2 column=pop/area algorithm=std \
+ nbclasses=5 colors=0:0:255,50:100:255,255:100:50,255:0:0,156:0:0 \
+ legendfile=legend_pop_dens
+# open a monitor
+d.mon wx0
+# draw the map
+d.vect.thematic map=communes2 column=pop/area algorithm=std \
+# draw the legend
+d.graph input=legend_pop_dens
+</pre></div>
+If you are not pleased with the legend, you can edit the legend file
+as you wish and run the process again.
<h2>SEE ALSO</h2>
<em>
