[GRASS-SVN] r65870 - in grass-addons/grass7/raster: . r.soils.texture
svn_grass at osgeo.org
Sun Aug 9 12:59:21 PDT 2015
Author: gianluca
Date: 2015-08-09 12:59:21 -0700 (Sun, 09 Aug 2015)
New Revision: 65870
Added:
grass-addons/grass7/raster/r.soils.texture/
grass-addons/grass7/raster/r.soils.texture/Makefile
grass-addons/grass7/raster/r.soils.texture/local_include.h
grass-addons/grass7/raster/r.soils.texture/main.c
grass-addons/grass7/raster/r.soils.texture/r.soils.texture.html
grass-addons/grass7/raster/r.soils.texture/scheme/
r.soils.texture - grass7 porting
Property changes on: grass-addons/grass7/raster/r.soils.texture
___________________________________________________________________
Added: svn:ignore
+ OBJ.x86_64-unknown-linux-gnu
Added: grass-addons/grass7/raster/r.soils.texture/Makefile
--- grass-addons/grass7/raster/r.soils.texture/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.soils.texture/Makefile 2015-08-09 19:59:21 UTC (rev 65870)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.soils.texture
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.soils.texture/local_include.h
--- grass-addons/grass7/raster/r.soils.texture/local_include.h (rev 0)
+++ grass-addons/grass7/raster/r.soils.texture/local_include.h 2015-08-09 19:59:21 UTC (rev 65870)
@@ -0,0 +1,42 @@
+ * MODULE: r.soils.texture
+ * AUTHOR(S): Gianluca Massei (g_massa at libero.it)
+ * PURPOSE: Intended to define soil texture from sand and clay grid.
+ * Require texture scheme supplied in scheme directory
+ * COPYRIGHT: (C) 2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+/* for gettext macros - i18N localization */
+#define MAX_POINT 15
+#define MAX_LABEL 50
+/*///////List element prototipe/////////////////////////////// */
+struct TextureTriangleCoord
+ int numVertex; // polygons vertex of texture triangle
+ float xSand[MAX_POINT], yClay[MAX_POINT]; // coordinate vector polygons in triangle
+ int codeTexture; // code for identify textural type
+ struct TextureTriangleCoord *PointToNext; //pointer to next element
+struct label_struct
+ int id;
+ char etichetta[1024];
+ * function prototype
+struct TextureTriangleCoord *ReadTriangle(int *, char *); //read texture file criteria (es. USDA.DAT)
+int ReadList(struct TextureTriangleCoord *, int *, float, float); //read all list of texture criteria
+int DefineTexture(int numVert, float *xSand, float *yClay, float SandVal, float ClayVal, int codeTxt); /*define texture for each point */
+void reclassTexture(char *SchemeName, char *result); //reclass texture file with label
Added: grass-addons/grass7/raster/r.soils.texture/main.c
--- grass-addons/grass7/raster/r.soils.texture/main.c (rev 0)
+++ grass-addons/grass7/raster/r.soils.texture/main.c 2015-08-09 19:59:21 UTC (rev 65870)
@@ -0,0 +1,408 @@
+ * COPYRIGHT: (C) 2008 by Gianluca MAssei and the GRASS Development Team
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <stddef.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster.h>
+#include "local_include.h"
+/* global function declaration */
+extern CELL f_c(CELL);
+extern FCELL f_f(FCELL);
+extern DCELL f_d(DCELL);
+CELL c_calc(CELL c_sand, CELL c_clay, struct TextureTriangleCoord *punt_lista,
+ int *numPoly)
+ CELL out;
+ int polygons;
+ polygons = *numPoly;
+ out = ReadList(punt_lista, &polygons, c_sand, c_clay);
+ return out;
+FCELL f_calc(FCELL f_sand, FCELL f_clay,
+ struct TextureTriangleCoord * punt_lista, int *numPoly)
+ FCELL out;
+ int polygons;
+ out = ReadList(punt_lista, &polygons, f_sand, f_clay);
+ return out;
+DCELL d_calc(DCELL d_sand, DCELL d_clay,
+ DCELL out;
+ int polygons;
+ out = ReadList(punt_lista, &polygons, d_sand, d_clay);
+ return out;
+ * main function
+ * it copies raster inputSand raster file, calling the appropriate function for each
+ * data type (CELL, DCELL, FCELL)
+int main(int argc, char *argv[])
+ struct Cell_head cellhd; /* it stores region information, and header information of rasters */
+ char *SandName, *ClayName, *SchemeName; /* inputSand raster name */
+ char *result; /* output raster name */
+ char *mapsetSand, *mapsetClay; /* mapset name */
+ void *inrastSand, *inrastClay; /* input buffer */
+ unsigned char *outrast; /* output buffer */
+ int nrows, ncols;
+ int row, col;
+ int infdSand, infdClay, outfd; /* file descriptor */
+ int verbose;
+ int polygons;
+ RASTER_MAP_TYPE data_type_Sand, data_type_Clay, data_type; /* type of the map (CELL/DCELL/...) */
+ struct History history; /* holds meta-data (title, comments,..)*/
+ struct GModule *module; /* GRASS module for parsing arguments */
+ struct Option *inputSand, *inputClay, *inputTextureScheme, *output; /* options */
+ struct TextureTriangleCoord *punt_lista;
+ /* initialize GIS environment */
+ G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
+ /* initialize module */
+ module = G_define_module();
+ G_add_keyword(_("raster"));
+ G_add_keyword(_("soil"));
+ G_add_keyword(_("texture"));
+ module->description = _("Define soil texture from sand and clay grid.");
+ /* Define the different options for SAND file */
+ inputSand = G_define_standard_option(G_OPT_R_INPUT);
+ inputSand->key = "sand";
+ inputSand->description = _("Name of input sand map [0-100]");
+ /* Define the different options for CLAY file */
+ inputClay = G_define_standard_option(G_OPT_R_INPUT);
+ inputClay->key = "clay";
+ inputClay->description = _("Name of input clay map [0-100]");
+ /*Define the texture file scheme: USDA, FAO, International or other scheme */
+ inputTextureScheme = G_define_standard_option(G_OPT_F_INPUT);
+ inputTextureScheme->key = "scheme";
+ inputTextureScheme->description = _("Text file with texture scheme");
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
+ /* options and flags pareser */
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ /* stores options and flags to variables */
+ SandName = inputSand->answer;
+ ClayName = inputClay->answer;
+ SchemeName = inputTextureScheme->answer;
+ result = output->answer;
+/*************************************control sand file*****************************/
+ /* returns NULL if the map was not found in any mapset,
+ * mapset name otherwise */
+ mapsetSand = (char *) G_find_raster2(SandName, "");
+ if (mapsetSand == NULL)
+ G_fatal_error(_("cell file [%s] not found"), SandName);
+ /* if (G_legal_filename(result) < 0)
+ G_fatal_error(_("[%s] is an illegal name"), result);*/
+ /* determine the input map type (CELL/FCELL/DCELL) */
+ data_type_Sand = Rast_map_type(SandName, mapsetSand);
+ /* G_open_cell_old - returns file destriptor (>0) */
+ infdSand = Rast_open_old(SandName, mapsetSand);
+ /* controlling, if we can open inputSand raster */
+ Rast_get_cellhd(SandName, mapsetSand, &cellhd);
+ G_debug(3, "number of rows %d", cellhd.rows);
+/*********************************control clay file **********************************/
+ mapsetClay = (char *) G_find_raster2(ClayName, "");
+ if (mapsetClay == NULL)
+ G_fatal_error(_("cell file [%s] not found"), ClayName);
+ /*if (G_legal_filename(result) < 0)
+ data_type_Clay = Rast_map_type(ClayName, mapsetClay);
+ infdClay = Rast_open_old(ClayName, mapsetClay);
+ /* controlling, if we can open inputClay raster */
+ Rast_get_cellhd(ClayName, mapsetClay, &cellhd);
+ /* Allocate input buffer */
+ inrastSand = Rast_allocate_buf(data_type_Sand);
+ inrastClay = Rast_allocate_buf(data_type_Clay);
+ /* Allocate output buffer, use input Sand map data_type */
+ nrows = Rast_window_rows();
+ ncols = Rast_window_rows();
+ outrast = Rast_allocate_buf(data_type_Sand);
+ data_type = data_type_Sand;
+ /* controlling, if we can write the raster */
+ outfd = Rast_open_new(result, data_type);
+ punt_lista = ReadTriangle(&polygons, SchemeName); //read texture criteria file (es USDA.DAT) and buil a list
+ CELL c_sand, c_clay, c;
+ FCELL f_sand, f_clay, f;
+ DCELL d_sand, d_clay, d;
+ /* for each row */
+ for (row = 0; row < nrows; row++) {
+ if (verbose)
+ G_percent(row, nrows, 2);
+ /* read input Sand map */
+ Rast_get_row(infdSand, inrastSand, row, data_type_Sand);
+ Rast_get_row(infdClay, inrastClay, row, data_type_Sand);
+ /* process the data */
+ for (col = 0; col < ncols; col++) {
+ /* use different function for each data type */
+ switch (data_type) {
+ case CELL_TYPE:
+ c_sand = ((CELL *) inrastSand)[col];
+ c_clay = ((CELL *) inrastClay)[col];
+ c = c_calc(c_sand, c_clay, punt_lista, &polygons); /* calculate */
+ ((CELL *) outrast)[col] = c;
+ break;
+ case FCELL_TYPE:
+ f_sand = ((FCELL *) inrastSand)[col];
+ f_clay = ((FCELL *) inrastClay)[col];
+ f = f_calc(f_sand, f_clay, punt_lista, &polygons); /* calculate */
+ ((FCELL *) outrast)[col] = f;
+ break;
+ case DCELL_TYPE:
+ d_sand = ((DCELL *) inrastSand)[col];
+ d_clay = ((DCELL *) inrastClay)[col];
+ d = d_calc(d_sand, d_clay, punt_lista, &polygons); /* calculate */
+ ((DCELL *) outrast)[col] = d;
+ break;
+ /* write raster row to output raster file */
+ Rast_put_row(outfd, outrast, data_type);
+ /* memory cleanup */
+ G_free(inrastSand);
+ G_free(inrastClay);
+ G_free(outrast);
+ /* closing raster files */
+ Rast_close(infdSand);
+ Rast_close(infdClay);
+ Rast_close(outfd);
+ /* add command line incantation to history file */
+ Rast_short_history(result, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(result, &history);
+ reclassTexture(SchemeName, result);
+ G_done_msg(_("Soil texture file generated with name: <%s>"), result);
+ exit(EXIT_SUCCESS);
+struct TextureTriangleCoord *ReadTriangle(int *numPoly, char *SchemeName)
+ /*//////////// Declare Read Poly texture structure //////////////////////////// */
+ struct TextureTriangleCoord Triangle, *pTxt, *paus;
+ pTxt = &Triangle; //pointer to struct
+ int i, j, polygons;
+ FILE *fp_dat;
+ fp_dat = fopen(SchemeName, "r");
+ if (fp_dat == NULL) {
+ printf("Could not read from <%s>", SchemeName);
+ fscanf(fp_dat, "%d", numPoly);
+ if (polygons == 0) {
+ pTxt = NULL; /*break if no polygons */
+ else {
+ pTxt = (struct TextureTriangleCoord *)malloc(sizeof(struct TextureTriangleCoord)); /*first struct PolygonCoord */
+ fscanf(fp_dat, "%d", &pTxt->codeTexture);
+ fscanf(fp_dat, "%d", &pTxt->numVertex);
+ for (j = 0; j < (pTxt->numVertex); j++) { //fill sand array with coord. polygons array
+ fscanf(fp_dat, "%f", &pTxt->xSand[j]);
+ for (j = 0; j < (pTxt->numVertex); j++) { //fill clay array with coord. polygons array
+ fscanf(fp_dat, "%f", &pTxt->yClay[j]);
+ paus = pTxt;
+ for (i = 2; i <= polygons; i++) {
+ paus->PointToNext =
+ (struct TextureTriangleCoord *)
+ malloc(sizeof(struct TextureTriangleCoord));
+ paus = paus->PointToNext;
+ fscanf(fp_dat, "%d", &paus->codeTexture);
+ fscanf(fp_dat, "%d", &paus->numVertex);
+ for (j = 0; j < (paus->numVertex); j++) { //fill sand array with coord. polygons array
+ fscanf(fp_dat, "%f", &paus->xSand[j]);
+ for (j = 0; j < (paus->numVertex); j++) { //fill clay array with coord. polygons array
+ fscanf(fp_dat, "%f", &paus->yClay[j]);
+ paus->PointToNext = NULL;
+ fclose(fp_dat);
+ return (pTxt);
+int ReadList(struct TextureTriangleCoord *pTxt, int *numPoly, float SandVal,
+ float ClayVal)
+ int polygons, textureOUT;
+ textureOUT = 0;
+ while (pTxt != NULL && textureOUT == 0) {
+ textureOUT =
+ DefineTexture(pTxt->numVertex, pTxt->xSand, pTxt->yClay, SandVal,
+ ClayVal, pTxt->codeTexture);
+ pTxt = pTxt->PointToNext;
+ return textureOUT;
+ float ClayVal, int codeTxt)
+ int i, j, textureVER = 0;
+ for (i = 0, j = numVert - 1; i < numVert; j = i++) {
+ if ((((yClay[i] <= ClayVal) && (ClayVal < yClay[j])) ||
+ ((yClay[j] <= ClayVal) && (ClayVal < yClay[i]))) &&
+ (SandVal <
+ (xSand[j] - xSand[i]) * (ClayVal - yClay[i]) / (yClay[j] -
+ yClay[i]) +
+ xSand[i]))
+ textureVER = !textureVER;
+ if (textureVER == 1) {
+ textureVER = codeTxt;
+ else {
+ textureVER = 0;
+ return textureVER;
+{ /*reclass texture file with label in scheme file */
+ int control, i;
+ char c, tag[1024];
+ struct label_struct label, *plabel;
+ struct Categories pcats;
+ FILE *fp_dat;
+ DCELL dcat;
+ plabel = &label;
+ Rast_init_cats ("", &pcats); /*Initialize category structure. */
+ if ( Rast_read_cats (result, G_mapset(), &pcats) < 0) /*read raster category file */
+ G_fatal_error(("%s: %s in %s - can't read category file"),
+ G_program_name(), result, G_mapset());
+ G_fatal_error(_("Could not open <%s>"), SchemeName);
+ fscanf(fp_dat, "%d", &control);
+ while (c != '#') {
+ fscanf(fp_dat, "%c", &c);
+ sprintf(tag, "NULL");
+ /*set a category label. The label is copied into the cats structure for category n. */
+ Rast_set_d_cat(&dcat, &dcat, tag, &pcats);
+ for (i = 1; i <= control; i++) {
+ dcat=(double) i;
+ fscanf(fp_dat, "%s", &plabel->etichetta);
+ sprintf(tag, "%s", plabel->etichetta);
+ Rast_write_cats (result, &pcats);
+ fclose(fp_dat);
+ /*return (0); */
Added: grass-addons/grass7/raster/r.soils.texture/r.soils.texture.html
--- grass-addons/grass7/raster/r.soils.texture/r.soils.texture.html (rev 0)
+++ grass-addons/grass7/raster/r.soils.texture/r.soils.texture.html 2015-08-09 19:59:21 UTC (rev 65870)
@@ -0,0 +1,39 @@
+<h2>DESCRIPTION</h2>
+<em>r.soils.texture</em> define soils texture from sand and clay
+distribution grid and a texture scheme definition.
+<br>
+Sand and clay grid are simple grid theme; scheme file is text
+ASCII file with *.dat extention like USDA.dat, FAO.dat and
+nternational.dat supplied with source code module in scheme
+directory.
+<h2>SEE ALSO<br></h2>
+<em><a href="http://grass.osgeo.org/programming6/">GRASS 7 Programmer's Manual</a></em>
+<h2>AUTHOR</h2>
+Gianluca Massei (g_massa at libero.it)
+<br>
+<br>
+<h2>REFERENCE</h2>
+<p>Bourke P., 1987 Determining if a point lies on the interior of a polygon. Downloaded printed</p>
+<p>Cavallini P, Neteler M., 2005 I GIS Open Source: una alternativa possible? MondoGIS n° 47</p>
+<p>Cavallini P, Neteler M., 2006 L'analisi geografica Open Source: GRASS GIS parte 2 raster MondoGIS n° 52</p>
+<p>Neteler M. and H. Mitasova 2004 Open Source GIS: A GRASS GIS Approach - Kluwer Academic Publisher/Springer, Boston, -Second edition ISBN: 1-4020-8064-6</p>
+<p>Sanesi G., 2000 - Elementi di pedologia - Edagricole, Bologna</p>
+<p>Texture AutoLookup (TAL) ver 4.2, 2002 </p>
+<p>Van Rossum G. - 2005 - Manuale di riferimento di python - Ed. Italiana, Fred L. Drake, Jr., editor</p>
+<p>WATTON J. D., 1997 - Comparing C, Fortran, Lisp, java, python, perl,
+scheme (guile), and tcl using a floating point numerical test - point inside
+polygon. Applied mathematics and computer technology center alcoa technical
+center. Distribution documents.</p>
+<p>
+<br><br>
+</p>
+<p>
+<i>Last changed: $Date: 2013-07-12 00:46:52 +0200 (ven, 12 lug 2013) $</i>
