[GRASS-SVN] r65878 - grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata
svn_grass at osgeo.org
Mon Aug 10 07:33:40 PDT 2015
Author: krejcmat
Date: 2015-08-10 07:33:39 -0700 (Mon, 10 Aug 2015)
New Revision: 65878
grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html
grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
update for g.gui.metadata
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html 2015-08-10 14:24:30 UTC (rev 65877)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.html 2015-08-10 14:33:39 UTC (rev 65878)
@@ -5,7 +5,7 @@
<p>
-Metadata editor includes graphical interface for conversion metadata from r.info and v.info to ISO based metadata, editing metadata files and creating metadata templates. In addition, the graphical module allows validating of INSPIRE and Basic profile.
+Metadata editor includes graphical interface for conversion metadata from r.info and v.info to ISO based metadata, editing metadata files and creating metadata templates. In addition, the graphical module allows validating of INSPIRE and GRASS Basic profile.
<h2>NOTES</h2>
@@ -35,15 +35,16 @@
get from native GRASS metadata are filled by text
string <tt>'$NULL'</tt>. This rule applies for both profiles.
+<h4>Profile for temporal datast</h4>
+This function is based on t.info.iso which allows to create ISO based metadata for temporal maps. Product of this function cannot be compiled by INSPIRE profile becouse a additionl attributes from ISO 19115 package have been added.
<h3>Creation of metadata</h3>
Editor offers two editing modes. The first one allows to create metadata from selected GRASS maps from an active location. The second one allows editing of external metadata file.
+<h4>Metadata editor for spatial and temporal maps</h4>
-<h4>Metadata map editor </h4>
-The basis of this editor mode is similar to r|v.info.iso. After selection of map, the editor convert native metadata of map to ISO based. By exported xml file is metadata editor initialized.
+The basis of this editor is similar to r|v.info.iso. After selection of map, the editor convert native metadata of map to ISO based. By exported xml file is metadata editor initialized.
There are three options to select:
<b>basic</b>,
<b>inspire</b> or <b>load custom</b>. Last one allows to load metadata profile from file. For example in case of using predefined template. The intersection of GRASS Basic profile(all available metadata for selected map) and loaded custom profile will proced with this selection.
@@ -78,12 +79,22 @@
The g.gui.metadata module allows updating native GRASS metadata with using modules r.support and v.support. The intersection between ISO based metadata and r|v.support is limited by available parameters for these modules.
+<h3>Creating reports for GRASS maps in PDF format</h3>
+This function allows to automatically generate metadata reports to PDF document. Missed values are filled by "Unknown" string.
+This tools supports ato generating report
<h2>SEE ALSO</h2>
<em>
<a href="r.info.html">r.info</a>,
- <a href="v.info.iso.html">v.info.iso</a>
+ <a href="v.info.iso.html">v.info.iso</a>,
<a href="g.gui.metadata.html">g.gui.metadata</a>
+ <a href="db.csw.harvest">db.csw.harvest</a>
+ <a href="db.csw.admin">db.csw.admin</a>
+ <a href="db.csw.run">db.csw.run</a>
</em>
<p>
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py 2015-08-10 14:24:30 UTC (rev 65877)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py 2015-08-10 14:33:39 UTC (rev 65878)
@@ -28,38 +28,35 @@
#% keyword: metadata
#%end
-import os
-import sys
-import glob
-from lxml import etree
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'mdlib'))
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'pdf'))
+import sys,os
+sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]),'etc', 'mdlib'))
+from lxml import etree
import wx
from wx.lib.buttons import ThemedGenBitmapTextButton as BitmapBtnTxt
-from wx import SplitterWindow, EVT_BUTTON
-from wx.lib.pubsub import setupkwargs, pub
+from wx import SplitterWindow
import grass.script as grass
-import grass.script.setup as gsetup
+from pydispatch import dispatcher
import webbrowser
import mdgrass
import mdutil
from mdpdffactory import PdfCreator
+from cswlib import CSWConnectionPanel
+from mdeditorfactory import MdMainEditor
-from core.utils import _
-from editor import MdMainEditor
from lmgr import datacatalog
from core.gcmd import RunCommand, GError, GMessage
import grass.temporal as tgis
-from core.utils import GetListOfLocations, ListOfMapsets
+import tempfile
# MAIN FRAME
-class MdMainFrame(wx.Frame):
+MAINFRAME=None
+class MdMainFrame(wx.Frame):
'''Main frame of metadata editor
@@ -94,41 +91,306 @@
self.editStatus=None
self.onInitEditor()
- pub.subscribe(self.initNewMD, 'NEW_MD.create')
- pub.subscribe(self.onEditingMode, 'EDITING_MODE.update')
- pub.subscribe(self.setStatusbarText, 'STATUS_BAR_TEXT.update')
- pub.subscribe(self.onExportTemplate, 'EXPORT_TEMPLATE.create')
- pub.subscribe(self.onExportPDF, 'EXPORT_PDF.create')
+ dispatcher.connect(self.initNewMD,signal= 'NEW_MD.create',sender=dispatcher.Any)
+ dispatcher.connect(self.onEditingMode,signal= 'EDITING_MODE.update',sender=dispatcher.Any)
+ dispatcher.connect(self.setStatusbarText,signal= 'STATUS_BAR_TEXT.update',sender=dispatcher.Any)
+ dispatcher.connect(self.onRefreshTreeBrowser,signal= 'REFRESH_TREE_BROWSER.update',sender=dispatcher.Any)
+ dispatcher.connect(self.onChangeEditMapProfile,signal= 'ISO_PROFILE.update',sender=dispatcher.Any)
+ dispatcher.connect(self.onUpdateGrassMetadata,signal= 'GRASS_METADATA.update',sender=dispatcher.Any)
- pub.subscribe(self.onExportXML, 'EXPORT_XML.create')
- pub.subscribe(self.onEditMapMetadata, 'EDIT_MAP_METADATA.create')
- pub.subscribe(self.onInitEditor, 'INIT_EDITOR.create')
- pub.subscribe(self.onTemplateEditor, 'TEMPLATE_EDITOR_STATUS.update')
- pub.subscribe(self.onHideLeftPanel, 'HIDE_LEFT_PANEL.update')
- pub.subscribe(self.onRefreshTreeBrowser, 'REFRESH_TREE_BROWSER.update')
- pub.subscribe(self.onChangeEditMapProfile, 'ISO_PROFILE.update')
- pub.subscribe(self.onUpdateGrassMetadata, 'GRASS_METADATA.update')
- pub.subscribe(self.setMdDestionation, 'MD_DESTINATION.update')
- pub.subscribe(self.onSetJaX, 'SET_JINJA_AND_XML.update')
+ def initConfigurePanel(self):
+ self.configPanelLeft=wx.Panel(self.leftPanel, id=wx.ID_ANY)
+ self.SetMinSize((240, -1))
+ self.mapGrassEdit = True
- def onSetJaX(self, jinja, xml):
- '''Set profile ad xml paths
- self.jinjaPath = jinja
- self.xmlPath = xml
+ self.rbGrass = wx.RadioButton(self.configPanelLeft, id=wx.ID_ANY, label='Metadata map editor', style=wx.RB_GROUP)
+ self.rbExternal = wx.RadioButton(self.configPanelLeft, id=wx.ID_ANY, label='Metadata external editor')
+ self.comboBoxProfile = wx.ComboBox(self.configPanelLeft, choices=['INSPIRE', 'GRASS BASIC', 'TEMPORAL','Load Custom'])
+ dispatcher.connect( self.onSetProfile, signal='SET_PROFILE.update', sender=dispatcher.Any )
+ self.comboBoxProfile.SetStringSelection('INSPIRE')
- def setMdDestionation(self, value):
- '''Set md
- self.mdDestination = value
+ self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbGrass.GetId())
+ self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbExternal.GetId())
- def initDefaultPathStorageMetadata(self):
- '''set working folder
+ def onSetRadioType(self, evt=None):
+ self.mapGrassEdit = self.rbGrass.GetValue()
+ if self.mapGrassEdit is False:
+ self.comboBoxProfile.Hide()
+ else:
+ self.comboBoxProfile.Show()
+ self.onEditingMode(editStatus=self.mapGrassEdit)
+ def onSetProfile(self, profile):
+ self.comboBoxProfile.SetStringSelection(profile)
+ def initToolbar(self):
+ #self.toolbarPanel=wx.Panel(self, id=wx.ID_ANY)
+ self.batch = False
+ self.extendEdit = False
+ self.toolbar = wx.ToolBar(self, 1, wx.DefaultPosition, (-1, -1))
+ bitmapSave = wx.Image(
+ os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'save.png'),
+ wx.BITMAP_TYPE_PNG).ConvertToBitmap()
+ bitmapNew = wx.Image(
+ os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'create.png'),
+ bitmapLoad = wx.Image(
+ os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'open.png'),
+ bitmaSettings = wx.Image(
+ os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'settings.png'),
+ #-------------------------------------------------------------------- EDIT
+ self.toolbar.AddSeparator()
+ bitmapEdit = wx.Image(
+ os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'edit.png'),
+ self.bttEdit = BitmapBtnTxt(self.toolbar, -1, bitmapEdit,size=(40, -1))
+ self.toolbar.AddControl(control=self.bttEdit)
+ self.bttEdit.Disable()
+ #-------------------------------------------------------------------- NEW SESION
+ #self.toolbar.AddSeparator()
+ self.bttNew = BitmapBtnTxt(self.toolbar, -1, bitmapNew, '', size=(40, -1))
+ self.toolbar.AddControl(control=self.bttNew)
+ self.bttNew.Disable()
+ #-------------------------------------------------------------------- NEW TEMPLATE
+ self.bttCreateTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapNew, "template", size=(100, -1))
+ self.toolbar.AddControl(control=self.bttCreateTemplate)
+ self.bttCreateTemplate.Disable()
+ #----------------------------------------------------------------- OPEN TEMPLATE
+ self.bttLoad = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "profile", size=(100, -1))
+ self.toolbar.AddControl(control=self.bttLoad)
+ self.bttLoad.Disable()
+ #---------------------------------------------------------------------- OPEN XML
+ self.bttLoadXml = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "xml")
+ self.toolbar.AddControl(control=self.bttLoadXml)
+ self.bttLoadXml.Disable()
+ #-------------------------------------------------------------------------- export xml
+ self.bttSave = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "xml")
+ self.bttSave.Disable()
+ self.toolbar.AddControl(control=self.bttSave)
+ #-------------------------------------------------------------------------- export template
+ self.bttSaveTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "template", size=(100, -1))
+ self.bttSaveTemplate.Disable()
+ self.toolbar.AddControl(control=self.bttSaveTemplate)
+ #-------------------------------------------------------------------------- update grass
+ self.bttUpdateGRASS = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "GRASS", size=(100, -1))
+ self.bttUpdateGRASS.Disable()
+ self.toolbar.AddControl(control=self.bttUpdateGRASS)
+ #-------------------------------------------------------------------------- export pdf
+ self.bttExportPdf = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "pdf", size=(100, -1))
+ self.bttExportPdf.Disable()
+ self.toolbar.AddControl(control=self.bttExportPdf)
+ #-------------------------------------------------------------------------- publish csw
+ self.bttExportCSW = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "csw", size=(100, -1))
+ self.bttExportCSW.Disable()
+ self.toolbar.AddControl(control=self.bttExportCSW)
+ #-------------------------------------------------------------------------- Config
+ self.bttConfig = BitmapBtnTxt(self.toolbar, -1, bitmaSettings, "", size=(40, -1))
+ self.toolbar.AddControl(control=self.bttConfig)
+ self.toolbar.Realize()
+ self.bttLoad.Bind(wx.EVT_BUTTON, self.onLoadTemplate)
+ self.bttSave.Bind(wx.EVT_BUTTON, self.onSaveXML)
+ self.bttLoadXml.Bind(wx.EVT_BUTTON, self.onLoadXml)
+ self.bttSaveTemplate.Bind(wx.EVT_BUTTON, self.onSaveTemplate)
+ self.bttNew.Bind(wx.EVT_BUTTON, self.onNewSession)
+ self.bttEdit.Bind(wx.EVT_BUTTON, self.onEdit)
+ self.bttExportCSW.Bind(wx.EVT_BUTTON, self.onExportCSW)
+ self.bttCreateTemplate.Bind(wx.EVT_BUTTON, self.onCreateTemplate)
+ self.bttExportPdf.Bind(wx.EVT_BUTTON, self.onExportPdf)
+ self.bttConfig.Bind(wx.EVT_BUTTON,self.onSettings)
+ def onExportCSW(self,evt):
+ self.cswDialog = wx.Dialog(self, id=wx.ID_ANY,
+ title='Geometry creator',
+ style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+ size=wx.DefaultSize,
+ pos=wx.DefaultPosition)
+ self.cswPanel=CswPublisher(self.cswDialog,self)
+ self.cswDialog.SetSize((1024, 760))
+ self.cswPanel.publishBtt.Bind(wx.EVT_BUTTON, self._onExportCsw)
+ dbSizer = wx.BoxSizer(wx.VERTICAL)
+ dbSizer.Add(self.cswPanel, flag=wx.EXPAND, proportion=1)
+ self.cswDialog.SetSizer(dbSizer)
+ self.cswDialog.SetBestFittingSize()
+ self.cswDialog.ShowModal()
+ self.cswDialog.Destroy()
+ def _onExportCsw(self,evt):
+ self.exportXMLTemp()
+ XMLhead, XMLtail = os.path.split(self.xmlPath)
+ outPath=tempfile.gettempdir()
+ path=os.path.join(outPath,XMLtail)
+ self.cswPanel.publishCSW(str(path))
+ def onExportPdf(self,evt):
+ dlg = wx.FileDialog(self,
+ message="Set output file",
+ defaultDir=self.mdDestination,
+ defaultFile=XMLtail.split('.')[0]+'.pdf',
+ wildcard="*.pdf",
+ style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
+ if dlg.ShowModal() == wx.ID_OK:
+ outPath=dlg.GetDirectory()
+ outFileName=dlg.GetFilename()
+ self.exportPDF(outPath=outPath,outFileName=outFileName)
+ if mdutil.yesNo(self,'Do you want to open report?'):
+ webbrowser.open(os.path.join(outPath,outFileName))
+ def onSettings(self, evt):
+ dlg = wx.DirDialog(self,
+ message="Select metadata working directory",
+ defaultPath=self.mdDestination,
+ style=wx.DD_DEFAULT_STYLE | wx.DD_NEW_DIR_BUTTON)
+ self.mdDestination = dlg.GetPath()
+ dlg.Destroy()
+ GMessage('Metadata destination: %s' % self.mdDestination)
+ def onCreateTemplate(self, evt):
+ self.setTemplateEditorPath(value=True)
+ if self.onEdit():
+ self.bttSaveTemplate.Enable()
+ def onEdit(self, evt=None):
- self.mdDestination = os.path.join(mdutil.pathToMapset(), 'metadata')
- if not os.path.exists(self.mdDestination):
- os.makedirs(self.mdDestination)
+ @var : extendEdit if xml and jinja is loaded from file
+ if self.extendEdit:
+ if self.rbGrass.GetValue():
+ ok = self.editMapMetadata()
+ if not ok:
+ return False
+ else:
+ self.onInitEditor()
+ self.bttSave.Enable()
+ self.bttExportCSW.Enable()
+ self.bttExportPdf.Enable()
+ try: # if multiediting mode ON
+ if self.numOfMap > 1:
+ self.batch = mdutil.yesNo(self, 'Do you want to save metadata of: <%s> without editing ? ' % XMLtail, 'Multiple editing')
+ if self.batch:
+ self.onSaveXML()
+ except:
+ pass
+ return True
+ def onNewSession(self, evt):
+ self.setTemplateEditorPath(value=False, template=False)
+ # check current editing mode(grass or external xml editor)
+ if self.rbGrass is False:
+ self.bttLoad.Enable()
+ self.bttLoadXml.Enable()
+ self.sb.SetStatusText('')
+ self.jinjaPath = None
+ self.xmlPath = None
+ self.bttSave.SetLabel('xml')
+ self.showMultipleEdit()
+ self.MdDataCatalogPanelLeft.onChanged(None)
+ def onLoadXml(self, evt=None):
+ "Select XML metadata file",
+ self.mdDestination,
+ "*.xml",
+ wx.OPEN)
+ self.xmlPath = dlg.GetPath()
+ tx = self.sb.GetStatusText()
+ self.sb.SetStatusText(tx + ' Selected XML: ' + self.xmlPath)
+ self.updateXMLorTemplate()
+ dlg.Destroy()
+ def onSaveTemplate(self, evt=None):
+ "Select output file",
+ "*.xml",
+ wx.SAVE)
+ self.onExportTemplate(outPath=dlg.GetDirectory(),
+ outFileName=dlg.GetFilename())
+ def onLoadTemplate(self, evt):
+ "Select metadata ISO profile",
+ "*.xml",
+ wx.OPEN)
+ self.jinjaPath = dlg.GetPath()
+ self.sb.SetStatusText(tx + ' Selected profile: ' + self.jinjaPath)
+ dlg.Destroy()
+ def onSaveXML(self, evt=None,path=None):
+ self.XMLhead, self.XMLtail = os.path.split(self.xmlPath)
+ if not self.batch: # if normal saving with user-task-dialog
+ defaultFile=self.XMLtail,
+ wildcard="*.xml",
+ self.exportXML(outPath=dlg.GetDirectory(), outFileName=dlg.GetFilename())
+ if self.bttSave.GetLabelText() == 'next':
+ self.editMapMetadata( multipleEditing=True)
+ else:
+ ask = mdutil.yesNo(self, 'File is not saved. Do you want to save it? ', 'Save dialog')
+ if ask:
+ self.onSaveXML()
+ else:
+ GMessage('File not saved')
+ dlg.Destroy()
+ else:
+ self.exportXML( outPath=None, outFileName=None)
def onUpdateGrassMetadata(self):
'''Update r.support and v.support
@@ -136,12 +398,6 @@
self.mdCreator.updateGrassMd(md)
GMessage('GRASS GIS metadata has been updated')
- def onChangeEditMapProfile(self):
- '''Update vars
- self.profileChoice = self.configPanelLeft.comboBoxProfile.GetValue()
- self.ntbRight.profile = self.profileChoice
def onExportTemplate(self, outPath, outFileName):
'''Export defined(pre-filled) template
@@ -149,11 +405,59 @@
outPath=outPath,
xmlOutName=outFileName)
- def onExportPDF(self, outPath, outFileName):
+ def updateXMLorTemplate(self, evt=None):
+ '''in case if path of template and xml path are initialized -> enable buttons for next step
+ if self.jinjaPath is not None and self.xmlPath is not None:
+ self.onHideLeftPanel()
+ self.bttEdit.Enable()
+ self.bttCreateTemplate.Enable()
+ self.extendEdit = True
+ def hideMultipleEdit(self):
+ '''Multiple editor is off
+ self.bttLoad.Hide()
+ self.bttLoadXml.Hide()
+ self.bttNew.Hide()
+ self.bttEdit.Hide()
+ self.bttCreateTemplate.Hide()
+ self.bttSaveTemplate.Hide()
+ self.bttUpdateGRASS.Hide()
+ self.bttExportPdf.Hide()
+ def showMultipleEdit(self):
+ '''Multiple editor is on
+ self.bttLoad.Show()
+ self.bttLoadXml.Show()
+ self.bttNew.Show()
+ self.bttEdit.Show()
+ self.bttCreateTemplate.Show()
+ self.bttSaveTemplate.Show()
+ self.bttUpdateGRASS.Show()
+ self.bttExportPdf.Show()
+ def initDefaultPathStorageMetadata(self):
+ '''set working folder
+ self.mdDestination = os.path.join(mdutil.pathToMapset(), 'metadata')
+ if not os.path.exists(self.mdDestination):
+ os.makedirs(self.mdDestination)
+ def onChangeEditMapProfile(self):
+ '''Update vars
+ self.profileChoice = self.comboBoxProfile.GetValue()
+ self.ntbRight.profile = self.profileChoice
+ def exportPDF(self, outPath, outFileName):
self.initNewMD()
pdfFile=os.path.join(outPath,outFileName)
- if self.mdCreator is None and self.toolbar.extendEdit: #if editing map from grass database
+ if self.mdCreator is None and self.extendEdit: #if editing map from grass database
profileName=os.path.basename(self.jinjaPath)
xmlFile=os.path.basename(self.xmlPath)
doc = PdfCreator(self.md, pdfFile, map=None, type=None,filename=xmlFile,profile=profileName)
@@ -166,8 +470,15 @@
except:
GError('Export pdf error %s'% sys.exc_info()[0])
+ def exportXMLTemp(self):
+ self.editor.exportToXml(self.jinjaPath,
+ outPath=outPath,
+ xmlOutName=XMLtail,
+ msg=False)
- def onExportXML(self, outPath, outFileName):
+ def exportXML(self, outPath, outFileName):
'''Save metadta xml file
if outPath is None and outFileName is None:
@@ -201,8 +512,8 @@
self.sb.SetStatusText(text)
- def onTemplateEditor(self, value, template=None):
- '''Update local var
+ def setTemplateEditorPath(self, value, template=None):
+ '''Setup name of temporal template
self.templateEditor = value
if template == None:
@@ -216,7 +527,6 @@
self.md=self.editor.saveMDfromGUI()
self.ntbRight.md = self.editor.md
def resizeFrame(self, x1=1, y1=0):
'''Some widgets need refresh frame for proper working
@@ -229,7 +539,7 @@
def onHideLeftPanel(self):
'''In editing mode config panel is hidden
- self.toolbar.bttNew.Enable()
+ self.bttNew.Enable()
self.Hsizer.Remove(self.leftPanel)
self.Hsizer.Layout()
self.leftPanel.SetSize((1, 1))
@@ -238,21 +548,36 @@
self.resizeFrame()
self.editStatus=editStatus
self.Layout()
if editStatus:
self.MdDataCatalogPanelLeft.Show()
- self.toolbar.bttLoad.Disable()
- self.toolbar.bttLoadXml.Disable()
else:
self.MdDataCatalogPanelLeft.Hide()
- self.toolbar.bttEdit.Disable()
- self.toolbar.bttCreateTemplate.Disable()
- self.toolbar.bttLoad.Enable()
- self.toolbar.bttLoadXml.Enable()
self.MdDataCatalogPanelLeft.UnselectAll()
- def onEditMapMetadata(self, multipleEditing=False):
+ def chckProfileSelection(self,type):
+ parent=self.MdDataCatalogPanelLeft.GetSelection()
+ while True:
+ text=self.MdDataCatalogPanelLeft.GetItemText(parent)
+ if text == 'Temporal maps':
+ baseType='temporal'
+ break
+ elif text == 'Spatial maps':
+ baseType='spatial'
+ break
+ parent=self.MdDataCatalogPanelLeft.GetItemParent(parent)
+ if baseType == type:
+ return True
+ else:
+ return False
+ def editMapMetadata(self, multipleEditing=False):
'''Initialize editor by selection of GRASS map in data catalog
@param multipleEditing: if user selects more than one map mutlipleEditing=True
@param numOfMap: holds information about number of selected maps for editing
@@ -261,7 +586,7 @@
if not multipleEditing:
self.ListOfMapTypeDict = self.MdDataCatalogPanelLeft.ListOfMapTypeDict
self.numOfMap = len(self.ListOfMapTypeDict)
if self.numOfMap == 0 and multipleEditing is False:
@@ -270,22 +595,41 @@
# if editing just one map
if self.numOfMap == 1 and multipleEditing is False:
- self.mdCreator = mdgrass.GrassMD(self.ListOfMapTypeDict[-1][self.ListOfMapTypeDict[-1].keys()[0]],
+ if self.profileChoice == 'INSPIRE' :
+ if self.chckProfileSelection('spatial'):
+ self.mdCreator = mdgrass.GrassMD(self.ListOfMapTypeDict[-1][self.ListOfMapTypeDict[-1].keys()[0]],
self.ListOfMapTypeDict[-1].keys()[0])
- if self.profileChoice == 'INSPIRE':
- self.mdCreator.createGrassInspireISO()
+ self.mdCreator.createGrassInspireISO()
+ self.jinjaPath = self.mdCreator.profilePathAbs
+ else:
+ GMessage('Cannot use this template for temporal metadata')
+ return
elif self.profileChoice == 'GRASS BASIC':
- self.mdCreator.createGrassBasicISO()
+ self.ListOfMapTypeDict[-1].keys()[0])
+ self.mdCreator.createGrassBasicISO()
+ else:
+ return
elif self.profileChoice == 'TEMPORAL':
- self.mdCreator.createTemporalISO()
+ if self.chckProfileSelection('temporal'):
+ self.mdCreator.createTemporalISO()
+ else:
+ GMessage('Cannot use this template for spatial metadata')
+ return
- self.jinjaPath = self.mdCreator.profilePathAbs
self.xmlPath = self.mdCreator.saveXML(self.mdDestination, self.nameTMPteplate, self)
self.onInitEditor()
# if editing multiple maps or just one but with loading own custom profile
if self.profileChoice == 'Load Custom' and self.numOfMap != 0:
- # load profile. IF for just one map ELSE for multiple editing
+ # load profile. IF - just one map, ELSE - multiple editing
if multipleEditing is False:
dlg = wx.FileDialog(self, "Select profile", os.getcwd(), "", "*.xml", wx.OPEN)
@@ -296,8 +640,8 @@
# if multiple map are selected
- self.toolbar.xmlPath = self.xmlPath
- self.toolbar.jinjaPath = self.jinjaPath
+ self.xmlPath = self.xmlPath
+ self.jinjaPath = self.jinjaPath
self.batch = True
self.ListOfMapTypeDict.pop()
self.initMultipleEditor()
@@ -311,9 +655,6 @@
- self.ListOfMapTypeDict
@@ -322,7 +663,7 @@
if self.numOfMap == 0 and multipleEditing is True:
multipleEditing = False
- self.toolbar.onNewSession(None)
+ self.onNewSession(None)
GMessage('All selected maps are edited')
self.secondMultiEdit = True
@@ -331,8 +672,8 @@
self.batch = mdutil.yesNo(self, 'Do you want to save metadata of : %s without editing ? ' % XMLtail, 'Multiple editing')
if self.batch:
- self.toolbar.batch = True
- self.toolbar.onSaveXML()
+ self.batch = True
+ self.onSaveXML()
return True
def initMultipleEditor(self):
@@ -345,13 +686,13 @@
self.firstAfterChoice = False
self.secondAfterChoice = True
- self.toolbar.bttsave.SetLabel('next')
- self.toolbar.hideMultipleEdit()
+ self.bttSave.SetLabel('next')
+ self.hideMultipleEdit()
self.mainSizer.Layout()
self.editor = MdMainEditor(self.splitter,
self.jinjaPath,
self.xmlPath,
- self.profileEditor)
+ self.templateEditor)
self.ntbRight = NotebookRight(self.splitter, self.xmlPath)
self.splitter.SplitVertically(self.editor, self.ntbRight, sashPosition=0.65)
self.splitter.SetSashGravity(0.65)
@@ -360,8 +701,8 @@
elif self.secondAfterChoice or self.secondMultiEdit:
if self.secondMultiEdit:
self.second = False
self.onInitEditor()
@@ -370,20 +711,16 @@
@var first: True= First initialize main frame
@var firstAfterChoice: True=Init editor editor after set configuration and click onEdit in toolbar
- @var second: init editor after first initialize
+ @var second: refresh editor after first initialize
@var secondAfterChoice: init editor one more time
if self.first:
self.first = False
self.firstAfterChoice = True
- self.toolbar = MdToolbar(self,
- self.jinjaPath,
- self.xmlPath,
- self.sb,
- self.mdDestination)
+ self.initToolbar()
self.leftPanel = wx.Panel(self, id=wx.ID_ANY)
- self.configPanelLeft = MdEditConfigPanel(self.leftPanel)
+ self.initConfigurePanel()
self.MdDataCatalogPanelLeft = MdDataCatalog(self.leftPanel)
self._layout()
@@ -413,8 +750,8 @@
self.second = False
self.splitter.Hide()
- self.toolbar.bttNew.Disable()
- self.toolbar.bttsave.Disable()
self.Hsizer.Insert(0, self.leftPanel, proportion=1, flag=wx.EXPAND)
self.resizeFrame()
@@ -423,8 +760,8 @@
self.secondAfterChoice = False
self.second = True
self.splitter.Show()
- self.toolbar.bttsave.Enable()
ntbRightBCK = self.ntbRight
@@ -445,18 +782,27 @@
else:
GMessage('Select map in data catalog...')
def _layout(self):
self.mainSizer = wx.BoxSizer(wx.VERTICAL)
- self.SetSizer(self.mainSizer)
- self.mainSizer.Add(self.toolbar)
+ #self.toolbarPanelSizer = wx.BoxSizer(wx.HORIZONTAL)
+ #self.toolbarPanel.SetSizer(self.toolbarPanelSizer)
+ #self.toolbarPanelSizer.Add(self.toolbar,proportion=1, flag=wx.EXPAND)
+ self.mainSizer.Add(self.toolbar, flag=wx.EXPAND)
self.mainSizer.Add(wx.StaticLine(self, -1, style=wx.LI_HORIZONTAL, size=(10000, 5)))
self.mainSizer.AddSpacer(5, 5, 1, wx.EXPAND)
+ self.configPanelLeftSizer = wx.BoxSizer(wx.VERTICAL)
+ self.configPanelLeft.SetSizer(self.configPanelLeftSizer)
+ self.configPanelLeftSizer.Add(self.rbGrass)
+ self.configPanelLeftSizer.Add(self.rbExternal)
+ self.configPanelLeftSizer.Add(self.comboBoxProfile)
self.leftPanelSizer = wx.BoxSizer(wx.VERTICAL)
self.leftPanel.SetSizer(self.leftPanelSizer)
self.leftPanelSizer.Add(self.configPanelLeft, proportion=0, flag=wx.EXPAND)
@@ -465,7 +811,7 @@
self.Hsizer = wx.BoxSizer(wx.HORIZONTAL)
self.mainSizer.Add(self.Hsizer, proportion=1, flag=wx.EXPAND)
+ self.SetSizer(self.mainSizer)
self.Hsizer.Add(self.leftPanel, proportion=1, flag=wx.EXPAND)
self.resizeFrame(300, 0)
@@ -489,6 +835,7 @@
self.InitTreeItems()
self.map = None
self.mapType = None
+ self.baseType=None
def __del__(self):
"""Close the database interface and stop the messenger and C-interface
@@ -500,17 +847,14 @@
def InitTreeItems(self):
"""Add locations and layers to the tree"""
self.rootTmp=self.root
- var=self.AppendItem(self.root,'Grass maps')
+ var=self.AppendItem(self.root,'Spatial maps')
self.root=var
gisenv = grass.gisenv()
location = gisenv['LOCATION_NAME']
- #GMessage(location)
self.mapset = gisenv['MAPSET']
- #GMessage(self.mapset)
self.initGrassTree(location=location, mapset=self.mapset)
self.initTemporalTree(location=location, mapset=self.mapset)
@@ -579,7 +923,6 @@
# get list of all maps in location
for ml in allDatasets:
# add mapset
if self.itemExists(ml[1], varloc) == False:
varmapset = self.getItemByName(ml[1], varloc)
@@ -591,9 +934,6 @@
self.AppendItem(vartype, ml[0])
- #self.ExpandAll()
self.Bind(wx.EVT_TREE_SEL_CHANGED, self.onChanged)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.onChanged)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnRClickAllChildren)
@@ -611,49 +951,53 @@
self.ListOfMapTypeDict = list()
maps = list()
- if self.GetChildrenCount(evt.Item) == 0: # is selected map
- for item in self.GetSelections():
+ if evt is not None:
+ item=evt.Item
+ else:
+ item=self.GetSelection()
+ if self.GetChildrenCount(item) == 0: # is selected map
+ #check temporal selection
+ for i in self.GetSelections():
MapTypeDict = {}
- maps.append(self.GetItemText(item))
- map = self.GetItemText(item) #+ '@' + self.mapset @TODO to test
- mapType = self.GetItemParent(item)
+ maps.append(self.GetItemText(i))
+ map = self.GetItemText(i)
+ mapType = self.GetItemParent(i)
mapType = self.GetItemText(mapType)
if mapType == 'vect':
mapType = 'vector'
elif mapType == 'rast':
mapType = 'raster'
MapTypeDict[mapType] = map
self.ListOfMapTypeDict.append(MapTypeDict)
- pub.sendMessage('bttEdit.enable')
- pub.sendMessage('bttCreateTemplate.enable')
+ MAINFRAME.bttEdit.Enable()
+ MAINFRAME.bttCreateTemplate.Enable(True)
else:
self.Unselect()
- #pub.sendMessage('bttEdit.disable')
- #pub.sendMessage('bttCreateTemplate.disable')
- #GMessage('Please select map')
if len(maps) == 0:
- pub.sendMessage('bttEdit.disable')
- pub.sendMessage('bttCreateTemplate.disable')
+ MAINFRAME.bttEdit.Disable()
+ MAINFRAME.bttCreateTemplate.Enable(False)
return
status = ''
for map in maps:
status += map + ' '
if len(maps) > 1:
- pub.sendMessage('SET_PROFILE.update', profile='Load Custom')
+ dispatcher.send( signal='SET_PROFILE.update',profile='Load Custom')
+ MAINFRAME.bttUpdateGRASS.Disable()
+ MAINFRAME.bttCreateTemplate.Disable()
- pub.sendMessage('comboBoxProfile.disable')
else:
- pub.sendMessage('comboBoxProfile.enable')
- pub.sendMessage('STATUS_BAR_TEXT.update', text=status)
+ dispatcher.send( signal='STATUS_BAR_TEXT.update',text=status)
# NOTEBOOK ON THE RIGHT SIDE-xml browser+validator
@@ -698,7 +1042,7 @@
pass
def onRefreshXmlBrowser(self, evt=None):
- pub.sendMessage('REFRESH_TREE_BROWSER.update')
+ dispatcher.send( signal='REFRESH_TREE_BROWSER.update')
def refreshXmlBrowser(self, path):
treeBCK = self.tree
@@ -710,8 +1054,10 @@
def validate(self, evt):
self.md = None
- pub.sendMessage('NEW_MD.create')
- pub.sendMessage('ISO_PROFILE.update')
+ dispatcher.send( signal='NEW_MD.create')
+ dispatcher.send( signal='ISO_PROFILE.update')
self.validator.validate(self.md, self.profile)
def _layout(self):
@@ -726,7 +1072,7 @@
self.panelSizer1.Add(self.tree, flag=wx.EXPAND, proportion=1)
self.panelSizer1.Add(self.buttRefresh)
- panelSizer2 = wx.BoxSizer(wx.VERTICAL)
+ #panelSizer2 = wx.BoxSizer(wx.VERTICAL)
# self.notebook_panel2.SetSizer(panelSizer2)
# panelSizer2.Add(self.notebook_panel2,flag=wx.EXPAND, proportion=1)
@@ -881,467 +1227,26 @@
self.text.SetValue(str1)
-# CONFIGURATION PANEL ON THE LEFT SIDE
-class MdEditConfigPanel(wx.Panel):
- '''Configuration pane for selection editing mode.
- @var mapGrassEdit: True = editing metadata of GRASS maps, false= editing externally loaded xml and profile
- def __init__(self, parent):
- wx.Panel.__init__(self, parent, id=wx.ID_ANY)
- self.SetMinSize((240, -1))
- self.mapGrassEdit = True
- self.rbGrass = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata map editor', style=wx.RB_GROUP)
- self.rbExternal = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata external editor')
- self.comboBoxProfile = wx.ComboBox(self, choices=['INSPIRE', 'GRASS BASIC', 'TEMPORAL','Load Custom'])
- pub.subscribe(self.onComboboxDisable, "comboBoxProfile.disable")
- pub.subscribe(self.onComboboxEnable, "comboBoxProfile.enable")
- pub.subscribe(self.onSetProfile, "SET_PROFILE.update")
- self.comboBoxProfile.SetStringSelection('INSPIRE')#TODO
- self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbGrass.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbExternal.GetId())
- self.comboBoxProfile.Bind(wx.EVT_COMBOBOX, self.onChangeComboBoxProfile)
- self._layout()
- def onChangeComboBoxProfile(self, evt):
- pass
- def onComboboxDisable(self):
- self.comboBoxProfile.Disable()
- def onComboboxEnable(self):
- self.comboBoxProfile.Enable()
- def onSetProfile(self, profile):
- self.comboBoxProfile.SetStringSelection(profile)
- def SetVal(self, event):
- state1 = str()
- state2 = str(self.rb2.GetValue())
- self.statusbar.SetStatusText(state1, 0)
- self.statusbar.SetStatusText(state2, 1)
- def onSetRadioType(self, evt=None):
- self.mapGrassEdit = self.rbGrass.GetValue()
- if self.mapGrassEdit is False:
- self.comboBoxProfile.Hide()
- else:
- self.comboBoxProfile.Show()
- pub.sendMessage('EDITING_MODE.update', editStatus=self.mapGrassEdit)
- def _layout(self):
- self.mainsizer = wx.BoxSizer(wx.VERTICAL)
- self.SetSizer(self.mainsizer)
- self.mainsizer.Add(self.rbGrass)
- self.mainsizer.Add(self.rbExternal)
- self.mainsizer.Add(self.comboBoxProfile)
-# TOOLBAR
+# CSW
+class CswPublisher(CSWConnectionPanel):
+ def __init__(self,parent,main):
+ super(CswPublisher, self).__init__(parent, main,cswBrowser=False)
+ self.publishBtt=wx.Button(self.panelLeft,label='Publish')
+ self.configureSizer.AddSpacer(40, 10, 1, wx.EXPAND)
+ self.configureSizer.Add(self.publishBtt, 0, wx.EXPAND)
+ self.publishBtt.SetBackgroundColour((255, 127, 80))
-class MdToolbar(wx.Panel):
- '''Main toolbar of editor
- def __init__(self, parent, jinjaPath, xmlPath, sb, mdDestionation):
- self.mdDestination = mdDestionation
- self.batch = False
- self.jinjaPath = jinjaPath
- self.statusBar = sb
- self.xmlPath = xmlPath
- self.extendEdit = False
- self.toolbar = wx.ToolBar(self, 1, wx.DefaultPosition, (-1, -1))
- bitmapSave = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'save.png'),
- wx.BITMAP_TYPE_PNG).ConvertToBitmap()
- bitmapNew = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'create.png'),
- bitmapLoad = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'open.png'),
- bitmaSettings = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'settings.png'),
- #-------------------------------------------------------------------- EDIT
- self.toolbar.AddSeparator()
- bitmapEdit = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'edit.png'),
- self.bttEdit = BitmapBtnTxt(self.toolbar, -1, bitmapEdit,size=(40, -1))
- self.toolbar.AddControl(control=self.bttEdit)
- self.bttEdit.Disable()
- #-------------------------------------------------------------------- NEW SESION
- #self.toolbar.AddSeparator()
- self.bttNew = BitmapBtnTxt(self.toolbar, -1, bitmapNew, '', size=(40, -1))
- self.toolbar.AddControl(control=self.bttNew)
- self.bttNew.Disable()
- #-------------------------------------------------------------------- NEW TEMPLATE
- self.bttCreateTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapNew, "template", size=(100, -1))
- self.toolbar.AddControl(control=self.bttCreateTemplate)
- self.bttCreateTemplate.Disable()
- #----------------------------------------------------------------- OPEN TEMPLATE
- self.bttLoad = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "profile", size=(100, -1))
- self.toolbar.AddControl(control=self.bttLoad)
- self.bttLoad.Disable()
- #---------------------------------------------------------------------- OPEN XML
- self.bttLoadXml = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "xml")
- self.toolbar.AddControl(control=self.bttLoadXml)
- self.bttLoadXml.Disable()
- #-------------------------------------------------------------------------- export xml
- self.bttsave = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "xml")
- self.bttsave.Disable()
- self.toolbar.AddControl(control=self.bttsave)
- #-------------------------------------------------------------------------- export template
- self.bttSaveTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "template", size=(100, -1))
- self.bttSaveTemplate.Disable()
- self.toolbar.AddControl(control=self.bttSaveTemplate)
- #-------------------------------------------------------------------------- update grass
- self.bttUpdateGRASS = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "GRASS", size=(100, -1))
- self.bttUpdateGRASS.Disable()
- self.toolbar.AddControl(control=self.bttUpdateGRASS)
- #-------------------------------------------------------------------------- export pdf
- self.bttExportPdf = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "pdf", size=(100, -1))
- self.bttExportPdf.Disable()
- self.toolbar.AddControl(control=self.bttExportPdf)
- #-------------------------------------------------------------------------- Config
- self.bttConfig = BitmapBtnTxt(self.toolbar, -1, bitmaSettings, "", size=(40, -1))
- self.toolbar.AddControl(control=self.bttConfig)
- self.toolbar.Realize()
- self._layout()
- self.bttLoad.Bind(wx.EVT_BUTTON, self.OnLoadTemplate)
- pub.subscribe(self.onBttSaveEnable, "bttLoad.enable")
- pub.subscribe(self.onBttSaveDisable, "bttLoad.disable")
- self.bttsave.Bind(wx.EVT_BUTTON, self.onSaveXML)
- pub.subscribe(self.onBttLoadEnable, "bttSave.enable")
- pub.subscribe(self.onBttLoadDisable, "bttSave.disable")
- self.bttLoadXml.Bind(wx.EVT_BUTTON, self.onLoadXml)
- pub.subscribe(self.onBttLoadXmlEnable, "bttLoadXml.enable")
- pub.subscribe(self.onBttLoadXmlDisable, "bttLoadXml.disable")
- self.bttNew.Bind(wx.EVT_BUTTON, self.onNewSession)
- pub.subscribe(self.onBttNewEnable, "bttNew.enable")
- pub.subscribe(self.onBttNewDisable, "bttNew.disable")
- self.bttEdit.Bind(wx.EVT_BUTTON, self.onEdit)
- pub.subscribe(self.onBtEditEnable, "bttEdit.enable")
- pub.subscribe(self.onBttEditDisable, "bttEdit.disable")
- self.bttCreateTemplate.Bind(wx.EVT_BUTTON, self.onCreateTemplate)
- pub.subscribe(self.onBttCreateTemplateEnable, "bttCreateTemplate.enable")
- pub.subscribe(self.onBttCreateTemplateDisable, "bttCreateTemplate.disable")
- self.bttSaveTemplate.Bind(wx.EVT_BUTTON, self.onSaveTemplate)
- pub.subscribe(self.onBttSaveTemplateEnable, "bttSaveTemplate.enable")
- pub.subscribe(self.onBttSaveTemplateDisable, "bttSaveTemplate.disable")
- self.bttUpdateGRASS.Bind(wx.EVT_BUTTON, self.onUpdateGRASS)
- pub.subscribe(self.onBttUpdateGRASSEnable, "bttSaveTemplate.enable")
- pub.subscribe(self.onBttUpdateGRASSDisable, "bttSaveTemplate.disable")
- self.bttExportPdf.Bind(wx.EVT_BUTTON, self.onExportPdf)
- pub.subscribe(self.onBttExportPdfEnable, "bttExportPdf.enable")
- pub.subscribe(self.onBttExportPdfDisable, "bttExportPdf.disable")
- self.bttConfig.Bind(wx.EVT_BUTTON, self.onSettings)
- def onBttSaveDisable(self):
- self.bttSave.Disable()
- def onBttSaveEnable(self):
- self.bttSave.Enable()
- def onBttLoadDisable(self):
- def onBttLoadEnable(self):
- self.bttLoad.Enable()
- def onBttLoadXmlDisable(self):
- def onBttLoadXmlEnable(self):
- self.bttLoadXml.Enable()
- def onBttNewDisable(self):
- def onBttNewEnable(self):
- self.bttNew.Enable()
- def onBttEditDisable(self):
- def onBtEditEnable(self):
- self.bttEdit.Enable()
- def onBttCreateTemplateDisable(self):
- def onBttCreateTemplateEnable(self):
- self.bttCreateTemplate.Enable()
- def onBttSaveTemplateDisable(self):
- def onBttSaveTemplateEnable(self):
- self.bttSaveTemplate.Enable()
- def onBttUpdateGRASSDisable(self):
- def onBttUpdateGRASSEnable(self):
- self.bttUpdateGRASS.Enable()
- def onBttExportPdfDisable(self):
- def onBttExportPdfEnable(self):
- self.bttExportPdf.Enable()
- def onUpdateGRASS(self, evt):
- pub.sendMessage('GRASS_METADATA.update')
- def onExportPdf(self,evt):
- self.xmlPath=self.GetParent().xmlPath
- XMLhead, XMLtail = os.path.split(self.xmlPath)
- dlg = wx.FileDialog(self,
- message="Set output file",
- defaultDir=self.mdDestination,
- defaultFile=XMLtail.split('.')[0]+'.pdf',
- wildcard="*.pdf",
- style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
- if dlg.ShowModal() == wx.ID_OK:
- outPath=dlg.GetDirectory()
- outFileName=dlg.GetFilename()
- pub.sendMessage('EXPORT_PDF.create',
- outPath=outPath,
- outFileName=outFileName)
- if mdutil.yesNo(self,'Do you want to open report?'):
- webbrowser.open(os.path.join(outPath,outFileName))
- def onSettings(self, evt):
- dlg = wx.DirDialog(self,
- message="Select metadata working directory",
- defaultPath=self.mdDestination,
- style=wx.DD_DEFAULT_STYLE | wx.DD_NEW_DIR_BUTTON)
- self.mdDestination = dlg.GetPath()
- pub.sendMessage('MD_DESTINATION.update', value=self.mdDestination)
- dlg.Destroy()
- GMessage('Metadata destination: %s' % self.mdDestination)
- def hideMultipleEdit(self):
- '''Multiple editor is off
- self.bttLoad.Hide()
- self.bttLoadXml.Hide()
- self.bttNew.Hide()
- self.bttEdit.Hide()
- self.bttCreateTemplate.Hide()
- self.bttSaveTemplate.Hide()
- self.bttUpdateGRASS.Hide()
- self.bttExportPdf.Hide()
- def showMultipleEdit(self):
- '''Multiple editor is on
- self.bttLoad.Show()
- self.bttLoadXml.Show()
- self.bttNew.Show()
- self.bttEdit.Show()
- self.bttCreateTemplate.Show()
- self.bttSaveTemplate.Show()
- self.bttUpdateGRASS.Show()
- self.bttExportPdf.Show()
- def onCreateTemplate(self, evt):
- pub.sendMessage('TEMPLATE_EDITOR_STATUS.update', value=True)
- self.onEdit(evt=None)
- def onEdit(self, evt=None):
- @var : extendEdit if xml and jinja is loaded from file
- if self.extendEdit:
- pub.sendMessage('SET_JINJA_AND_XML.update', jinja=self.jinjaPath, xml=self.xmlPath)
- if self.GetParent().configPanelLeft.rbGrass.GetValue():
- ok = self.GetParent().onEditMapMetadata()
- if not ok:
- return
- else:
- pub.sendMessage('INIT_EDITOR.create')
- self.bttsave.Enable()
- if not self.extendEdit:
- try: # if multiediting mode ON
- if self.GetParent().numOfMap > 1:
- self.batch = mdutil.yesNo(self, 'Do you want to save metadata of : %s without editing ? ' % XMLtail, 'Multiple editing')
- if self.batch:
- self.onSaveXML()
- except:
- pass
- def onNewSession(self, evt):
- pub.sendMessage('TEMPLATE_EDITOR_STATUS.update', value=False, template=False)
- # check current editing mode(grass or external xml editor)
- if self.GetParent().configPanelLeft.rbGrass is False:
- self.statusBar.SetStatusText('')
- self.jinjaPath = None
- self.xmlPath = None
- self.bttsave.SetLabel('xml')
- self.showMultipleEdit()
- def onChangeXmlorTemplate(self, evt=None):
- '''in case if path of template and xml path are initialized -> enable buttons for next step
- if self.jinjaPath is not None and self.xmlPath is not None:
- pub.sendMessage('HIDE_LEFT_PANEL.update')
- self.extendEdit = True
- def onLoadXml(self, evt=None):
- "Select XML metadata file",
- self.mdDestination,
- "*.xml",
- wx.OPEN)
- self.xmlPath = dlg.GetPath()
- tx = self.statusBar.GetStatusText()
- self.statusBar.SetStatusText(tx + ' Selected XML: ' + self.xmlPath)
- self.onChangeXmlorTemplate()
- dlg.Destroy()
- def onSaveTemplate(self, evt=None):
- "Select output file",
- "*.xml",
- wx.SAVE)
- pub.sendMessage('EXPORT_TEMPLATE.create',
- outPath=dlg.GetDirectory(),
- outFileName=dlg.GetFilename())
- def OnLoadTemplate(self, evt):
- "Select metadata ISO profile",
- "*.xml",
- wx.OPEN)
- self.jinjaPath = dlg.GetPath()
- self.statusBar.SetStatusText(tx + ' Selected profile: ' + self.jinjaPath)
- dlg.Destroy()
- def onSaveXML(self, evt=None):
- self.XMLhead, self.XMLtail = os.path.split(self.xmlPath)
- if not self.batch: # if normal saving with user-task-dialog
- defaultFile=self.XMLtail,
- wildcard="*.xml",
- pub.sendMessage('EXPORT_XML.create', outPath=dlg.GetDirectory(), outFileName=dlg.GetFilename())
- if self.bttsave.GetLabelText() == 'next':
- pub.sendMessage('EDIT_MAP_METADATA.create', multipleEditing=True)
- else:
- ask = mdutil.yesNo(self, 'File is not saved. Do you want to save it? ', 'Save dialog')
- if ask:
- self.onSaveXML()
- else:
- GMessage('File not saved')
- dlg.Destroy()
- else:
- pub.sendMessage('EXPORT_XML.create', outPath=None, outFileName=None)
- self.mainsizer = wx.BoxSizer(wx.HORIZONTAL)
- self.mainsizer.Add(self.toolbar)
def main():
+ global MAINFRAME
app = wx.App(False)
- MdMainFrame()
+ MAINFRAME=MdMainFrame()
app.MainLoop()
if __name__ == '__main__':
- options, flags = grass.parser()
+ grass.parser()
main()
