[GRASS-SVN] r65883 - grass-addons/grass7/general/g.proj.identify
svn_grass at osgeo.org
Tue Aug 11 01:41:59 PDT 2015
Author: krejcmat
Date: 2015-08-11 01:41:59 -0700 (Tue, 11 Aug 2015)
New Revision: 65883
grass-addons/grass7/general/g.proj.identify/g.proj.identify.html
grass-addons/grass7/general/g.proj.identify/g.proj.identify.py
g.proj.identify addon: add epsg2standards
Modified: grass-addons/grass7/general/g.proj.identify/g.proj.identify.html
--- grass-addons/grass7/general/g.proj.identify/g.proj.identify.html 2015-08-11 07:29:15 UTC (rev 65882)
+++ grass-addons/grass7/general/g.proj.identify/g.proj.identify.html 2015-08-11 08:41:59 UTC (rev 65883)
@@ -1,11 +1,16 @@
<h2>DESCRIPTION</h2>
-<em>g.proj.identify</em> allows to automaticaly identify EPSG code for given WKT prj. User can print EPSG from currnt location or for given WKT file.
+<em>g.proj.identify</em> allows to automaticaly identify EPSG code for given WKT prj.
+User can print EPSG from current location or for given WKT file.
+Conversion from given EPSG code to WKT and proj4 is supported.
<h2>EXAMPLE</h2>
<div class="code"><pre>
print EPSG code of current Location- without parameters
g.proj.identify
+print WKT and proj4 for gieven EPSG code
+g.proj.identify.py -p -w epsg=4326
</pre></div>
<h2>SEE ALSO</h2>
Modified: grass-addons/grass7/general/g.proj.identify/g.proj.identify.py
--- grass-addons/grass7/general/g.proj.identify/g.proj.identify.py 2015-08-11 07:29:15 UTC (rev 65882)
+++ grass-addons/grass7/general/g.proj.identify/g.proj.identify.py 2015-08-11 08:41:59 UTC (rev 65883)
@@ -20,9 +20,17 @@
#%option G_OPT_F_INPUT
#% key: wkt
+#% label: WKT prj input
#% required: no
#%end
+#%option
+#% key: epsg
+#% type: integer
+#% label: EPSG input
+#% required: no
+#%end
#%flag
#% key: p
#% label: Proj4
@@ -30,12 +38,6 @@
#%end
#%flag
-#% key: s
-#% label: Shape prj
-#% description: Print Shape prj
-#%end
-#%flag
#% key: w
#% label: WKT
#% description: Print WKT
@@ -62,24 +64,17 @@
quiet=True,
stdout_=PIPE)
proj=proj.outputs.stdout
- esriprj2standards(proj)
+ wkt2standards(proj)
except:
grass.error('WKT input error')
-def esriprj2standards(prj_txt):
+def wkt2standards(prj_txt):
srs = osr.SpatialReference()
srs.ImportFromESRI([prj_txt])
- if flags['s']:
- str='shape_prj=%s' % prj_txt
- #str.rstrip()
- print str
- return
if flags['w']:
print('wkt=%s' % srs.ExportToWkt())
- return
if flags['p']:
print('proj4=%s' % srs.ExportToProj4())
- return
srs.AutoIdentifyEPSG()
try :
int(srs.GetAuthorityCode(None))
@@ -87,13 +82,32 @@
except:
grass.error('Epsg code cannot be identified')
+def epsg2standards(epsg):
+ srs = osr.SpatialReference()
+ srs.ImportFromEPSG(int(epsg))
+ if flags['w']:
+ print('wkt=%s' % srs.ExportToWkt())
+ if flags['p']:
+ print('proj4=%s' % srs.ExportToProj4())
def main():
- if options['wkt']:
- io=open(options['wkt'],'r')
- wkt=io.read().rstrip()
- esriprj2standards(wkt)
+ epsg=options['epsg']
+ pathwkt=options['wkt']
+ if epsg and pathwkt:
+ grass.error('Only one type of conversions can be processed concurrently')
+ if epsg:
+ epsg2standards(epsg)
else:
- grassEpsg()
+ if pathwkt:
+ try:
+ io= open(pathwkt,'r')
+ wkt=io.read().rstrip()
+ wkt2standards(wkt)
+ except IOError as e:
+ grass.error('Cannot open file %s, %s'%(e.errno, e.strerror))
+ else:
+ grassEpsg()
if __name__ == "__main__":
options, flags = grass.parser()
