[GRASS-SVN] r65895 - grass/trunk/vector/v.overlay
svn_grass at osgeo.org
Tue Aug 11 15:08:37 PDT 2015
Author: neteler
Date: 2015-08-11 15:08:37 -0700 (Tue, 11 Aug 2015)
New Revision: 65895
Added:
grass/trunk/vector/v.overlay/v_overlay_op_and.png
grass/trunk/vector/v.overlay/v_overlay_op_not.png
grass/trunk/vector/v.overlay/v_overlay_op_or.png
grass/trunk/vector/v.overlay/v_overlay_op_xor.png
grass/trunk/vector/v.overlay/v.overlay.html
v.overlay manual: semi-synthetic NC example added (contributed by Carol X Garzon-Lopez)
Modified: grass/trunk/vector/v.overlay/v.overlay.html
--- grass/trunk/vector/v.overlay/v.overlay.html 2015-08-11 22:08:23 UTC (rev 65894)
+++ grass/trunk/vector/v.overlay/v.overlay.html 2015-08-11 22:08:37 UTC (rev 65895)
@@ -79,6 +79,82 @@
<h2>EXAMPLES</h2>
+Preparation of example data (North Carolina sample dataset):
+<div class="code"><pre>
+# Create an empty box for overlaying to ZIP code vector map
+v.mkgrid map=box grid=1,1 position=coor \
+ coordinates=584037.093198,201970.387191 box=50000,50000
+# set region to ZIP codes and box vector maps
+g.region vector=zipcodes_wake,box -p res=100 -a
+# enlarge region a bit for "white border" around map in monitor
+g.region n=n+1000 s=s-1000 w=w-1000 e=e+1000 -p
+d.mon wx0
+</pre></div>
+<h3>AND operator</h3>
+d.vect map=zipcodes_wake fill_color=0:128:0
+d.vect map=box fill_color=85:130:176
+v.overlay -t ainput=box binput=zipcodes_wake operator=and output=v_overlay_AND
+d.vect map=v_overlay_AND
+</pre></div>
+<center>
+<img src="v_overlay_op_and.png" alt="v.overlay with AND operator"><br>
+v.overlay with AND operator
+</center>
+<h3>OR operator</h3>
+v.overlay -t ainput=box binput=zipcodes_wake operator=or output=v_overlay_OR
+d.vect map=v_overlay_OR
+</pre></div>
+<center>
+<img src="v_overlay_op_or.png" alt="v.overlay with OR operator"><br>
+v.overlay with OR operator
+</center>
+<h3>XOR operator</h3>
+v.overlay -t ainput=box binput=zipcodes_wake operator=xor output=v_overlay_XOR
+d.vect map=v_overlay_XOR
+</pre></div>
+<center>
+<img src="v_overlay_op_xor.png" alt="v.overlay with XOR operator"><br>
+v.overlay with XOR operator
+</center>
+<h3>NOT operator</h3>
+v.overlay -t ainput=box binput=zipcodes_wake operator=not output=v_overlay_NOT
+d.vect map=v_overlay_NOT
+</pre></div>
+<center>
+<img src="v_overlay_op_not.png" alt="v.overlay with NOT operator"><br>
+v.overlay with NOT operator
+</center>
<h3>Overlay operations: AND, OR, NOT, XOR</h3>
Examples based on North Carolina sample dataset:
Added: grass/trunk/vector/v.overlay/v_overlay_op_and.png
(Binary files differ)
Property changes on: grass/trunk/vector/v.overlay/v_overlay_op_and.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Added: grass/trunk/vector/v.overlay/v_overlay_op_not.png
Property changes on: grass/trunk/vector/v.overlay/v_overlay_op_not.png
+ image/png
Added: grass/trunk/vector/v.overlay/v_overlay_op_or.png
Property changes on: grass/trunk/vector/v.overlay/v_overlay_op_or.png
+ image/png
Added: grass/trunk/vector/v.overlay/v_overlay_op_xor.png
Property changes on: grass/trunk/vector/v.overlay/v_overlay_op_xor.png
+ image/png
