[GRASS-SVN] r65924 - grass-addons/grass7/gui/wxpython/wx.metadata
svn_grass at osgeo.org
Thu Aug 13 02:24:49 PDT 2015
Author: krejcmat
Date: 2015-08-13 02:24:49 -0700 (Thu, 13 Aug 2015)
New Revision: 65924
Added:
grass-addons/grass7/gui/wxpython/wx.metadata/dependency.py
grass-addons/grass7/gui/wxpython/wx.metadata/Makefile
addons wx.metadata: chck dependency from Makefile
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/Makefile
--- grass-addons/grass7/gui/wxpython/wx.metadata/Makefile 2015-08-13 07:18:35 UTC (rev 65923)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/Makefile 2015-08-13 09:24:49 UTC (rev 65924)
@@ -1,5 +1,12 @@
MODULE_TOPDIR = ..
+SHELL_OUTPUT := $(shell python dependency.py 2>&1)
+ifeq ($(filter File dependency.py,$(SHELL_OUTPUT)),)
+ $(info $(SHELL_OUTPUT))
+else
+ $(error $(SHELL_OUTPUT))
+endif
SUBDIRS = \
mdlib \
r.info.iso \
Added: grass-addons/grass7/gui/wxpython/wx.metadata/dependency.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/dependency.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/dependency.py 2015-08-13 09:24:49 UTC (rev 65924)
@@ -0,0 +1,46 @@
+owslib=False
+try:
+ import owslib
+ owslib=True
+except:
+ print'owslib library is missing. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >'
+if owslib:
+ import owslib
+ owsvs= owslib.__version__
+ try:
+ from owslib.iso import *
+ MD_Metadata()
+ except:
+ print ('Installed version of owslib library is < %s >.'%owsvs)
+ print('owslib >=0.9 is required. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >')
+try:
+ import jinja2
+except:
+ print'jinja2 library is missing. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >'
+pycsw=False
+try:
+ import pycsw
+ pycsw=True
+except:
+ print('pycsw library is missing. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >')
+if pycsw:
+ import pycsw
+ cswvs= pycsw.__version__
+ try:
+ from pycsw.core import admin
+ except:
+ print ('Installed version of pycsw library is < %s >.'%cswvs)
+ print('pycsw >=2.0 is required. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >')
+from owslib.iso import *
+import jinja2
+from pycsw.core import admin
