[GRASS-SVN] r65929 - in grass/trunk/lib/python/pygrass: . vector
svn_grass at osgeo.org
Fri Aug 14 02:04:03 PDT 2015
Author: huhabla
Date: 2015-08-14 02:04:03 -0700 (Fri, 14 Aug 2015)
New Revision: 65929
grass/trunk/lib/python/pygrass/errors.py
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass vector: Added mapinfo pointer checks and some alive() methods
Modified: grass/trunk/lib/python/pygrass/errors.py
--- grass/trunk/lib/python/pygrass/errors.py 2015-08-14 05:36:21 UTC (rev 65928)
+++ grass/trunk/lib/python/pygrass/errors.py 2015-08-14 09:04:03 UTC (rev 65929)
@@ -16,3 +16,15 @@
else:
get_msgr().warning(_("The map is close!"))
return wrapper
+def mapinfo_must_be_set(method):
+ @wraps(method)
+ def wrapper(self, *args, **kargs):
+ if self.c_mapinfo:
+ return method(self, *args, **kargs)
+ else:
+ raise GrassError(_("The self.c_mapinfo pointer must be "\
+ "correctly initiated"))
+ return wrapper
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-14 05:36:21 UTC (rev 65928)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-14 09:04:03 UTC (rev 65929)
@@ -14,7 +14,7 @@
import grass.lib.gis as libgis
import grass.lib.vector as libvect
-from grass.pygrass.errors import GrassError
+from grass.pygrass.errors import GrassError, mapinfo_must_be_set
from grass.pygrass.vector.basic import Ilist, Bbox, Cats
from grass.pygrass.vector import sql
@@ -297,6 +297,7 @@
else:
return False
+ @mapinfo_must_be_set
def read(self):
"""Read and set the coordinates of the centroid from the vector map,
using the centroid_id and calling the Vect_read_line C function"""
@@ -639,6 +640,13 @@
pnt.is2D = self.is2D
return pnt
+ def alive(self):
+ """Return True if this line is alive or False if this line is
+ dead or its index is out of range.
+ return(bool(libvect.Vect_line_alive(self.c_mapinfo, self.id)))
def append(self, pnt):
"""Appends one point to the end of a line, using the
``Vect_append_point`` C function.
@@ -802,6 +810,7 @@
point.is2D = self.is2D
return LineDist(point, dist.value, sp_dist.value, lp_dist.value)
def get_first_cat(self):
"""Fetches FIRST category number for given vector line and field, using
the ``Vect_get_line_cat`` C function.
@@ -811,7 +820,7 @@
Not implemented yet.
# TODO: add this method.
- libvect.Vect_get_line_cat(self.map, self.id, self.field)
+ # libvect.Vect_get_line_cat(self.c_mapinfo, self.id, self.field)
pass
def pop(self, indx):
@@ -1086,8 +1095,15 @@
libvect.Vect_reset_line(self.c_points)
def nodes(self):
- """Return the nodes in the line"""
+ """Return the start and end nodes of the line
+ This method requires topology build.
+ return: A tuple of Node objects that represent the
+ start and end point of this line.
if self.is_with_topology():
n1 = ctypes.c_int()
n2 = ctypes.c_int()
@@ -1099,9 +1115,29 @@
class Node(object):
+ """Node class for topological analysis of line neighbors.
+ Objects of this class will be returned by the node() function
+ of a Line object.
+ All methods in this class require a proper setup of the Node
+ objects. Hence, the correct id and a valid pointer to a mapinfo
+ object must be provided in the constructions. Otherwise a segfault
+ may happen.
def __init__(self, v_id, c_mapinfo):
+ """Construct a Node object
+ param v_id: The unique node id
+ param c_mapinfo: A valid pointer to the mapinfo object
self.id = v_id # vector id
self.c_mapinfo = c_mapinfo
+ self._setup()
+ def _setup(self):
self.is2D = bool(libvect.Vect_is_3d(self.c_mapinfo) != 1)
self.nlines = libvect.Vect_get_node_n_lines(self.c_mapinfo, self.id)
@@ -1114,6 +1150,14 @@
def __repr__(self):
return "Node(%d)" % self.id
+ def alive(self):
+ """Return True if this node is alive or False if this node is
+ return(bool(libvect.Vect_node_alive(self.c_mapinfo, self.id)))
def coords(self):
"""Return a tuple with the node coordinates."""
x = ctypes.c_double()
@@ -1138,6 +1182,7 @@
if (not only_in and lid > 0) or (not only_out and lid < 0):
yield lid
def lines(self, only_in=False, only_out=False):
"""Return a generator with all lines connected to a node.
@@ -1149,6 +1194,7 @@
for iline in self.ilines(only_in, only_out):
yield Line(v_id=abs(iline), c_mapinfo=self.c_mapinfo)
def angles(self):
"""Return a generator with all lines angles in a node."""
for iline in range(self.nlines):
@@ -1182,6 +1228,7 @@
def __repr__(self):
return "Boundary(v_id=%r)" % self.id
def _get_centroid(self, side, idonly=False):
if side > 0:
v_id = libvect.Vect_get_area_centroid(self.c_mapinfo, side)
@@ -1208,6 +1255,7 @@
return self._get_centroid(self.left_id, idonly)
def get_left_right(self):
"""Return left and right value"""
@@ -1265,6 +1313,7 @@
def __repr__(self):
return "Centoid(%s)" % ', '.join(['%f' % co for co in self.coords()])
def get_centroid_id(self):
"""Return the centroid_id, using the c_mapinfo and an area_id
attributes of the class, and calling the Vect_get_area_centroid
@@ -1273,6 +1322,7 @@
self.area_id)
return centroid_id if centroid_id != 0 else None
def get_area_id(self):
"""Return the area_id, using the c_mapinfo and an centroid_id
attributes of the class, and calling the Vect_get_centroid_area
@@ -1292,6 +1342,7 @@
def __repr__(self):
return "Isle(%d)" % (self.id)
def boundaries(self):
"""Return a list of boundaries"""
ilist = Ilist()
@@ -1299,31 +1350,37 @@
ilist.c_ilist)
return ilist
def bbox(self, bbox=None):
"""Return bounding box of Isle"""
bbox = bbox if bbox else Bbox()
libvect.Vect_get_isle_box(self.c_mapinfo, self.id, bbox.c_bbox)
return bbox
def points(self):
"""Return a Line object with the outer ring points"""
line = Line()
libvect.Vect_get_isle_points(self.c_mapinfo, self.id, line.c_points)
return line
def points_geos(self):
return libvect.Vect_get_isle_points_geos(self.c_mapinfo, self.id)
def area_id(self):
"""Returns area id for isle."""
return libvect.Vect_get_isle_area(self.c_mapinfo, self.id)
def alive(self):
"""Check if isle is alive or dead (topology required)"""
return bool(libvect.Vect_isle_alive(self.c_mapinfo, self.id))
def contain_pnt(self, pnt):
"""Check if point is in area.
@@ -1359,6 +1416,7 @@
self._isles_id = self.get_isles_id()
self._isles = self.get_isles()
def __len__(self):
return libvect.Vect_get_area_num_isles(self.c_mapinfo, self.area_id)
@@ -1370,11 +1428,13 @@
self.get_isles()
return self._isles[key]
def get_isles_id(self):
"""Return the id of isles"""
return [libvect.Vect_get_area_isle(self.c_mapinfo, self.area_id, i)
for i in range(self.__len__())]
def get_isles(self):
"""Return isles"""
return [Isle(v_id=isle_id, c_mapinfo=self.c_mapinfo)
@@ -1442,6 +1502,7 @@
# get isles
self.get_isles()
def get_points(self, line=None):
@@ -1452,6 +1513,7 @@
libvect.Vect_get_area_points(self.c_mapinfo, self.id, line.c_points)
return line
def get_centroid(self, centroid=None):
@@ -1467,9 +1529,11 @@
return Centroid(v_id=centroid_id, c_mapinfo=self.c_mapinfo,
area_id=self.id)
def num_isles(self):
return libvect.Vect_get_area_num_isles(self.c_mapinfo, self.id)
def get_isles(self, isles=None):
"""Instantiate the boundary attribute reading area_id"""
if isles is not None:
@@ -1477,17 +1541,20 @@
return isles
return Isles(self.c_mapinfo, self.id)
def area(self):
"""Returns area of area without areas of isles.
double Vect_get_area_area (const struct Map_info \*Map, int area)
return libvect.Vect_get_area_area(self.c_mapinfo, self.id)
def alive(self):
"""Check if area is alive or dead (topology required)
return bool(libvect.Vect_area_alive(self.c_mapinfo, self.id))
"""Return the Bbox of area
@@ -1498,6 +1565,7 @@
libvect.Vect_get_area_box(self.c_mapinfo, self.id, bbox.c_bbox)
return bbox
def buffer(self, dist=None, dist_x=None, dist_y=None,
angle=0, round_=True, caps=True, tol=0.1):
"""Return the buffer area around the area, using the
@@ -1537,6 +1605,7 @@
isles=[Line(c_points=pp_isle[i].contents)
for i in range(n_isles.contents.value)])
def boundaries(self, ilist=False):
"""Creates list of boundaries for given area.
@@ -1550,6 +1619,7 @@
return ilist
return [Boundary(v_id=abs(v_id), c_mapinfo=self.c_mapinfo) for v_id in ilst]
def cats(self, cats=None):
"""Get area categories.
@@ -1564,9 +1634,12 @@
"""Find FIRST category of given field and area.
int Vect_get_area_cat(const struct Map_info \*Map, int area, int field)
+ ..warning: Not implemented
pass
def contain_pnt(self, pnt, bbox=None):
@@ -1580,6 +1653,7 @@
bbox.c_bbox))
def perimeter(self):
"""Calculate area perimeter.
