[GRASS-SVN] r65948 - in grass/branches/releasebranch_7_0/gui/wxpython: core gmodeler gui_core lmgr modules vnet
Mon Aug 17 19:43:07 PDT 2015
Author: annakrat
Date: 2015-08-17 19:43:07 -0700 (Mon, 17 Aug 2015)
New Revision: 65948
   grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py
   grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py
   grass/branches/releasebranch_7_0/gui/wxpython/lmgr/frame.py
   grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py
   grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py
   grass/branches/releasebranch_7_0/gui/wxpython/modules/vclean.py
   grass/branches/releasebranch_7_0/gui/wxpython/vnet/vnet_core.py
wxGUI: fix GDALImport dialog to add multiple imported layers to layer manager; update onDone methods to pass event as argument (merge from trunk, r64372 and r64373)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py
--- grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/core/gconsole.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -457,7 +457,6 @@
         if command[0] in globalvar.grassCmd:
             # send GRASS command without arguments to GUI command interface
             # except ignored commands (event is emitted)
             if self._ignoredCmdPattern and \
               re.compile(self._ignoredCmdPattern).search(' '.join(command)) and \
               '--help' not in command and '--ui' not in command:
@@ -628,7 +627,7 @@
                          notification=event.notification)
         if event.onDone:
-            event.onDone(cmd=event.cmd, returncode=event.returncode)
+            event.onDone(event)
         self.cmdOutputTimer.Stop()
@@ -670,7 +669,8 @@
                     for lname in lnames:
                         if '@' not in lname:
                             lname += '@' + grass.gisenv()['MAPSET']
-                        self.mapCreated.emit(name=lname, ltype=prompt)
+                        if grass.find_file(lname, element=p.get('element'))['fullname']:
+                            self.mapCreated.emit(name=lname, ltype=prompt)
         if name == 'r.mask':
             self.updateMap.emit()
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/frame.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -503,7 +503,7 @@
         """Run entire model"""
         self.model.Run(self._gconsole, self.OnDone, parent = self)
-    def OnDone(self, cmd, returncode):
+    def OnDone(self, event):
         """Computation finished
         .. todo::
@@ -1728,7 +1728,7 @@
         event.Skip()
         """Python script finished"""
         try_remove(self.filename)
         self.filename = None
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -22,7 +22,7 @@
  - :class:`SqlQueryFrame`
  - :class:`SymbolDialog`
-(C) 2008-2011 by the GRASS Development Team
+(C) 2008-2015 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -46,7 +46,7 @@
 from grass.pydispatch.signal import Signal
 from core import globalvar
-from core.gcmd import GError, RunCommand, GMessage
+from core.gcmd import GError, RunCommand, GMessage, GWarning
 from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
                              OgrTypeSelect, GdalSelect, MapsetSelect, \
                              SubGroupSelect
@@ -1695,7 +1695,7 @@
         self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
         self.Bind(wx.EVT_CLOSE, lambda evt: self.Destroy())
     def doLayout(self):
         """Do layout"""
         dialogSizer = wx.BoxSizer(wx.VERTICAL)
@@ -1786,7 +1786,7 @@
         """Import/Link data (each layes as separate vector map)"""
         pass
-    def AddLayers(self, returncode, cmd = None):
+    def AddLayers(self, returncode, cmd = None, userData = None):
         """Add imported/linked layers into layer tree"""
         if not self.add.IsChecked() or returncode != 0:
             return
@@ -1808,14 +1808,32 @@
         # connect to this signal
         llist = self._giface.GetLayerList()
         if self.importType == 'gdal':
-            cmd = ['d.rast',
-                   'map=%s' % name]
+            if userData:
+                nBands = int(userData.get('nbands', 1))
+            else:
+                nBands = 1
             if UserSettings.Get(group = 'rasterLayer', key = 'opaque', subkey = 'enabled'):
-                cmd.append('-n')
-            llist.AddLayer(ltype='raster',
-                           name=name, checked=True,
-                           cmd=cmd)
+                nFlag = True
+            else:
+                nFlag = False
+            for i in range(1, nBands+1):
+                nameOrig = name
+                if nBands > 1:
+                    mapName, mapsetName = name.split('@')
+                    mapName += '.%d' % i
+                    name = mapName + '@' + mapsetName
+                cmd = ['d.rast',
+                       'map=%s' % name]
+                if nFlag:
+                    cmd.append('-n')
+                llist.AddLayer(ltype='raster',
+                               name=name, checked=True,
+                               cmd=cmd)
+                name = nameOrig
         else:
             llist.AddLayer(ltype='vector',
@@ -1832,7 +1850,7 @@
         pass
-    def OnCmdDone(self, cmd, returncode):
+    def OnCmdDone(self, event):
         """Do what has to be done after importing"""
         pass
@@ -1869,13 +1887,10 @@
                                    ogr = ogr, link = link)
         self.dsnInput.reloadDataRequired.connect(lambda data: self.list.LoadData(data))
-        mightNotWork = _("this might not work for multiple bands")
         if link:
-            self.add.SetLabel(_("Add linked layers into layer tree"
-                                " ({mightNotWork})".format(mightNotWork=mightNotWork)))
+            self.add.SetLabel(_("Add linked layers into layer tree"))
         else:
-            self.add.SetLabel(_("Add imported layers into layer tree"
+            self.add.SetLabel(_("Add imported layers into layer tree"))
         self.add.SetValue(UserSettings.Get(group = 'cmd', key = 'addNewLayer', subkey = 'enabled'))
@@ -1885,7 +1900,7 @@
         else:
             self.btn_run.SetLabel(_("&Import"))
             self.btn_run.SetToolTipString(_("Import selected layers"))
         self.doLayout()
     def OnRun(self, event):
@@ -1910,6 +1925,7 @@
             os.environ['GRASS_VECTOR_OGR'] = '1'
         for layer, output in data:
+            userData = {}
             if self.importType == 'ogr':
                 if ext and layer.rfind(ext) > -1:
                     layer = layer.replace('.' + ext, '')
@@ -1934,7 +1950,23 @@
                     idsn = os.path.join(dsn, layer)
                 else:
                     idsn = dsn
+                # check number of bands
+                nBandsStr = RunCommand('r.in.gdal',
+                                       flags = 'p',
+                                       input = idsn, read = True)
+                nBands = -1
+                if nBandsStr:
+                    try:
+                        nBands = int(nBandsStr.rstrip('\n'))
+                    except:
+                        pass
+                if nBands < 0:
+                    GWarning(_("Unable to determine number of raster bands"),
+                             parent = self)
+                    nBands = 1
+                userData['nbands'] = nBands
                 if self.link:
                     cmd = ['r.external',
                            'input=%s' % idsn,
@@ -1943,6 +1975,8 @@
                     cmd = ['r.in.gdal',
                            'input=%s' % idsn,
                            'output=%s' % output]
+                    if nBands > 1:
+                        cmd.append('-k')
             if self.overwrite.IsChecked():
                 cmd.append('--overwrite')
@@ -1960,19 +1994,19 @@
             # run in Layer Manager
-            self._giface.RunCmd(cmd, onDone=self.OnCmdDone)
+            self._giface.RunCmd(cmd, onDone = self.OnCmdDone, userData = userData)
         """Load layers and close if required"""
         if not hasattr(self, 'AddLayers'):
             return
-        self.AddLayers(cmd, returncode)
+        self.AddLayers(event.returncode, event.cmd, event.userData)
         if self.popOGR:
             os.environ.pop('GRASS_VECTOR_OGR')
-        if returncode == 0 and self.closeOnFinish.IsChecked():
+        if event.returncode == 0 and self.closeOnFinish.IsChecked():
             self.Close()
     def _getCommand(self):
@@ -2132,12 +2166,12 @@
             return
+        self.AddLayers(event.returncode, event.cmd)
         if self.closeOnFinish.IsChecked():
             self.Close()
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/forms.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -629,13 +629,10 @@
         if event:
             event.Skip()
         """This function is launched from OnRun() when command is
         finished
-        :param returncode: command's return code (0 for success)
         if hasattr(self, "btn_cancel"):
             self.btn_cancel.Enable(True)
@@ -652,7 +649,7 @@
                     self.get_dcmd is None and \
                     hasattr(self, "closebox") and \
                     self.closebox.IsChecked() and \
-                    (returncode == 0):
+                    (event.returncode == 0):
             # was closed also when aborted but better is leave it open
             wx.FutureCall(2000, self.Close)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/lmgr/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/lmgr/frame.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/lmgr/frame.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -490,7 +490,7 @@
         win.Show()
         """Command execution finished"""
         if hasattr(self, "model"):
             self.model.DeleteIntermediateData(log = self._gconsole)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py
--- grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -231,8 +231,8 @@
         if cmd:
             log.RunCmd(cmd, onDone = self.OnDone)
-        if returncode == 0:
+        if event.returncode == 0:
             if not os.getenv('GRASS_ADDON_BASE'):
                 SetAddOnPath(key = 'BASE')
Modified: grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py
--- grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/modules/mcalc_builder.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -593,12 +593,12 @@
             RunCommand(self.cmd,
                        **params)
         """Add create map to the layer tree
         Sends the mapCreated signal from the grass interface.
-        if returncode != 0:
+        if event.returncode != 0:
             return
         name = self.newmaptxt.GetValue().strip(' "') + '@' + grass.gisenv()['MAPSET']
         ltype = 'raster'
Modified: grass/branches/releasebranch_7_0/gui/wxpython/modules/vclean.py
--- grass/branches/releasebranch_7_0/gui/wxpython/modules/vclean.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/modules/vclean.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -440,7 +440,7 @@
         else:
             self.selected = -1
         """Command done"""
         self.SetStatusText('')
Modified: grass/branches/releasebranch_7_0/gui/wxpython/vnet/vnet_core.py
--- grass/branches/releasebranch_7_0/gui/wxpython/vnet/vnet_core.py	2015-08-17 11:47:30 UTC (rev 65947)
+++ grass/branches/releasebranch_7_0/gui/wxpython/vnet/vnet_core.py	2015-08-18 02:43:07 UTC (rev 65948)
@@ -282,15 +282,15 @@
         return True
-    def _createTtbDone(self, cmd, returncode):
+    def _createTtbDone(self, event):
             GMessage(parent = self.guiparent,
                      message = _("Creation of turntable failed."))
             return
         else:
             params = {}
-            for c in cmd:
+            for c in event.cmd:
                 spl_c = c.split("=")
                 if len(spl_c) != 2:
                     continue
@@ -302,7 +302,7 @@
             self.vnet_data.SetParams(params, {})
-        self.ttbCreated.emit(returncode = returncode)
+        self.ttbCreated.emit(returncode = event.returncode)
     def SaveTmpLayer(self, layer_name):
         """Permanently saves temporary map of analysis result"""
@@ -460,24 +460,24 @@
         else:
             self.goutput.RunCmd(command = cmdParams, onDone = self._vnetPathRunAnDone)
-    def _vnetPathRunTurnsAnDone(self, cmd, returncode):
+    def _vnetPathRunTurnsAnDone(self, event):
         #TODO
         #self.tmp_maps.DeleteTmpMap(self.tmpTurnAn)
-        self._vnetPathRunAnDone(cmd, returncode)
+        self._vnetPathRunAnDone(event)
-    def _vnetPathRunAnDone(self, cmd, returncode):
+    def _vnetPathRunAnDone(self, event):
         """Called when v.net.path analysis is done"""
         try_remove(self.coordsTmpFile)
-        self._onDone(cmd, returncode)
+        self._onDone(event)
-    def _onDone(self, cmd, returncode):
-        for c in cmd:
+    def _onDone(self, event):
             if "output=" in c:
                 output = c.split("=")[1]
                 break
-        self.onAnDone(cmd, returncode, output)
+        self.onAnDone(event.cmd, event.returncode, output)
     def _runTurnsAn(self, analysis, output, params, flags, catPts):
@@ -585,11 +585,11 @@
         try_remove(sqlFile)
-    def _runTurnsAnDone(self, cmd, returncode):
+    def _runTurnsAnDone(self, event):
         """Called when analysis is done"""
         #self.tmp_maps.DeleteTmpMap(self.tmpTurnAn) #TODO remove earlier (OnDone lambda?)
     def _runAn(self, analysis, output, params, flags, catPts):
@@ -691,7 +691,7 @@
         self._prepareCmd(cmdParams)
         self.goutput.RunCmd(command = cmdParams, onDone = self._runAnDone)
-    def _runAnDone(self, cmd, returncode):
+    def _runAnDone(self, event):
         self.tmp_maps.DeleteTmpMap(self.tmpInPts) #TODO remove earlier (OnDone lambda?)
         self.tmp_maps.DeleteTmpMap(self.tmpInPtsConnected)
@@ -700,7 +700,7 @@
         if cmd[0] == "v.net.flow":
             self.tmp_maps.DeleteTmpMap(self.vnetFlowTmpCut)
     def _setInputParams(self, analysis, params, flags):
         """Return list of chosen values (vector map, layers).
