[GRASS-SVN] r65974 - grass/branches/releasebranch_7_0/raster/r.external
svn_grass at osgeo.org
Thu Aug 20 04:05:51 PDT 2015
Author: neteler
Date: 2015-08-20 04:05:51 -0700 (Thu, 20 Aug 2015)
New Revision: 65974
grass/branches/releasebranch_7_0/raster/r.external/r.external.html
r.external manual: added processing workflow example
Modified: grass/branches/releasebranch_7_0/raster/r.external/r.external.html
--- grass/branches/releasebranch_7_0/raster/r.external/r.external.html 2015-08-20 11:05:16 UTC (rev 65973)
+++ grass/branches/releasebranch_7_0/raster/r.external/r.external.html 2015-08-20 11:05:51 UTC (rev 65974)
@@ -34,6 +34,30 @@
r.composite r=ortho.1 g=ortho.2 b=ortho.3 output=ortho.rgb
</pre></div>
+<h3>Processing workflow without data import and export</h3>
+External raster maps to be processed can be directly linked using <em>r.external</em>;
+likewise, results can be written out to standard raster formats with
+<em>r.external.out</em> (GDAL supported formats):
+<div class="code"><pre>
+# register GeoTIFF file to be used in current mapset:
+r.external terra_lst1km20030314.LST_Day.tif out=modis_celsius
+# define output directory for files resulting from GRASS calculation:
+r.external.out directory=$HOME/gisoutput/ format="GTiff"
+# perform GRASS calculation (here: extract pixels > 20 deg C)
+# this stores the output map directly as GeoTIFF:
+r.mapcalc "warm.tif = if(modis_celsius > 20.0, modis_celsius, null() )"
+# cease GDAL output connection and turn back to write GRASS raster files:
+r.external.out -r
+# now use the result elsewhere
+gdalinfo $HOME/gisoutput/warm.tif
+</pre></div>
<h2>REFERENCES</h2>
GDAL Pages: <a href="http://www.gdal.org">http://www.gdal.org/</a><br>
