[GRASS-SVN] r65989 - in grass-addons/grass7/gui/wxpython/wx.metadata: g.gui.metadata mdlib
svn_grass at osgeo.org
Fri Aug 21 02:52:51 PDT 2015
Author: krejcmat
Date: 2015-08-21 02:52:51 -0700 (Fri, 21 Aug 2015)
New Revision: 65989
grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py
wx.metadata addons: fix GUI bugs
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py 2015-08-21 09:40:12 UTC (rev 65988)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py 2015-08-21 09:52:51 UTC (rev 65989)
@@ -103,7 +103,7 @@
style=wx.RB_GROUP)
self.rbExternal = wx.RadioButton(self.configPanelLeft, id=wx.ID_ANY, label='Metadata external editor')
self.comboBoxProfile = wx.ComboBox(self.configPanelLeft,
- choices=['INSPIRE', 'GRASS BASIC', 'TEMPORAL', 'Load Custom'])
+ choices=['INSPIRE', 'GRASS BASIC', 'TEMPORAL', 'Load custom'])
dispatcher.connect(self.onSetProfile, signal='SET_PROFILE.update', sender=dispatcher.Any)
self.comboBoxProfile.SetStringSelection('INSPIRE')
@@ -119,8 +119,17 @@
self.comboBoxProfile.Show()
self.onEditingMode(editStatus=self.mapGrassEdit)
- def onSetProfile(self, profile):
- self.comboBoxProfile.SetStringSelection(profile)
+ def onSetProfile(self, profile=None,multi=False):
+ if profile is not None:
+ self.comboBoxProfile.SetStringSelection(profile)
+ if multi:
+ self.comboBoxProfile.Disable()
+ else:
+ self.comboBoxProfile.Enable()
+ if profile == 'Load custom':
+ self.bttCreateTemplate.Disable()
+ else:
+ self.bttCreateTemplate.Enable()
def initToolbar(self):
#self.toolbarPanel=wx.Panel(self, id=wx.ID_ANY)
@@ -593,7 +602,7 @@
return
# if editing just one map
- if self.numOfMap == 1 and multipleEditing is False:
+ if self.numOfMap == 1 and multipleEditing is False and self.profileChoice != 'Load custom':
if self.profileChoice == 'INSPIRE':
if self.chckProfileSelection('spatial'):
self.mdCreator = mdgrass.GrassMD(self.ListOfMapTypeDict[-1][self.ListOfMapTypeDict[-1].keys()[0]],
@@ -627,16 +636,22 @@
self.xmlPath = self.mdCreator.saveXML(self.mdDestination, self.nameTMPteplate, self)
self.onInitEditor()
# if editing multiple maps or just one but with loading own custom profile
- if self.profileChoice == 'Load Custom' and self.numOfMap != 0:
+ if self.profileChoice == 'Load custom' and self.numOfMap != 0:
# load profile. IF - just one map, ELSE - multiple editing
if multipleEditing is False:
dlg = wx.FileDialog(self, "Select profile", os.getcwd(), "", "*.xml", wx.OPEN)
if dlg.ShowModal() == wx.ID_OK:
self.ListOfMapTypeDict[-1].keys()[0])
- self.mdCreator.createGrassInspireISO()
+ if self.chckProfileSelection('temporal'): #if map is temporal, use temporal md pareser
+ self.mdCreator.createTemporalISO()
+ else:
+ self.mdCreator.createGrassInspireISO()
self.jinjaPath = dlg.GetPath()
# if multiple map are selected
if self.numOfMap > 1:
self.xmlPath = self.xmlPath
@@ -872,7 +887,7 @@
maplist = RunCommand('g.list', flags='mt', type='raster,vector', mapset=mapset,
quiet=True, read=True)
maplist = maplist.splitlines()
+ vartype=None
for ml in maplist:
# parse
parts1 = ml.split('/')
@@ -882,16 +897,17 @@
ltype = parts1[0]
# add mapset
- if self.itemExists(mapset, varloc) == False:
+ if self.itemExists(mapset, varloc) is False:
varmapset = self.AppendItem(varloc, mapset)
else:
varmapset = self.getItemByName(mapset, varloc)
# add type node if not exists
- if self.itemExists(ltype, varmapset) == False:
+ if self.itemExists(ltype, varmapset) is False:
vartype = self.AppendItem(varmapset, ltype)
- self.AppendItem(vartype, mlayer)
+ if vartype is not None:
+ self.AppendItem(vartype, mlayer)
def initTemporalTree(self, location, mapset):
varloc = self.AppendItem(self.rootTmp, 'Temporal maps')
@@ -907,23 +923,30 @@
allDatasets = [i for i in sorted(allDatasets,
key=lambda l: mapsets.index(l[1]))]
- first = True
loc = location
varloc = self.AppendItem(varloc, loc)
# get list of all maps in location
+ vartype=None
+ env = grass.gisenv()
+ mapset = env['MAPSET']
for ml in allDatasets:
# add mapset
- if self.itemExists(ml[1], varloc) == False:
- varmapset = self.getItemByName(ml[1], varloc)
- else:
- # add type node if not exists
- if self.itemExists(ml[2], varmapset) == False:
- vartype = self.AppendItem(varmapset, ml[2])
+ if ml[1] == mapset:#chck current mapset
+ it = self.itemExists(ml[1], varloc)
+ if it is False:
+ varmapset = it
+ else:
+ varmapset = self.getItemByName(ml[1], varloc)
+ # add type node if not exists
+ if varmapset is not None:
+ if self.itemExists(ml[2], varmapset) is False:
+ vartype = self.AppendItem(varmapset, ml[2])
- self.AppendItem(vartype, ml[0])
+ self.AppendItem(vartype, ml[0])
self.Bind(wx.EVT_TREE_SEL_CHANGED, self.onChanged)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.onChanged)
@@ -935,6 +958,18 @@
else:
self.CollapseAllChildren(evt.Item)
+ def isMapExist(self,map,type):
+ '''Check if the map is in current mapset'''
+ types=['raster',
+ 'vector',
+ 'stvds',
+ 'strds',
+ if type in types:
+ return True
+ else:
+ return False
def onChanged(self, evt=None):
@var ListOfMapTypeDict: list of dic with maps and map-type values
@@ -946,8 +981,10 @@
item = evt.Item
else:
item = self.GetSelection()
- if self.GetChildrenCount(item) == 0: # is selected map
+ name=self.GetItemText(item)
+ parentItem = self.GetItemParent(item)
+ mapType = self.GetItemText(parentItem)
+ if self.GetChildrenCount(item) == 0 and self.isMapExist(name,mapType): # is selected map
#check temporal selection
for i in self.GetSelections():
@@ -981,12 +1018,13 @@
status += map + ' '
if len(maps) > 1:
- dispatcher.send(signal='SET_PROFILE.update', profile='Load Custom')
+ dispatcher.send(signal='SET_PROFILE.update', profile='Load custom',multi=True)
MAINFRAME.bttUpdateGRASS.Disable()
MAINFRAME.bttCreateTemplate.Disable()
else:
MAINFRAME.bttCreateTemplate.Enable(True)
+ dispatcher.send(signal='SET_PROFILE.update',multi=False)
dispatcher.send(signal='STATUS_BAR_TEXT.update', text=status)
@@ -1197,7 +1235,7 @@
def validate(self, md, profile):
'''For externally loaded xml file is by default inspire validator
- if profile == 'INSPIRE' or profile == 'Load Custom':
+ if profile == 'INSPIRE' or profile == 'Load custom':
result = mdutil.isnpireValidator(md)
str1 = 'INSPIRE VALIDATOR\n'
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py 2015-08-21 09:40:12 UTC (rev 65988)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py 2015-08-21 09:52:51 UTC (rev 65989)
@@ -53,6 +53,7 @@
def __init__(self, map, type):
self.map = map
self.type = type
# function to check if map exist
self.md_grass = {}
self.md_abstract = ''
@@ -85,8 +86,11 @@
grass.fatal(_("Map <%s> does not exist in current mapset") % self.map)
def parseTemporal(self):
+ self.map="%s@%s"%(self.map,mapset)
tinfo = Module('t.info',
- input=self.map,
+ self.map,
flags='g',
type=self.type,
stdout_=PIPE)
