[GRASS-SVN] r65999 - in grass/trunk: man tools
Sun Aug 23 21:09:10 PDT 2015
Author: wenzeslaus
Date: 2015-08-23 21:09:10 -0700 (Sun, 23 Aug 2015)
New Revision: 65999
Added:
   grass/trunk/man/build_graphical_index.py
   grass/trunk/man/Makefile
   grass/trunk/man/build_html.py
   grass/trunk/tools/mkhtml.py
docs: add graphical index
* takes some time to create (finding images in HTML files)
* image titles created from HTML name and image name
* page is large (images scaled by browser)
* title is visible only on hower (perhaps different element would be better)
* assumes every image is used just once
* on hover change of border (using padding and background)
Modified: grass/trunk/man/Makefile
--- grass/trunk/man/Makefile	2015-08-24 03:56:52 UTC (rev 65998)
+++ grass/trunk/man/Makefile	2015-08-24 04:09:10 UTC (rev 65999)
@@ -23,7 +23,7 @@
 IDXCATS := $(foreach cat,$(categories),$(lastword $(subst :, ,$(cat))))
-IDXSRC = full_index index topics keywords $(IDXCATS)
+IDXSRC = full_index index topics keywords graphical_index $(IDXCATS)
 INDICES := $(patsubst %,$(HTMLDIR)/%.html,$(IDXSRC))
@@ -67,6 +67,12 @@
 	$(PYTHON) ./build_keywords.py $(HTMLDIR)
 endef
+define build_graphical_index
+GISBASE="$(RUN_GISBASE)" ARCH="$(ARCH)" ARCH_DISTDIR="$(ARCH_DISTDIR)" \
+	VERSION_NUMBER=$(GRASS_VERSION_NUMBER) VERSION_DATE=$(GRASS_VERSION_DATE) \
+	$(PYTHON) ./build_graphical_index.py $(HTMLDIR)
+endef
 $(HTMLDIR)/topics.html: $(ALL_HTML)
 	$(call build_topics)
 	touch $@
@@ -83,6 +89,10 @@
 	$(call build_keywords)
 	touch $@
+$(HTMLDIR)/graphical_index.html: $(ALL_HTML)
+	$(call build_graphical_index)
+	touch $@
 define category_rule
 $$(HTMLDIR)/$(2).html: $$(wildcard $$(HTMLDIR)/$(1).*.html) build_class.py build_html.py
 	$$(call build,class,$(1) $(2))
Added: grass/trunk/man/build_graphical_index.py
--- grass/trunk/man/build_graphical_index.py	                        (rev 0)
+++ grass/trunk/man/build_graphical_index.py	2015-08-24 04:09:10 UTC (rev 65999)
@@ -0,0 +1,136 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:    build_graphical_index
+# AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
+# PURPOSE:   Build index from images from all HTML files
+# COPYRIGHT: (C) 2015 by Vaclav Petras and the GRASS Development Team
+#        This program is free software under the GNU General Public
+#        License (>=v2). Read the file COPYING that comes with GRASS
+#        for details.
+import os
+import sys
+import fnmatch
+import re
+from build_html import write_html_footer, grass_version, header1_tmpl
+output_name = 'graphical_index.html'
+img_extensions = ['png', 'jpg', 'gif']
+img_patterns = ['*.' + extension for extension in img_extensions]
+# we don't want some images to show up
+# logos
+img_blacklist = ['grass_logo.png', 'grass_icon.png']
+# circles with numbers from helptext.html (unfortunate we have to list it here)
+img_blacklist.extend(['circle_{}.png'.format(num) for num in range(1, 6)])
+year = os.getenv("VERSION_DATE")
+# other similar strings are in a different file
+# TODO: all HTML manual building needs refactoring (perhaps grass.tools?)
+header_graphical_index_tmpl = """\
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+<style>
+img.linkimg {
+    max-width: 20%;
+    padding: 1%;
+img.linkimg:hover {
+    background-color: #eee;
+</style>
+</head>
+<body style="width: 99%">
+<div id="container">
+<a href="index.html"><img src="grass_logo.png" alt="GRASS logo"></a>
+<hr class="header">
+<h2>Graphical index of GRASS GIS modules</h2>
+def img_in_html(filename, imagename):
+    # for some reason, calling search just once is much faster
+    # than calling it on every line (time is spent in _compile)
+    pattern = re.compile('<img .*src=.{}.*>'.format(imagename))
+    with open(filename) as file:
+        if re.search(pattern, file.read()):
+            return True
+    return False
+def file_matches(filename, patterns):
+    for pattern in patterns:
+        if fnmatch.fnmatch(filename, pattern):
+            return True
+    return False
+def get_files(directory, patterns, exclude_name):
+    files = []
+    for filename in os.listdir(directory):
+        if file_matches(filename, patterns):
+            if filename != exclude_name:
+                files.append(filename)
+    return files
+def title_form_names(html_name, img_name):
+    # we ignore the possibility of having extension at the end of image
+    # so possibly r.out.png fails but image name should use _ anyway
+    # strictly speaking, it could be also, e.g., index name
+    module_name = html_name.replace('.html', '')
+    for extension in img_extensions:
+        img_name = img_name.replace('.' + extension, '')
+    img_name = img_name.replace(module_name.replace('.', '_'), '')  # using _
+    img_name = img_name.replace(module_name.replace('.', ''), '')  # using nothing
+    img_name = img_name.replace(module_name, '')  # using original dots
+    img_name = img_name.replace('_', ' ')
+    img_name = img_name.strip()
+    if img_name:
+        return "{name} ({desc})".format(name=module_name, desc=img_name)
+    else:
+        return "{name}".format(name=module_name)
+def main():
+    html_dir = sys.argv[1]
+    html_files = get_files(html_dir, ['*.html'], output_name)
+    img_html_files = {}
+    for filename in os.listdir(html_dir):
+        if filename in img_blacklist:
+            continue
+        if file_matches(filename, img_patterns):
+            for html_file in html_files:
+                if img_in_html(os.path.join(html_dir, html_file), filename):
+                    img_html_files[filename] = html_file
+                    # for now suppose one image per html
+    with open(os.path.join(html_dir, output_name), 'w') as output:
+        output.write(header1_tmpl.substitute(title="GRASS GIS %s Reference "
+                                               "Manual: Graphical index" % grass_version))
+        output.write(header_graphical_index_tmpl)
+        for image, html_file in img_html_files.iteritems():
+            title = title_form_names(html_file, image)
+            output.write(
+                '<a href="{html}" title="{title}">'
+                '<img class="linkimg" src="{img}">'
+                '</a>'
+                .format(html=html_file, img=image, title=title))
+        write_html_footer(output, "index.html", year)
+if __name__ == '__main__':
+    main()
Property changes on: grass/trunk/man/build_graphical_index.py
___________________________________________________________________
Added: svn:executable
Modified: grass/trunk/man/build_html.py
--- grass/trunk/man/build_html.py	2015-08-24 03:56:52 UTC (rev 65998)
+++ grass/trunk/man/build_html.py	2015-08-24 04:09:10 UTC (rev 65999)
@@ -191,6 +191,7 @@
 <a href="${index_url}">Main index</a> |
 <a href="topics.html">Topics index</a> |
 <a href="keywords.html">Keywords index</a> |
+<a href="graphical_index.html">Graphical index</a> |
 <a href="full_index.html">Full index</a>
 </p>
 <p>
Modified: grass/trunk/tools/mkhtml.py
--- grass/trunk/tools/mkhtml.py	2015-08-24 03:56:52 UTC (rev 65998)
+++ grass/trunk/tools/mkhtml.py	2015-08-24 04:09:10 UTC (rev 65999)
@@ -60,6 +60,7 @@
 <a href="${INDEXNAME}.html">${INDEXNAMECAP} index</a> |
 </p>
 <p>
@@ -79,6 +80,7 @@
 <a href="index.html">Main index</a> |
 </p>
 <p>
