[GRASS-SVN] r66002 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Mon Aug 24 05:27:56 PDT 2015
Author: huhabla
Date: 2015-08-24 05:27:56 -0700 (Mon, 24 Aug 2015)
New Revision: 66002
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass vector: Added wkt generation for Areas
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-24 10:13:58 UTC (rev 66001)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-24 12:27:56 UTC (rev 66002)
@@ -1619,6 +1619,20 @@
return ilist
return [Boundary(v_id=abs(v_id), c_mapinfo=self.c_mapinfo) for v_id in ilst]
+ def get_wkt(self):
+ """Return a Well Known Text string of the Area. ::
+ For now the outer ring is returned
+ TODO: Implement inner rings detected from isles
+ line = self.get_points()
+ return "Polygon((%s))" % ', '.join([
+ ' '.join(['%f' % coord for coord in pnt])
+ for pnt in line.tolist()])
@mapinfo_must_be_set
def cats(self, cats=None):
"""Get area categories.
