[GRASS-SVN] r66007 - in grass-addons/grass7/gui/wxpython/wx.metadata: r.info.iso t.info.iso v.info.iso
Mon Aug 24 11:46:16 PDT 2015
Author: krejcmat
Date: 2015-08-24 11:46:16 -0700 (Mon, 24 Aug 2015)
New Revision: 66007
   grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
   grass-addons/grass7/gui/wxpython/wx.metadata/t.info.iso/t.info.iso.py
   grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
wx.metadata addons: improved import err msg
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py	2015-08-24 16:27:10 UTC (rev 66006)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py	2015-08-24 18:46:16 UTC (rev 66007)
@@ -41,15 +41,18 @@
 from grass.pygrass.utils import get_lib_path
-def load_mdlib():
-    path = get_lib_path(modname=os.path.join('wx.metadata','mdlib') ,libname='mdgrass')
-    if path is None:
-        fatal("Not able to find the metadata library directory")
-    sys.path.append(path)
+def load_mdlib(libs):
+    for lib in libs:
+        path = get_lib_path(modname=os.path.join('wx.metadata','mdlib') ,libname=lib)
+        if path is not None and path not in sys.path:
+            sys.path.append(path)
+        elif path is  None:
+            fatal("Fatal error: library < %s > not found "%lib)
 def main():
     # load metadata library
-    load_mdlib()
+    load_mdlib(['mdgrass'])
     from mdgrass import GrassMD
     if not options['output']:
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/t.info.iso/t.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/t.info.iso/t.info.iso.py	2015-08-24 16:27:10 UTC (rev 66006)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/t.info.iso/t.info.iso.py	2015-08-24 18:46:16 UTC (rev 66007)
@@ -41,15 +41,18 @@
-def load_mdlib():
-    if path is None:
+    for lib in libs:
 def main():
-    load_mdlib()
+    # load metadata library
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py	2015-08-24 16:27:10 UTC (rev 66006)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py	2015-08-24 18:46:16 UTC (rev 66007)
@@ -40,16 +40,17 @@
-def load_mdlib():
-    if path is None:
+    for lib in libs:
 def main():
-    load_mdlib()
