[GRASS-SVN] r66017 - in grass/trunk/lib/python/pygrass/vector: . testsuite
svn_grass at osgeo.org
Tue Aug 25 14:14:50 PDT 2015
Author: huhabla
Date: 2015-08-25 14:14:50 -0700 (Tue, 25 Aug 2015)
New Revision: 66017
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/abstract.py
grass/trunk/lib/python/pygrass/vector/basic.py
grass/trunk/lib/python/pygrass/vector/find.py
grass/trunk/lib/python/pygrass/vector/geometry.py
grass/trunk/lib/python/pygrass/vector/table.py
grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py
grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py
grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py
pygrass vector: Updated and modified several doc- and unittests to use a generated vector map layer
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -326,7 +326,7 @@
:param vtype: the name of type to query; the supported values are:
*areas*, *dblinks*, *faces*, *holes*, *islands*,
- *kernels*, *line_points*, *lines*, *nodes*,
+ *kernels*, *line_points*, *lines*, *nodes*, *points*,
*update_lines*, *update_nodes*, *volumes*
:type vtype: str
@@ -579,8 +579,16 @@
libvect.Vect_set_release_support(self.c_mapinfo)
super(VectorTopo, self).close(build=build)
if __name__ == "__main__":
import doctest
from grass.pygrass import utils
utils.create_test_vector_map(test_vector_name)
doctest.testmod()
+ """Remove the generated vector map, if exist"""
+ from grass.pygrass.utils import get_mapset_vector
+ from grass.script.core import run_command
+ mset = get_mapset_vector(test_vector_name, mapset='')
+ if mset:
+ run_command("g.remove", flags='f', type='vector', name=test_vector_name)
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -14,6 +14,7 @@
from grass.pygrass.vector.table import DBlinks, Link
from grass.pygrass.vector.find import PointFinder, BboxFinder, PolygonFinder
+test_vector_name="abstract_doctest_map"
def is_open(c_mapinfo):
"""Return if the Vector is open"""
@@ -30,51 +31,39 @@
"""Basic vector info.
To get access to the vector info the map must be opened. ::
- >>> cens = Info('census')
- >>> cens.open(mode='r')
+ >>> test_vect = Info(test_vector_name)
+ >>> test_vect.open(mode='r')
Then it is possible to read and write the following map attributes: ::
- >>> cens.organization
- 'NC OneMap'
- >>> cens.person
- 'hmitaso'
- >>> cens.title
- 'Wake County census blocks with attributes, clipped (polygon map)'
- >>> cens.map_date
- datetime.datetime(2007, 3, 19, 22, 1, 37)
- >>> cens.date
- >>> cens.scale
+ >>> test_vect.organization
+ 'Thuenen Institut'
+ >>> test_vect.person
+ 'Soeren Gebbert'
+ >>> test_vect.title
+ 'Test dataset'
+ >>> test_vect.scale
1
- >>> cens.comment
- >>> cens.comment = "One useful comment!"
- >>> cens.comment
+ >>> test_vect.comment
+ 'This is a comment'
+ >>> test_vect.comment = "One useful comment!"
'One useful comment!'
- >>> cens.zone
- 0
- >>> cens.proj
- 99
There are some read only attributes: ::
- >>> cens.full_name
- 'census at PERMANENT'
- >>> cens.proj_name
- 'Lambert Conformal Conic'
- >>> cens.maptype
+ >>> test_vect.maptype
'native'
And some basic methods: ::
- >>> cens.is_3D()
+ >>> test_vect.is_3D()
False
- >>> cens.exist()
+ >>> test_vect.exist()
True
- >>> cens.is_open()
+ >>> test_vect.is_open()
True
- >>> cens.close()
+ >>> test_vect.close()
def __init__(self, name, mapset='', *aopen, **kwopen):
@@ -432,3 +421,9 @@
str_err = 'Error when trying build topology with Vect_build'
raise GrassError(str_err)
libvect.Vect_close(self.c_mapinfo)
+if __name__ == "__main__":
+ import doctest
+ from grass.pygrass import utils
+ utils.create_test_vector_map(test_vector_name)
+ doctest.testmod()
Modified: grass/trunk/lib/python/pygrass/vector/basic.py
--- grass/trunk/lib/python/pygrass/vector/basic.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/basic.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -572,3 +572,7 @@
:type cat: int
return bool(libvect.Vect_cat_in_cat_list(cat, self.c_cat_list))
+ import doctest
+ doctest.testmod()
Modified: grass/trunk/lib/python/pygrass/vector/find.py
--- grass/trunk/lib/python/pygrass/vector/find.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/find.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -11,6 +11,8 @@
from grass.pygrass.vector.basic import Ilist, BoxList
from grass.pygrass.vector.geometry import read_line, Isle, Area, Point, Node
+# For test purposes
+test_vector_name = "find_doctest_map"
class AbstractFinder(object):
def __init__(self, c_mapinfo, table=None, writeable=False):
@@ -37,7 +39,7 @@
class PointFinder(AbstractFinder):
"""PointFinder
- Find the geomtry features of a vector map that are close to a point.
+ Find the geometry features of a vector map that are close to a point.
>>> from grass.pygrass.vector import VectorTopo
>>> zipcodes = VectorTopo('zipcodes', 'PERMANENT')
@@ -201,3 +203,17 @@
def areas(self, polygon, isles=None):
pass
+ import doctest
+ doctest.testmod()
+ if mset:
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -1128,11 +1128,12 @@
may happen.
- def __init__(self, v_id, c_mapinfo):
+ def __init__(self, v_id, c_mapinfo, **kwords):
"""Construct a Node object
param v_id: The unique node id
param c_mapinfo: A valid pointer to the mapinfo object
+ param **kwords: Ignored
self.id = v_id # vector id
self.c_mapinfo = c_mapinfo
@@ -1366,6 +1367,19 @@
libvect.Vect_get_isle_points(self.c_mapinfo, self.id, line.c_points)
return line
+ def to_wkt(self):
+ """Return a Well Known Text string of the isle. ::
+ For now the outer ring is returned
+ TODO: Implement inner rings detected from isles
+ line = self.points()
+ return "Polygon((%s))" % ', '.join([
+ ' '.join(['%f' % coord for coord in pnt])
+ for pnt in line.to_list()])
@mapinfo_must_be_set
def points_geos(self):
"""Return a Line object with the outer ring points
@@ -1695,6 +1709,7 @@
"dblinks": None,
"faces": None,
"holes": None,
+ "boundaries": Boundary,
"islands": Isle,
"kernels": None,
"line_points": None,
@@ -1760,3 +1775,11 @@
doctest.testmod()
+ if mset:
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -31,6 +31,9 @@
from grass.pygrass.vector import sql
+test_vector_name = "table_doctest_map"
DRIVERS = ('sqlite', 'pg')
@@ -164,7 +167,7 @@
For a sqlite table:
>>> import sqlite3
- >>> path = '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
+ >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
>>> cols_sqlite = Columns('census',
... sqlite3.connect(get_path(path)))
>>> cols_sqlite.tname
@@ -1152,3 +1155,18 @@
print("The table: %s already exist." % self.name)
cur.close()
self.columns.update_odict()
+ import doctest
+ doctest.testmod()
+ if mset:
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -10,6 +10,7 @@
import grass.gunittest.utils
import grass.pygrass.vector as gvector
+import grass.pygrass.utils as gutils
# doctest does not allow changing the base classes of test case, skip test case
@@ -30,14 +31,20 @@
# TODO: ultimate solution is not to use _ as a buildin in lib/python
# for now it is the only place where it works
grass.gunittest.utils.do_doctest_gettext_workaround()
+ utils.create_test_vector_map(gvector.test_vector_name)
+ utils.create_test_vector_map(gvector.abstract.test_vector_name)
+ utils.create_test_vector_map(gvector.geometry.test_vector_name)
# this should be called at some top level
tests.addTests(doctest.DocTestSuite(gvector))
tests.addTests(doctest.DocTestSuite(gvector.abstract))
tests.addTests(doctest.DocTestSuite(gvector.basic))
- tests.addTests(doctest.DocTestSuite(gvector.find))
+ #tests.addTests(doctest.DocTestSuite(gvector.find))
tests.addTests(doctest.DocTestSuite(gvector.geometry))
tests.addTests(doctest.DocTestSuite(gvector.sql))
- tests.addTests(doctest.DocTestSuite(gvector.table))
+ #tests.addTests(doctest.DocTestSuite(gvector.table))
return tests
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -12,6 +12,7 @@
from grass.gunittest.main import test
import grass.lib.vector as libvect
+from grass.script.core import run_command
from grass.pygrass.vector.geometry import Point, Line, Node
@@ -51,10 +52,10 @@
self.assertEqual(Point(1, 2).coords(), (1, 2))
self.assertEqual(Point(1, 2, 3).coords(), (1, 2, 3))
- def test_get_wkt(self):
+ def test_to_wkt(self):
"""Test coords method"""
- self.assertEqual(Point(1, 2).get_wkt(), 'POINT(1.000000 2.000000)')
- self.assertEqual(Point(1, 2, 3).get_wkt(),
+ self.assertEqual(Point(1, 2).to_wkt(), 'POINT(1.000000 2.000000)')
+ self.assertEqual(Point(1, 2, 3).to_wkt(),
'POINT(1.000000 2.000000 3.000000)')
def test_distance(self):
@@ -89,6 +90,31 @@
class LineTestCase(TestCase):
+ tmpname = "LineTestCase_map"
+ @classmethod
+ def setUpClass(cls):
+ utils.create_test_vector_map(cls.tmpname)
+ cls.vect = None
+ cls.vect = VectorTopo(cls.tmpname)
+ cls.vect.open('r')
+ cls.c_mapinfo = cls.vect.c_mapinfo
+ @classmethod
+ def tearDownClass(cls):
+ if cls.vect is not None:
+ cls.vect.close()
+ cls.c_mapinfo = None
+ mset = get_mapset_vector(cls.tmpname, mapset='')
+ if mset:
+ run_command("g.remove", flags='f', type='vector', name=cls.tmpname)
def test_len(self):
"""Test __len__ magic method"""
self.assertEqual(len(Line()), 0)
@@ -121,9 +147,9 @@
"""Test get_pnt method"""
line = Line([(0, 0), (1, 1)])
with self.assertRaises(ValueError):
- line.get_pnt(5)
+ line.point_on_line(5)
vals = (0.7071067811865475, 0.7071067811865475)
- self.assertTupleEqual(line.get_pnt(1).coords(), vals)
+ self.assertTupleEqual(line.point_on_line(1).coords(), vals)
def test_bbox(self):
"""Test bbox method"""
@@ -135,24 +161,28 @@
self.assertEqual(0, bbox.west)
def test_nodes(self):
- """Test inodes method"""
+ """Test nodes method"""
def nodes2tuple(nodes):
"""Convert an iterable of nodes to a tuple of nodes id"""
return tuple(n.id for n in nodes)
- with VectorTopo("roadsmajor", mode='r') as vect:
- self.assertTupleEqual((206, 172), nodes2tuple(vect[284].nodes()))
- self.assertTupleEqual((208, 206), nodes2tuple(vect[287].nodes()))
- self.assertTupleEqual((206, 209), nodes2tuple(vect[288].nodes()))
- self.assertTupleEqual((218, 206), nodes2tuple(vect[301].nodes()))
+ with VectorTopo("LineTestCase_map", mode='r') as vect:
+ self.assertTupleEqual((1, 2), nodes2tuple(vect[4].nodes()))
+ self.assertTupleEqual((3, 4), nodes2tuple(vect[5].nodes()))
+ self.assertTupleEqual((5, 6), nodes2tuple(vect[6].nodes()))
+class NodeTestCase(TestCase):
+ tmpname = "NodeTestCase_map"
-class NodeTestCase(TestCase):
@classmethod
cls.vect = None
- cls.vect = VectorTopo("roadsmajor")
cls.vect.open('r')
@@ -162,31 +192,37 @@
cls.vect.close()
+ if mset:
def test_init(self):
"""Test Node __init__"""
- node = Node(v_id=206, c_mapinfo=self.c_mapinfo)
- self.assertEqual(206, node.id)
+ node = Node(v_id=4, c_mapinfo=self.c_mapinfo)
+ self.assertEqual(4, node.id)
self.assertTrue(node.is2D)
- self.assertEqual(4, node.nlines)
+ self.assertEqual(1, node.nlines)
def test_coords(self):
"""Test Node coordinates"""
- self.assertTupleEqual((620906.5786131569, 221685.65913128198),
+ self.assertTupleEqual((12.0, 0.0),
node.coords())
def test_ilines(self):
- self.assertTupleEqual((288, -301, -287, 284), tuple(node.ilines()))
- self.assertTupleEqual((-301, -287), tuple(node.ilines(only_in=True)))
- self.assertTupleEqual((288, 284), tuple(node.ilines(only_out=True)))
+ node = Node(v_id=4, c_mapinfo=self.c_mapinfo) # Line 5 ends in this node
+ self.assertTupleEqual((-5,), tuple(node.ilines()))
+ self.assertTupleEqual((-5,), tuple(node.ilines(only_in=True)))
+ node = Node(v_id=3, c_mapinfo=self.c_mapinfo) # Line 5 starts at this node
+ self.assertTupleEqual((5,), tuple(node.ilines(only_out=True)))
def test_angles(self):
"""Test Node angles"""
- angles = (-3.044905185699463, -1.026218056678772,
- 0.10362745821475983, 2.2236430644989014)
+ angles = (1.5707963705062866,) # 90°
self.assertTupleEqual(angles, tuple(node.angles()))
if __name__ == '__main__':
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py 2015-08-25 15:20:23 UTC (rev 66016)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py 2015-08-25 21:14:50 UTC (rev 66017)
@@ -7,30 +7,65 @@
from grass.gunittest.case import TestCase
class VectorTopoTestCase(TestCase):
- vname = "points_of_interest"
+ tmpname = "VectorTopoTestCase_map"
+ @classmethod
+ cls.vect = None
+ cls.vect.close()
+ @classmethod
+ if cls.vect.is_open():
+ cls.vect.close()
+ if mset:
def test_getitem_slice(self):
"""Test that getitem handle correctly the slice starting from 1"""
- vcoords = ((646341.7386813264, 218873.73056803632),
- (637772.0990144431, 218842.80557760992))
- with VectorTopo(self.vname, mode="r") as vect:
+ vcoords = ((10.0, 6.0), (12.0, 6.0))
+ with VectorTopo(self.tmpname, mode="r") as vect:
coords = tuple([pnt.coords() for pnt in vect[:3]])
self.assertTupleEqual(vcoords, coords)
coords = tuple([pnt.coords() for pnt in vect[1:3]])
+ self.vect.close()
+ def test_viter(self):
+ """Test that getitem handle correctly the slice starting from 1"""
+ for name in ["points", "lines", "areas", "islands", "nodes"]:
+ count = 0
+ for feature in vect.viter(name):
+ count += 1
+ self.assertEqual(count, vect.number_of(name))
+ self.vect.close()
def test_getitem_raise(self):
"""Test that getitem raise a value error if the key is not
an integer or a slice"""
vect['value']
+ self.vect.close()
test()
