[GRASS-SVN] r66026 - in grass-addons/grass7/raster/r.green/r.green.hydro: r.green.hydro.optimal r.green.hydro.recommended
svn_grass at osgeo.org
Wed Aug 26 00:53:19 PDT 2015
Author: Giulia
Date: 2015-08-26 00:53:19 -0700 (Wed, 26 Aug 2015)
New Revision: 66026
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
r.green: bugs in the cleanup
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py 2015-08-26 07:52:13 UTC (rev 66025)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.optimal/r.green.hydro.optimal.py 2015-08-26 07:53:19 UTC (rev 66026)
@@ -134,7 +134,7 @@
def main(options, flags):
TMPRAST, TMPVECT, DEBUG = [], [], False
- atexit.register(cleanup, rast=TMPRAST, vect=TMPVECT, debug=DEBUG)
+ atexit.register(cleanup, raster=TMPRAST, vector=TMPVECT, debug=DEBUG)
elevation = options['elevation']
river = options['river'] # raster
discharge = options['discharge'] # vec
@@ -172,11 +172,10 @@
range_plant = (len_min, len_plant)
plants = find_segments(river, discharge, elevation, range_plant, distance,
p_max)
- if output_plant:
- write_plants(plants, output_plant, efficiency, p_min)
- write_points(plants, output_point, efficiency, p_min)
+ if output_point:
+ write_points(plants, output_point, efficiency, p_min)
+ write_plants(plants, output_plant, efficiency, p_min)
if __name__ == "__main__":
options, flags = gcore.parser()
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py 2015-08-26 07:52:13 UTC (rev 66025)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py 2015-08-26 07:53:19 UTC (rev 66026)
@@ -166,11 +166,6 @@
#% required: yes
#%end
#%option G_OPT_V_OUTPUT
-#% key: output_point
-#% description: Name of output vector with potential intakes and restitution
-#% required: no
-#%end
-#%option G_OPT_V_OUTPUT
#% key: output_vis
#% description: Name of output vector with viewed areas
#% required: no
@@ -229,7 +224,7 @@
def main(opts, flgs):
TMPRAST, TMPVECT, DEBUG = [], [], flgs['d']
OVW = gcore.overwrite()
dtm = options['elevation']
@@ -241,7 +236,6 @@
len_min = options['len_min']
distance = options['distance']
output_plant = options['output_plant']
- output_point = options['output_point']
area = options['area']
buff = options['buff']
efficiency = options['efficiency']
@@ -264,11 +258,12 @@
if area:
if buff:
+ area_tmp = 'tmp_buff_area_%05d' % pid
gcore.run_command('v.buffer',
input=area,
- output='buff_area',
+ output=area_tmp,
distance=buff, overwrite=OVW)
- area = 'tmp_buff_area_%05d' % pid
+ area = area_tmp
TMPVECT.append(area)
oriver = 'tmp_river_%05d' % pid
@@ -347,7 +342,6 @@
elevation=dtm,
len_plant=len_plant,
output_plant=output_plant,
- output_point=output_point,
distance=distance,
len_min=len_min,
efficiency=efficiency,
