[GRASS-SVN] r66043 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical
svn_grass at osgeo.org
Thu Aug 27 01:04:06 PDT 2015
Author: Giulia
Date: 2015-08-27 01:04:06 -0700 (Thu, 27 Aug 2015)
New Revision: 66043
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
r.green: uncommit r.green.hydro.structures
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2015-08-27 07:58:38 UTC (rev 66042)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2015-08-27 08:04:06 UTC (rev 66043)
@@ -656,15 +656,15 @@
conv_segpoints(plant, options['output_point'])
# set the opions to execute the r.green.hydro.structure
-# struct_opts = dict(elevation=elevation, plant=plant,
-# output_struct=output_struct,
-# ndigits=options['ndigits'],
-# contour=options['contour'], overwrite=gcore.overwrite())
-# if options['resolution']:
-# struct_opts['resolution'] = options['resolution']
-# gcore.run_command('r.green.hydro.strucintake_idture', **struct_opts)
-# gcore.run_command('v.build', map=output_struct)
+ struct_opts = dict(elevation=elevation, plant=plant,
+ output_struct=output_struct,
+ ndigits=options['ndigits'],
+ contour=options['contour'], overwrite=gcore.overwrite())
+ if options['resolution']:
+ struct_opts['resolution'] = options['resolution']
+ gcore.run_command('r.green.hydro.strucintake_idture', **struct_opts)
+ gcore.run_command('v.build', map=output_struct)
with VectorTopo(output_struct, mode='rw') as struct:
list_intakeid = compute_losses(struct, options,
