[GRASS-SVN] r66046 - in grass/trunk: include/defs lib/vector/Vlib
svn_grass at osgeo.org
Thu Aug 27 05:48:17 PDT 2015
Author: huhabla
Date: 2015-08-27 05:48:17 -0700 (Thu, 27 Aug 2015)
New Revision: 66046
Added:
grass/trunk/lib/vector/Vlib/geos_to_wktb.c
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/geos.c
vector library: Added new methods to generate Well Known Text (WTK) and Well Known Binary (WTB) out of GEOS geometries
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2015-08-27 09:19:03 UTC (rev 66045)
+++ grass/trunk/include/defs/vector.h 2015-08-27 12:48:17 UTC (rev 66046)
@@ -313,7 +313,7 @@
int Vect_select_areas_by_box(struct Map_info *, const struct bound_box *,
struct boxlist *);
int Vect_select_isles_by_box(struct Map_info *, const struct bound_box *,
- struct boxlist *);
+ struct boxlist *);
int Vect_select_nodes_by_box(struct Map_info *, const struct bound_box *,
struct ilist *);
int Vect_find_node(struct Map_info *, double, double, double, double, int);
@@ -595,10 +595,15 @@
/* GEOS support */
#ifdef HAVE_GEOS
GEOSGeometry *Vect_read_line_geos(struct Map_info *, int, int*);
-GEOSGeometry *Vect_line_to_geos(struct Map_info *, const struct line_pnts*, int);
+GEOSGeometry *Vect_line_to_geos(const struct line_pnts*, int, int);
GEOSGeometry *Vect_read_area_geos(struct Map_info *, int);
GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *, int);
GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *, int);
+char *Vect_line_to_wkt(const struct line_pnts *, int, int);
+unsigned char *Vect_line_to_wkb(const struct line_pnts *,
+ int, int, size_t *);
+char *Vect_read_area_to_wkt(struct Map_info *, int);
+unsigned char *Vect_read_area_to_wkb(struct Map_info *, int, size_t *);
#endif
/* Raster color tables */
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c 2015-08-27 09:19:03 UTC (rev 66045)
+++ grass/trunk/lib/vector/Vlib/geos.c 2015-08-27 12:48:17 UTC (rev 66046)
@@ -1,15 +1,15 @@
\file lib/vector/Vlib/geos.c
\brief Vector library - GEOS support
Higher level functions for reading/writing/manipulating vectors.
(C) 2009 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
\author Martin Landa <landa.martin gmail.com>
@@ -31,13 +31,13 @@
- GV_POINT -> POINT
- GV_LINE -> LINESTRING
- GV_BOUNDARY -> LINESTRING / LINEARRING
You should free allocated memory by GEOSGeom_destroy().
\param Map pointer to Map_info structure
\param line feature id
\param[out] type feature type or NULL
\return pointer to GEOSGeometry instance
\return empty GEOSGeometry for unsupported feature type
\return NULL on error
@@ -45,25 +45,25 @@
GEOSGeometry *Vect_read_line_geos(struct Map_info *Map, int line, int *type)
struct P_line *Line;
G_debug(3, "Vect_read_line_geos(): line = %d", line);
if (!VECT_OPEN(Map))
- G_fatal_error("Vect_read_line_geos(): %s", _("vector map is not opened"));
+ G_fatal_error("Vect_read_line_geos(): %s", _("vector map is not opened"));
if (line < 1 || line > Map->plus.n_lines)
- G_fatal_error(_("Vect_read_line_geos(): feature id %d is not reasonable "
- "(max features in vector map <%s>: %d)"),
- line, Vect_get_full_name(Map), Map->plus.n_lines);
+ G_fatal_error(_("Vect_read_line_geos(): feature id %d is not reasonable "
+ "(max features in vector map <%s>: %d)"),
+ line, Vect_get_full_name(Map), Map->plus.n_lines);
if (Map->format != GV_FORMAT_NATIVE)
- G_fatal_error("Vect_read_line_geos(): %s", _("only native format supported"));
+ G_fatal_error("Vect_read_line_geos(): %s", _("only native format supported"));
Line = Map->plus.Line[line];
if (Line == NULL)
- G_fatal_error("Vect_read_line_geos(): %s %d",
- _("Attempt to read dead line"), line);
+ G_fatal_error("Vect_read_line_geos(): %s %d",
+ _("Attempt to read dead line"), line);
return Vect__read_line_geos(Map, Line->offset, type);
@@ -73,7 +73,7 @@
- \param area area id
+ \param area area id
@@ -82,29 +82,29 @@
int i, nholes, isle;
GEOSGeometry *boundary, *poly, **holes;
G_debug(3, "Vect_read_area_geos(): area = %d", area);
boundary = GEOSGeom_createLinearRing(Vect_get_area_points_geos(Map, area));
if (!boundary) {
- G_fatal_error(_("Vect_read_area_geos(): unable to read area id %d"),
- area);
+ G_fatal_error(_("Vect_read_area_geos(): unable to read area id %d"),
+ area);
nholes = Vect_get_area_num_isles(Map, area);
holes = (GEOSGeometry **) G_malloc(nholes * sizeof(GEOSGeometry *));
for (i = 0; i < nholes; i++) {
- isle = Vect_get_area_isle(Map, area, i);
- if (isle < 1) {
- nholes--;
- continue;
- holes[i] = GEOSGeom_createLinearRing(Vect_get_isle_points_geos(Map, isle));
- if (!(holes[i]))
- G_fatal_error(_("Vect_read_area_geos(): unable to read isle id %d of area id %d"),
- isle, area);
+ isle = Vect_get_area_isle(Map, area, i);
+ if (isle < 1) {
+ nholes--;
+ continue;
+ holes[i] = GEOSGeom_createLinearRing(Vect_get_isle_points_geos(Map, isle));
+ if (!(holes[i]))
+ G_fatal_error(_("Vect_read_area_geos(): unable to read isle id %d of area id %d"),
+ isle, area);
poly = GEOSGeom_createPolygon(boundary, holes, nholes);
G_free(holes);
@@ -116,73 +116,72 @@
Supported types:
- GV_POINT -> POINT
+ - GV_CENTROID -> POINT
- GV_BOUNDARY -> LINEARRING
- \param Map pointer to Map_info structure
\param points pointer to line_pnts structure
\param type feature type (see supported types)
+ \param with_z Set to 1 if the feature is 3d, 0 otherwise
-GEOSGeometry *Vect_line_to_geos(struct Map_info *Map,
- const struct line_pnts *points, int type)
+GEOSGeometry *Vect_line_to_geos(const struct line_pnts *points,
+ int type, int with_z)
- int i, with_z;
+ int i;
GEOSGeometry *geom;
GEOSCoordSequence *pseq;
G_debug(3, "Vect_line_to_geos(): type = %d", type);
- with_z = Vect_is_3d(Map);
/* read only points / lines / boundaries */
- if (!(type & (GV_POINT | GV_LINES)))
- return NULL;
+ if (!(type & (GV_POINT | GV_CENTROID | GV_LINES)))
+ return NULL;
- if (type == GV_POINT) {
- if (points->n_points != 1)
- /* point is not valid */
- return NULL;
+ if (type == GV_POINT || type == GV_CENTROID) {
+ if (points->n_points != 1)
+ /* point is not valid */
+ return NULL;
- else {
- if (points->n_points < 2)
- /* line/boundary is not valid */
- return NULL;
+ else {
+ if (points->n_points < 2)
+ /* line/boundary is not valid */
+ return NULL;
pseq = GEOSCoordSeq_create(points->n_points, with_z ? 3 : 2);
for (i = 0; i < points->n_points; i++) {
- GEOSCoordSeq_setX(pseq, i, points->x[i]);
- GEOSCoordSeq_setY(pseq, i, points->y[i]);
- if (with_z)
- GEOSCoordSeq_setZ(pseq, i, points->z[i]);
+ GEOSCoordSeq_setX(pseq, i, points->x[i]);
+ GEOSCoordSeq_setY(pseq, i, points->y[i]);
+ if (with_z)
+ GEOSCoordSeq_setZ(pseq, i, points->z[i]);
- geom = GEOSGeom_createPoint(pseq);
+ geom = GEOSGeom_createPoint(pseq);
else if (type == GV_LINE)
- geom = GEOSGeom_createLineString(pseq);
+ geom = GEOSGeom_createLineString(pseq);
else { /* boundary */
- if (GEOSisRing(geom)) {
- /* GEOSGeom_destroy(geom); */
- geom = GEOSGeom_createLinearRing(pseq);
+ if (GEOSisRing(geom)) {
+ /*GEOSGeom_destroy(geom);*/
+ geom = GEOSGeom_createLinearRing(pseq);
/* GEOSCoordSeq_destroy(pseq); */
return geom;
\brief Read line from coor file
@@ -197,50 +196,50 @@
GEOSGeometry *Vect__read_line_geos(struct Map_info *Map, long offset, int *type)
int ftype;
GEOSGeometry *geom;
pseq = V1_read_line_geos(Map, offset, &ftype);
if (!pseq)
- G_fatal_error(_("Unable to read line offset %ld"), offset);
+ G_fatal_error(_("Unable to read line offset %ld"), offset);
if (ftype & GV_POINT) {
- G_debug(3, " geos_type = point");
+ G_debug(3, " geos_type = point");
else if (ftype & GV_LINE) {
- G_debug(3, " geos_type = linestring");
+ G_debug(3, " geos_type = linestring");
- G_debug(3, " geos_type = linearring");
- else {
+ /* GEOSGeom_destroy(geom); */
+ G_debug(3, " geos_type = linearring");
+ else {
if (type)
*type = ftype;
return geom;
\brief Read line from coor file into GEOSCoordSequence
You should free allocated memory by GEOSCoordSeq_destroy().
\param line line id
\return pointer to GEOSCoordSequence
\return empty GEOSCoordSequence for dead line or unsuppored feature type
\return NULL end of file
@@ -249,31 +248,31 @@
int ftype;
G_debug(3, "V2_read_line_geos(): line = %d", line);
if (Line == NULL)
- G_fatal_error("V2_read_line_geos(): %s %d",
+ G_fatal_error("V2_read_line_geos(): %s %d",
return V1_read_line_geos(Map, Line->offset, &ftype);
\brief Read feature from coor file into GEOSCoordSequence
Note: Function reads only points, lines and boundaries, other
feature types are ignored (empty coord array is returned)!
\param offset line offset
@@ -285,103 +284,103 @@
char rhead, nc;
long size;
double *x, *y, *z;
G_debug(3, "V1_read_line_geos(): offset = %ld", offset);
Map->head.last_offset = offset;
/* reads must set in_head, but writes use default */
dig_set_cur_port(&(Map->head.port));
dig_fseek(&(Map->dig_fp), offset, 0);
if (0 >= dig__fread_port_C(&rhead, 1, &(Map->dig_fp)))
- return NULL; /* end of file */
- if (!(rhead & 0x01)) /* dead line */
- return GEOSCoordSeq_create(0, (Map->head.with_z) ? 3 : 2);
+ return NULL; /* end of file */
- if (rhead & 0x02) /* categories exists */
- do_cats = 1; /* do not return here let file offset moves forward to next */
- else /* line */
- do_cats = 0;
+ if (!(rhead & 0x01)) /* dead line */
+ return GEOSCoordSeq_create(0, (Map->head.with_z) ? 3 : 2);
+ if (rhead & 0x02) /* categories exists */
+ do_cats = 1; /* do not return here let file offset moves forward to next */
+ else /* line */
+ do_cats = 0;
rhead >>= 2;
*type = dig_type_from_store((int) rhead);
if (!(*type & (GV_POINT | GV_LINES)))
/* skip categories */
if (do_cats) {
- if (Map->head.coor_version.minor == 1) { /* coor format 5.1 */
- if (0 >= dig__fread_port_I(&n_cats, 1, &(Map->dig_fp)))
- return NULL;
- else { /* coor format 5.0 */
- if (0 >= dig__fread_port_C(&nc, 1, &(Map->dig_fp)))
- return NULL;
- n_cats = (int) nc;
- G_debug(3, " n_cats = %d", n_cats);
+ if (Map->head.coor_version.minor == 1) { /* coor format 5.1 */
+ if (0 >= dig__fread_port_I(&n_cats, 1, &(Map->dig_fp)))
+ return NULL;
+ else { /* coor format 5.0 */
+ if (0 >= dig__fread_port_C(&nc, 1, &(Map->dig_fp)))
+ return NULL;
+ n_cats = (int) nc;
+ G_debug(3, " n_cats = %d", n_cats);
- size = (2 * PORT_INT) * n_cats;
- size = (PORT_SHORT + PORT_INT) * n_cats;
- dig_fseek(&(Map->dig_fp), size, SEEK_CUR);
+ size = (2 * PORT_INT) * n_cats;
+ size = (PORT_SHORT + PORT_INT) * n_cats;
+ dig_fseek(&(Map->dig_fp), size, SEEK_CUR);
if (*type & GV_POINTS) {
- n_points = 1;
+ n_points = 1;
else {
- if (0 >= dig__fread_port_I(&n_points, 1, &(Map->dig_fp)))
- return NULL;
+ if (0 >= dig__fread_port_I(&n_points, 1, &(Map->dig_fp)))
+ return NULL;
G_debug(3, " n_points = %d dim = %d", n_points, (Map->head.with_z) ? 3 : 2);
pseq = GEOSCoordSeq_create(n_points, (Map->head.with_z) ? 3 : 2);
x = (double *) G_malloc(n_points * sizeof(double));
y = (double *) G_malloc(n_points * sizeof(double));
if (Map->head.with_z)
- z = (double *) G_malloc(n_points * sizeof(double));
+ z = (double *) G_malloc(n_points * sizeof(double));
else
- z = NULL;
+ z = NULL;
if (0 >= dig__fread_port_D(x, n_points, &(Map->dig_fp)))
if (0 >= dig__fread_port_D(y, n_points, &(Map->dig_fp)))
if (Map->head.with_z) {
- if (0 >= dig__fread_port_D(z, n_points, &(Map->dig_fp)))
+ if (0 >= dig__fread_port_D(z, n_points, &(Map->dig_fp)))
for (i = 0; i < n_points; i++) {
- GEOSCoordSeq_setX(pseq, i, x[i]);
- GEOSCoordSeq_setY(pseq, i, y[i]);
- if (Map->head.with_z)
- GEOSCoordSeq_setZ(pseq, i, z[i]);
+ GEOSCoordSeq_setX(pseq, i, x[i]);
+ GEOSCoordSeq_setY(pseq, i, y[i]);
+ if (Map->head.with_z)
+ GEOSCoordSeq_setZ(pseq, i, z[i]);
G_debug(3, " off = %ld", (long) dig_ftell(&(Map->dig_fp)));
G_free((void *) x);
G_free((void *) y);
if (z)
- G_free((void *) z);
+ G_free((void *) z);
return pseq;
@@ -403,17 +402,17 @@
struct Plus_head *Plus;
struct P_area *Area;
G_debug(3, "Vect_get_area_points_geos(): area = %d", area);
Plus = &(Map->plus);
Area = Plus->Area[area];
- if (Area == NULL) { /* dead area */
- G_warning(_("Attempt to read points of nonexistent area id %d"), area);
- return NULL; /* error , because we should not read dead areas */
+ if (Area == NULL) { /* dead area */
+ G_warning(_("Attempt to read points of nonexistent area id %d"), area);
+ return NULL; /* error , because we should not read dead areas */
return read_polygon_points(Map, Area->n_lines, Area->lines);
@@ -421,7 +420,7 @@
\brief Returns the polygon (isle) array of points (inner ring)
See also Vect_get_isle_points().
@@ -434,7 +433,7 @@
struct P_isle *Isle;
G_debug(3, "Vect_get_isle_points_geos(): isle = %d", isle);
@@ -450,7 +449,7 @@
unsigned int n_points, n_points_shell;
double x, y, z;
int *dir;
GEOSCoordSequence **pseq, *pseq_shell;
G_debug(3, " n_lines = %d", n_lines);
@@ -459,64 +458,64 @@
n_points_shell = 0;
for (i = 0; i < n_lines; i++) {
- line = lines[i];
- aline = abs(line);
- G_debug(3, " append line(%d) = %d", i, line);
+ line = lines[i];
+ aline = abs(line);
+ G_debug(3, " append line(%d) = %d", i, line);
- if (line > 0)
- dir[i] = GV_FORWARD;
- else
- dir[i] = GV_BACKWARD;
- pseq[i] = V2_read_line_geos(Map, aline);
- if (!(pseq[i])) {
- G_fatal_error(_("Unable to read feature id %d"), aline);
- GEOSCoordSeq_getSize(pseq[i], &n_points);
- G_debug(3, " line n_points = %d", n_points);
- n_points_shell += n_points;
+ if (line > 0)
+ dir[i] = GV_FORWARD;
+ else
+ dir[i] = GV_BACKWARD;
+ pseq[i] = V2_read_line_geos(Map, aline);
+ if (!(pseq[i])) {
+ G_fatal_error(_("Unable to read feature id %d"), aline);
+ GEOSCoordSeq_getSize(pseq[i], &n_points);
+ G_debug(3, " line n_points = %d", n_points);
+ n_points_shell += n_points;
/* create shell (outer ring) */
pseq_shell = GEOSCoordSeq_create(n_points_shell, Map->head.with_z ? 3 : 2);
k = 0;
- if (dir[i] == GV_FORWARD) {
- for (j = 0; j < (int) n_points; j++, k++) {
- GEOSCoordSeq_getX(pseq[i], j, &x);
- GEOSCoordSeq_setX(pseq_shell, k, x);
- GEOSCoordSeq_getY(pseq[i], j, &y);
- GEOSCoordSeq_setY(pseq_shell, k, y);
- if (Map->head.with_z) {
- GEOSCoordSeq_getY(pseq[i], j, &z);
- GEOSCoordSeq_setZ(pseq_shell, k, z);
- else { /* GV_BACKWARD */
- for (j = (int) n_points - 1; j > -1; j--, k++) {
- GEOSCoordSeq_destroy(pseq[i]);
+ if (dir[i] == GV_FORWARD) {
+ for (j = 0; j < (int) n_points; j++, k++) {
+ GEOSCoordSeq_getX(pseq[i], j, &x);
+ GEOSCoordSeq_setX(pseq_shell, k, x);
+ GEOSCoordSeq_getY(pseq[i], j, &y);
+ GEOSCoordSeq_setY(pseq_shell, k, y);
+ if (Map->head.with_z) {
+ GEOSCoordSeq_getY(pseq[i], j, &z);
+ GEOSCoordSeq_setZ(pseq_shell, k, z);
+ else { /* GV_BACKWARD */
+ for (j = (int) n_points - 1; j > -1; j--, k++) {
+ GEOSCoordSeq_destroy(pseq[i]);
G_free((void *) pseq);
G_free((void *) dir);
return pseq_shell;
#endif /* HAVE_GEOS */
Added: grass/trunk/lib/vector/Vlib/geos_to_wktb.c
--- grass/trunk/lib/vector/Vlib/geos_to_wktb.c (rev 0)
+++ grass/trunk/lib/vector/Vlib/geos_to_wktb.c 2015-08-27 12:48:17 UTC (rev 66046)
@@ -0,0 +1,195 @@
+ \file lib/vector/Vlib/geos_to_wktb.c
+ \brief Vector library - GEOS powered WKT and WKB export
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2015 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Soeren Gebbert <soerengebbert googlemail.com>
+#include <stdlib.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#ifdef HAVE_GEOS
+ \brief Read vector area and stores it as WKB unsigned char array
+ \param Map pointer to Map_info structure
+ \param area area idmetry instance
+ \param size The size of the returned byte array
+ \return NULL on error
+ \return pointer to char array
+unsigned char *Vect_read_area_to_wkb(struct Map_info * Map, int area, size_t *size)
+ static int init = 0;
+ /* The writer is static for performance reasons */
+ static GEOSWKBWriter *writer = NULL;
+ unsigned char *wkb = NULL;
+ if(init == 0) {
+ initGEOS(NULL, NULL);
+ writer = GEOSWKBWriter_create();
+ init += 1;
+ GEOSWKBWriter_setOutputDimension(writer, 2);
+ GEOSGeometry *geom = Vect_read_area_geos(Map, area);
+ if(!geom) {
+ return(NULL);
+ wkb = GEOSWKBWriter_write(writer, geom, size);
+ GEOSGeom_destroy(geom);
+ return(wkb);
+ \brief Read vector area and stores it as WKT char array
+char *Vect_read_area_to_wkt(struct Map_info * Map, int area)
+ static GEOSWKTWriter *writer = NULL;
+ char *wkt = NULL;
+ if(init == 0) {
+ writer = GEOSWKTWriter_create();
+ init += 1;
+ GEOSWKTWriter_setOutputDimension(writer, 2);
+ if(!geom) {
+ return(NULL);
+ wkt = GEOSWKTWriter_write(writer, geom);
+ return(wkt);
+ \brief Create a WKB representation of given type from feature points.
+ This function is not thread safe, it uses static variables for speedup.
+ Supported types:
+ - GV_POINT -> POINT
+ - GV_LINE -> LINESTRING
+ - GV_BOUNDARY -> LINEARRING
+ \param points pointer to line_pnts structure
+ \param type feature type (see supported types)
+unsigned char *Vect_line_to_wkb(const struct line_pnts *points,
+ int type, int with_z, size_t *size)
+ if(init == 0) {
+ init += 1;
+ GEOSWKBWriter_setOutputDimension(writer, with_z ? 3 : 2);
+ GEOSGeometry *geom = Vect_line_to_geos(points, type, with_z);
+ if(!geom) {
+ return(NULL);
+ return(wkb);
+ \brief Create a WKT representation of given type from feature points.
+ Supported types:
+char *Vect_line_to_wkt(const struct line_pnts *points,
+ char *wkt = NULL;
+ if(init == 0) {
+ init += 1;
+ GEOSWKTWriter_setOutputDimension(writer, with_z ? 3 : 2);
+ if(!geom) {
+ return(NULL);
+ return(wkt);
+#endif /* HAVE_GEOS */
