[GRASS-SVN] r66059 - in grass/trunk/lib/python/pygrass/raster: . testsuite testsuite/data
Sat Aug 29 10:21:36 PDT 2015
Author: huhabla
Date: 2015-08-29 10:21:36 -0700 (Sat, 29 Aug 2015)
New Revision: 66059
Added:
   grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/category.py
   grass/trunk/lib/python/pygrass/raster/history.py
   grass/trunk/lib/python/pygrass/raster/testsuite/data/geology_cats
   grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py
   grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
pygrass raster: Modified several tests and added some new, now all tests are location independent
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -79,7 +79,7 @@
         >>> elev.info.rows
         4
-	Editing the history
+        Editing the history
         >>> elev.hist.read()
         >>> elev.hist.title = "A test map"
@@ -98,22 +98,22 @@
          ('P', 44, None)]
-	>>> elev.cats.labels() # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
-	['A', 'B', 'C', 'D', 'E',
+        >>> elev.cats.labels() # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
+        ['A', 'B', 'C', 'D', 'E',
          'F', 'G', 'H', 'I', 'J',
          'K', 'L', 'M', 'n', 'O', 'P']
-	>>> elev.cats[0]
-	('A', 11, None)
-	>>> elev.cats[2]
-	('C', 13, None)
-	>>> elev.cats[0] = ('AA', 11)
-	>>> elev.cats[1] = ('BB', 12)
-	>>> elev.cats.write()
-	>>> elev.cats.read()
-	>>> elev.cats[0]
-	('AA', 11, None)
-	>>> elev.cats[1]
-	('BB', 12, None)
+        >>> elev.cats[0]
+        ('A', 11, None)
+        >>> elev.cats[2]
+        ('C', 13, None)
+        >>> elev.cats[0] = ('AA', 11)
+        >>> elev.cats[1] = ('BB', 12)
+        >>> elev.cats.write()
+        >>> elev.cats.read()
+        >>> elev.cats[0]
+        ('AA', 11, None)
+        >>> elev.cats[1]
+        ('BB', 12, None)
         Open a raster map using the *with statement*:
@@ -266,14 +266,14 @@
         :type row_buffer: Buffer object
             >>> elev = RasterRowIO(test_raster_name)
-	    >>> elev.open('r')
+            >>> elev.open('r')
             >>> for row in elev:
             ...     row
             Buffer([11, 21, 31, 41], dtype=int32)
             Buffer([12, 22, 32, 42], dtype=int32)
             Buffer([13, 23, 33, 43], dtype=int32)
             Buffer([14, 24, 34, 44], dtype=int32)
             >>> elev.close()
@@ -366,14 +366,14 @@
             >>> for row in elev:
             ...     row
             >>> elev.close()
@@ -397,14 +397,14 @@
             :param row: a Row object to insert into raster
             :type row: Buffer object
-	    Input and output must have the same type in case of row copy
+            Input and output must have the same type in case of row copy
             >>> map_a = RasterSegment(test_raster_name)
             >>> map_b = RasterSegment(test_raster_name + "_segment")
-	    >>> map_a.open('r')
-	    >>> map_b.open('w', mtype="CELL", overwrite=True)
+            >>> map_a.open('r')
+            >>> map_b.open('w', mtype="CELL", overwrite=True)
             >>> for row in xrange(map_a.info.rows):
-	    ...     map_b[row] = map_a[row] + 1000
+            ...     map_b[row] = map_a[row] + 1000
             >>> map_a.close()
             >>> map_b.close()
@@ -412,11 +412,11 @@
             >>> map_b.open("r")
             >>> for row in map_b:
             ...         row
-	    Buffer([1011, 1021, 1031, 1041], dtype=int32)
-	    Buffer([1012, 1022, 1032, 1042], dtype=int32)
-	    Buffer([1013, 1023, 1033, 1043], dtype=int32)
-	    Buffer([1014, 1024, 1034, 1044], dtype=int32)
-	    >>> map_b.close()
+            Buffer([1011, 1021, 1031, 1041], dtype=int32)
+            Buffer([1012, 1022, 1032, 1042], dtype=int32)
+            Buffer([1013, 1023, 1033, 1043], dtype=int32)
+            Buffer([1014, 1024, 1034, 1044], dtype=int32)
+            >>> map_b.close()
         self.segment.put_row(row, row_buffer)
@@ -432,10 +432,10 @@
             >>> elev = RasterSegment(test_raster_name)
             >>> for i in xrange(4):
             ...     elev.get(i,i)
-	    11
+            11
             22
             33
             44
@@ -468,8 +468,8 @@
-	    >>> map_b.open('w', mtype="FCELL", overwrite=True)
+            >>> map_b.open('w', mtype="FCELL", overwrite=True)
             ...     for col in xrange(map_a.info.cols):
             ...         value = map_a.get(row,col)
@@ -481,11 +481,11 @@
             >>> map_b.open("r")
             >>> for row in map_b:
             ...         row
-	    Buffer([ 111.,  121.,  131.,  141.], dtype=float32)
-	    Buffer([ 112.,  122.,  132.,  142.], dtype=float32)
-	    Buffer([ 113.,  123.,  133.,  143.], dtype=float32)
-	    Buffer([ 114.,  124.,  134.,  144.], dtype=float32)
-	    >>> map_b.close()
+            Buffer([ 111.,  121.,  131.,  141.], dtype=float32)
+            Buffer([ 112.,  122.,  132.,  142.], dtype=float32)
+            Buffer([ 113.,  123.,  133.,  143.], dtype=float32)
+            Buffer([ 114.,  124.,  134.,  144.], dtype=float32)
+            >>> map_b.close()
         self.segment.val.value = val
Modified: grass/trunk/lib/python/pygrass/raster/category.py
--- grass/trunk/lib/python/pygrass/raster/category.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/category.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -50,18 +50,6 @@
     Rast_copy_cats() <- This should be wrapped so that categories from an
     existing Python category class are copied.
-    >>> import grass.lib.raster as libraster
-    >>> import ctypes
-    >>> from grass.pygrass.raster.category import Category
-    >>> cats = Category('landuse')
-    >>> cats.read()
-    >>> cats.labels()                                     # doctest: +ELLIPSIS
-    ['undefined', 'developed', 'agriculture', ..., 'water', 'sediment']
-    >>> cats[0]
-    ('undefined', 0, None)
-    >>> cats[1]
-    ('developed', 1, None)
     def __init__(self, name, mapset='', mtype='CELL', *args, **kargs):
         self.name = name
Modified: grass/trunk/lib/python/pygrass/raster/history.py
--- grass/trunk/lib/python/pygrass/raster/history.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/history.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -37,6 +37,14 @@
     def __del__(self):
         """Rast_free_history"""
         pass
+    def __eq__(self, hist):
+        attrs = ['name', 'mapset', 'mtype', 'creator', 'src1', 'src2',
+                 'keyword', 'date', 'title']
+        for attr in attrs:
+           if getattr(self, attr) != getattr(hist, attr):
+                return False
+        return True
     def __len__(self):
         return self.length()
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/data/geology_cats
--- grass/trunk/lib/python/pygrass/raster/testsuite/data/geology_cats	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/data/geology_cats	2015-08-29 17:21:36 UTC (rev 66059)
@@ -1,1832 +1,16 @@
-Zml:1
-Zmf:2
-Zml:3
-Zml:4
-Ybgg:5
-Zml:6
-Ybgg:7
-Zmf:8
-Zml:9
-Zml:10
-Qp:11
-Zatm:12
-Qp:13
-Qp:14
-Zata:15
-Zmf:16
-Zata:17
-Qp:18
-Qp:19
-Ccl:20
-Qp:21
-Qp:22
-Zata:23
-Ccl:24
-Qp:25
-Zabg:26
-Qp:27
-Tpy:28
-Zabs:29
-Qp:30
-Ybgg:31
-CZam:32
-Qp:33
-Zabs:34
-Qp:35
-CZbb:36
-Qp:37
-OCg:38
-PzZq:39
-Tt:40
-Tt:41
-CZig:42
-Tt:43
-CZig:44
-CZms:45
-CZig:46
-OCg:47
-CZig:48
-PPmg:49
-CZms:50
-PPg:51
-OCg:52
-CZma1:53
-CZbg:54
-CZam:55
-Qp:56
-CZms:57
-Zata:58
-CZph:59
-CZg:60
-CZmg:61
-PPg:62
-CZve:63
-TRds:64
-CZv:65
-PzZg:66
-TRdc:67
-CZbg:68
-CZfv:69
-TRdp:70
-Sg:71
-CZve:72
-CZfg:73
-CZfg:74
-CZfg:75
-CZfv:76
-CZv:77
-OCg:78
-PzZg:79
-CZam:80
-CZfg:81
-CZmd:82
-Dqd:83
-PzZg:84
-CZam:85
-CZfg:86
-Qp:87
-PzZu:88
-Zg:89
-OCg:90
-Qp:91
-Qp:92
-Zats:93
-Tt:94
-PzZg:95
-Qp:96
-CZbg:97
-CZfg:98
-Qp:99
-TRdc:100
-CZfv:101
-Qp:102
-Qp:103
-Qp:104
-Qp:105
-Qp:106
-PzZu:107
-PzZu:108
-Zg:109
-TRdc:110
-CZfg:111
-CZfg:112
-Qp:113
-Qp:114
-Qp:115
-Zg:116
-Tt:117
-Tt:118
-PzZu:119
-Qp:120
-CZms:121
-PzZu:122
-Qp:123
-CZbg:124
-Qp:125
-Zabs:126
-Qp:127
-Qp:128
-Tt:129
-Zats:130
-Tt:131
-Zatm:132
-Zatm:133
-PzZq:134
-CZg:135
-CZfv:136
-CZiv:137
-Zabs:138
-Zatm:139
-PzZg:140
-Tt:141
-CZg:142
-Tt:143
-Qp:144
-Qp:145
-Zaba:146
-PzZg:147
-PPmg:148
-PzZu:149
-PzZq:150
-Qp:151
-Tt:152
-CZfg:153
-CZmd:154
-Zabs:155
-Qp:156
-Tt:157
-PzZg:158
-PPmg:159
-Tt:160
-CZq:161
-Zatm:162
-Qp:163
-TRdc:164
-Tt:165
-Zabs:166
-PzZu:167
-PzZq:168
-PzZg:169
-CZph:170
-Zg:171
-TRdc:172
-Qp:173
-TRdc:174
-PPg:175
-PzZu:176
-Tt:177
-Yg:178
-Zg:179
-Qp:180
-Dqd:181
-Tt:182
-Zg:183
-CZg:184
-CZms:185
-CZma1:186
-Zatm:187
-Zatm:188
-Tt:189
-TRdp:190
-Zatm:191
-CZfv:192
-Zatm:193
-Ccl:194
-CZbg:195
-PzZq:196
-CZfv:197
-Tpy:198
-Ygg:199
-PzZg:200
-Qp:201
-Ybgg:202
-Tt:203
-Qp:204
-Tt:205
-Zatm:206
-PzZu:207
-Zg:208
-Qp:209
-Qp:210
-PzZu:211
-CZam:212
-Qp:213
-CZq:214
-PPmg:215
-Kc:216
-CZfg:217
-Kc:218
-CZam:219
-Qp:220
-Tt:221
-PzZu:222
-Qp:223
-Qp:224
-PzZg:225
-Qp:226
-Qp:227
-Zg:228
-PzZu:229
-Qp:230
-Zatm:231
-PPg:232
-PzZq:233
-Yg:234
-CZg:235
-Qp:236
-Qp:237
-Qp:238
-PzZg:239
-Zatm:240
-PzZg:241
-PzZg:242
-CZmv:243
-Qp:244
-PzZq:245
-PzZq:246
-CZfg:247
-Qp:248
-Qp:249
-CZfv:250
-CZg:251
-Tt:252
-Qp:253
-Qp:254
-CZmd:255
-Qp:256
-Qp:257
-CZfg:258
-Tpy:259
-Qp:260
-Zg:261
-CZlg:262
-CZfv:263
-Dqd:264
-Qp:265
-Qp:266
-PzZg:267
-Tt:268
-Qp:269
-CZig:270
-Ccl:271
-Kc:272
-Tt:273
-Qp:274
-Qp:275
-Qp:276
-PzZg:277
-Ybgg:278
-Qp:279
-PzZg:280
-Zg:281
-CZma:282
-PzZg:283
-Qp:284
-Qp:285
-Tt:286
-CZbg:287
-Zbg:288
-PzZq:289
-CZg:290
-CZma1:291
-Qp:292
-Tt:293
-Qp:294
-CZma1:295
-Qp:296
-Tt:297
-Qp:298
-CZms:299
-Qp:300
-Qp:301
-Tt:302
-PzZg:303
-CZbf:304
-CZbg:305
-TRc:306
-Zg:307
-PzZg:308
-CZma2:309
-Qp:310
-Yg:311
-CZam:312
-CZms:313
-Tt:314
-Zg:315
-CZms:316
-Qp:317
-CZve:318
-Qp:319
-PPg:320
-Yg:321
-PPg:322
-Qp:323
-PzZg:324
-Qp:325
-PPg:326
-Qp:327
-CZms:328
-Tt:329
-PzZg:330
-Tt:331
-Tt:332
-Tt:333
-OCg:334
-CZbg:335
-Jd:336
-Tt:337
-CZph:338
-CZmg:339
-TRc:340
-PzZq:341
-CZfv:342
-CZmv:343
-Tt:344
-CZiv:345
-Zgma:346
-Zgms:347
-Zgmf:348
-Zgmg:349
-CZiv:350
-CZfv:351
-CZfv:352
-Zgmw:353
-Tt:354
-PzZq:355
-Zgms:356
-PzZu:357
-CZiv:358
-Tt:359
-PzZu:360
-PPg:361
-PzZg:362
-Ybrg:363
-PzZg:364
-CZiv:365
-Zgmu:366
-Zgmg:367
-CZms:368
-CZmg:369
-CZam:370
-Jd:371
-Ygg:372
-Zgma:373
-CZms:374
-CZfv:375
-CZfv:376
-PzZu:377
-Ymg:378
-CZve:379
-CZq:380
-Tt:381
-PzZg:382
-PzZu:383
-CZq:384
-Jd:385
-Zgmu:386
-CZam:387
-Zgmf:388
-Zgmg:389
-PPg:390
-Zlm:391
-CZmv:392
-CZms:393
-CZmg:394
-OCgm:395
-Ccl:396
-PPmg:397
-Ybgg:398
-CZq:399
-CZiv:400
-Tt:401
-Zgmg:402
-CZms:403
-Ybgg:404
-CZbg:405
-Zlm:406
-Jd:407
-PzZg:408
-Zlm:409
-CZms:410
-PzZu:411
-Ybrg:412
-CZms:413
-Ccl:414
-CZq:415
-Zlm:416
-Zlm:417
-Ccl:418
-CZmd:419
-CZms:420
-Zlm:421
-CZms:422
-PzZg:423
-Zlm:424
-Jd:425
-Tt:426
-CZiv:427
-CZms:428
-PzZg:429
-Ccu:430
-Zlm:431
-CZam:432
-Tt:433
-CZmv:434
-PzZg:435
-Zgmu:436
-PzZu:437
-Zlm:438
-Zs:439
-Zlm:440
-Zlm:441
-Zlm:442
-CZg:443
-Zgmg:444
-Tt:445
-Zlm:446
-Zgmu:447
-CZiv:448
-PzZg:449
-PzZm:450
-Ccl:451
-Ygg:452
-Tt:453
-Tt:454
-CZfv:455
-Tt:456
-CZiv:457
-Zata:458
-Zgmg:459
-CZbg:460
-CZmd:461
-CZms:462
-CZg:463
-CZam:464
-TRd:465
-Zatm:466
-CZiv:467
-CZmv:468
-Tt:469
-Zlm:470
-PzZu:471
-Zwc:472
-Ybgg:473
-Zlm:474
-PzZu:475
-PzZu:476
-PzZg:477
-Qp:478
-Jd:479
-CZph:480
-Zlm:481
-Tt:482
-Qp:483
-Qp:484
-PzZu:485
-Ygg:486
-Qp:487
-CZph:488
-PzZm:489
-Zg:490
-Zgmg:491
-CZfv:492
-Qp:493
-CZiv:494
-Tt:495
-CZmv:496
-CZiv:497
-CZms:498
-Qp:499
-Jd:500
-Qp:501
-Jd:502
-CZiv:503
-CZph:504
-Zss:505
-PzZg:506
-Zg:507
-Jd:508
-PzZg:509
-CZmv:510
-CZfv:511
-Jd:512
-Zata:513
-Zata:514
-CZg:515
-CZg:516
-OCg:517
-CZph:518
-PzZg:519
-Dqd:520
-Ccl:521
-Zata:522
-DOgb:523
-Tt:524
-CZph:525
-PzZu:526
-CZiv:527
-Zlm:528
-Ccu:529
-Zata:530
-Zata:531
-Chg:532
-Chg:533
-Zlm:534
-CZmd:535
-Zgmu:536
-Qp:537
-CZba:538
-CZpg:539
-OCg:540
-PzZg:541
-PzZm:542
-Zsp:543
-Tt:544
-Dqd:545
-CZms:546
-Dqd:547
-CZab:548
-CZms:549
-CZms:550
-CZg:551
-CZq:552
-OCg:553
-Qp:554
-PzZu:555
-Zss:556
-CZfv:557
-CZab:558
-Zlm:559
-Zata:560
-Zs:561
-Zsr:562
-CZg:563
-CZms:564
-Tt:565
-PPg:566
-CZfv:567
-PzZg:568
-Zaba:569
-CZiv:570
-PzZu:571
-CZbg:572
-CZiv:573
-PzZu:574
-CZg:575
-Zata:576
-PzZg:577
-Dqd:578
-CZve:579
-CZve:580
-Ccl:581
-Dqd:582
-CZve:583
-CZbg:584
-Dqd:585
-Zata:586
-Dqd:587
-Dqd:588
-Zss:589
-CZg:590
-Tt:591
-Zgmf:592
-Tt:593
-Qp:594
-Zsl:595
-Dqd:596
-PzZg:597
-PzZu:598
-PzZg:599
-CZab:600
-Dqd:601
-CZiv:602
-CZg:603
-Zm:604
-Qp:605
-CZg:606
-Zg:607
-DOgb:608
-Zaba:609
-Zgmu:610
-Cr:611
-Jd:612
-Zaba:613
-Cs:614
-PPmg:615
-Zg:616
-CZms:617
-CZg:618
-Kc:619
-CZfv:620
-Cs:621
-Tpy:622
-PzZu:623
-CZiv:624
-CZmd:625
-CZms:626
-PzZu:627
-CZg:628
-OCg:629
-Chg:630
-Ccu:631
-Zgmg:632
-PzZu:633
-CZms:634
-CZg:635
-bz:636
-CZg:637
-PzZu:638
-Tt:639
-PzZu:640
-CZg:641
-CZg:642
-CZms:643
-Dqd:644
-Ybrg:645
-Ccl:646
-Qp:647
-Dqd:648
-PzZu:649
-CZms:650
-CZfv1:651
-PzZu:652
-CZg:653
-Tt:654
-PPmg:655
-Zss:656
-Tt:657
-PzZg:658
-Qp:659
-Tt:660
-Zs:661
-Qp:662
-Qp:663
-Zm:664
-PzZu:665
-Qp:666
-Tt:667
-Qp:668
-Zatw:669
-OCg:670
-Tt:671
-CZg:672
-Zsw:673
-Dqd:674
-CZq:675
-Ccl:676
-CZmv:677
-PzZu:678
-Zabg:679
-CZbg:680
-Qp:681
-Zm:682
-CZab:683
-OCg:684
-Dqd:685
-PzZu:686
-Chg:687
-CZv:688
-Zabg:689
-Tt:690
-PzZu:691
-Zgmf:692
-CZv:693
-Chg:694
-PzZu:695
-CZbg:696
-Ybam:697
-Zabg:698
-CZfv:699
-Ccl:700
-Dqd:701
-Dqd:702
-CZiv:703
-PzZu:704
-Tt:705
-Ymg:706
-Ybam:707
-CZfv:708
-OCg:709
-Tt:710
-OCg:711
-PzZu:712
-Ybam:713
-OCg:714
-CZv:715
-CZfv:716
-Chg:717
-Chg:718
-Tt:719
-CZam:720
-Qp:721
-Ymam:722
-CZg:723
-Qp:724
-CZmv:725
-Ccu:726
-Tt:727
-Tt:728
-Qp:729
-CZfv:730
-Qp:731
-Ybam:732
-CZms:733
-CZmd:734
-Qp:735
-Tt:736
-Qp:737
-Tt:738
-Qp:739
-PzZq:740
-PzZu:741
-CZiv:742
-Qp:743
-CZiv:744
-CZg:745
-Qp:746
-PzZu:747
-Zsw:748
-PzZq:749
-Tt:750
-Zsr:751
-Zsl:752
-Zsp:753
-Qp:754
-Chg:755
-Qp:756
-Qp:757
-Ccu:758
-Qp:759
-Qp:760
-PPg:761
-OCg:762
-Tt:763
-Zsw:764
-CZg:765
-CZg:766
-Ymam:767
-Qp:768
-Chg:769
-CZmd2:770
-PzZq:771
-CZmd:772
-CZg:773
-Ybam:774
-CZms:775
-Zm:776
-Zrb:777
-CZmd:778
-CZmd:779
-PzZu:780
-Zch:781
-CZbg:782
-Qp:783
-CZph:784
-Cs:785
-PzZu:786
-CZmd:787
-CZms:788
-CZmd:789
-CZiv:790
-OCg:791
-Ymam:792
-OCg:793
-CZba:794
-Ccu:795
-DSg:796
-CZph:797
-Ymam:798
-CZmd1:799
-Ybgg:800
-CZfv:801
-Tt:802
-CZiv:803
-OCg:804
-CZg:805
-CZfv:806
-PzZg:807
-CZbg:808
-CZiv:809
-Ymam:810
-CZms:811
-CZiv:812
-CZmd:813
-CZfv:814
-Ybgg:815
-PzZm:816
-PPg:817
-CZmv1:818
-CZbg:819
-CZc:820
-CZmd:821
-Chg:822
-DSg:823
-Tt:824
-CZbf:825
-CZg:826
-CZiv:827
-CZg:828
-Tt:829
-CZfv:830
-Tt:831
-CZmv:832
-CZve:833
-ZYbn:834
-CZfv:835
-CZve:836
-Zchs:837
-PzZg:838
-Zbt:839
-CZfv2:840
-Tt:841
-PPg:842
-OCg:843
-CZbf:844
-PPg:845
-PPg:846
-CZab:847
-Ymam:848
-CZfv:849
-OCg:850
-CZab:851
-Zgs:852
-Tt:853
-CZmv:854
-CZms:855
-CZba:856
-CZfv:857
-PzZg:858
-CZfv:859
-CZmd:860
-PPmg:861
-CZam:862
-Tt:863
-PzZu:864
-Zbt:865
-CZc:866
-Ymam:867
-CZba:868
-Tt:869
-CZve:870
-CZmd:871
-PzZu:872
-Zsw:873
-CZbg:874
-PPg:875
-Za:876
-CZms:877
-Ymam:878
-Tt:879
-OCg:880
-CZiv:881
-CZbg:882
-PzZu:883
-CZpg:884
-CZbg:885
-Qp:886
-PPg:887
-CZve:888
-CZmd:889
-Kb:890
-PzZu:891
-CZbg:892
-Tt:893
-Zsr:894
-OCg:895
-OCg:896
-CZmd3:897
-OCg:898
-PPmg:899
-Tt:900
-Tt:901
-Qp:902
-Zsr:903
-Ybgg:904
-DOgb:905
-PPmg:906
-OCg:907
-Qp:908
-Tt:909
-CZbg:910
-PPg:911
-PzZu:912
-Zsw:913
-Tt:914
-PzZu:915
-CZmd:916
-Zsl:917
-Qp:918
-DSg:919
-CZab:920
-Km:921
-Qp:922
-Tt:923
-PzZg:924
-CZmd:925
-CZmv:926
-CZmv:927
-Zsl:928
-Zchs:929
-CZiv:930
-Tt:931
-CZfv:932
-Ymam:933
-PzZu:934
-PzZu:935
-CZms:936
-CZq:937
-PzZu:938
-CZbg:939
-PzZg:940
-Tt:941
-CZfv:942
-CZq:943
-CZbg:944
-CZbg:945
-CZam:946
-Tt:947
-CZam:948
-CZve:949
-Zchs:950
-CZiv:951
-PPmg:952
-PPmg:953
-OCg:954
-CZfv:955
-Tt:956
-Tec:957
-CZg:958
-CZfg:959
-Tt:960
-DSg:961
-Zs:962
-Tt:963
-CZbl:964
-CZg:965
-TRc:966
-DSg:967
-PzZm:968
-CZph:969
-TRcp:970
-PPmg:971
-CZbg:972
-CZve:973
-CZmv:974
-Zchs:975
-PzZu:976
-TRcp:977
-Tt:978
-Tt:979
-OCg:980
-Km:981
-Za:982
-Zgs:983
-Km:984
-PzZu:985
-PzZu:986
-CZg:987
-Zsl:988
-Tt:989
-CZbg:990
-CZfv:991
-CZmv:992
-CZve:993
-Kp:994
-Tt:995
-Zchs:996
-CZph:997
-Tpy:998
-CZve:999
-CZfv:1000
-PzZu:1001
-Tt:1002
-CZbg:1003
-CZve:1004
-PzZg:1005
-CZve:1006
-PzZu:1007
-TRcc:1008
-TRcs:1009
-PzZu:1010
-Zbt:1011
-CZfv:1012
-Tt:1013
-DOg:1014
-DSg:1015
-CZbg:1016
-Chg:1017
-Tt:1018
-PzZu:1019
-PzZg:1020
-Zs:1021
-CZmd:1022
-CZq:1023
-CZmd:1024
-PzZu:1025
-PzZg:1026
-Zgs:1027
-Kc:1028
-CZve:1029
-Zs:1030
-Tt:1031
-OCg:1032
-CZve:1033
-Qp:1034
-CZbg:1035
-TRcc:1036
-CZms:1037
-CZpg:1038
-PPg:1039
-CZfv:1040
-TRcp:1041
-PzZu:1042
-Tpy:1043
-CZg:1044
-CZmd:1045
-CZam:1046
-SOgg:1047
-PzZm:1048
-CZms:1049
-CZph:1050
-CZbg:1051
-CZms:1052
-ZYbn:1053
-OCg:1054
-Chg:1055
-Zatm:1056
-Tt:1057
-PzZu:1058
-TRcs:1059
-CZbg:1060
-CZam:1061
-CZmd:1062
-Tt:1063
-OCg:1064
-CZve:1065
-CZph:1066
-CZmd:1067
-PPmg:1068
-CZab:1069
-CZg:1070
-TRcc:1071
-CZbg:1072
-CZfv:1073
-CZbg:1074
-PzZg:1075
-Zwe:1076
-CZbg:1077
-CZve:1078
-TRcs:1079
-Ybgg:1080
-DOg:1081
-CZv:1082
-Zbg:1083
-CZmv1:1084
-CZfv:1085
-Chg:1086
-CZbg:1087
-PPmg:1088
-ZYbn:1089
-CZms:1090
-Tt:1091
-CZbg:1092
-Kb:1093
-Tt:1094
-CZph:1095
-CZfg:1096
-CZbg:1097
-DSg:1098
-CZmd3:1099
-PzZm:1100
-CZtp:1101
-Ybgg:1102
-CZms:1103
-CZms:1104
-Mc:1105
-Tpy:1106
-DSg:1107
-PzZm:1108
-CZab:1109
-Tt:1110
-CZph:1111
-DOg:1112
-TRcc:1113
-Jd:1114
-PzZm:1115
-Kp:1116
-Kp:1117
-Kp:1118
-CZbg:1119
-Qp:1120
-DSg:1121
-CZbg:1122
-Zwe:1123
-OCg:1124
-CZmd:1125
-Tt:1126
-CZab:1127
-CZph:1128
-CZmd:1129
-CZmd:1130
-CZmd:1131
-CZv:1132
-Jd:1133
-CZy:1134
-Km:1135
-TRcc:1136
-DOgb:1137
-CZbg:1138
-Zhha:1139
-CZmv:1140
-PzZu:1141
-CZbg:1142
-CZph:1143
-CZms:1144
-Zchs:1145
-Kc:1146
-CZbg:1147
-CZbg:1148
-Chg:1149
-PzZu:1150
-Zd:1151
-CZiv:1152
-PzZu:1153
-Kc:1154
-Znt:1155
-Tt:1156
-DOgb:1157
-CZgms:1158
-CZfv:1159
-Ybgg:1160
-CZab:1161
-CZfv:1162
-CZfv:1163
-CZfv:1164
-Dsc:1165
-TRcc:1166
-Tt:1167
-CZfv:1168
-CZmd:1169
-Dqd:1170
-Tt:1171
-CZmd2:1172
-CZph:1173
-Znt:1174
-TRcp:1175
-TRcc:1176
-CZph:1177
-Qp:1178
-CZms:1179
-CZq:1180
-TRcc:1181
-Jd:1182
-CZfv:1183
-CZms:1184
-Zb:1185
-CZfv:1186
-Jd:1187
-PzZu:1188
-Tpy:1189
-OCg:1190
-CZiv:1191
-OCg:1192
-DOg:1193
-Qp:1194
-DSg:1195
-CZq:1196
-Tt:1197
-PzZu:1198
-TRcs:1199
-CZv:1200
-DOgb:1201
-CZph:1202
-DOgb:1203
-DOgb:1204
-PzZu:1205
-DSs:1206
-Zatb:1207
-Km:1208
-CZfv:1209
-Zd:1210
-Tec:1211
-PPmg:1212
-CZph:1213
-CZbg:1214
-DOgb:1215
-CZfv:1216
-CZbg:1217
-CZam:1218
-CZtp:1219
-CZbg:1220
-CZms:1221
-CZg:1222
-CZph:1223
-Kc:1224
-Zman:1225
-Zchs:1226
-CZv:1227
-Qp:1228
-CZms:1229
-CZpg:1230
-Qp:1231
-CZmv:1232
-Zchs:1233
-CZfv:1234
-CZab:1235
-CZph:1236
-CZmd:1237
-CZtp:1238
-CZbg:1239
-Zmb:1240
-CZfv:1241
-Tpa:1242
-Qp:1243
-PzZm:1244
-Dqd:1245
-Zbg:1246
-CZab:1247
-Dqd:1248
-Qp:1249
-Qp:1250
-PzZu:1251
-Dqd:1252
-CZfv:1253
-TRcc:1254
-CZph:1255
-Qp:1256
-CZph:1257
-PPg:1258
-Qp:1259
-CZbg:1260
-TRcs:1261
-CZve:1262
-Zch:1263
-Zchs:1264
-Zf:1265
-Kb:1266
-PzZm:1267
-TRcs:1268
-Tt:1269
-Tpy:1270
-Km:1271
-CZms:1272
-TRcc:1273
-CZv:1274
-OCg:1275
-Mc:1276
-Dqd:1277
-Mc:1278
-Qp:1279
-Dqd:1280
-PzZm:1281
-SOgg:1282
-CZgms:1283
-DSs:1284
-PzZq:1285
-Tpa:1286
-Kc:1287
-Tpy:1288
-SOgg:1289
-Zwe:1290
-CZq:1291
-DSg:1292
-CZms:1293
-Zch:1294
-CZv:1295
-OCg:1296
-CZms:1297
-DOgb:1298
-OCg:1299
-Qp:1300
-Dqd:1301
-CZms:1302
-TRcs:1303
-Qp:1304
-CZq:1305
-DOgb:1306
-Tecs:1307
-CZbg:1308
-Tp:1309
-CZms:1310
-Tec:1311
-CZbg:1312
-Dsc:1313
-DOg:1314
-CZgms:1315
-CZms:1316
-Tp:1317
-CZbg:1318
-CZve:1319
-CZbg:1320
-DOg:1321
-TRcs:1322
-Tt:1323
-CZpg:1324
-Tpa:1325
-Zata:1326
-CZpg:1327
-OCg:1328
-Dqd:1329
-CZpg:1330
-CZms:1331
-CZmd:1332
-CZms:1333
-Tt:1334
-Dqd:1335
-PzZq:1336
-Dqd:1337
-CZiv:1338
-PzZm:1339
-Tec:1340
-TRc:1341
-Dsc:1342
-CZgms:1343
-Zch:1344
-CZph:1345
-ZYba:1346
-Dqd:1347
-ZYba:1348
-CZph:1349
-PzZu:1350
-Tp:1351
-PzZu:1352
-Dqd:1353
-ZYba:1354
-OCg:1355
-ZYba:1356
-TRc:1357
-PzZu:1358
-ZYba:1359
-OCg:1360
-ZYba:1361
-PzZu:1362
-Tec:1363
-Km:1364
-OCg:1365
-Tpa:1366
-ZYba:1367
-CZms:1368
-Dqd:1369
-Tec:1370
-CZph:1371
-Dqd:1372
-ZYba:1373
-CZiv:1374
-CZg:1375
-ZYba:1376
-Tpy:1377
-CZms:1378
-PzZu:1379
-ZYba:1380
-Km:1381
-CZgms:1382
-ZYba:1383
-CZms:1384
-Dqd:1385
-ZYba:1386
-CZms:1387
-CZtp:1388
-CZmd:1389
-TRcs:1390
-Km:1391
-Zata:1392
-Qp:1393
-DOg:1394
-Dsc:1395
-Qp:1396
-CZbg:1397
-Ytg:1398
-Dsc:1399
-CZtp:1400
-Zb:1401
-ZYba:1402
-ZYba:1403
-Km:1404
-Tpy:1405
-Zata:1406
-CZph:1407
-ZYba:1408
-PzZu:1409
-CZbg:1410
-PzZm:1411
-ZYba:1412
-CZbg:1413
-Org:1414
-DSg:1415
-ZYba:1416
-CZg:1417
-Tec:1418
-PzZu:1419
-ZYba:1420
-Tecs:1421
-ZYba:1422
-ZYba:1423
-CZgms:1424
-ZYba:1425
-ZYbA:1426
-Tor:1427
-Zata:1428
-CZam:1429
-Zman:1430
-Tpy:1431
-PzZu:1432
-TRc:1433
-Zch:1434
-PzZu:1435
-CZmd:1436
-Zco:1437
-Zata:1438
-ZYba:1439
-DOg:1440
-Tp:1441
-PzZu:1442
-Tpy:1443
-PzZm:1444
-DOgb:1445
-PzZu:1446
-PzZu:1447
-DSc:1448
-SOgg:1449
-ZYba:1450
-Zata:1451
-Km:1452
-Tec:1453
-Zco:1454
-ZYba:1455
-CZam:1456
-ZYba:1457
-Tpy:1458
-Km:1459
-Tpy:1460
-ZYba:1461
-CZiv:1462
-PzZu:1463
-Zatb:1464
-Tp:1465
-Tp:1466
-Zgs:1467
-PzZq:1468
-PzZq:1469
-Tor:1470
-Km:1471
-CZam:1472
-Tp:1473
-Qp:1474
-Zata:1475
-Qp:1476
-Zman:1477
-Qp:1478
-ZYba:1479
-Dqd:1480
-Tec:1481
-Kc:1482
-DOgb:1483
-Zata:1484
-Zman:1485
-CZmd3:1486
-Zata:1487
-Zch:1488
-TRc:1489
-Tp:1490
-CZfv:1491
-CZfv2:1492
-Zata:1493
-Zata:1494
-Zatb:1495
-ZYba:1496
-CZg:1497
-Qp:1498
-Qp:1499
-Tp:1500
-TRc:1501
-DOgb:1502
-DOg:1503
-Zch:1504
-Tp:1505
-Qp:1506
-ZYba:1507
-Qp:1508
-Zhha:1509
-PzZu:1510
-Zatb:1511
-Zata:1512
-Tpy:1513
-Tp:1514
-Tec:1515
-DSs:1516
-Tp:1517
-CZg:1518
-PzZu:1519
-Tpy:1520
-ZYba:1521
-CZmd:1522
-DOgb:1523
-DSg:1524
-Tpy:1525
-PPg:1526
-Kb:1527
-CZfv2:1528
-Qp:1529
-Tp:1530
-Tec:1531
-TRc:1532
-Qp:1533
-Km:1534
-CZph:1535
-TRc:1536
-Tp:1537
-Kb:1538
-Tec:1539
-Km:1540
-CZmd:1541
-CZmd:1542
-Qp:1543
-TRc:1544
-Qp:1545
-Km:1546
-Qp:1547
-Qp:1548
-Tp:1549
-Qp:1550
-Tob:1551
-Qp:1552
-Qp:1553
-Qp:1554
-Qp:1555
-Qp:1556
-Tpy:1557
-Qp:1558
-CZph:1559
-CZg:1560
-Tt:1561
-Qp:1562
-Km:1563
-PPg:1564
-Qp:1565
-Qp:1566
-Tt:1567
-CZph:1568
-Tp:1569
-Qp:1570
-Km:1571
-Qp:1572
-CZph:1573
-Qp:1574
-Qp:1575
-Qp:1576
-Qp:1577
-Tt:1578
-CZph:1579
-Km:1580
-Kb:1581
-Tpy:1582
-Tt:1583
-PPgb:1584
-CZph:1585
-Tpy:1586
-Qp:1587
-Tec:1588
-CZfv:1589
-Km:1590
-Qp:1591
-Qp:1592
-CZph:1593
-Km:1594
-CZmd:1595
-CZbg:1596
-CZg:1597
-Km:1598
-CZmd:1599
-Km:1600
-Km:1601
-Km:1602
-Km:1603
-Tp:1604
-CZmd:1605
-Km:1606
-Qp:1607
-Km:1608
-CZmd:1609
-Tt:1610
-CZph:1611
-Km:1612
-PzZm:1613
-CZph:1614
-CZph:1615
-CZph:1616
-CZmd:1617
-CZph:1618
-Tec:1619
-CZmd:1620
-Km:1621
-CZmd:1622
-CZph:1623
-CZph:1624
-CZph:1625
-Tpy:1626
-Tt:1627
-CZmd:1628
-Qp:1629
-CZph:1630
-Km:1631
-Qp:1632
-Qp:1633
-CZmd:1634
-Km:1635
-Km:1636
-Tec:1637
-Qp:1638
-Qp:1639
-Qp:1640
-Qp:1641
-Qp:1642
-Qp:1643
-Tpy:1644
-Tpy:1645
-Qp:1646
-Qp:1647
-Qp:1648
-Qp:1649
-Tpy:1650
-Qp:1651
-Qp:1652
-Qp:1653
-Tpy:1654
-Qp:1655
-Qp:1656
-Qp:1657
-Qp:1658
-Qp:1659
-Qp:1660
-Qp:1661
-Qp:1662
-Qp:1663
-Qp:1664
-Qp:1665
-Qp:1666
-Qp:1667
-Qp:1668
-Tob:1669
-Qp:1670
-Qp:1671
-Qp:1672
-Qp:1673
-Qp:1674
-Qp:1675
-Qp:1676
-Qp:1677
-Qp:1678
-Qp:1679
-Qp:1680
-Qp:1681
-Qp:1682
-Qp:1683
-Qp:1684
-Qp:1685
-Tpy:1686
-Qp:1687
-Qp:1688
-Qp:1689
-Qp:1690
-Tpy:1691
-Tpy:1692
-Qp:1693
-Qp:1694
-Qp:1695
-Qp:1696
-Tpy:1697
-Qp:1698
-Qp:1699
-Qp:1700
-Qp:1701
-Qp:1702
-Qp:1703
-Qp:1704
-Qp:1705
-Qp:1706
-Qp:1707
-Qp:1708
-Qp:1709
-Qp:1710
-Qp:1711
-Qp:1712
-Qp:1713
-Tec:1714
-Qp:1715
-Qp:1716
-Qp:1717
-Qp:1718
-Qp:1719
-Qp:1720
-Qp:1721
-Qp:1722
-Qp:1723
-Qp:1724
-Qp:1725
-Qp:1726
-Qp:1727
-Qp:1728
-Qp:1729
-Qp:1730
-Qp:1731
-Qp:1732
-Qp:1733
-Qp:1734
-Tpyw:1735
-Tor:1736
-Qp:1737
-Tor:1738
-Tpyw:1739
-Qp:1740
-Qp:1741
-Qp:1742
-Qp:1743
-Qp:1744
-Qp:1745
-Qp:1746
-Qp:1747
-Qp:1748
-Qp:1749
-Qp:1750
-Tpa:1751
-Qp:1752
-Qp:1753
-Qp:1754
-Qp:1755
-Qp:1756
-Qp:1757
-Qp:1758
-Qp:1759
-Qp:1760
-Tpyw:1761
-Qp:1762
-Qp:1763
-Qp:1764
-Qp:1765
-Qp:1766
-Qp:1767
-Tpyw:1768
-Qp:1769
-Qp:1770
-Qp:1771
-Qp:1772
-Tpy:1773
-Tpyw:1774
-Tpyw:1775
-Qp:1776
-Kb:1777
-Qp:1778
-Qp:1779
-Kp:1780
-Tpyw:1781
-Qp:1782
-Tpyw:1783
-Kp:1784
-Qp:1785
-Tpy:1786
-Qp:1787
-Tpyw:1788
-Qp:1789
-Qp:1790
-Qp:1791
-Qp:1792
-Qp:1793
-Qp:1794
-Qp:1795
-Qp:1796
-Qp:1797
-Tpyw:1798
-Qp:1799
-Qp:1800
-Qp:1801
-Tec:1802
-Qp:1803
-Tec:1804
-Tec:1805
-Tec:1806
-Qp:1807
-Tec:1808
-Tec:1809
-Qp:1810
-Qp:1811
-Qp:1812
-Qp:1813
-Qp:1814
-Tpyw:1815
-Qp:1816
-Tpyw:1817
-Qp:1818
-Qp:1819
-Qp:1820
-Qp:1821
-Qp:1822
-Qp:1823
-Qp:1824
-Qp:1825
-Qp:1826
-Tpyw:1827
-Tpyw:1828
-Tpyw:1829
-Tpyw:1830
-Tpyw:1831
-Tpyw:1832
\ No newline at end of file
+A:11
+B:12
+C:13
+D:14
+E:21
+F:22
+G:23
+H:24
+I:31
+J:32
+K:33
+L:34
+M:41
+n:42
+O:43
+P:44
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_category.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -13,26 +13,66 @@
 from grass.script.core import tempfile
-class RasterCategoryTestCate(TestCase):
+class RasterCategoryTestCase(TestCase):
-    name = 'geology'
-    catsname = ''
+    name = "RasterCategoryTestCase_map"
+    @classmethod
+    def setUpClass(cls):
+        """Create test raster map and region"""
+        cls.use_temp_region()
+        cls.runModule("g.region", n=40, s=0, e=40, w=0, res=10)
+        cls.runModule("r.mapcalc", expression="%s = row() + (10.0 * col())"%(cls.name),
+                                   overwrite=True)
+        cls.runModule("r.support", map=cls.name,
+                        title="A test map",
+                        history="Generated by r.mapcalc",
+                        description="This is a test map")
+        cats="""11:A
+                12:B
+                13:C
+                14:D
+                21:E
+                22:F
+                23:G
+                24:H
+                31:I
+                32:J
+                33:K
+                34:L
+                41:M
+                42:n
+                43:O
+                44:P"""
+        cls.runModule("r.category", rules="-", map=cls.name,
+                                 stdin_=cats, separator=":")
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the generated vector map, if exist"""
+        cls.runModule("g.remove", flags='f', type='raster',
+                      name=cls.name)
+        cls.del_temp_region()
     def testCategory(self):
         r = RasterRow(self.name)
         r.open()
         cats = r.cats
         cats1 = Category(self.name)
         cats1.read()
-        # this is not working, I don't know why
         self.assertEqual(cats, cats1)
         r.close()
     def testFirstCat(self):
-        cat0 = ('Zml', 1, None)
+        cat0 = ('A', 11, None)
+        cat7 = ('H', 24, None)
+        cat15 = ('P', 44, None)
         cats = Category(self.name)
         cats.read()
         self.assertEqual(cats[0], cat0)
+        self.assertEqual(cats[7], cat7)
+        self.assertEqual(cats[15], cat15)
     def testWrite(self):
         tmpfile = tempfile(False)
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_doctests.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -31,10 +31,42 @@
     # for now it is the only place where it works
     grass.gunittest.utils.do_doctest_gettext_workaround()
     # this should be called at some top level
+    from grass.pygrass.modules import Module
+    Module("g.region", n=40, s=0, e=40, w=0, res=10)
+    Module("r.mapcalc", expression="%s = row() + (10 * col())"%\
+                                   (pgrass.test_raster_name),
+                             overwrite=True)
+    Module("r.support", map=pgrass.test_raster_name,
+    cats="""11:A
+            12:B
+            13:C
+            14:D
+            21:E
+            22:F
+            23:G
+            24:H
+            31:I
+            32:J
+            33:K
+            34:L
+            41:M
+            42:n
+            43:O
+            44:P"""
+    Module("r.category", rules="-", map=pgrass.test_raster_name,
+                                   (pgrass.abstract.test_raster_name),
+                             overwrite=True)
     tests.addTests(doctest.DocTestSuite(pgrass))
     tests.addTests(doctest.DocTestSuite(pgrass.abstract))
-    tests.addTests(doctest.DocTestSuite(pgrass.category))
-    tests.addTests(doctest.DocTestSuite(pgrass.history))
     return tests
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_history.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -14,21 +14,63 @@
 class RasterHistoryTestCate(TestCase):
-    name = 'geology'
+    @classmethod
+        cls.runModule("r.mapcalc", expression="%s = row() + (10 * col())"%(cls.name),
+                                   overwrite=True)
+    @classmethod
+                      name=cls.name)
     def testHistory(self):
-        r.open()
+        r.open("r")
         hist = r.hist
+        self.assertEqual(hist.title, "A test map")
+        self.assertEqual(hist.keyword,  "This is a test map")
         hist1 = History(self.name)
         hist1.read()
-        #self.assertEqual(hist, hist1)
+        self.assertEqual(hist1.title, "A test map")
+        self.assertEqual(hist1.keyword,  "This is a test map")
+        self.assertEqual(hist, hist1)
         self.assertEqual(hist.creator, hist1.creator)
-        hist1.creator = 'markus'
+        hist1.creator = "Markus"
         self.assertNotEqual(hist.creator, hist1.creator)
         r.close()
+        hist1.title = "No such title"
+        hist1.keyword = "No such description"
+        hist1.src1 = "No such source 1"
+        hist1.src2 = "No such source 2"
+        hist1.write()
+        r.open("r")
+        hist = r.hist
+        self.assertEqual(hist.title, "No such title")
+        self.assertEqual(hist.keyword,  "No such description")
+        self.assertEqual(hist.creator, "Markus")
+        self.assertEqual(hist.src1, "No such source 1")
+        self.assertEqual(hist.src2, "No such source 2")
+        r.close()
 if __name__ == '__main__':
     test()
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_numpy.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -22,34 +22,35 @@
 class NumpyTestCase(TestCase):
+    name = "RasterRowTestCase_map"
     @classmethod
-        """Create a not empty table instance"""
-        cls.name = 'elevation'
-        cls.tmp = 'tmp' + cls.name
-        cls.runModule('g.region', raster=cls.name)
+        cls.runModule("g.region", n=40, s=0, e=60, w=0, res=1)
+        cls.runModule("r.mapcalc", expression="%s = float(row() + (10.0 * col()))"%(cls.name),
+                                   overwrite=True)
         cls.numpy_obj = raster2numpy(cls.name)
     @classmethod
-        from grass.pygrass.modules.shortcuts import general as g
-        g.remove(type='raster', name=cls.tmp, flags='f')
+                      name=cls.name)
     def test_type(self):
         self.assertTrue(str(self.numpy_obj.dtype), 'float32')
     def test_len(self):
-        self.assertTrue(len(self.numpy_obj), 1350)
-        self.assertTrue(len(self.numpy_obj[0]), 1500)
+        self.assertTrue(len(self.numpy_obj), 40)
+        self.assertTrue(len(self.numpy_obj[0]), 60)
     def test_write(self):
-        ran = random([1350, 1500])
-        numpy2raster(ran, 'FCELL', self.tmp, True)
-        self.assertTrue(check_raster(self.tmp))
+        ran = random([40, 60])
+        numpy2raster(ran, 'FCELL', self.name, True)
+        self.assertTrue(check_raster(self.name))
     test()
Modified: grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2015-08-29 16:25:06 UTC (rev 66058)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_raster.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -7,27 +7,29 @@
 from grass.pygrass.raster import RasterRow
-class RasterRowTestCate(TestCase):
+class RasterRowTestCase(TestCase):
     @classmethod
+                                   overwrite=True)
-        g.copy(raster=[cls.name, cls.tmp], overwrite=True)
     @classmethod
+                      name=cls.name)
         r.open(mode='r')
-        self.assertTrue(r.mtype,'FCELL')
+        self.assertTrue(r.mtype,'DCELL')
         r.close()
     def test_isopen(self):
@@ -53,18 +55,18 @@
         self.assertTrue(exist.exist())
     def test_open_r(self):
-        notexist = RasterRow(self.tmp + 'notexist')
+        notexist = RasterRow(self.name + 'notexist')
         with self.assertRaises(OpenError):
             # raster does not exist
             notexist.open(mode='r')
-        r.open(mode='r', mtype='DCELL')
+        r.open(mode='r', mtype='FCELL')
         # ignore the mtype if is open in read mode
-        self.assertEqual(r.mtype, 'FCELL')
+        self.assertEqual(r.mtype, 'DCELL')
         r.close()
     def test_open_w(self):
-        r = RasterRow(self.tmp)
+        r = RasterRow(self.name)
             # raster type is not defined!
             r.open(mode='w')
@@ -74,6 +76,7 @@
         # open in write mode and overwrite
         r.open(mode='w', mtype='DCELL', overwrite=True)
         self.assertTrue(r.mtype, 'DCELL')
+        r.close()
Added: grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py
--- grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/raster/testsuite/test_raster_region.py	2015-08-29 17:21:36 UTC (rev 66059)
@@ -0,0 +1,82 @@
+# -*- coding: utf-8
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from unittest import skip
+from grass.pygrass.raster import RasterRow
+from grass.pygrass.gis.region import Region
+class RasterRowRegionTestCase(TestCase):
+    name = "RasterRowRegionTestCase_map"
+    @classmethod
+                                   overwrite=True)
+    @classmethod
+                      name=cls.name)
+    def test_resampling_1(self):
+        region = Region()
+        region.ewres = 4
+        region.nsres = 4
+        region.north = 30
+        region.south = 10
+        region.east = 30
+        region.west = 10
+        region.adjust(rows=True, cols=True)
+        rast = RasterRow(self.name)
+        rast.set_region(region)
+        rast.open(mode='r')
+        self.assertItemsEqual(rast[0].tolist(), [22,22,22,22,22,32,32,32,32,32])
+        self.assertItemsEqual(rast[5].tolist(), [23,23,23,23,23,33,33,33,33,33])
+        rast.close()
+    def test_resampling_2(self):
+        region = Region()
+        region.ewres = 5
+        region.nsres = 5
+        region.north = 60
+        region.south = -20
+        region.east = 60
+        region.west = -20
+        [nan, nan, nan, nan, nan, nan, nan, nan]
+        [nan, nan, 11.0, 21.0, 31.0, 41.0, nan, nan]
+        [nan, nan, 12.0, 22.0, 32.0, 42.0, nan, nan]
+        [nan, nan, 13.0, 23.0, 33.0, 43.0, nan, nan]
+        [nan, nan, 14.0, 24.0, 34.0, 44.0, nan, nan]
+        self.assertItemsEqual(rast[2].tolist()[2:6], [11.,21.,31.,41.])
+        self.assertItemsEqual(rast[5].tolist()[2:6], [14.,24.,34.,44.])
+        rast.close()
+if __name__ == '__main__':
+    test()
