[GRASS-SVN] r66073 - in grass/trunk/lib/python/pygrass: . vector vector/testsuite
svn_grass at osgeo.org
Mon Aug 31 03:40:37 PDT 2015
Author: huhabla
Date: 2015-08-31 03:40:37 -0700 (Mon, 31 Aug 2015)
New Revision: 66073
grass/trunk/lib/python/pygrass/utils.py
grass/trunk/lib/python/pygrass/vector/abstract.py
grass/trunk/lib/python/pygrass/vector/table.py
grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py
pygrass raster: Fixed several doctests
Modified: grass/trunk/lib/python/pygrass/utils.py
--- grass/trunk/lib/python/pygrass/utils.py 2015-08-30 20:55:38 UTC (rev 66072)
+++ grass/trunk/lib/python/pygrass/utils.py 2015-08-31 10:40:37 UTC (rev 66073)
@@ -104,7 +104,7 @@
def copy(existingmap, newmap, maptype, **kwargs):
"""Copy a map
- >>> copy('census', 'mycensus', 'vector')
+ >>> copy('census_wake2000', 'mycensus', 'vector')
>>> rename('mycensus', 'mynewcensus', 'vector')
>>> remove('mynewcensus', 'vector')
@@ -137,7 +137,7 @@
def get_mapset_vector(mapname, mapset=''):
"""Return the mapset of the vector map
- >>> get_mapset_vector('census')
+ >>> get_mapset_vector('census_wake2000')
'PERMANENT'
@@ -174,8 +174,8 @@
(east, north) = coord
- return (libraster.Rast_northing_to_row(north, region.c_region),
- libraster.Rast_easting_to_col(east, region.c_region))
+ return (libraster.Rast_northing_to_row(north, region.byref()),
+ libraster.Rast_easting_to_col(east, region.byref()))
def pixel2coor(pixel, region):
@@ -190,8 +190,8 @@
(col, row) = pixel
- return (libraster.Rast_row_to_northing(row, region.c_region),
- libraster.Rast_col_to_easting(col, region.c_region))
+ return (libraster.Rast_row_to_northing(row, region.byref()),
+ libraster.Rast_col_to_easting(col, region.byref()))
def get_raster_for_points(poi_vector, raster, column=None, region=None):
@@ -201,23 +201,33 @@
>>> from grass.pygrass.vector import VectorTopo
>>> from grass.pygrass.raster import RasterRow
- >>> ele = RasterRow('elevation')
- >>> copy('schools','myschools','vector')
- >>> sch = VectorTopo('myschools')
- >>> sch.open(mode='r')
- >>> get_raster_for_points(sch, ele) # doctest: +ELLIPSIS
- [(1, 633649.2856743174, 221412.94434781274, 145.06602), ...]
- >>> sch.table.columns.add('elevation','double precision')
- >>> 'elevation' in sch.table.columns
+ >>> from grass.pygrass.gis.region import Region
+ >>> region = Region()
+ >>> region.from_rast('elev_state_500m')
+ >>> region.set_raster_region()
+ >>> ele = RasterRow('elev_state_500m')
+ >>> copy('firestations','myfirestations','vector')
+ >>> fire = VectorTopo('myfirestations')
+ >>> fire.open(mode='r')
+ >>> l = get_raster_for_points(fire, ele, region=region)
+ >>> l[0] # doctest: +ELLIPSIS
+ (1, 620856.9585876337, 230066.3831321055, 111.2153883384)
+ >>> l[1] # doctest: +ELLIPSIS
+ (2, 625331.9185974908, 229990.82160762616, 89.978796115200012)
+ >>> fire.table.columns.add('elev_state_500m','double precision')
+ >>> 'elev_state_500m' in fire.table.columns
True
- >>> get_raster_for_points(sch, ele, column='elevation')
+ >>> get_raster_for_points(fire, ele, column='elev_state_500m', region=region)
True
- >>> sch.table.filters.select('NAMESHORT','elevation')
- Filters(u'SELECT NAMESHORT, elevation FROM myschools;')
- >>> cur = sch.table.execute()
- >>> cur.fetchall() # doctest: +ELLIPSIS
- [(u'SWIFT CREEK', 145.06602), ... (u'9TH GRADE CTR', None)]
- >>> remove('myschools','vect')
+ >>> fire.table.filters.select('LABEL', 'elev_state_500m')
+ Filters(u'SELECT LABEL, elev_state_500m FROM myfirestations;')
+ >>> cur = fire.table.execute()
+ >>> r = cur.fetchall()
+ >>> r[0] # doctest: +ELLIPSIS
+ (u'Morrisville #3', 111.2153883384)
+ >>> r[1] # doctest: +ELLIPSIS
+ (u'Morrisville #1', 89.97879611520001)
+ >>> remove('myfirestations','vect')
:param point: point vector object
@@ -419,7 +429,7 @@
vect.comment = 'This is a comment'
vect.table.conn.commit()
vect.organization = "Thuenen Institut"
vect.person = "Soeren Gebbert"
vect.title = "Test dataset"
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2015-08-30 20:55:38 UTC (rev 66072)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2015-08-31 10:40:37 UTC (rev 66073)
@@ -377,8 +377,7 @@
self.layer = self.dblinks.by_layer(layer).layer
self.table = self.dblinks.by_layer(layer).table()
self.n_lines = self.table.n_rows()
- self.writeable = False
- self.mapset == utils.getenv("MAPSET")
+ self.writeable = self.mapset == utils.getenv("MAPSET")
# Initialize the finder
self.find = {'by_point': PointFinder(self.c_mapinfo, self.table,
self.writeable),
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2015-08-30 20:55:38 UTC (rev 66072)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2015-08-31 10:40:37 UTC (rev 66073)
@@ -168,18 +168,18 @@
>>> import sqlite3
>>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
- >>> cols_sqlite = Columns('census',
+ >>> cols_sqlite = Columns(test_vector_name,
... sqlite3.connect(get_path(path)))
>>> cols_sqlite.tname
- u'census'
+ u'table_doctest_map'
For a postgreSQL table:
>>> import psycopg2 as pg #doctest: +SKIP
- >>> cols_pg = Columns('boundary_municp_pg',
+ >>> cols_pg = Columns(test_vector_name,
... pg.connect('host=localhost dbname=grassdb')) #doctest: +SKIP
>>> cols_pg.tname #doctest: +SKIP
- 'boundary_municp_pg' #doctest: +SKIP
+ 'table_doctest_map' #doctest: +SKIP
def __init__(self, tname, connection, key='cat'):
@@ -212,15 +212,12 @@
"""Return True if two table have the same columns.
>>> import sqlite3
- >>> path = '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
+ >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
>>> connection = sqlite3.connect(get_path(path))
- >>> cols0 = Columns('census', connection)
- >>> cols1 = Columns('census', connection)
- >>> cols2 = Columns('hospitals', connection)
+ >>> cols0 = Columns(test_vector_name, connection)
+ >>> cols1 = Columns(test_vector_name, connection)
>>> cols0 == cols1
True
- >>> cols1 == cols2
- False
return obj.tname == self.tname and obj.odict == self.odict
@@ -234,13 +231,13 @@
"""Return True if is a psycopg connection.
>>> import sqlite3
>>> cols_sqlite.is_pg()
False
>>> cols_pg.is_pg() #doctest: +SKIP
True
@@ -290,16 +287,16 @@
Remove it is used to remove a columns.
>>> import sqlite3
>>> cols_sqlite.sql_descr() # doctest: +ELLIPSIS
- u'cat integer, OBJECTID integer, AREA double precision, ...'
+ u'cat INTEGER, name varchar(50), value double precision'
>>> import psycopg2 as pg # doctest: +SKIP
... pg.connect('host=localhost dbname=grassdb')) # doctest: +SKIP
>>> cols_pg.sql_descr() # doctest: +ELLIPSIS +SKIP
- 'cat int4, objectid int4, area float8, perimeter float8, ...'
if remove:
return ', '.join(['%s %s' % (key, val) for key, val in self.items()
@@ -312,16 +309,16 @@
"""Return a list with the column types.
>>> import sqlite3
>>> cols_sqlite.types() # doctest: +ELLIPSIS
- [u'integer', u'integer', ...]
+ [u'INTEGER', u'varchar(50)', u'double precision']
>>> cols_pg.types() # doctest: +ELLIPSIS +SKIP
- ['int4', 'int4', 'float8', 'float8', 'float8', ...]
return self.odict.values()
@@ -331,16 +328,16 @@
>>> import sqlite3
>>> cols_sqlite.names() # doctest: +ELLIPSIS
- [u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ...]
+ [u'cat', u'name', u'value']
- >>> cols_pg = Columns('boundary_municp_pg', # doctest: +SKIP
+ >>> cols_pg = Columns(test_vector_name, # doctest: +SKIP
>>> cols_pg.names() # doctest: +ELLIPSIS +SKIP
- ['cat', 'objectid', 'area', 'perimeter', ...]
if remove:
@@ -357,16 +354,16 @@
"""Return a list of tuple with column name and column type.
>>> import sqlite3
>>> cols_sqlite.items() # doctest: +ELLIPSIS
- [(u'cat', u'integer'), ...]
+ [(u'cat', u'INTEGER'), (u'name', u'varchar(50)'), (u'value', u'double precision')]
>>> cols_pg.items() # doctest: +ELLIPSIS +SKIP
- [('cat', 'int4'), ('objectid', 'int4'), ('area', 'float8'), ...]
return self.odict.items()
@@ -382,7 +379,7 @@
>>> import sqlite3
>>> from grass.pygrass.utils import copy, remove
- >>> copy('census','mycensus','vect')
+ >>> copy(test_vector_name,'mycensus','vect')
>>> cols_sqlite = Columns('mycensus',
>>> cols_sqlite.add(['n_pizza'], ['INT'])
@@ -436,7 +433,7 @@
>>> import sqlite3
@@ -449,7 +446,7 @@
True
>>> cols_pg.rename('n_pizza', 'n_pizzas') # doctest: +SKIP
>>> 'n_pizza' in cols_pg # doctest: +SKIP
@@ -490,7 +487,7 @@
>>> import sqlite3
>>> cols_sqlite.add(['n_pizzas'], ['INT'])
@@ -499,7 +496,7 @@
DBError: SQLite does not support to cast columns.
>>> cols_pg.cast('n_pizzas', 'float8') # doctest: +SKIP
>>> cols_pg['n_pizzas'] # doctest: +SKIP
@@ -531,18 +528,18 @@
>>> import sqlite3
- >>> cols_sqlite.drop('CHILD') # doctest: +ELLIPSIS
- >>> 'CHILD' in cols_sqlite
+ >>> cols_sqlite.drop('name') # doctest: +ELLIPSIS
+ >>> 'name' in cols_sqlite
False
- >>> cols_pg.drop('CHILD') # doctest: +SKIP
- >>> 'CHILD' in cols_pg # doctest: +SKIP
+ >>> cols_pg.drop('name') # doctest: +SKIP
+ >>> 'name' in cols_pg # doctest: +SKIP
False
>>> remove('mycensus','vect')
@@ -571,18 +568,18 @@
It is possible to define a Link object or given all the information
(layer, name, table name, key, database, driver):
- >>> link = Link(1, 'link0', 'census', 'cat',
- ... '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db', 'sqlite')
+ >>> link = Link(1, 'link0', test_vector_name, 'cat',
+ ... '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db', 'sqlite')
>>> link.layer
1
>>> link.name
'link0'
>>> link.table_name
- 'census'
>>> link.key
'cat'
>>> link.database
- '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
+ '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
>>> link.driver
'sqlite'
>>> link
@@ -693,12 +690,12 @@
def __eq__(self, link):
"""Return True if two Link instance have the same parameters.
- >>> l0 = Link(1, 'link0', 'census', 'cat',
+ >>> l0 = Link(1, 'link0', test_vector_name, 'cat',
+ >>> l1 = Link(1, 'link0', test_vector_name, 'cat',
+ >>> l2 = Link(2, 'link0', test_vector_name, 'cat',
- >>> l1 = Link(1, 'link0', 'census', 'cat',
- >>> l2 = Link(2, 'link0', 'census', 'cat',
>>> l0 == l1
True
>>> l1 == l2
@@ -719,16 +716,18 @@
def connection(self):
"""Return a connection object.
... 'sqlite')
>>> conn = link.connection()
>>> cur = conn.cursor()
- >>> cur.execute("SELECT cat,TOTAL_POP,PERIMETER FROM %s" %
+ >>> link.table_name
+ >>> cur.execute("SELECT cat, name, value from %s" %
... link.table_name) # doctest: +ELLIPSIS
<sqlite3.Cursor object at ...>
- >>> cur.fetchone()
- (1, 44, 757.669)
+ >>> cur.fetchone() #doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
+ (1, u'point', 1.0)
>>> cur.close()
>>> conn.close()
@@ -762,15 +761,15 @@
def table(self):
"""Return a Table object.
... 'sqlite')
>>> table = link.table()
- >>> table.filters.select('cat', 'TOTAL_POP', 'PERIMETER')
- Filters(u'SELECT cat, TOTAL_POP, PERIMETER FROM census;')
+ >>> table.filters.select('cat', 'name', 'value')
+ Filters(u'SELECT cat, name, value FROM table_doctest_map;')
>>> cur = table.execute()
>>> cur.fetchone()
- (1, 44, 757.669)
>>> cur.close()
@@ -779,15 +778,15 @@
def info(self):
"""Print information of the link.
... 'sqlite')
>>> link.info()
layer: 1
- table: census
+ table: table_doctest_map
key: cat
- database: $GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db
+ database: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
driver: sqlite
@@ -803,15 +802,15 @@
"""Interface containing link to the table DB.
- >>> cens = VectorTopo('census')
+ >>> cens = VectorTopo(test_vector_name)
>>> cens.open(mode='r')
>>> dblinks = DBlinks(cens.c_mapinfo)
>>> dblinks
- DBlinks([Link(1, census, sqlite)])
+ DBlinks([Link(1, table_doctest_map, sqlite)])
>>> dblinks[0]
- Link(1, census, sqlite)
- >>> dblinks['census']
+ Link(1, table_doctest_map, sqlite)
+ >>> dblinks[test_vector_name]
>>> cens.close()
@@ -882,16 +881,16 @@
:type link: a Link object
- >>> municip = VectorTopo('census')
- >>> municip.open(mode='r')
- >>> dblinks = DBlinks(municip.c_mapinfo)
+ >>> test_vect = VectorTopo(test_vector_name)
+ >>> test_vect.open(mode='r')
+ >>> dblinks = DBlinks(test_vect.c_mapinfo)
>>> dblinks
- >>> link = Link(2, 'pg_link', 'boundary_municp_pg', 'cat',
+ >>> link = Link(2, 'pg_link', test_vector_name, 'cat',
... 'host=localhost dbname=grassdb', 'pg') # doctest: +SKIP
>>> dblinks.add(link) # doctest: +SKIP
>>> dblinks # doctest: +SKIP
- DBlinks([Link(1, boundary_municp, sqlite)])
#TODO: check if open in write mode or not.
@@ -909,14 +908,14 @@
:type force: boole
>>> dblinks
>>> dblinks.remove('pg_link') # doctest: +SKIP
>>> dblinks # need to open vector map in write mode
@@ -940,12 +939,12 @@
>>> import sqlite3
- >>> tab_sqlite = Table(name='census',
+ >>> tab_sqlite = Table(name=test_vector_name,
... connection=sqlite3.connect(get_path(path)))
>>> tab_sqlite.name
- u'census'
>>> import psycopg2 # doctest: +SKIP
- >>> tab_pg = Table('boundary_municp_pg',
+ >>> tab_pg = Table(test_vector_name,
... psycopg2.connect('host=localhost dbname=grassdb',
... 'pg')) # doctest: +SKIP
>>> tab_pg.columns # doctest: +ELLIPSIS +SKIP
@@ -986,10 +985,10 @@
>>> import sqlite3
>>> tab_sqlite
- Table(u'census')
+ Table(u'table_doctest_map')
return "Table(%r)" % (self.name)
@@ -1030,11 +1029,11 @@
"""Return the number of rows
>>> import sqlite3
>>> tab_sqlite.n_rows()
- 2537
+ 3
cur = self.conn.cursor()
cur.execute(sql.SELECT.format(cols='Count(*)', tname=self.name))
@@ -1058,14 +1057,14 @@
:type values: list of tuple
>>> import sqlite3
- >>> tab_sqlite.filters.select('cat', 'TOTAL_POP').order_by('AREA')
- Filters(u'SELECT cat, TOTAL_POP FROM census ORDER BY AREA;')
+ >>> tab_sqlite.filters.select('cat', 'name').order_by('value')
+ Filters(u'SELECT cat, name FROM table_doctest_map ORDER BY value;')
>>> cur = tab_sqlite.execute()
- (1856, 0)
+ (1, u'point')
try:
@@ -1074,9 +1073,9 @@
if many and values:
return cur.executemany(sqlc, values)
return cur.execute(sqlc)
- except:
+ except Exception, e:
#import ipdb; ipdb.set_trace()
- raise ValueError("The SQL is not correct:\n%r" % sqlc)
+ raise ValueError("The SQL is not correct:\n%r, SQL error: %s" % (sqlc, str(e)))
def exist(self, cursor=None):
"""Return True if the table already exist in the DB, False otherwise
@@ -1167,6 +1166,6 @@
"""Remove the generated vector map, if exist"""
from grass.pygrass.utils import get_mapset_vector
from grass.script.core import run_command
- mset = get_mapset_vector(test_vector_name, mapset='')
- if mset:
- run_command("g.remove", flags='f', type='vector', name=test_vector_name)
+ #mset = get_mapset_vector(test_vector_name, mapset='')
+ #if mset:
+ # run_command("g.remove", flags='f', type='vector', name=test_vector_name)
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py 2015-08-30 20:55:38 UTC (rev 66072)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_doctests.py 2015-08-31 10:40:37 UTC (rev 66073)
@@ -37,6 +37,7 @@
utils.create_test_vector_map(gvector.abstract.test_vector_name)
utils.create_test_vector_map(gvector.geometry.test_vector_name)
utils.create_test_vector_map(gvector.find.test_vector_name)
+ utils.create_test_vector_map(gvector.table.test_vector_name)
# this should be called at some top level
tests.addTests(doctest.DocTestSuite(gvector))
@@ -45,7 +46,7 @@
tests.addTests(doctest.DocTestSuite(gvector.find))
tests.addTests(doctest.DocTestSuite(gvector.geometry))
tests.addTests(doctest.DocTestSuite(gvector.sql))
- #tests.addTests(doctest.DocTestSuite(gvector.table))
+ tests.addTests(doctest.DocTestSuite(gvector.table))
return tests
