[GRASS-SVN] r66994 - in grass/trunk/scripts: . g.search.modules g.search.modules/testsuite
Tue Dec 1 00:49:42 PST 2015
Author: jachym
Date: 2015-12-01 00:49:42 -0800 (Tue, 01 Dec 2015)
New Revision: 66994
Added:
   grass/trunk/scripts/g.search.modules/
   grass/trunk/scripts/g.search.modules/g.search.modules.html
   grass/trunk/scripts/g.search.modules/g.search.modules.py
   grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py
Removed:
   grass/trunk/scripts/g.search.module/
   grass/trunk/scripts/g.search.modules/g.search.module.html
   grass/trunk/scripts/g.search.modules/g.search.module.py
   grass/trunk/scripts/g.search.modules/testsuite/test_g_search_module.py
   grass/trunk/scripts/Makefile
   grass/trunk/scripts/g.search.modules/Makefile
renaming g.search.module -> g.search.modules
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile	2015-11-30 23:46:18 UTC (rev 66993)
+++ grass/trunk/scripts/Makefile	2015-12-01 08:49:42 UTC (rev 66994)
@@ -21,7 +21,7 @@
 	g.extension \
 	g.extension.all \
 	g.manual \
-	g.search.module \
+	g.search.modules \
 	i.colors.enhance \
 	i.image.mosaic \
 	i.in.spotvgt \
Modified: grass/trunk/scripts/g.search.modules/Makefile
--- grass/trunk/scripts/g.search.module/Makefile	2015-11-30 23:46:18 UTC (rev 66993)
+++ grass/trunk/scripts/g.search.modules/Makefile	2015-12-01 08:49:42 UTC (rev 66994)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = g.search.module
+PGM = g.search.modules
 include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass/trunk/scripts/g.search.modules/g.search.module.html
--- grass/trunk/scripts/g.search.module/g.search.module.html	2015-11-30 23:46:18 UTC (rev 66993)
+++ grass/trunk/scripts/g.search.modules/g.search.module.html	2015-12-01 08:49:42 UTC (rev 66994)
@@ -1,70 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.search.module</em> searches for given keyword in GRASS modules name,
-description, keywords and optionally manpages too.
-<h2>NOTES</h2>
-There can be more keywords, <em>g.search.module</em> will search for each of them
-<h2>EXAMPLE</h2>
-Search all modules, where keywords <em>buffer</em> OR <em>clip</em> can be found
-<div class="code"><pre>
-g.search.module keyword=buffer,clip
-r.circle
-    keywords: raster,buffer,geometry,circle
-    description: Creates a raster map containing concentric rings around a
-                 given point.
-r.buffer.lowmem
-    description: Creates a raster map showing buffer zones surrounding cells
-                 that contain non-NULL category values. This is the low-
-                 memory alternative to the classic r.buffer module.
-r.buffer
-</pre></div>
-Search all modules, where keywords <em>overlay</em> AND <em>clip</em> can be
-found with some fancy terminal output
-g.search.module keyword=clip,overlay -a -c
-v.overlay
-    keywords: vector,geometry,spatial query,intersection,union,clip
-    description: Overlays two vector maps.;
-</pre></div>
-Search in manual pages too
-g.search.module -m keyword=kapri
-db.execute
-    keywords: database,attribute table,SQL
-    description: Executes any SQL statement. For SELECT statements use
-                 'db.select'.
-db.select
-    description: Selects data from attribute table. Performs SQL query
-                 statement(s).
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-  <a href="g.manual.html">g.manual</a>
-  <!-- <a href="g.search.map.html">g.search.map</a>, -->
-</em>
-<h2>AUTHORS</h2>
-Jachym Cepicky, OpenGeoLabs s.r.o., Czech Republic
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass/trunk/scripts/g.search.modules/g.search.module.py
--- grass/trunk/scripts/g.search.module/g.search.module.py	2015-11-30 23:46:18 UTC (rev 66993)
+++ grass/trunk/scripts/g.search.modules/g.search.module.py	2015-12-01 08:49:42 UTC (rev 66994)
@@ -1,235 +0,0 @@
-#!/usr/bin/env python
-# MODULE:	g.search.module
-# AUTHOR(S):	Jachym Cepicky <jachym.cepicky gmail.com>
-# PURPOSE:	g.search.module in grass modules using keywords
-# COPYRIGHT:	(C) 2015-2016 by the GRASS Development Team
-#		This program is free software under the GNU General
-#		Public License (>=v2). Read the file COPYING that
-#		comes with GRASS for details.
-#%module
-#% description: Search in GRASS modules using keywords
-#% keyword: general
-#% keyword: modules
-#% keyword: search
-#%end
-#%option
-#% key: keyword
-#% multiple: yes
-#% type: string
-#% description: Keyword to be searched
-#% required : yes
-#%end
-#%flag
-#% key: a
-#% description: Display only modules where all keywords are available (AND), default: OR
-#% guisection: Output
-#%end
-#%flag
-#% key: m
-#% description: Search in manual pages too (can be slow)
-#%end
-#%flag
-#% key: c
-#% description: Use colorized (more readable) output to terminal
-#%end
-#%flag
-#% key: g
-#% description: Shell script format
-#%end
-#%flag
-#% key: j
-#% description: JSON format
-#%end
-import os
-import sys
-from grass.script.utils import diff_files, try_rmdir
-from grass.script import core as grass
-try:
-    import xml.etree.ElementTree   as etree
-except ImportError:
-    import elementtree.ElementTree as etree # Python <= 2.4
-COLORIZE=False
-def main():
-    global COLORIZE
-    keywords = options['keyword'].lower().split(',')
-    AND = flags['a']
-    manpages = flags['m']
-    out_format = None
-    if flags['g']:
-        out_format = 'shell'
-    elif flags['j']:
-        out_format = 'json'
-    else:
-        COLORIZE = flags['c']
-    modules = _search_module(keywords, AND, manpages)
-    print_results(modules, out_format)
-def print_results(data, out_format=None):
-    Print result of the searching method
-    each data item should have
-        'name': name of the item,
-        'attributes': {
-            # list of attributes to be shown too
-    :param list.<dict> data: input list of found data items
-    :param str out_format: output format 'shell', 'json', None
-    if not out_format:
-        _print_results(data)
-    elif out_format == 'shell':
-        _print_results_shell(data)
-    elif out_format == 'json':
-        _print_results_json(data)
-def _print_results_shell(data):
-    """Print just the name attribute"""
-    for item in data:
-        print item['name']
-def _print_results_json(data):
-    """Print JSON output"""
-    import json
-    print json.dumps(data, sort_keys=True, indent=4, separators=(',', ': '))
-def _print_results(data):
-    import textwrap
-    for item in data:
-        print '\n{}'.format(colorize(item['name'], attrs=['bold']))
-        for attr in item['attributes']:
-            out = '{}: {}'.format(attr, item['attributes'][attr])
-            out = textwrap.wrap(out, width=79, initial_indent=4*' ',
-                    subsequent_indent=4*' '+len(attr)*' '+'  ')
-            for line in out:
-                print line
-def colorize(text, attrs=None, pattern=None):
-    """Colorize given text input
-    :param string text: input text to be colored
-    :param list.<string> attrs: list of attributes as defined in termcolor package
-    :param string pattern: text to be highlighted in input text
-    :return: colored string
-    if COLORIZE:
-        from termcolor import colored
-    else:
-        def colored(pattern, attrs):
-            return pattern
-    if pattern:
-        return text.replace(pattern, colored(pattern, attrs=attrs))
-    else:
-        return colored(text, attrs=attrs)
-def _search_module(keywords, logical_and=False, manpages=False):
-    """Search modules by given keywords
-    :param list.<str> keywords: list of keywords
-    :param boolean logical_and: use AND (default OR)
-    :param boolean manpages: search in manpages too
-    :return dict: modules
-    WXGUIDIR = os.path.join(os.getenv("GISBASE"), "gui", "wxpython")
-    filename = os.path.join(WXGUIDIR, 'xml', 'module_items.xml')
-    menudata_file = open(filename, 'r')
-    menudata = etree.parse(menudata_file)
-    menudata_file.close()
-    items = menudata.findall('module-item')
-    found_modules = []
-    for item in items:
-        name = item.attrib['name']
-        description = item.find('description').text
-        module_keywords = item.find('keywords').text
-        found = [False]
-        if logical_and:
-            found = [False] * len(keywords)
-        for idx in range(len(keywords)):
-            keyword = keywords[idx]
-            keyword_found = False
-            keyword_found = _basic_search(keyword, name, description, module_keywords)
-            if not keyword_found and manpages:
-                keyword_found = _manpage_search(keyword, name)
-            if keyword_found:
-                if logical_and:
-                    found[idx] = True
-                else:
-                    found = [True]
-                description = colorize(description,
-                                        attrs=['underline'],
-                                        pattern=keyword)
-                module_keywords = colorize(module_keywords,
-                                            pattern=keyword)
-        if False not in found:
-            found_modules.append({
-                'name': name,
-                'attributes': {
-                    'keywords': module_keywords,
-                    'description': description
-    return found_modules
-def _basic_search(pattern, name, description, module_keywords):
-    if name.lower().find(pattern) > -1 or\
-       description.lower().find(pattern) > -1 or\
-       module_keywords.lower().find(pattern) > -1:
-        return True
-    else:
-        return False
-def _manpage_search(pattern, name):
-    manpage = grass.read_command('g.manual', flags='m', entry=name)
-    return manpage.lower().find(pattern) > -1
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
Copied: grass/trunk/scripts/g.search.modules/g.search.modules.html (from rev 66993, grass/trunk/scripts/g.search.module/g.search.module.html)
--- grass/trunk/scripts/g.search.modules/g.search.modules.html	                        (rev 0)
+++ grass/trunk/scripts/g.search.modules/g.search.modules.html	2015-12-01 08:49:42 UTC (rev 66994)
@@ -0,0 +1,70 @@
+<h2>DESCRIPTION</h2>
+<em>r.search.module</em> searches for given keyword in GRASS modules name,
+description, keywords and optionally manpages too.
+<h2>NOTES</h2>
+There can be more keywords, <em>g.search.modules</em> will search for each of them
+<h2>EXAMPLE</h2>
+Search all modules, where keywords <em>buffer</em> OR <em>clip</em> can be found
+<div class="code"><pre>
+g.search.modules keyword=buffer,clip
+r.circle
+    keywords: raster,buffer,geometry,circle
+    description: Creates a raster map containing concentric rings around a
+                 given point.
+r.buffer.lowmem
+    description: Creates a raster map showing buffer zones surrounding cells
+                 that contain non-NULL category values. This is the low-
+                 memory alternative to the classic r.buffer module.
+r.buffer
+</pre></div>
+Search all modules, where keywords <em>overlay</em> AND <em>clip</em> can be
+found with some fancy terminal output
+g.search.modules keyword=clip,overlay -a -c
+v.overlay
+    keywords: vector,geometry,spatial query,intersection,union,clip
+    description: Overlays two vector maps.;
+</pre></div>
+Search in manual pages too
+g.search.modules -m keyword=kapri
+db.execute
+    keywords: database,attribute table,SQL
+    description: Executes any SQL statement. For SELECT statements use
+                 'db.select'.
+db.select
+    description: Selects data from attribute table. Performs SQL query
+                 statement(s).
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="g.manual.html">g.manual</a>
+  <!-- <a href="g.search.map.html">g.search.map</a>, -->
+</em>
+<h2>AUTHORS</h2>
+Jachym Cepicky, OpenGeoLabs s.r.o., Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/g.search.modules/g.search.modules.py (from rev 66993, grass/trunk/scripts/g.search.module/g.search.module.py)
--- grass/trunk/scripts/g.search.modules/g.search.modules.py	                        (rev 0)
+++ grass/trunk/scripts/g.search.modules/g.search.modules.py	2015-12-01 08:49:42 UTC (rev 66994)
@@ -0,0 +1,235 @@
+#!/usr/bin/env python
+# MODULE:	g.search.modules
+# AUTHOR(S):	Jachym Cepicky <jachym.cepicky gmail.com>
+# PURPOSE:	g.search.modules in grass modules using keywords
+# COPYRIGHT:	(C) 2015-2016 by the GRASS Development Team
+#		This program is free software under the GNU General
+#		Public License (>=v2). Read the file COPYING that
+#		comes with GRASS for details.
+#%module
+#% description: Search in GRASS modules using keywords
+#% keyword: general
+#% keyword: modules
+#% keyword: search
+#%end
+#%option
+#% key: keyword
+#% multiple: yes
+#% type: string
+#% description: Keyword to be searched
+#% required : yes
+#%end
+#%flag
+#% key: a
+#% description: Display only modules where all keywords are available (AND), default: OR
+#% guisection: Output
+#%end
+#%flag
+#% key: m
+#% description: Search in manual pages too (can be slow)
+#%end
+#%flag
+#% key: c
+#% description: Use colorized (more readable) output to terminal
+#%end
+#%flag
+#% key: g
+#% description: Shell script format
+#%end
+#%flag
+#% key: j
+#% description: JSON format
+#%end
+import os
+import sys
+from grass.script.utils import diff_files, try_rmdir
+from grass.script import core as grass
+try:
+    import xml.etree.ElementTree   as etree
+except ImportError:
+    import elementtree.ElementTree as etree # Python <= 2.4
+COLORIZE=False
+def main():
+    global COLORIZE
+    keywords = options['keyword'].lower().split(',')
+    AND = flags['a']
+    manpages = flags['m']
+    out_format = None
+    if flags['g']:
+        out_format = 'shell'
+    elif flags['j']:
+        out_format = 'json'
+    else:
+        COLORIZE = flags['c']
+    modules = _search_module(keywords, AND, manpages)
+    print_results(modules, out_format)
+def print_results(data, out_format=None):
+    Print result of the searching method
+    each data item should have
+        'name': name of the item,
+        'attributes': {
+            # list of attributes to be shown too
+    :param list.<dict> data: input list of found data items
+    :param str out_format: output format 'shell', 'json', None
+    if not out_format:
+        _print_results(data)
+    elif out_format == 'shell':
+        _print_results_shell(data)
+    elif out_format == 'json':
+        _print_results_json(data)
+def _print_results_shell(data):
+    """Print just the name attribute"""
+    for item in data:
+        print item['name']
+def _print_results_json(data):
+    """Print JSON output"""
+    import json
+    print json.dumps(data, sort_keys=True, indent=4, separators=(',', ': '))
+def _print_results(data):
+    import textwrap
+    for item in data:
+        print '\n{}'.format(colorize(item['name'], attrs=['bold']))
+        for attr in item['attributes']:
+            out = '{}: {}'.format(attr, item['attributes'][attr])
+            out = textwrap.wrap(out, width=79, initial_indent=4*' ',
+                    subsequent_indent=4*' '+len(attr)*' '+'  ')
+            for line in out:
+                print line
+def colorize(text, attrs=None, pattern=None):
+    """Colorize given text input
+    :param string text: input text to be colored
+    :param list.<string> attrs: list of attributes as defined in termcolor package
+    :param string pattern: text to be highlighted in input text
+    :return: colored string
+    if COLORIZE:
+        from termcolor import colored
+    else:
+        def colored(pattern, attrs):
+            return pattern
+    if pattern:
+        return text.replace(pattern, colored(pattern, attrs=attrs))
+    else:
+        return colored(text, attrs=attrs)
+def _search_module(keywords, logical_and=False, manpages=False):
+    """Search modules by given keywords
+    :param list.<str> keywords: list of keywords
+    :param boolean logical_and: use AND (default OR)
+    :param boolean manpages: search in manpages too
+    :return dict: modules
+    WXGUIDIR = os.path.join(os.getenv("GISBASE"), "gui", "wxpython")
+    filename = os.path.join(WXGUIDIR, 'xml', 'module_items.xml')
+    menudata_file = open(filename, 'r')
+    menudata = etree.parse(menudata_file)
+    menudata_file.close()
+    items = menudata.findall('module-item')
+    found_modules = []
+    for item in items:
+        name = item.attrib['name']
+        description = item.find('description').text
+        module_keywords = item.find('keywords').text
+        found = [False]
+        if logical_and:
+            found = [False] * len(keywords)
+        for idx in range(len(keywords)):
+            keyword = keywords[idx]
+            keyword_found = False
+            keyword_found = _basic_search(keyword, name, description, module_keywords)
+            if not keyword_found and manpages:
+                keyword_found = _manpage_search(keyword, name)
+            if keyword_found:
+                if logical_and:
+                    found[idx] = True
+                else:
+                    found = [True]
+                description = colorize(description,
+                                        attrs=['underline'],
+                                        pattern=keyword)
+                module_keywords = colorize(module_keywords,
+                                            pattern=keyword)
+        if False not in found:
+            found_modules.append({
+                'name': name,
+                'attributes': {
+                    'keywords': module_keywords,
+                    'description': description
+    return found_modules
+def _basic_search(pattern, name, description, module_keywords):
+    if name.lower().find(pattern) > -1 or\
+       description.lower().find(pattern) > -1 or\
+       module_keywords.lower().find(pattern) > -1:
+        return True
+    else:
+        return False
+def _manpage_search(pattern, name):
+    manpage = grass.read_command('g.manual', flags='m', entry=name)
+    return manpage.lower().find(pattern) > -1
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Deleted: grass/trunk/scripts/g.search.modules/testsuite/test_g_search_module.py
--- grass/trunk/scripts/g.search.module/testsuite/test_g_search_module.py	2015-11-30 23:46:18 UTC (rev 66993)
+++ grass/trunk/scripts/g.search.modules/testsuite/test_g_search_module.py	2015-12-01 08:49:42 UTC (rev 66994)
@@ -1,64 +0,0 @@
-TEST:      test_g_search_module.py
-AUTHOR(S): Jachym Cepicky <jachym.cepicky gmail com>
-PURPOSE:   Test g.search.module script outputs
-COPYRIGHT: (C) 2015 Jachym Ceppicky, and by the GRASS Development Team
-           This program is free software under the GNU General Public
-           License (>=v2). Read the file COPYING that comes with GRASS
-           for details.
-from grass.gunittest.case import TestCase
-from grass.gunittest.main import test
-from grass.gunittest.gmodules import SimpleModule
-import termcolor
-import os
-class TestSearchModule(TestCase):
-    def test_terminal_output(self):
-        module = SimpleModule('g.search.module', keyword="water")
-        self.assertModule(module)
-        stdout = module.outputs.stdout
-        self.assertEqual(stdout.split()[0], 'r.watershed')
-    def test_json_output(self):
-        import json
-        module = SimpleModule('g.search.module', keyword="water", flags="j")
-        stdout = json.loads(module.outputs.stdout)
-        self.assertEqual(len(stdout), 6, 'Six modules found')
-        self.assertEqual(stdout[3]['name'], 'r.basins.fill', 'r.basins.fill')
-        self.assertTrue('keywords' in stdout[3]['attributes'])
-    def test_shell_outout(self):
-        module = SimpleModule('g.search.module', keyword="water", flags="g")
-        stdout = module.outputs.stdout.split()
-        self.assertEqual(len(stdout), 6)
-        self.assertEqual(stdout[3], 'r.basins.fill')
-    def test_colored_terminal(self):
-        module = SimpleModule('g.search.module', keyword="water", flags="c")
-        self.assertEqual(stdout[0],
-                         termcolor.colored('r.watershed',
-                         attrs=['bold']))
-    def test_manual_pages(self):
-        module = SimpleModule('g.search.module', keyword="kapri", flags="gm")
-        self.assertEqual(len(stdout), 2)
-if __name__ == '__main__':
-    test()
Copied: grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py (from rev 66993, grass/trunk/scripts/g.search.module/testsuite/test_g_search_module.py)
--- grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py	                        (rev 0)
+++ grass/trunk/scripts/g.search.modules/testsuite/test_g_search_modules.py	2015-12-01 08:49:42 UTC (rev 66994)
@@ -0,0 +1,64 @@
+TEST:      test_g.search.modules.py
+AUTHOR(S): Jachym Cepicky <jachym.cepicky gmail com>
+PURPOSE:   Test g.search.modules script outputs
+COPYRIGHT: (C) 2015 Jachym Ceppicky, and by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+import termcolor
+import os
+class TestSearchModule(TestCase):
+    def test_terminal_output(self):
+        module = SimpleModule('g.search.modules', keyword="water")
+        self.assertModule(module)
+        stdout = module.outputs.stdout
+        self.assertEqual(stdout.split()[0], 'r.watershed')
+    def test_json_output(self):
+        import json
+        module = SimpleModule('g.search.modules', keyword="water", flags="j")
+        stdout = json.loads(module.outputs.stdout)
+        self.assertEqual(len(stdout), 6, 'Six modules found')
+        self.assertEqual(stdout[3]['name'], 'r.basins.fill', 'r.basins.fill')
+        self.assertTrue('keywords' in stdout[3]['attributes'])
+    def test_shell_outout(self):
+        module = SimpleModule('g.search.modules', keyword="water", flags="g")
+        stdout = module.outputs.stdout.split()
+        self.assertEqual(len(stdout), 6)
+        self.assertEqual(stdout[3], 'r.basins.fill')
+    def test_colored_terminal(self):
+        module = SimpleModule('g.search.modules', keyword="water", flags="c")
+        self.assertEqual(stdout[0],
+                         termcolor.colored('r.watershed',
+                         attrs=['bold']))
+    def test_manual_pages(self):
+        module = SimpleModule('g.search.modules', keyword="kapri", flags="gm")
+        self.assertEqual(len(stdout), 2)
+if __name__ == '__main__':
+    test()
