[GRASS-SVN] r67000 - grass/trunk/raster/r.mapcalc
svn_grass at osgeo.org
Tue Dec 1 13:53:43 PST 2015
Author: glynn
Date: 2015-12-01 13:53:43 -0800 (Tue, 01 Dec 2015)
New Revision: 67000
grass/trunk/raster/r.mapcalc/evaluate.c
grass/trunk/raster/r.mapcalc/main.c
grass/trunk/raster/r.mapcalc/map.c
grass/trunk/raster/r.mapcalc/map3.c
grass/trunk/raster/r.mapcalc/mapcalc.h
Add -l (list maps) flag (issue #2592)
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c 2015-12-01 20:22:20 UTC (rev 66999)
+++ grass/trunk/raster/r.mapcalc/evaluate.c 2015-12-01 21:53:43 UTC (rev 67000)
@@ -362,4 +362,34 @@
G_unset_error_routine();
+void describe_maps(FILE *fp, expr_list *ee)
+ expr_list *l;
+ fprintf(fp, "output=");
+ for (l = ee; l; l = l->next) {
+ expression *e = l->exp;
+ const char *var;
+ if (e->type != expr_type_binding && e->type != expr_type_function)
+ G_fatal_error("internal error: execute: invalid type: %d",
+ e->type);
+ initialize(e);
+ if (e->type != expr_type_binding)
+ continue;
+ var = e->data.bind.var;
+ fprintf(fp, "%s%s", l != ee ? "," : "", var);
+ fprintf(fp, "\n");
+ fprintf(fp, "input=");
+ list_maps(fp, ",");
Modified: grass/trunk/raster/r.mapcalc/main.c
--- grass/trunk/raster/r.mapcalc/main.c 2015-12-01 20:22:20 UTC (rev 66999)
+++ grass/trunk/raster/r.mapcalc/main.c 2015-12-01 21:53:43 UTC (rev 67000)
@@ -106,7 +106,7 @@
struct GModule *module;
struct Option *expr, *file, *seed;
- struct Flag *random;
+ struct Flag *random, *describe;
int all_ok;
G_gisinit(argv[0]);
@@ -140,6 +140,10 @@
random->key = 's';
random->description = _("Generate random seed (result is non-deterministic)");
+ describe = G_define_flag();
+ describe->key = 'l';
+ describe->description = _("List input and output maps");
if (argc == 1)
char **p = G_malloc(3 * sizeof(char *));
@@ -186,6 +190,11 @@
G_debug(3, "Generated random seed (-s): %ld", seed_value);
+ if (describe->answer) {
+ describe_maps(stdout, result);
+ return EXIT_SUCCESS;
pre_exec();
execute(result);
post_exec();
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c 2015-12-01 20:22:20 UTC (rev 66999)
+++ grass/trunk/raster/r.mapcalc/map.c 2015-12-01 21:53:43 UTC (rev 67000)
@@ -651,6 +651,16 @@
#endif
+void list_maps(FILE *fp, const char *sep)
+ int i;
+ for (i = 0; i < num_maps; i++) {
+ const struct map *m = &maps[i];
+ fprintf(fp, "%s%s@%s", i ? sep : "", m->name, m->mapset);
int check_output_map(const char *name)
Modified: grass/trunk/raster/r.mapcalc/map3.c
--- grass/trunk/raster/r.mapcalc/map3.c 2015-12-01 20:22:20 UTC (rev 66999)
+++ grass/trunk/raster/r.mapcalc/map3.c 2015-12-01 21:53:43 UTC (rev 67000)
@@ -575,6 +575,16 @@
num_maps = 0;
+ int i;
Modified: grass/trunk/raster/r.mapcalc/mapcalc.h
--- grass/trunk/raster/r.mapcalc/mapcalc.h 2015-12-01 20:22:20 UTC (rev 66999)
+++ grass/trunk/raster/r.mapcalc/mapcalc.h 2015-12-01 21:53:43 UTC (rev 67000)
@@ -38,6 +38,7 @@
/* evaluate.c */
extern void execute(expr_list *);
+extern void describe_maps(FILE *, expr_list *);
/* map.c/map3.c */
@@ -49,6 +50,7 @@
extern void get_map_row(int idx, int mod, int depth, int row, int col,
void *buf, int res_type);
extern void close_maps(void);
+extern void list_maps(FILE *, const char *);
extern int check_output_map(const char *name);
extern int open_output_map(const char *name, int res_type);
