[GRASS-SVN] r67002 - grass-addons/grass7/raster/r.biodiversity
svn_grass at osgeo.org
Wed Dec 2 01:49:26 PST 2015
Author: pvanbosgeo
Date: 2015-12-02 01:49:26 -0800 (Wed, 02 Dec 2015)
New Revision: 67002
grass-addons/grass7/raster/r.biodiversity/r.biodiversity.html
grass-addons/grass7/raster/r.biodiversity/r.biodiversity.py
1) Dealing with problem in Windows with overwrite/rename existing raster layers (a problem possibly related to ticket #2434?), 2) some small improvements of manual page
Modified: grass-addons/grass7/raster/r.biodiversity/r.biodiversity.html
--- grass-addons/grass7/raster/r.biodiversity/r.biodiversity.html 2015-12-02 09:04:05 UTC (rev 67001)
+++ grass-addons/grass7/raster/r.biodiversity/r.biodiversity.html 2015-12-02 09:49:26 UTC (rev 67002)
@@ -117,25 +117,57 @@
r.mapcalc "spec5 = 4"
</pre></div>
-<p>Now we can calculate the renyi index for alpha is 0, 1 and 2 (this
-will give you 1.61, 1.06 and 0.83 respectively)
+<p>Now we can calculate the renyi index for alpha is 0, 1 and 2
+(this should be 1.61, 1.06 and 0.83 respectively)
<div class="code"><pre>
-r.biodiversity in=spec1,spec2,spec3,spec4,spec5 out=renyi alpha=0,1,2
+r.biodiversity -r in=spec1,spec2,spec3,spec4,spec5 out=renyi alpha=0,1,2
+r.info -r map=renyi_Renyi_0_0
+min=1.6094379124341
+max=1.6094379124341
+r.info -r map=renyi_Renyi_1_0
+min=1.05813420869358
+max=1.05813420869358
+r.info -r map=renyi_Renyi_2_0
+min=0.834250021537946
+max=0.834250021537946
</pre></div>
-<p>You can also compute the species richness, shannon, simpson,
-inverse simpson and gini-simpson indices
+<p>You can also compute the species richness, shannon, inverse
+simpson and gini-simpson indices
-r.biodiversity -s -h -d -p -g in=spec1,spec2,spec3,spec4,spec5 out=biodiversity
+r.biodiversity -s -h -p -g in=spec1,spec2,spec3,spec4,spec5 out=biodiversity
</pre></div>
<p>The species richness you get should of course be 5. The shannon
index is the same as the renyi index with alpha=1 (1.06). The
-simpson should be 0.43, and inverse simpson and gini-simpson will be
-2.3 and 0.57 respectively.
+inverse simpson and gini-simpson should be 2.3 and 0.57
+respectively. Let's check:
+<div class="code"><pre>
+r.info -r map=biodiversity_richness
+min=5
+max=5
+r.info -r map=biodiversity_shannon
+r.info -r map=biodiversity_invsimpson
+min=2.30308613542147
+max=2.30308613542147
+r.info -r map=biodiversity_ginisimpson
+min=0.5658
+max=0.5658
+</pre></div>
<h2>SEE ALSO</h2>
<em>
Modified: grass-addons/grass7/raster/r.biodiversity/r.biodiversity.py
--- grass-addons/grass7/raster/r.biodiversity/r.biodiversity.py 2015-12-02 09:04:05 UTC (rev 67001)
+++ grass-addons/grass7/raster/r.biodiversity/r.biodiversity.py 2015-12-02 09:49:26 UTC (rev 67002)
@@ -166,7 +166,7 @@
IN = options['input']
IN = IN.split(',')
CheckLayer(IN)
# Diversity indici
flag_r = flags['r']
flag_s = flags['s']
@@ -176,7 +176,7 @@
flag_g = flags['g']
flag_n = flags['n']
if options['alpha']:
- Q = map(float, options['alpha'].split(','))
+ Q = map(float, options['alpha'].split(','))
else:
Q = map(float, [])
Qoriginal = list(Q)
@@ -206,73 +206,82 @@
tmpt = tmpname("sht")
clean_rast.add(tmpt)
- grass.run_command("r.series", quiet=True, output=tmpt,
- input=IN, method="sum")
+ grass.run_command("r.series", quiet=True, output=tmpt,
+ input=IN, method="sum")
for n in xrange(len(Q)):
Qn = str(Q[n])
Qn = Qn.replace('.', '_')
out_renyi = OUT + "_Renyi_" + Qn
tmpl = []
- if Q[n] == 1:
+ if Q[n] == 1:
# If alpha = 1
for i in xrange(len(IN)):
tmpi = tmpname('shi' + str(i) + "_")
tmpl.append(tmpi)
clean_rast.add(tmpi)
- grass.mapcalc("$tmpi = ($inl/$tmpt) * log(($inl/$tmpt))",
+ grass.mapcalc("$tmpi = ($inl/$tmpt) * log(($inl/$tmpt))",
tmpi=tmpi,
inl=IN[i],
tmpt=tmpt,
quiet=True)
- grass.run_command("r.series", output=out_renyi, input=tmpl,
- method="sum", quiet=True)
- grass.mapcalc("$outl = -1 * $outl",
+ tmpta = tmpname("sht")
+ clean_rast.add(tmpta)
+ grass.run_command("r.series", output=tmpta, input=tmpl,
+ method="sum", quiet=True)
+ grass.mapcalc("$outl = -1 * $tmpta",
outl=out_renyi,
+ tmpta=tmpta,
overwrite=True,
quiet=True)
+ grass.run_command("g.remove", type="raster",
+ name=tmpta, flags="f")
else:
# If alpha != 1
tmpi = tmpname('reni')
- tmpl.append(tmpi)
- grass.mapcalc("$tmpi = if($inl==0,0,pow($inl/$tmpt,$alpha))",
+ tmpl.append(tmpi)
+ grass.mapcalc("$tmpi = if($inl==0,0,pow($inl/$tmpt,$alpha))",
tmpi=tmpi,
tmpt=tmpt,
inl=IN[i],
alpha=Q[n],
quiet=True)
- method="sum", quiet=True, overwrite=True)
- grass.mapcalc("$outl = (1/(1-$alpha)) * log($outl)",
+ grass.mapcalc("$outl = (1/(1-$alpha)) * log($tmpta)",
outl=out_renyi,
+ tmpta=tmpta,
alpha=Q[n],
- overwrite=True,
quiet=True)
- grass.run_command("g.remove", type="raster",
+ name=tmpta, flags="f", quiet=True)
name=tmpl, flags="f", quiet=True)
# Species richness
if flag_s:
- out_div = OUT + "_richness"
+ out_div = OUT + "_richness"
in_div = OUT + "_Renyi_0_0"
grass.mapcalc("$out_div = exp($in_div)",
out_div=out_div,
in_div=in_div,
quiet=True)
if 0.0 not in Qoriginal and not flag_e:
- grass.run_command("g.remove", flags="f", type="raster",
+ grass.run_command("g.remove", flags="f", type="raster",
name=in_div, quiet=True)
# Shannon index
if flag_h:
- out_div = OUT + "_shannon"
+ out_div = OUT + "_shannon"
in_div = OUT + "_Renyi_1_0"
if 1.0 in Qoriginal or flag_e or flag_n:
grass.run_command("g.copy", raster=(in_div,out_div), quiet=True)
@@ -283,21 +292,21 @@
# Shannon Effective Number of Species (ENS)
if flag_n:
- out_div = OUT + "_ens"
+ out_div = OUT + "_ens"
out_div=out_div,
in_div=in_div,
quiet=True)
if 1.0 not in Qoriginal and not flag_e:
# Eveness
if flag_e:
- out_div = OUT + "_eveness"
+ out_div = OUT + "_eveness"
in_div1 = OUT + "_Renyi_0_0"
in_div2 = OUT + "_Renyi_1_0"
grass.mapcalc("$out_div = $in_div2 / $in_div1",
@@ -306,43 +315,43 @@
in_div2=in_div2,
quiet=True)
if 0.0 not in Qoriginal:
name=in_div1, quiet=True)
if 1.0 not in Qoriginal:
name=in_div2, quiet=True)
# Inversed Simpson index
if flag_p:
- out_div = OUT + "_invsimpson"
+ out_div = OUT + "_invsimpson"
in_div = OUT + "_Renyi_2_0"
out_div=out_div,
in_div=in_div,
quiet=True)
if 2.0 not in Qoriginal and not flag_g:
# Gini Simpson index
if flag_g:
- out_div = OUT + "_ginisimpson"
+ out_div = OUT + "_ginisimpson"
grass.mapcalc("$out_div = 1.0 - (1.0 / exp($in_div))",
out_div=out_div,
in_div=in_div,
quiet=True)
if 2.0 not in Qoriginal:
# Clean up temporary files
- grass.run_command("g.remove", type="raster", name=tmpt,
+ grass.run_command("g.remove", type="raster", name=tmpt,
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
