[GRASS-SVN] r67005 - grass-addons/grass7/imagery/i.spec.sam
svn_grass at osgeo.org
Wed Dec 2 02:48:29 PST 2015
Author: ychemin
Date: 2015-12-02 02:48:29 -0800 (Wed, 02 Dec 2015)
New Revision: 67005
Added:
grass-addons/grass7/imagery/i.spec.sam/test1.py
Updated test data map generation based on python specangle test
Added: grass-addons/grass7/imagery/i.spec.sam/test1.py
--- grass-addons/grass7/imagery/i.spec.sam/test1.py (rev 0)
+++ grass-addons/grass7/imagery/i.spec.sam/test1.py 2015-12-02 10:48:29 UTC (rev 67005)
@@ -0,0 +1,90 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+from __future__ import (nested_scopes, generators, division, absolute_import,
+ with_statement, print_function, unicode_literals)
+#Spectral data to load as maps
+# Band: r g b i1 i2 i3
+# Spektren zeilenweise eingeben!
+# 1. Sagebrush
+# 2. Saltbush
+# 3. Ground
+# 4. Dry Grass
+#row0: 8.87 13.14 11.71 35.85
+#Matrix: 4 by 4
+#row1: 13.59 20.12 19.61 50.66
+#row2: 28.26 34.82 38.27 40.1
+#row3: 10.54 16.35 23.7 38.98
+#Define the spectral signatures for each land use class
+cls1=[8.87, 13.14, 11.71, 35.85]
+cls2=[13.59, 20.12, 19.61, 50.66]
+cls3=[28.26, 34.82, 38.27, 40.10]
+cls4=[10.54, 16.35, 23.70, 38.98]
+#Generate a disturbed class manually
+cls1_wannabe=[9, 14, 12, 36]
+cls2_wannabe=[14, 21, 20, 51]
+cls3_wannabe=[29, 35, 39, 41]
+cls4_wannabe=[11, 17, 24, 39]
+# Load Library
+from grass.pygrass.raster import RasterSegment
+from grass.pygrass.gis.region import Region
+#Raster layers names
+outrast1='sam_test_b1'
+outrast2='sam_test_b2'
+outrast3='sam_test_b3'
+outrast4='sam_test_b4'
+# Create output raster file
+out1 = RasterSegment(outrast1)
+out2 = RasterSegment(outrast2)
+out3 = RasterSegment(outrast3)
+out4 = RasterSegment(outrast4)
+# we must specify the map type the default is "CELL"
+out1.open('w', mtype='DCELL', overwrite=True)
+out2.open('w', mtype='DCELL', overwrite=True)
+out3.open('w', mtype='DCELL', overwrite=True)
+out4.open('w', mtype='DCELL', overwrite=True)
+# Get the number of rows
+rg = Region()
+# Loop through the rows
+for r in range(rg.rows):
+ '''Loop through the region rows'''
+ if(r < (1/4.0 * rg.rows)):
+ for c in range(rg.cols):
+ out1.put(r,c,cls1_wannabe[0])
+ out2.put(r,c,cls1_wannabe[1])
+ out3.put(r,c,cls1_wannabe[2])
+ out4.put(r,c,cls1_wannabe[3])
+ elif(r >= (1/4.0 * rg.rows) and r < (1/2.0 * rg.rows)):
+ out1.put(r,c,cls2_wannabe[0])
+ out2.put(r,c,cls2_wannabe[1])
+ out3.put(r,c,cls2_wannabe[2])
+ out4.put(r,c,cls2_wannabe[3])
+ elif(r >= (1/2.0 * rg.rows) and r < (3/4.0 * rg.rows)):
+ out1.put(r,c,cls3_wannabe[0])
+ out2.put(r,c,cls3_wannabe[1])
+ out3.put(r,c,cls3_wannabe[2])
+ out4.put(r,c,cls3_wannabe[3])
+ else:
+ out1.put(r,c,cls4_wannabe[0])
+ out2.put(r,c,cls4_wannabe[1])
+ out3.put(r,c,cls4_wannabe[2])
+ out4.put(r,c,cls4_wannabe[3])
+# Close the raster maps
+out1.close()
+out2.close()
+out3.close()
+out4.close()
