[GRASS-SVN] r67007 - grass/trunk/vector/v.db.select
svn_grass at osgeo.org
Wed Dec 2 07:47:13 PST 2015
Author: lucadelu
Date: 2015-12-02 07:47:13 -0800 (Wed, 02 Dec 2015)
New Revision: 67007
grass/trunk/vector/v.db.select/main.c
grass/trunk/vector/v.db.select/v.db.select.html
v.db.select: added group option to use GROUP BY SQL clause
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2015-12-02 10:49:00 UTC (rev 67006)
+++ grass/trunk/vector/v.db.select/main.c 2015-12-02 15:47:13 UTC (rev 67007)
@@ -2,13 +2,14 @@
* MODULE: v.db.select
* AUTHOR(S): Radim Blazek
* OGR support by Martin Landa <landa.martin gmail.com>
* -f flag by Huidae Cho <grass4u gmail.com>
+ * group option by Luca Delucchi <lucadeluge gmail.com>
* PURPOSE: Print vector attributes
* COPYRIGHT: (C) 2005-2009, 2011-2014 by the GRASS Development Team
* This program is free software under the GNU General
@@ -32,7 +33,7 @@
struct GModule *module;
struct Option *map_opt, *field_opt, *fs_opt, *vs_opt, *nv_opt, *col_opt,
- *where_opt, *file_opt;
+ *where_opt, *file_opt, *group_opt;
struct Flag *c_flag, *v_flag, *r_flag, *f_flag;
dbDriver *driver;
dbString sql, value_string;
@@ -63,10 +64,16 @@
col_opt = G_define_standard_option(G_OPT_DB_COLUMNS);
col_opt->guisection = _("Selection");
where_opt = G_define_standard_option(G_OPT_DB_WHERE);
where_opt->guisection = _("Selection");
+ group_opt = G_define_option();
+ group_opt->key = "group";
+ group_opt->required = NO;
+ group_opt->description = _("GROUP BY conditions of SQL statement without 'group by' keyword");
+ group_opt->guisection = _("Selection");
fs_opt = G_define_standard_option(G_OPT_F_SEP);
fs_opt->guisection = _("Format");
@@ -79,12 +86,12 @@
nv_opt = G_define_standard_option(G_OPT_M_NULL_VALUE);
nv_opt->guisection = _("Format");
- file_opt = G_define_standard_option(G_OPT_F_OUTPUT);
+ file_opt = G_define_standard_option(G_OPT_F_OUTPUT);
file_opt->key = "file";
- file_opt->required = NO;
- file_opt->description =
- _("Name for output file (if omitted or \"-\" output to stdout)");
+ file_opt->required = NO;
+ file_opt->description =
+ _("Name for output file (if omitted or \"-\" output to stdout)");
r_flag = G_define_flag();
r_flag->key = 'r';
r_flag->description =
@@ -112,12 +119,12 @@
exit(EXIT_FAILURE);
/* set input vector map name and mapset */
- if (file_opt->answer && strcmp(file_opt->answer, "-") != 0) {
- if (NULL == freopen(file_opt->answer, "w", stdout)) {
- G_fatal_error(_("Unable to open file <%s> for writing"), file_opt->answer);
+ if (file_opt->answer && strcmp(file_opt->answer, "-") != 0) {
+ if (NULL == freopen(file_opt->answer, "w", stdout)) {
+ G_fatal_error(_("Unable to open file <%s> for writing"), file_opt->answer);
min_box = line_box = NULL;
list_lines = NULL;
@@ -137,7 +144,7 @@
vs = G_option_to_separator(vs_opt);
else
vs = NULL;
db_init_string(&sql);
db_init_string(&value_string);
@@ -186,6 +193,15 @@
G_free(buf);
+ if (group_opt->answer) {
+ char *buf = NULL;
+ buf = G_malloc((strlen(group_opt->answer) + 8));
+ sprintf(buf, " GROUP BY %s", group_opt->answer);
+ db_append_string(&sql, buf);
+ G_free(buf);
if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) != DB_OK)
G_fatal_error(_("Unable to open select cursor"));
Modified: grass/trunk/vector/v.db.select/v.db.select.html
--- grass/trunk/vector/v.db.select/v.db.select.html 2015-12-02 10:49:00 UTC (rev 67006)
+++ grass/trunk/vector/v.db.select/v.db.select.html 2015-12-02 15:47:13 UTC (rev 67007)
@@ -65,6 +65,67 @@
</pre></div>
+<h3>Select features with distinct road names</h3>
+<div class="code"><pre>
+v.db.select map=roadsmajor columns=ROAD_NAME group=ROAD_NAME
+ROAD_NAME
+I-40
+I-440
+I-540
+NC-231
+NC-39
+NC-42
+</pre></div>
+It is also possible to combine with <em>where</em> option
+v.db.select map=roadsmajor columns=ROAD_NAME,MULTILANE group=ROAD_NAME where='ROAD_NAME is not null'
+ROAD_NAME|MULTILANE
+I-40|yes
+I-440|yes
+I-540|yes
+NC-231|no
+NC-39|no
+NC-42|no
+NC-50|no
+NC-54|no
+NC-55|no
+NC-96|no
+NC-97|no
+NC-98|no
+US-1|
+US-401|no
+US-64|yes
+US-70|yes
+</pre></div>
+It can also use more columns in <em>group</em> option
+v.db.select map=roadsmajor columns=ROAD_NAME,MULTILANE group=ROAD_NAME,MULTILANE where='ROAD_NAME is not null'
+I-40|yes
+I-440|yes
+I-540|yes
+NC-231|no
+NC-39|no
+NC-42|no
+NC-50|no
+NC-54|no
+NC-55|no
+NC-96|no
+NC-97|no
+NC-98|no
+US-1|
+US-1|yes
+US-401|no
+US-401|yes
+US-64|yes
+US-70|yes
+</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -75,6 +136,8 @@
Radim Blazek, ITC-Irst, Trento, Italy<br>
Minimal region extent added by Martin Landa,
-FBK-irst (formerly ITC-irst), Trento, Italy (2008/08)
+FBK-irst (formerly ITC-irst), Trento, Italy (2008/08)<br>
+Group option added by Luca Delucchi,
+Fondazione Edmund Mach, Trento, Italy (2015/12)
<p><i>Last changed: $Date$</i>
