[GRASS-SVN] r67035 - in grass/branches/releasebranch_7_0: gui/wxpython/animation gui/wxpython/core gui/wxpython/psmap lib/python/imaging lib/python/script scripts/wxpyimgview
svn_grass at osgeo.org
Mon Dec 7 06:54:58 PST 2015
Author: annakrat
Date: 2015-12-07 06:54:58 -0800 (Mon, 07 Dec 2015)
New Revision: 67035
Removed:
grass/branches/releasebranch_7_0/lib/python/script/setup.py
grass/branches/releasebranch_7_0/gui/wxpython/animation/utils.py
grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py
grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py
grass/branches/releasebranch_7_0/gui/wxpython/psmap/frame.py
grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py
grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py
grass/branches/releasebranch_7_0/lib/python/imaging/images2swf.py
grass/branches/releasebranch_7_0/scripts/wxpyimgview/wxpyimgview_gui.py
replace PIL obsolete functions (merge from trunk r67011,r67012)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/animation/utils.py
--- grass/branches/releasebranch_7_0/gui/wxpython/animation/utils.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/gui/wxpython/animation/utils.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -258,7 +258,7 @@
def WxImageToPil(image):
"""Converts wx.Image to PIL image"""
pilImage = Image.new('RGB', (image.GetWidth(), image.GetHeight()))
- pilImage.fromstring(image.GetData())
+ getattr(pilImage, "frombytes", getattr(pilImage, "fromstring"))(image.GetData())
return pilImage
Modified: grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py
--- grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/gui/wxpython/core/utils.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -1071,19 +1071,22 @@
import wx
hasAlpha = pilImage.mode[-1] == 'A'
- if copyAlpha and hasAlpha : # Make sure there is an alpha layer copy.
+ if copyAlpha and hasAlpha: # Make sure there is an alpha layer copy.
wxImage = wx.EmptyImage(*pilImage.size)
pilImageCopyRGBA = pilImage.copy()
pilImageCopyRGB = pilImageCopyRGBA.convert('RGB') # RGBA --> RGB
- pilImageRgbData = pilImageCopyRGB.tostring()
+ fn = getattr(pilImageCopyRGB, "tobytes", getattr(pilImageCopyRGB, "tostring"))
+ pilImageRgbData = fn()
wxImage.SetData(pilImageRgbData)
- wxImage.SetAlphaData(pilImageCopyRGBA.tostring()[3::4]) # Create layer and insert alpha values.
+ fn = getattr(pilImageCopyRGBA, "tobytes", getattr(pilImageCopyRGBA, "tostring"))
+ wxImage.SetAlphaData(fn()[3::4]) # Create layer and insert alpha values.
- else : # The resulting image will not have alpha.
+ else: # The resulting image will not have alpha.
pilImageCopy = pilImage.copy()
pilImageCopyRGB = pilImageCopy.convert('RGB') # Discard any alpha from the PIL image.
return wxImage
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -52,7 +52,7 @@
import grass.script as grass
from core import globalvar
-from core.utils import _
+from core.utils import _, PilImageToWxImage
from dbmgr.vinfo import VectorDBInfo
from gui_core.gselect import Select
from core.gcmd import RunCommand, GError, GMessage
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/frame.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/frame.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -35,7 +35,7 @@
from psmap.toolbars import PsMapToolbar
from core.settings import UserSettings
from gui_core.forms import GUI
from gui_core.dialogs import HyperlinkDialog
from gui_core.ghelp import ShowAboutDialog
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -362,30 +362,8 @@
return rasterType
else:
return None
-def PilImageToWxImage(pilImage, copyAlpha = True):
- """Convert PIL image to wx.Image
- Based on http://wiki.wxpython.org/WorkingWithImages
- hasAlpha = pilImage.mode[-1] == 'A'
- wxImage = wx.EmptyImage( *pilImage.size )
- pilImageCopyRGBA = pilImage.copy()
- pilImageCopyRGB = pilImageCopyRGBA.convert('RGB') # RGBA --> RGB
- wxImage.SetData(pilImageRgbData)
- wxImage = wx.EmptyImage(*pilImage.size)
- pilImageCopy = pilImage.copy()
- pilImageCopyRGB = pilImageCopy.convert('RGB') # Discard any alpha from the PIL image.
- return wxImage
def BBoxAfterRotation(w, h, angle):
"""Compute bounding box or rotated rectangle
Modified: grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py
--- grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/lib/python/imaging/images2gif.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -744,7 +744,7 @@
# Initialize
self.setconstants(samplefac, colors)
- self.pixels = np.fromstring(image.tostring(), np.uint32)
+ self.pixels = np.fromstring(getattr(image, "tobytes", getattr(image, "tostring"))(), np.uint32)
self.setUpArrays()
self.learn()
Modified: grass/branches/releasebranch_7_0/lib/python/imaging/images2swf.py
--- grass/branches/releasebranch_7_0/lib/python/imaging/images2swf.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/lib/python/imaging/images2swf.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -167,7 +167,8 @@
return self._len # self.data.shape[0]
def __repr__(self):
- return self.data[:self._len].tostring().decode('ascii')
+ fn = getattr(self.data[:self._len], "tobytes", getattr(self.data[:self._len], "tostring"))
+ return fn().decode('ascii')
def _checkSize(self):
# check length... grow if necessary
Deleted: grass/branches/releasebranch_7_0/lib/python/script/setup.py
--- grass/branches/releasebranch_7_0/lib/python/script/setup.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/lib/python/script/setup.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -1,191 +0,0 @@
-"""Setup and initialization functions
-Function can be used in Python scripts to setup a GRASS environment
-without starting an actual GRASS session.
-Usage::
- import os
- import sys
- import subprocess
- # define GRASS Database
- # add your path to grassdata (GRASS GIS database) directory
- gisdb = os.path.join(os.path.expanduser("~"), "grassdata")
- # the following path is the default path on MS Windows
- # gisdb = os.path.join(os.path.expanduser("~"), "Documents/grassdata")
- # specify (existing) Location and Mapset
- location = "nc_spm_08"
- mapset = "user1"
- # path to the GRASS GIS launch script
- # we assume that the GRASS GIS start script is available and on PATH
- # query GRASS itself for its GISBASE
- # (with fixes for specific platforms)
- # needs to be edited by the user
- grass7bin = 'grass70'
- if sys.platform.startswith('win'):
- # MS Windows
- grass7bin = r'C:\OSGeo4W\bin\grass70.bat'
- # uncomment when using standalone WinGRASS installer
- # grass7bin = r'C:\Program Files (x86)\GRASS GIS 7.0.0\grass70.bat'
- # this can be avoided if GRASS executable is added to PATH
- elif sys.platform == 'darwin':
- # Mac OS X
- # TODO: this have to be checked, maybe unix way is good enough
- grass7bin = '/Applications/GRASS/GRASS-7.0.app/'
- # query GRASS GIS itself for its GISBASE
- startcmd = [grass7bin, '--config', 'path']
- try:
- p = subprocess.Popen(startcmd, shell=False,
- stdout=subprocess.PIPE, stderr=subprocess.PIPE)
- out, err = p.communicate()
- except OSError as error:
- sys.exit("ERROR: Cannot find GRASS GIS start script"
- " {cmd}: {error}".format(cmd=startcmd[0], error=error))
- if p.returncode != 0:
- sys.exit("ERROR: Issues running GRASS GIS start script"
- " {cmd}: {error}"
- .format(cmd=' '.join(startcmd), error=err))
- gisbase = out.strip(os.linesep)
- # set GISBASE environment variable
- os.environ['GISBASE'] = gisbase
- # define GRASS-Python environment
- grass_pydir = os.path.join(gisbase, "etc", "python")
- sys.path.append(grass_pydir)
- # import (some) GRASS Python bindings
- import grass.script as gscript
- # launch session
- rcfile = gscript.setup.init(gisbase, gisdb, location, mapset)
- # example calls
- gscript.message('Current GRASS GIS 7 environment:')
- print gscript.gisenv()
- gscript.message('Available raster maps:')
- for rast in gscript.list_strings(type='raster'):
- print rast
- gscript.message('Available vector maps:')
- for vect in gscript.list_strings(type='vector'):
- print vect
- # delete the rcfile
- os.remove(rcfile)
-(C) 2010-2012 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Martin Landa <landa.martin gmail.com>
- at author Vaclav Petras <wenzeslaus gmail.com>
-# TODO: this should share code from lib/init/grass.py
-# perhaps grass.py can import without much trouble once GISBASE
-# is known, this would allow moving things from there, here
-# then this could even do locking
-import os
-import sys
-import tempfile as tmpfile
-def write_gisrc(dbase, location, mapset):
- """Write the ``gisrc`` file and return its path."""
- fd, gisrc = tmpfile.mkstemp()
- os.write(fd, "GISDBASE: %s\n" % dbase)
- os.write(fd, "LOCATION_NAME: %s\n" % location)
- os.write(fd, "MAPSET: %s\n" % mapset)
- os.close(fd)
- return gisrc
-# TODO: there should be a function to do the clean up
-# (unset the GISRC and delete the file)
-def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
- """Initialize system variables to run GRASS modules
- This function is for running GRASS GIS without starting it
- explicitly. No GRASS modules shall be called before call of this
- function but any module or user script can be called afterwards
- as if it would be called in an actual GRASS session. GRASS Python
- libraries are usable as well in general but the ones using
- C libraries through ``ctypes`` are not (which is caused by
- library path not being updated for the current process
- which is a common operating system limitation).
- To create a (fake) GRASS session a ``gisrc`` file is created.
- Caller is resposible for deleting the ``gisrc`` file.
- Basic usage::
- # ... setup GISBASE and PYTHON path before import
- gisrc = gscript.setup.init("/usr/bin/grass7",
- "/home/john/grassdata",
- "nc_spm_08", "user1")
- # ... use GRASS modules here
- # remove the session's gisrc file to end the session
- os.remove(gisrc)
- :param gisbase: path to GRASS installation
- :param dbase: path to GRASS database (default: '')
- :param location: location name (default: 'demolocation')
- :param mapset: mapset within given location (default: 'PERMANENT')
- :returns: path to ``gisrc`` file (to be deleted later)
- # TODO: why we don't set GISBASE?
- mswin = sys.platform.startswith('win')
- # define PATH
- os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin')
- os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'scripts')
- if mswin: # added for winGRASS
- os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'extrabin')
- # add addons to the PATH
- # copied and simplified from lib/init/grass.py
- if mswin:
- config_dirname = "GRASS7"
- config_dir = os.path.join(os.getenv('APPDATA'), config_dirname)
- else:
- config_dirname = ".grass7"
- config_dir = os.path.join(os.getenv('HOME'), config_dirname)
- addon_base = os.path.join(config_dir, 'addons')
- os.environ['GRASS_ADDON_BASE'] = addon_base
- if not mswin:
- os.environ['PATH'] += os.pathsep + os.path.join(addon_base, 'scripts')
- # define LD_LIBRARY_PATH
- if '@LD_LIBRARY_PATH_VAR@' not in os.environ:
- os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
- os.environ['@LD_LIBRARY_PATH_VAR@'] += os.pathsep + os.path.join(gisbase, 'lib')
- os.environ['GIS_LOCK'] = str(os.getpid())
- # Set PYTHONPATH to find GRASS Python modules
- # TODO: isn't this useless? user already imported this somehow
- path = os.getenv('PYTHONPATH')
- etcpy = os.path.join(gisbase, 'etc', 'python')
- if path:
- path = etcpy + os.pathsep + path
- else:
- path = etcpy
- os.environ['PYTHONPATH'] = path
- # TODO: isn't this contra-productive? may fail soon since we cannot
- # write to the installation (applies also to defaults for Location
- # and mapset) I don't see what would be the use case here.
- if not dbase:
- dbase = gisbase
- os.environ['GISRC'] = write_gisrc(dbase, location, mapset)
- return os.environ['GISRC']
Modified: grass/branches/releasebranch_7_0/scripts/wxpyimgview/wxpyimgview_gui.py
--- grass/branches/releasebranch_7_0/scripts/wxpyimgview/wxpyimgview_gui.py 2015-12-07 14:47:27 UTC (rev 67034)
+++ grass/branches/releasebranch_7_0/scripts/wxpyimgview/wxpyimgview_gui.py 2015-12-07 14:54:58 UTC (rev 67035)
@@ -78,7 +78,8 @@
dc = wx.PaintDC(self)
data = app.imgbuf.reshape((app.i_height, app.i_width, 4))
data = data[::,::,2::-1]
- image = wx.ImageFromData(app.i_width, app.i_height, data.tostring())
+ fn = getattr(data, "tobytes", getattr(data, "tostring"))
+ image = wx.ImageFromData(app.i_width, app.i_height, fn())
dc.DrawBitmap(wx.BitmapFromImage(image), x0, y0, False)
def redraw(self, ev):
