[GRASS-SVN] r67062 - grass-addons/grass7/raster/r.series.diversity
Fri Dec 11 00:22:28 PST 2015
Author: pvanbosgeo
Date: 2015-12-11 00:22:28 -0800 (Fri, 11 Dec 2015)
New Revision: 67062
   grass-addons/grass7/raster/r.series.diversity/r.series.diversity.html
   grass-addons/grass7/raster/r.series.diversity/r.series.diversity.py
change old name of addon in description
Modified: grass-addons/grass7/raster/r.series.diversity/r.series.diversity.html
--- grass-addons/grass7/raster/r.series.diversity/r.series.diversity.html	2015-12-11 08:20:12 UTC (rev 67061)
+++ grass-addons/grass7/raster/r.series.diversity/r.series.diversity.html	2015-12-11 08:22:28 UTC (rev 67062)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-<em>r.biodiversity</em> computes one or more biodiversity indices
+<em>r.series.diversity</em> computes one or more diversity indices
 based on 2 or more input layers. Each layer should represents a
 species (or other categories being used), and its raster values the
 category count/value. The name of the output layers will consist of
@@ -22,7 +22,7 @@
 resulting index (Jost 2006, Legendre & Legendre 1998). The name of
 the output layer is composed of the basename + renyi + alpha.
-<h4>Species richness</h4>
+<h4>Richness</h4>
 The species richness is simply the count of the number of layers.
 It is a special case of the Reny enthropy: <i>S = exp(R0)</i>,
@@ -121,7 +121,7 @@
 (this should be 1.61, 1.06 and 0.83 respectively)
 <div class="code"><pre>
-r.biodiversity -r in=spec1,spec2,spec3,spec4,spec5 out=renyi alpha=0,1,2
+r.series.diversity -r in=spec1,spec2,spec3,spec4,spec5 out=renyi alpha=0,1,2
 r.info -r map=renyi_Renyi_0_0
 min=1.6094379124341
@@ -140,7 +140,7 @@
 simpson and gini-simpson indices
-r.biodiversity -s -h -p -g in=spec1,spec2,spec3,spec4,spec5 out=biodiversity
+r.series.diversity -s -h -p -g in=spec1,spec2,spec3,spec4,spec5 out=biodiversity
 </pre></div>
 <p>The species richness you get should of course be 5. The shannon
Modified: grass-addons/grass7/raster/r.series.diversity/r.series.diversity.py
--- grass-addons/grass7/raster/r.series.diversity/r.series.diversity.py	2015-12-11 08:20:12 UTC (rev 67061)
+++ grass-addons/grass7/raster/r.series.diversity/r.series.diversity.py	2015-12-11 08:22:28 UTC (rev 67062)
@@ -3,7 +3,7 @@
-# MODULE:       r.biodiversity
+# MODULE:       r.series.diversity
 # AUTHOR(S):    Paulo van Breugel <p.vanbreugel AT gmail.com>
 # PURPOSE:      Compute biodiversity indici over input layers
@@ -18,7 +18,7 @@
 #%Module
-#% description: Compute biodiversity indici over input layers
+#% description: Compute diversity indici over input layers
 #% keyword: raster
 #% keyword: diversity index
 #% keyword: renyi entrophy
