[GRASS-SVN] r67067 - grass/trunk/mswindows/osgeo4w
svn_grass at osgeo.org
Fri Dec 11 14:38:46 PST 2015
Author: martinl
Date: 2015-12-11 14:38:46 -0800 (Fri, 11 Dec 2015)
New Revision: 67067
grass/trunk/mswindows/osgeo4w/package.sh
update package.sh to ming32-w64 toolchain
Modified: grass/trunk/mswindows/osgeo4w/package.sh
--- grass/trunk/mswindows/osgeo4w/package.sh 2015-12-11 21:31:25 UTC (rev 67066)
+++ grass/trunk/mswindows/osgeo4w/package.sh 2015-12-11 22:38:46 UTC (rev 67067)
@@ -1,4 +1,4 @@
-#!sh
+#!/usr/bin/sh
set -e
@@ -17,22 +17,34 @@
fi
fi
-export PACKAGE=${1:-1}
-# package name for osgeo4w
-# eg. 70-dev -> grass70-dev, empty for release
-export PACKAGE_NAME=$2
-# OSGeo4W directory postfix, separate OSGeo4W installations are used
-# for building GRASS 6.x and 7.x
-if test -z "$3" ; then
- OSGEO4W_ROOT_POSTFIX=""
+# package patch number
+# e.g. 'r65400-1' for daily builds, '-1' for release
+if [ -z $PACKAGE_PATCH ]; then
+ PACKAGE_PATCH=1
+fi
+# package name
+# eg. '-daily' -> 'grass-daily', empty for release
+if [ -z $PACKAGE_POSTFIX ]; then
+ PACKAGE_POSTFIX=""
+fi
+# OSGeo4W directory postfix
+# eg. '64' for 64bit, empty for 32bit
+if [ -z $OSGEO4W_POSTFIX ]; then
+ OSGEO4W_POSTFIX=""
+fi
+if [ "$OSGEO4W_POSTFIX" = "64" ]; then
+ MINGW_POSTFIX=64
else
- OSGEO4W_ROOT_POSTFIX="$3"
+ MINGW_POSTFIX=32
fi
-export OSGEO4W_ROOT_MSYS="/c/OSGeo4W${OSGEO4W_ROOT_POSTFIX}"
-export OSGEO4W_ROOT="C:\\\OSGeo4W${OSGEO4W_ROOT_POSTFIX}"
-export PATH=.:/usr/local/bin:/bin:$OSGEO4W_ROOT_MSYS/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Subversion/bin:$PWD/mswindows/osgeo4w
+export OSGEO4W_ROOT_MSYS="/c/OSGeo4W${OSGEO4W_POSTFIX}"
+export OSGEO4W_ROOT="C:\\\OSGeo4W${OSGEO4W_POSTFIX}"
+export PATH=/usr/bin:/mingw${MINGW_POSTFIX}/bin/:$OSGEO4W_ROOT_MSYS/bin:$PWD/mswindows/osgeo4w/lib
T0=$(date +%s)
LT=$T0
CS=""
@@ -44,10 +56,10 @@
if [ -n "$CS" ]; then
local D H M S
- (( S=T-$LT ))
- (( M=S/60 )); (( S=S%60 ))
- (( H=M/60 )); (( M=M%60 ))
- (( D=H/24 )); (( H=H%24 ))
+ S=$(( $T-$LT ))
+ M=$(( S/60 )); S=$(( S%60 ))
+ H=$(( M/60 )); M=$(( M%60 ))
+ D=$(( H/24 )); H=$(( H%24 ))
echo -n "$NOW: FINISHED $CS AFTER "
(( D>0 )) && echo -n "${D}d"
@@ -81,27 +93,54 @@
GRASS_EXECUTABLE=grass${MAJOR}${MINOR}
fi
-export GRASS_PYTHON="$OSGEO4W_ROOT_MSYS/bin/python.exe"
-export PYTHONHOME="$OSGEO4W_ROOT_MSYS/apps/Python27"
if [ -f mswindows/osgeo4w/package.log ]; then
i=0
while [ -f mswindows/osgeo4w/package.log.$i ]; do
- (( i++ ))
+ (( i+=1 ))
done
mv mswindows/osgeo4w/package.log mswindows/osgeo4w/package.log.$i
fi
exec 3>&1 >> mswindows/osgeo4w/package.log 2>&1
+dll_to_a() {
+ # http://sourceforge.net/apps/trac/mingw-w64/wiki/Answer%2064%20bit%20MSVC-generated%20x64%20.lib
+ echo "$1 => $2"
+ gendef - $1 >$2.def
+ if [ "$MINGW_POSTFIX" = "64" ]; then
+ dlltool --as-flags=--64 -m i386:x86-64 -k --output-lib $2.dll.a --input-def $2.def
+ else
+ dlltool -k --output-lib $2.dll.a --input-def $2.def
+ fi
+log dll.to.a
[ -d mswindows/osgeo4w/lib ] || mkdir mswindows/osgeo4w/lib
-cp -uv $OSGEO4W_ROOT_MSYS/lib/sqlite3_i.lib mswindows/osgeo4w/lib/libsqlite3.a
-cp -uv $OSGEO4W_ROOT_MSYS/lib/proj_i.lib mswindows/osgeo4w/lib/libproj.a
-cp -uv $OSGEO4W_ROOT_MSYS/lib/libtiff_i.lib mswindows/osgeo4w/lib/libtiff.a
-cp -uv $OSGEO4W_ROOT_MSYS/lib/libpq.lib mswindows/osgeo4w/lib/libpq.a
-cp -uv $OSGEO4W_ROOT_MSYS/lib/jpeg_i.lib mswindows/osgeo4w/lib/libjpeg.a
-cp -uv $OSGEO4W_ROOT_MSYS/lib/zlib.lib mswindows/osgeo4w/lib/libz.a
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/proj.dll mswindows/osgeo4w/lib/libproj
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/zlib1.dll mswindows/osgeo4w/lib/libz
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/iconv.dll mswindows/osgeo4w/lib/libiconv
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/gdal111.dll mswindows/osgeo4w/lib/libgdal
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/liblas_c.dll mswindows/osgeo4w/lib/liblas_c
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/geos_c.dll mswindows/osgeo4w/lib/libgeos_c
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/libtiff.dll mswindows/osgeo4w/lib/libtiff
+if [ "$MINGW_POSTFIX" = "64" ]; then
+ dll_to_a $OSGEO4W_ROOT_MSYS/bin/libpng16.dll mswindows/osgeo4w/lib/libpng
+ dll_to_a $OSGEO4W_ROOT_MSYS/bin/jpeg.dll mswindows/osgeo4w/lib/libjpeg
+else
+# TODO (related to dependecies)
+# dll_to_a $OSGEO4W_ROOT_MSYS/bin/libpng12-0.dll mswindows/osgeo4w/lib/libpng
+ dll_to_a $OSGEO4W_ROOT_MSYS/bin/jpeg_osgeo.dll mswindows/osgeo4w/lib/libjpeg
+fi
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/libpq.dll mswindows/osgeo4w/lib/libpq
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/sqlite3.dll mswindows/osgeo4w/lib/libsqlite3
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/cairo.dll mswindows/osgeo4w/lib/libcairo
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/libfftw3-3.dll mswindows/osgeo4w/lib/libfftw3
+dll_to_a $OSGEO4W_ROOT_MSYS/bin/pdcurses.dll mswindows/osgeo4w/lib/libpdcurses
+cp -uv $OSGEO4W_ROOT_MSYS/lib/libxdr.a mswindows/osgeo4w/lib
+#cp -uv $OSGEO4W_ROOT_MSYS/lib/libregex.a mswindows/osgeo4w/lib
+cp -uv $OSGEO4W_ROOT_MSYS/lib/libfreetype.dll.a mswindows/osgeo4w/lib
if ! [ -f mswindows/osgeo4w/configure-stamp ]; then
if [ -e include/Make/Platform.make ] ; then
@@ -112,19 +151,25 @@
log remove old logs
rm -f mswindows/osgeo4w/package.log.[0-9][0-9][0-9]
+ conf_host=x86_64-w64-mingw32
+ else
+ conf_host=i386-w64-mingw32
+ fi
log configure
- ./configure \
- --with-libs="$PWD/mswindows/osgeo4w/lib $OSGEO4W_ROOT_MSYS/lib $OSGEO4W_ROOT_MSYS/apps/msys/lib" \
- --with-includes="$OSGEO4W_ROOT_MSYS/include $OSGEO4W_ROOT_MSYS/apps/msys/include" \
- --libexecdir=$OSGEO4W_ROOT_MSYS/bin \
- --prefix=$OSGEO4W_ROOT_MSYS/apps/grass \
- --bindir=$OSGEO4W_ROOT_MSYS/bin \
- --includedir=$OSGEO4W_ROOT_MSYS/include \
- --disable-x --without-x \
+ LDFLAGS="-L$PWD/mswindows/osgeo4w/lib -lz" ./configure \
+ --host=$conf_host \
+ --with-libs="$PWD/mswindows/osgeo4w/lib "\
+ --with-includes=$OSGEO4W_ROOT_MSYS/include \
+ --libexecdir=$OSGEO4W_ROOT_MSYS/bin \
+ --prefix=$OSGEO4W_ROOT_MSYS/apps/grass \
+ --bindir=$OSGEO4W_ROOT_MSYS/bin \
+ --includedir=$OSGEO4W_ROOT_MSYS/include \
+ --without-x \
--with-cxx \
--enable-shared \
--enable-largefile \
- --with-opengl=windows \
--with-fftw \
--with-freetype \
--with-proj-share=$OSGEO4W_ROOT_MSYS/share/proj \
@@ -132,14 +177,13 @@
--with-geos=$PWD/mswindows/osgeo4w/geos-config \
--with-liblas=$PWD/mswindows/osgeo4w/liblas-config \
--with-sqlite \
- --with-curses \
--with-regex \
--with-nls \
--with-freetype-includes=$OSGEO4W_ROOT_MSYS/include/freetype2 \
--with-odbc \
--with-cairo \
- --with-cairo-includes=$OSGEO4W_ROOT_MSYS/include/cairo \
- --with-postgres
+ --with-postgres \
+ --with-opengl=windows
touch mswindows/osgeo4w/configure-stamp
fi
@@ -151,6 +195,9 @@
make install
log cleanup
+rm -f diib*
+log prepare packaging
mv $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h \
$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h.mingw
cp mswindows/osgeo4w/config.h.switch $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h
@@ -161,58 +208,70 @@
sed -e "s#@VERSION@#$VERSION#g" -e "s#@OSGEO4W_ROOT_MSYS@#$OSGEO4W_ROOT#g" \
mswindows/osgeo4w/env.bat.tmpl >$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/env.bat
sed -e "s#@VERSION@#$VERSION#g" -e "s#@GRASS_EXECUTABLE@#$GRASS_EXECUTABLE#g" \
- mswindows/osgeo4w/postinstall.bat >$OSGEO4W_ROOT_MSYS/etc/postinstall/grass${PACKAGE_NAME}.bat
+ mswindows/osgeo4w/postinstall.bat >$OSGEO4W_ROOT_MSYS/etc/postinstall/grass${PACKAGE_POSTFIX}.bat
- mswindows/osgeo4w/preremove.bat >$OSGEO4W_ROOT_MSYS/etc/preremove/grass${PACKAGE_NAME}.bat
+ mswindows/osgeo4w/preremove.bat >$OSGEO4W_ROOT_MSYS/etc/preremove/grass${PACKAGE_POSTFIX}.bat
-if [ -n "$PACKAGE" ]; then
+if [ -n "$PACKAGE_PATCH" ]; then
log building vc libraries
sh mswindows/osgeo4w/mklibs.sh $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib/*.$VERSION.dll
mv mswindows/osgeo4w/vc/grass*.lib $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib
- # rm $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib/*.dll
- # log BUILDING GDAL GRASS plugins
- # $COMSPEC /c "mswindows\\osgeo4w\\gdalplugins.cmd $VERSION"
- log CREATING PACKAGES
+ log creating package
mkdir -p mswindows/osgeo4w/package
PDIR=$PWD/mswindows/osgeo4w/package
SRC=$PWD
cd $OSGEO4W_ROOT_MSYS
+ # update startup script
sed -e "s#@VERSION@#$VERSION#g" -e "s#@POSTFIX@#$MAJOR$MINOR#g" \
- $SRC/mswindows/osgeo4w/grass.bat.tmpl >$OSGEO4W_ROOT_MSYS/bin/${GRASS_EXECUTABLE}.bat.tmpl
+ $SRC/mswindows/osgeo4w/grass.bat.tmpl > bin/${GRASS_EXECUTABLE}.bat.tmpl
# bat files - unix2dos
unix2dos bin/${GRASS_EXECUTABLE}.bat.tmpl
- unix2dos etc/postinstall/grass${PACKAGE_NAME}.bat
- unix2dos etc/preremove/grass${PACKAGE_NAME}.bat
+ unix2dos etc/postinstall/grass${PACKAGE_POSTFIX}.bat
+ unix2dos etc/preremove/grass${PACKAGE_POSTFIX}.bat
- # grass package
- tar -cjf $PDIR/grass$PACKAGE_NAME-$VERSION-$PACKAGE.tar.bz2 \
+ # copy dependecies (TODO: to be reduced)
+ mingw_libgcc=libgcc_s_seh-1.dll
+ else
+ mingw_libgcc=libgcc_s_dw2-1.dll
+ fi
+ cp -uv /mingw${MINGW_POSTFIX}/bin/libintl-8.dll \
+ /mingw${MINGW_POSTFIX}/bin/libiconv-2.dll \
+ /mingw${MINGW_POSTFIX}/bin/libfontconfig-1.dll \
+ /mingw${MINGW_POSTFIX}/bin/$mingw_libgcc \
+ /mingw${MINGW_POSTFIX}/bin/libwinpthread-1.dll \
+ /mingw${MINGW_POSTFIX}/bin/libexpat-1.dll \
+ /mingw${MINGW_POSTFIX}/bin/libfreetype-6.dll \
+ /mingw${MINGW_POSTFIX}/bin/libbz2-1.dll \
+ /mingw${MINGW_POSTFIX}/bin/libharfbuzz-0.dll \
+ /mingw${MINGW_POSTFIX}/bin/libglib-2.0-0.dll \
+ /mingw${MINGW_POSTFIX}/bin/libpng16-16.dll \
+ bin
+ # creating grass package
+ tar -cjf $PDIR/grass$PACKAGE_POSTFIX-$VERSION-$PACKAGE_PATCH.tar.bz2 \
apps/grass/grass-$VERSION \
bin/${GRASS_EXECUTABLE}.bat.tmpl \
- etc/postinstall/grass${PACKAGE_NAME}.bat \
- etc/preremove/grass${PACKAGE_NAME}.bat
+ etc/postinstall/grass${PACKAGE_POSTFIX}.bat \
+ etc/preremove/grass${PACKAGE_POSTFIX}.bat \
+ bin/libintl-8.dll \
+ bin/libiconv-2.dll \
+ bin/libfontconfig-1.dll \
+ bin/$mingw_libgcc \
+ bin/libwinpthread-1.dll \
+ bin/libexpat-1.dll \
+ bin/libfreetype-6.dll \
+ bin/libbz2-1.dll \
+ bin/libharfbuzz-0.dll \
+ bin/libglib-2.0-0.dll \
+ bin/libpng16-16.dll \
+ # clean up
rm bin/${GRASS_EXECUTABLE}.bat.tmpl
- # grass-devel package (obsolete)
- ###tar -cjf $PDIR/grass-devel-$VERSION-$PACKAGE.tar.bz2 \
- ###apps/grass/grass-$VERSION/include
- # grass-devel-mingw package (obsolete)
- ###tar -cjf $PDIR/grass-devel-mingw-$VERSION-$PACKAGE.tar.bz2 \
- ###apps/grass/grass-$VERSION/lib/*.a
- # grass-devel-vc package (obsolete)
- ###tar -cjf $PDIR/grass-devel-vc-$VERSION-$PACKAGE.tar.bz2 \
- ###apps/grass/grass-$VERSION/lib/*.lib
- # grass-locale package (obsolete)
- ###tar -cjf $PDIR/grass-locale-$VERSION-$PACKAGE.tar.bz2 \
- ###apps/grass/grass-$VERSION/locale
fi
log
