[GRASS-SVN] r67113 - in grass-addons/grass7/raster: . r.vector.ruggedness
svn_grass at osgeo.org
Sun Dec 13 22:39:27 PST 2015
Author: spawley
Date: 2015-12-13 22:39:27 -0800 (Sun, 13 Dec 2015)
New Revision: 67113
Added:
grass-addons/grass7/raster/r.vector.ruggedness/
grass-addons/grass7/raster/r.vector.ruggedness/Makefile
grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.html
grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.py
First comit of new module r.vector.ruggedness
Added: grass-addons/grass7/raster/r.vector.ruggedness/Makefile
--- grass-addons/grass7/raster/r.vector.ruggedness/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.vector.ruggedness/Makefile 2015-12-14 06:39:27 UTC (rev 67113)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.vector.ruggedness
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.vector.ruggedness/Makefile
___________________________________________________________________
Added: svn:eol-style
+ native
Added: grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.html
--- grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.html (rev 0)
+++ grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.html 2015-12-14 06:39:27 UTC (rev 67113)
@@ -0,0 +1,30 @@
+<h2>DESCRIPTION</h2>
+<em><b>r.vector.ruggedness</b></em> represents a measurement of terrain
+ruggedness based on the methodology conceived by Sappington et al.
+(2007). The measure is calculated by decomposing slope and aspect into
+3-dimensional vectors, and calculating the resultant vector magnitude
+within a user-specified moving window size, using <i>r.neighbors</i>.
+The user can specify neighborhood size to measure ruggedness across
+larger landscale scales. Neighborhood operations are performed using a
+rectangular window shape.
+<h2>NOTES</h2>
+<p>This script was adapted from the original Sappington et al. (2007)
+script.
+<h2>EXAMPLE</h2>
+r.vector.ruggedness elevation=srtm wsize=5 output=vrm
+<h2>REFERENCES</h2>
+Sappington, J.M., K.M. Longshore, and D.B. Thomson. 2007. Quantifying
+Landscape Ruggedness for Animal Habitat Analysis: A case Study Using
+Bighorn Sheep in the Mojave Desert. Journal of Wildlife Management.
+71(5): 1419 -1426.
+<h2>AUTHOR</h2>
+Steven Pawley <br><i>Last changed: Sunday 13 December 2015</i>
\ No newline at end of file
Property changes on: grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.html
+ native
Added: grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.py
--- grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.py (rev 0)
+++ grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.py 2015-12-14 06:39:27 UTC (rev 67113)
@@ -0,0 +1,130 @@
+#!/usr/bin/env python
+# MODULE: Vector Ruggedness Measure
+# AUTHOR(S): Adaption of original Sappington et al. (2007) script
+# by Steven Pawley
+# PURPOSE: This tool measures terrain ruggedness by calculating the vector
+# ruggedness measure described in Sappington, J.M., K.M. Longshore,
+# and D.B. Thomson. 2007. Quantifiying Landscape Ruggedness for
+# Animal Habitat Anaysis: A case Study Using Bighorn Sheep in
+# the Mojave Desert.
+# Journal of Wildlife Management. 71(5): 1419 -1426.
+# COPYRIGHT: (C) 2015 Steven Pawley, and by the GRASS Development Team
+# DATE: 21 April 2015
+#%module
+#% description: Vector Ruggedness Measure
+#%end
+import grass.script as grass
+import random
+import string
+import atexit
+#%option G_OPT_R_INPUTS
+#% key: elevation
+#% label: DEM Raster Input
+#%end
+#%option
+#% key: size
+#% type: integer
+#% description: Size of neighbourhood
+#% answer: 3
+#% guisection: Required
+#%end
+#%option G_OPT_R_OUTPUTS
+#% key: output
+#% label: Vector Ruggedness Index Output
+#%end
+tmp_rast = []
+def cleanup():
+ for rast in tmp_rast:
+ grass.run_command("g.remove", name = rast, type = 'raster', flags = 'fb', quiet = True)
+def main():
+ # User specified variables
+ dem = options['elevation']
+ neighborhood_size = options['size']
+ OutRaster = options['output']
+ # Internal raster map names
+ SlopeRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ AspectRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ xyRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ zRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ xRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ yRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ xSumRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ ySumRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ zSumRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ ResultRaster = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in xrange(8)])
+ tmp_rast.append(SlopeRaster)
+ tmp_rast.append(AspectRaster)
+ tmp_rast.append(xyRaster)
+ tmp_rast.append(zRaster)
+ tmp_rast.append(xRaster)
+ tmp_rast.append(yRaster)
+ tmp_rast.append(xSumRaster)
+ tmp_rast.append(ySumRaster)
+ tmp_rast.append(zSumRaster)
+ tmp_rast.append(ResultRaster)
+ # Create Slope and Aspect rasters
+ grass.message("Calculating slope and aspect...")
+ grass.run_command("r.slope.aspect",
+ elevation = dem,
+ slope = SlopeRaster,
+ aspect = AspectRaster,
+ format = "degrees",
+ precision = "FCELL",
+ zscale = 1.0,
+ min_slope = 0.0,
+ quiet = True)
+ # Calculate x y and z rasters
+ # Note - GRASS sin/cos functions differ from ArcGIS which expects input grid in radians, whereas GRASS functions expect degrees
+ # No need to convert slope and aspect to radians as in the original ArcGIS script
+ grass.message("Calculating x, y, and z rasters...")
+ grass.mapcalc('{x} = sin({a})'.format(x=xyRaster, a=SlopeRaster))
+ grass.mapcalc('{x} = cos({a})'.format(x=zRaster, a=SlopeRaster))
+ grass.mapcalc('{x} = sin({a}) * {b}'.format(x=xRaster, a=AspectRaster, b=xyRaster))
+ grass.mapcalc('{x} = cos({a}) * {b}'.format(x=yRaster, a=AspectRaster, b=xyRaster))
+ # Calculate sums of x, y, and z rasters for selected neighborhood size
+ grass.message("Calculating sums of x, y, and z rasters in selected neighborhood...")
+ grass.run_command("r.neighbors", input = xRaster, output = xSumRaster, method = "average", size = neighborhood_size)
+ grass.run_command("r.neighbors", input = yRaster, output = ySumRaster, method = "average", size = neighborhood_size)
+ grass.run_command("r.neighbors", input = zRaster, output = zSumRaster, method = "average", size = neighborhood_size)
+ # Calculate the resultant vector
+ # Modified from the original script to multiple each SumRaster by the n neighborhood cells to get the sum
+ grass.message("Calculating the resultant vector...")
+ maxValue = int(neighborhood_size) * int(neighborhood_size)
+ grass.mapcalc('{x} = sqrt(({a}*{d})^2 + ({b}*{d})^2 + ({c}*{d})^2)'.format(x=ResultRaster, a=xSumRaster, b=ySumRaster, c=zSumRaster, d=maxValue))
+ # Calculate the Ruggedness raster
+ grass.message("Calculating the final ruggedness raster...")
+ grass.mapcalc('{x} = 1-({a} / {b})'.format(x=OutRaster, a=ResultRaster, b=maxValue))
+ # Set the default color table
+ grass.run_command("r.colors", flags = 'e', map = OutRaster, color = "ryb")
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/raster/r.vector.ruggedness/r.vector.ruggedness.py
Added: svn:executable
+ native
