[GRASS-SVN] r67121 - grass/branches/releasebranch_7_0/vector/v.net.distance
svn_grass at osgeo.org
Mon Dec 14 04:56:17 PST 2015
Author: neteler
Date: 2015-12-14 04:56:17 -0800 (Mon, 14 Dec 2015)
New Revision: 67121
grass/branches/releasebranch_7_0/vector/v.net.distance/v.net.distance.html
v.net.distance manual: remove OS specific paths; break long lines (trunk, r67120)
Modified: grass/branches/releasebranch_7_0/vector/v.net.distance/v.net.distance.html
--- grass/branches/releasebranch_7_0/vector/v.net.distance/v.net.distance.html 2015-12-14 12:50:56 UTC (rev 67120)
+++ grass/branches/releasebranch_7_0/vector/v.net.distance/v.net.distance.html 2015-12-14 12:56:17 UTC (rev 67121)
@@ -51,16 +51,18 @@
<p><div class="code"><pre>
# connect schools to streets as layer 2
-v.net input=streets_wake points=schools_wake output=streets_net1 operation=connect thresh=400 arc_layer=1 node_layer=2
+v.net input=streets_wake points=schools_wake output=streets_net1 \
+ operation=connect thresh=400 arc_layer=1 node_layer=2
# connect hospitals to streets as layer 3
-v.net input=streets_net1 points=hospitals output=streets_net2 operation=connect thresh=400 arc_layer=1 node_layer=3
+v.net input=streets_net1 points=hospitals output=streets_net2 \
+ operation=connect thresh=400 arc_layer=1 node_layer=3
# inspect the result
v.category in=streets_net2 op=report
# shortest paths from schools (points in layer 2) to nearest hospitals (points in layer 3)
-v.net.distance in=streets_net2 out=schools_to_hospitals flayer=2 tlayer=3
+v.net.distance in=streets_net2 out=schools_to_hospitals flayer=2 turn_layer=3
</pre></div>
<h3>Distance between point source of pollution and sample points along streams</h3>
@@ -72,7 +74,7 @@
pollution.txt:
634731.563206905|216390.501834892
-v.in.ascii input=C:\data\pollution.txt output=pollution
+v.in.ascii input=pollution.txt output=pollution
# add table to vector
v.db.addtable map=pollution
@@ -83,14 +85,17 @@
634893.462007813|216273.763350851
634918.660011082|216254.949609689
-v.in.ascii input=C:\data\samples.txt output=samples
+v.in.ascii input=samples.txt output=samples
v.db.addtable map=samples
# connect samples and pollution to streams
-v.net -c input=streams points=samples output=streams_samples operation=connect node_layer=3 threshold=10
-v.net -c input=streams_samples points=pollution output=streams_samples_pollution operation=connect node_layer=4 threshold=10
+v.net -c input=streams points=samples output=streams_samples \
+ operation=connect node_layer=3 threshold=10 \
+v.net -c input=streams_samples points=pollution
+ output=streams_samples_pollution operation=connect \
+ node_layer=4 threshold=10
# check vector layers
v.category input=streams_samples_pollution option=report
@@ -126,7 +131,8 @@
all 1 1 1
# calculate distance between sample points and pollution point source
-v.net.distance input=streams_samples_pollution output=distance_samples_to_pollution from_layer=3 to_layer=4
+v.net.distance input=streams_samples_pollution \
+ output=distance_samples_to_pollution from_layer=3 to_layer=4
# check results
v.report map=distance_samples_to_pollution at vnettest option=length
@@ -136,7 +142,6 @@
3|1|231.446|231.446
</pre></div>
-<p>
<h2>SEE ALSO</h2>
<em>
