[GRASS-SVN] r67126 - grass/trunk/mswindows/osgeo4w
svn_grass at osgeo.org
Mon Dec 14 12:44:17 PST 2015
Author: martinl
Date: 2015-12-14 12:44:17 -0800 (Mon, 14 Dec 2015)
New Revision: 67126
Removed:
grass/trunk/mswindows/osgeo4w/msys.bat
osgeo4w: remove unsed file
Deleted: grass/trunk/mswindows/osgeo4w/msys.bat
--- grass/trunk/mswindows/osgeo4w/msys.bat 2015-12-14 20:40:33 UTC (rev 67125)
+++ grass/trunk/mswindows/osgeo4w/msys.bat 2015-12-14 20:44:17 UTC (rev 67126)
@@ -1,207 +0,0 @@
- at echo off
-rem Copyright (C): 2001, 2002, 2003, 2004, 2005 Earnie Boyd
-rem mailto:earnie at users.sf.net
-rem This file is part of Minimal SYStem
-rem http://www.mingw.org/msys.shtml
-rem
-rem File: msys.bat
-rem Revision: 2.4
-rem Revision Date: December 8th, 2005
-rem --- MODIFIED FOR GRASS Aug 2009: Quote path name variables ---
-rem ember to set the "Start in:" field of the shortcut.
-rem A value similar to C:\msys\1.0\bin is what the "Start in:" field needs
-rem to represent.
-rem ember value of GOTO: is used to know recursion has happened.
-if "%1" == "GOTO:" goto %2
-if NOT "x%WD%" == "x" set WD=
-rem ember command.com only uses the first eight characters of the label.
-goto _WindowsNT
-rem ember that we only execute here if we are in command.com.
-:_Windows
-if "x%COMSPEC%" == "x" set COMSPEC=command.com
-start /min "%COMSPEC%" /e:4096 /c %0 GOTO: _Resume %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
-goto EOF
-rem ember that we execute here if we recursed.
-:_Resume
-for %%F in (1 2 3) do shift
-if NOT EXIST "%WD%msys-1.0.dll" set WD=.\bin\
-rem ember that we get here even in command.com.
-:_WindowsNT
-rem Hopefully a temporary workaround for getting MSYS shell to run on x64
-rem (WoW64 cmd prompt sets PROCESSOR_ARCHITECTURE to x86)
-if not "x%PROCESSOR_ARCHITECTURE%" == "xAMD64" goto _NotX64
-set COMSPEC=%WINDIR%\SysWOW64\cmd.exe
-"%COMSPEC%" /c %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
-goto EOF
-:_NotX64
-if NOT EXIST "%WD%msys-1.0.dll" set WD=%~dps0bin\
-rem echo %WD%
-rem ember Set up option to use rxvt based on value of %1
-set MSYSCON=unknown
-if "x%1" == "x-norxvt" set MSYSCON=sh.exe
-if "x%1" == "x--norxvt" set MSYSCON=sh.exe
-if "x%1" == "x-rxvt" set MSYSCON=rxvt.exe
-if "x%1" == "x--rxvt" set MSYSCON=rxvt.exe
-if "x%1" == "x-mintty" set MSYSCON=mintty.exe
-if "x%1" == "x--mintty" set MSYSCON=mintty.exe
-if NOT "x%MSYSCON%" == "xunknown" shift
-if "x%MSYSCON%" == "xunknown" set MSYSCON=sh.exe
-rem the default is a MSYS (user), not a MINGW (developer) console
-if "x%MSYSTEM%" == "x" set MSYSTEM=MSYS
-if "%1" == "MINGW32" set MSYSTEM=MINGW32
-if "%1" == "MSYS" set MSYSTEM=MSYS
-if NOT "x%DISPLAY%" == "x" set DISPLAY=
-if "x%MSYSCON%" == "xmintty.exe" goto startmintty
-if "x%MSYSCON%" == "xrxvt.exe" goto startrxvt
-if "x%MSYSCON%" == "xsh.exe" goto startsh
-:unknowncon
-echo %MSYSCON% is an unknown option for msys.bat.
-pause
-exit 1
-:notfound
-echo Cannot find the rxvt.exe or sh.exe binary -- aborting.
-pause
-exit 1
-:startmintty
-if NOT EXIST "%WD%mintty.exe" goto startsh
-start "%WD%mintty" /bin/bash -l
-exit
-rem If you don't want to use rxvt then rename the file rxvt.exe to something
-rem else. Then sh.exe will be used instead.
-:startrxvt
-if NOT EXIST "%WD%rxvt.exe" goto startsh
-rem Setup the default colors for rxvt.
-if "x%MSYSBGCOLOR%" == "x" set MSYSBGCOLOR=White
-if "x%MSYSFGCOLOR%" == "x" set MSYSFGCOLOR=Black
-if "x%MINGW32BGCOLOR%" == "x" set MINGW32BGCOLOR=Black
-if "x%MINGW32FGCOLOR%" == "x" set MINGW32FGCOLOR=White
-if "%MSYSTEM%" == "MSYS" set BGCOLOR=%MSYSBGCOLOR%
-if "%MSYSTEM%" == "MSYS" set FGCOLOR=%MSYSFGCOLOR%
-if "%MSYSTEM%" == "MINGW32" set BGCOLOR=%MINGW32BGCOLOR%
-if "%MSYSTEM%" == "MINGW32" set FGCOLOR=%MINGW32FGCOLOR%
-if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
-exit
-:startsh
-if NOT EXIST "%WD%sh.exe" goto notfound
-if "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -c "%*"
-exit
-:EOF
-rem ChangeLog:
-rem 2002.03.07 Earnie Boyd mailto:earnie at users.sf.net
-rem * Move the @echo off to the top.
-rem * Change the binmode setting to nobinmode.
-rem * Remove the angle brackets around email address to workaround MS
-rem buggy command processor.
-rem
-rem 2002.03.12 Earnie Boyd mailto:earnie at users.sf.net
-rem * Add filter logic to find rxvt.exe
-rem
-rem 2002.03.13 Earnie Boyd mailto:earnie at users.sf.net
-rem * Revert the nobinmode change.
-rem
-rem 2002.03.20 Earnie Boyd mailto:earnie at users.sf.net
-rem * Add logic for stating bash.
-rem
-rem 2002.04.11 Earnie Boyd mailto;earnie at users.sf.net
-rem * Add logic for setting MSYSTEM value based on parameter.
-rem
-rem 2002.04.15 Olivier Gautherot mailto:olivier_gautherot at mentorg.com
-rem * Reduce number test conditions for finding an executable.
-rem
-rem 2002.04.15 Earnie Boyd mailto:earnie at users.sf.net
-rem * Unset DISPLAY if set before starting shell.
-rem
-rem 2002.04.16 Earnie Boyd mailto:earnie at users.sf.net
-rem * Remove use of DEFINED in conditional statments for variables for
-rem command.com support.
-rem * Add check for nonexistance of USERNAME variable for Win9x support.
-rem
-rem 2002.04.17 Earnie Boyd mailto:earnie at users.sf.net
-rem * Add foreground and background color defaults based on MSYSTEM value.
-rem
-rem 2002.04.22 Earnie Boyd mailto:earnie at users.sf.net
-rem * More Win 9x changes.
-rem
-rem 2002.05.04 Earnie Boyd mailto:earnie at users.sf.net
-rem * Remove the SET of USERNAME and HOME.
-rem
-rem 2002.11.18 Earnie Boyd mailto:earnie at users.sf.net
-rem * Add command.com detection and restart with a larger environment to
-rem avoid errors on w9x.
-rem Many thanks to Randy W. Sims mailto:RandyS at ThePierianSpring.org.
-rem See Randy's response to "RE: [Mingw-msys] Installation on WindowsME"
-rem from 11/06/2002 in the archives of mingw-msys at lists.sf.net.
-rem
-rem 2002.11.19 Paul Garceau mailto:pgarceau at attbi.com
-rem * Fix a typo: Change COMPSPEC to COMSPEC.
-rem
-rem 2002.11.25 Earnie Boyd mailto:earnie at users.sf.net
-rem * Remove the SET CYGWIN since it doesn't matter any longer.
-rem
-rem 2003.02.03 Earnie Boyd mailto:earnie at users.sf.net
-rem * Win9x doesn't like ``EXISTS dir'' so change it to ``EXISTS dir\nul''.
-rem Thanks to Nicolas Weber mailto:nicolasweber at gmx.de.
-rem
-rem 2003.03.06 Earnie Boyd mailto:earnie at users.sf.net
-rem * Add -backspacekey switch to rxvt startup.
-rem * Move RXVT color setup to startrxvt label
-rem
-rem 2004.01.30 Earnie Boyd mailto:earnie at users.sf.net
-rem * Add -geometry parameter to work around an off by one issue with
-rem the default values.
-rem Thanks to Dave Schuyler mailto:parameter at users.sf.net
-rem
-rem 2004.03.28 Earnie Boyd mailto:earnie at users.sf.net
-rem * Add -norxvt or --norxvt switch argument.
-rem Thanks to Keith Marshall mailto:Keith.Marshall at total.com.
-rem * Add method to determine absolute path of msys.bat so that we no
-rem longer need to change to the bin directory. This allows msys.bat to be
-rem called from any working directory.
-rem Thanks to Kevin Mack mailto:kevin.mack at us.cd-adapco.com
-rem
-rem 2005.07.06 Max TE Woodbury mailto:mtew at users.sf.net
-rem * Fixed WD check for command.com systems.
-rem * Minimized intermediate CMD window to reduce startup flashyness.
-rem * If rxvt.exe cannot be found, try sh.exe.
-rem
-rem 2005.12.06 Tuomo Latto mailto:nonperson at users.sf.net
-rem * Added a temporary workaround for getting MSYS shell to run on x64.
-rem
-rem 2005.12.07 Keith Marshall mailto:keithmarshall at users.sf.net
-rem * ``EXISTS %WD%\sh.exe'' should be ``EXISTS %WD%sh.exe''; corrected.
-rem * Modified Tuomo's patch, to avoid trashing Window settings in Win32.
-rem
-rem 2005.12.08 Tuomo Latto mailto:nonperson at users.sf.net
-rem * Keith's modified patch fails on x64; start did funny things.
-rem Reworked, for correct behaviour on both platforms.
-rem
-rem 2009.03.17 Keith Marshall mailto:keithmarshall at users.sf.net
-rem * Add -rxvt or --rxvt switch; start in --norxvt mode by default.
-rem Make it deterministic; (do not inherit MSYSCON from parent).
-rem
