[GRASS-SVN] r67159 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Tue Dec 15 14:03:52 PST 2015
Author: wenzeslaus
Date: 2015-12-15 14:03:52 -0800 (Tue, 15 Dec 2015)
New Revision: 67159
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: add RGB import as categories
Adds also a missing number of returns needed for first/mid/last indentification.
Gives a message when layer number for table is automatically determined.
RGB values can be stored separately or in one category.
This is in sync with v.out.lidar r66855.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-12-15 20:36:36 UTC (rev 67158)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-12-15 22:03:52 UTC (rev 67159)
@@ -110,7 +110,10 @@
float xmin = 0., ymin = 0., xmax = 0., ymax = 0.;
struct GModule *module;
struct Option *in_opt, *out_opt, *spat_opt, *filter_opt, *class_opt;
- struct Option *id_layer_opt, *return_layer_opt, *class_layer_opt;
+ struct Option *id_layer_opt, *return_layer_opt, *n_returns_layer_opt;
+ struct Option *class_layer_opt;
+ struct Option *red_layer_opt, *green_layer_opt, *blue_layer_opt;
+ struct Option *rgb_layer_opt;
struct Option *vector_mask_opt, *vector_mask_field_opt;
struct Option *skip_opt, *preserve_opt, *offset_opt, *limit_opt;
struct Option *outloc_opt, *zrange_opt;
@@ -187,16 +190,53 @@
return_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
return_layer_opt->key = "return_layer";
- return_layer_opt->label = _("Layer number to store return number as category");
+ return_layer_opt->label =
+ _("Layer number to store return number as category");
return_layer_opt->answer = NULL;
return_layer_opt->guisection = _("Categories");
+ n_returns_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ n_returns_layer_opt->key = "n_returns_layer";
+ n_returns_layer_opt->label =
+ _("Layer number to store number of returns as category");
+ n_returns_layer_opt->answer = NULL;
+ n_returns_layer_opt->guisection = _("Categories");
class_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
class_layer_opt->key = "class_layer";
- class_layer_opt->label = _("Layer number to store class number as category");
+ class_layer_opt->label =
+ _("Layer number to store class number as category");
class_layer_opt->answer = NULL;
class_layer_opt->guisection = _("Categories");
+ rgb_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ rgb_layer_opt->key = "rgb_layer";
+ rgb_layer_opt->label =
+ _("Layer number where RBG colors is stored as category");
+ rgb_layer_opt->answer = NULL;
+ rgb_layer_opt->guisection = _("Categories");
+ red_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ red_layer_opt->key = "red_layer";
+ red_layer_opt->label =
+ _("Layer number where red color is stored as category");
+ red_layer_opt->answer = NULL;
+ red_layer_opt->guisection = _("Categories");
+ green_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ green_layer_opt->key = "green_layer";
+ green_layer_opt->label =
+ green_layer_opt->answer = NULL;
+ green_layer_opt->guisection = _("Categories");
+ blue_layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ blue_layer_opt->key = "blue_layer";
+ blue_layer_opt->label =
+ _("Layer number where blue color is stored as category");
+ blue_layer_opt->answer = NULL;
+ blue_layer_opt->guisection = _("Categories");
spat_opt = G_define_option();
spat_opt->key = "spatial";
spat_opt->type = TYPE_DOUBLE;
@@ -342,7 +382,9 @@
no_import_flag->suppress_required = YES;
G_option_exclusive(skip_opt, preserve_opt, NULL);
- G_option_excludes(nocats_flag, id_layer_opt, return_layer_opt, class_layer_opt, NULL);
+ G_option_excludes(nocats_flag, id_layer_opt, return_layer_opt,
+ n_returns_layer_opt, class_layer_opt, rgb_layer_opt,
+ red_layer_opt, green_layer_opt, blue_layer_opt, NULL);
/* The parser checks if the map already exists in current mapset, this is
* wrong if location options is used, so we switch out the check and do it
@@ -410,13 +452,28 @@
int id_layer = 0;
int return_layer = 0;
+ int n_returns_layer = 0;
int class_layer = 0;
+ int rgb_layer = 0;
+ int red_layer = 0;
+ int green_layer = 0;
+ int blue_layer = 0;
if (id_layer_opt->answer)
id_layer = atoi(id_layer_opt->answer);
if (return_layer_opt->answer)
return_layer = atoi(return_layer_opt->answer);
+ if (n_returns_layer_opt->answer)
+ n_returns_layer = atoi(n_returns_layer_opt->answer);
if (class_layer_opt->answer)
class_layer = atoi(class_layer_opt->answer);
+ if (rgb_layer_opt->answer)
+ rgb_layer = atoi(rgb_layer_opt->answer);
+ if (red_layer_opt->answer)
+ red_layer = atoi(red_layer_opt->answer);
+ if (green_layer_opt->answer)
+ green_layer = atoi(green_layer_opt->answer);
+ if (blue_layer_opt->answer)
+ blue_layer = atoi(blue_layer_opt->answer);
/* If no layer specified by user, force 1 to be used for ids.
* If id_layer not specified by the attributes table was, find a layer.
* nocats implies notab and we don't add any layers.
@@ -426,16 +483,31 @@
* are about to turn on.
* Later on, layer set to 0 is considered as no layer set.
- if (!nocats_flag->answer && !id_layer_opt->answer && !return_layer && !class_layer) {
+ if (!nocats_flag->answer && !id_layer_opt->answer && !return_layer
+ && !n_returns_layer && !class_layer && !rgb_layer && !red_layer
+ && !green_layer && !blue_layer) {
id_layer = 1;
+ G_message(_("Storing generated point IDs as categories in the layer %d"), id_layer);
+ /* no cats forces no table earlier */
if (!notab_flag->answer && !id_layer) {
+ /* get the maximum layer number used */
+ int max_used_layer;
+ max_used_layer = MAX(return_layer, n_returns_layer);
+ max_used_layer = MAX(max_used_layer, class_layer);
+ max_used_layer = MAX(max_used_layer, rgb_layer);
+ max_used_layer = MAX(max_used_layer, red_layer);
+ max_used_layer = MAX(max_used_layer, green_layer);
+ max_used_layer = MAX(max_used_layer, blue_layer);
/* get the first free layer number */
- for (i = 1; i <= MAX(return_layer, class_layer) + 1; i++) {
- if (i != return_layer && i != class_layer)
+ for (i = 1; i <= max_used_layer + 1; i++) {
+ if (i != return_layer && i != n_returns_layer
+ && i != class_layer && i != rgb_layer
+ && i != red_layer && i != green_layer && i != blue_layer)
break;
id_layer = i;
double zrange_min, zrange_max;
@@ -969,8 +1041,30 @@
Vect_cat_set(Cats, id_layer, cat);
if (return_layer)
Vect_cat_set(Cats, return_layer, LASPoint_GetReturnNumber(LAS_point));
+ if (n_returns_layer)
+ Vect_cat_set(Cats, n_returns_layer, LASPoint_GetNumberOfReturns(LAS_point));
if (class_layer)
Vect_cat_set(Cats, class_layer, LASPoint_GetClassification(LAS_point));
+ if (have_color && (rgb_layer || red_layer || green_layer || blue_layer)) {
+ /* TODO: if attr table, acquired again, performance difference? */
+ /* TODO: the getters are called too when separate layers are used */
+ LASColorH LAS_color = LASPoint_GetColor(LAS_point);
+ if (rgb_layer) {
+ int red = LASColor_GetRed(LAS_color);
+ int green = LASColor_GetGreen(LAS_color);
+ int blue = LASColor_GetBlue(LAS_color);
+ int rgb = red;
+ rgb = (rgb << 8) + green;
+ rgb = (rgb << 8) + blue;
+ Vect_cat_set(Cats, rgb_layer, rgb);
+ if (red_layer)
+ Vect_cat_set(Cats, red_layer, LASColor_GetRed(LAS_color));
+ if (green_layer)
+ Vect_cat_set(Cats, green_layer, LASColor_GetGreen(LAS_color));
+ if (blue_layer)
+ Vect_cat_set(Cats, blue_layer, LASColor_GetBlue(LAS_color));
Vect_write_line(&Map, GV_POINT, Points, Cats);
/* Attributes */
