[GRASS-SVN] r67164 - grass-addons/grass7/raster/r.bioclim
Wed Dec 16 01:34:18 PST 2015
Author: mmetz
Date: 2015-12-16 01:34:18 -0800 (Wed, 16 Dec 2015)
New Revision: 67164
   grass-addons/grass7/raster/r.bioclim/r.bioclim.html
   grass-addons/grass7/raster/r.bioclim/r.bioclim.py
r.bioclim: +user-defined output separator
Modified: grass-addons/grass7/raster/r.bioclim/r.bioclim.html
--- grass-addons/grass7/raster/r.bioclim/r.bioclim.html	2015-12-16 09:23:13 UTC (rev 67163)
+++ grass-addons/grass7/raster/r.bioclim/r.bioclim.html	2015-12-16 09:34:18 UTC (rev 67164)
@@ -3,10 +3,12 @@
 <em><b>r.bioclim</b></em> calculates various bioclimatic indices from
 monthly temperature and optional precipitation time series. The time
 series can be averages for several years or monthly values for a
-specific year. In any case all 12 months must be provided. It a precipitation
-time series is not provided, only those indices based on temperature
-are calculated. The names of the output maps are <output>.bio01, <output>.bio02,
-<output>.bio03, etc.
+specific year. In any case all 12 months must be provided. It a
+precipitation time series is not provided, only those indices based on
+temperature are calculated. The names of the output maps are
+<output>bio01, <output>bio02, <output>bio03, etc. If
+the suffix bioXY needs to be separated from the <b>output</b> prefix,
+that separator must be part of the prefix, e.g. <i>output=eurolst_</i>.
 <p>
 If the input temperatures are scaled, e.g. as input = Celsius * 10, then
 the <b>inscale</b> option must be set to 10. Similarly, the <b>outscale</b>
@@ -65,7 +67,7 @@
 r.bioclim tmin=`g.list type=rast pat=tmin_* map=. sep=,` \
           tmax=`g.list type=rast pat=tmax_* map=. sep=,` \
           prec=`g.list type=rast pat=prec_* map=. sep=,` \
-          out=worldclim workers=4
+          out=worldclim_ workers=4
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass-addons/grass7/raster/r.bioclim/r.bioclim.py
--- grass-addons/grass7/raster/r.bioclim/r.bioclim.py	2015-12-16 09:23:13 UTC (rev 67163)
+++ grass-addons/grass7/raster/r.bioclim/r.bioclim.py	2015-12-16 09:34:18 UTC (rev 67164)
@@ -165,14 +165,14 @@
     # BIO1 = Annual Mean Temperature
     grass.message(_("BIO1 = Annual Mean Temperature ..."))
-    output = outpre + '.bio01.' + str(pid)
+    output = outpre + 'bio01.' + str(pid)
     grass.run_command('r.series', input = tavg, output = output, method = 'average')
     grass.mapcalc("$bio = round(double($oscale) * $input / $iscale)",
-                  bio = outpre + '.bio01',
+                  bio = outpre + 'bio01',
                   oscale = toutscale, input = output, iscale = tinscale)
-    grass.run_command('r.support', map = outpre + '.bio01',
+    grass.run_command('r.support', map = outpre + 'bio01',
                       description = 'BIOCLIM01: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio01',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio01',history = os.environ['CMDLINE'])
     grass.run_command('g.remove', flags = 'f', type = 'raster', name = output, quiet = True);
     # BIO2 = Mean Diurnal Range (Mean of monthly (max temp - min temp))
@@ -205,80 +205,80 @@
     tr = tr.strip('\n')
-    output = outpre + '.bio02.' + str(pid)
+    output = outpre + 'bio02.' + str(pid)
     grass.run_command('r.series', input = tr, output = output, method = 'average')
-                  bio = outpre + '.bio02',
+                  bio = outpre + 'bio02',
                   oscale = toutscale,
                   input = output,
                   iscale = tinscale)
-    grass.run_command('r.support', map = outpre + '.bio02',
+    grass.run_command('r.support', map = outpre + 'bio02',
                       description = 'BIOCLIM02: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio02',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio02',history = os.environ['CMDLINE'])
     grass.run_command('g.remove', flags = 'f', type = 'raster', pattern = '%s.tr??.%d' % (outpre, pid), quiet = True)
     # BIO4 = Temperature Seasonality (standard deviation * 100)
     grass.message(_("BIO4 = Temperature Seasonality ..."))
-    output = outpre + '.bio04.' + str(pid)
+    output = outpre + 'bio04.' + str(pid)
     grass.run_command('r.series', input = tavg, output = output, method = 'stddev')
     grass.mapcalc("$bio = round(100.0 * $biotmp / $iscale * $oscale)",
-                  bio = outpre + '.bio04',
+                  bio = outpre + 'bio04',
                   biotmp = output,
                   iscale = tinscale,
                   oscale = toutscale)
-    grass.run_command('r.support', map = outpre + '.bio04',
+    grass.run_command('r.support', map = outpre + 'bio04',
                       description = 'BIOCLIM04: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio04',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio04',history = os.environ['CMDLINE'])
     # BIO5 = Max Temperature of Warmest Month
     grass.message(_("BIO5 = Max Temperature of Warmest Month ..."))
-    output = outpre + '.bio05.' + str(pid)
+    output = outpre + 'bio05.' + str(pid)
     grass.run_command('r.series', input = tmax, output = output, method = 'maximum')
     grass.mapcalc("$bio = round(double($oscale) * $biotmp / $iscale)",
-                  bio = outpre + '.bio05',
+                  bio = outpre + 'bio05',
                   oscale = toutscale,
                   iscale = tinscale,
                   biotmp = output)
-    grass.run_command('r.support', map = outpre + '.bio05',
+    grass.run_command('r.support', map = outpre + 'bio05',
                       description = 'BIOCLIM05: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio05',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio05',history = os.environ['CMDLINE'])
     # BIO6 = Min Temperature of Coldest Month
     grass.message(_("BIO6 = Min Temperature of Coldest Month ..."))
-    output = outpre + '.bio06.' + str(pid)
+    output = outpre + 'bio06.' + str(pid)
     grass.run_command('r.series', input = tmin, output = output, method = 'minimum')
-                  bio = outpre + '.bio06',
+                  bio = outpre + 'bio06',
                   oscale = toutscale,
                   biotmp = output,
                   iscale = tinscale)
-    grass.run_command('r.support', map = outpre + '.bio06',
+    grass.run_command('r.support', map = outpre + 'bio06',
                       description = 'BIOCLIM06: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio06',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio06',history = os.environ['CMDLINE'])
     # BIO7 = Temperature Annual Range (BIO5-BIO6)
     grass.message(_("BIO7 = Temperature Annual Range ..."))
     grass.mapcalc("$bio = $bio5 - $bio6",
-                  bio = outpre + '.bio07',
-                  bio5 = outpre + '.bio05',
-                  bio6 = outpre + '.bio06')
-    grass.run_command('r.support', map = outpre + '.bio07',
+                  bio = outpre + 'bio07',
+                  bio5 = outpre + 'bio05',
+                  bio6 = outpre + 'bio06')
+    grass.run_command('r.support', map = outpre + 'bio07',
                       description = 'BIOCLIM07: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio07',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio07',history = os.environ['CMDLINE'])
     # BIO3 = Isothermality (BIO2/BIO7) (* 100)
     grass.message(_("BIO3 = Isothermality (BIO2/BIO7) ..."))
     grass.mapcalc("$bio = round(100.0 * $bio2 / $bio7)",
-                  bio = outpre + '.bio03',
-                  bio2 = outpre + '.bio02',
-                  bio7 = outpre + '.bio07')
-    grass.run_command('r.support', map = outpre + '.bio03',
+                  bio = outpre + 'bio03',
+                  bio2 = outpre + 'bio02',
+                  bio7 = outpre + 'bio07')
+    grass.run_command('r.support', map = outpre + 'bio03',
                       description = 'BIOCLIM03: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio03',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio03',history = os.environ['CMDLINE'])
     # mean of mean for each quarter year
     grass.message(_("Mean temperature for each quarter year ..."))
@@ -309,28 +309,28 @@
                              mapset= '.')
     tavgq = tavgq.strip("\n")
-    bio10 = outpre + '.bio10.' + str(pid)
-    bio11 = outpre + '.bio11.' + str(pid)
+    bio10 = outpre + 'bio10.' + str(pid)
+    bio11 = outpre + 'bio11.' + str(pid)
     grass.run_command('r.series', input = tavgq,
                       output = "%s,%s" % (bio10, bio11),
                       method = 'maximum,minimum')
-                  bio = outpre + '.bio10',
+                  bio = outpre + 'bio10',
                   oscale = toutscale,
                   biotmp = bio10,
                   iscale = tinscale)
-    grass.run_command('r.support', map = outpre + '.bio10',
+    grass.run_command('r.support', map = outpre + 'bio10',
                       description = 'BIOCLIM10: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio10',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio10',history = os.environ['CMDLINE'])
-                  bio = outpre + '.bio11',
+                  bio = outpre + 'bio11',
                   oscale = toutscale,
                   biotmp = bio11,
                   iscale = tinscale)
-    grass.run_command('r.support', map = outpre + '.bio11',
+    grass.run_command('r.support', map = outpre + 'bio11',
                       description = 'BIOCLIM11: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio11',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio11',history = os.environ['CMDLINE'])
     grass.run_command('g.remove', flags = 'f', type = 'raster', name = "%s,%s" % (bio10, bio11), quiet = True);
@@ -392,7 +392,7 @@
 				    if($wettestq == 2, $tavgq2, \
 				    if($wettestq == 3, $tavgq3, null())))) \
 				    * $oscale / $iscale)",
-		      bio = outpre + '.bio08',
+		      bio = outpre + 'bio08',
 		      wettestq = wettestq,
 		      tavgq0 = tavgql[0], tavgq1 = tavgql[1],
 		      tavgq2 = tavgql[2], tavgq3 = tavgql[3],
@@ -412,7 +412,7 @@
 				    if($wettestq == 10, $tavgq10, \
 				    if($wettestq == 11, $tavgq11, null())))))))))))) \
@@ -422,9 +422,9 @@
 		      tavgq10 = tavgql[10], tavgq11 = tavgql[11],
 		      oscale = toutscale, iscale = tinscale)
-    grass.run_command('r.support', map = outpre + '.bio08',
+    grass.run_command('r.support', map = outpre + 'bio08',
                       description = 'BIOCLIM08: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio08',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio08',history = os.environ['CMDLINE'])
     # BIO9 = Mean Temperature of Driest Quarter
     grass.message(_("BIO9 = Mean Temperature of Driest Quarter ..."))
@@ -435,7 +435,7 @@
 				    if($driestq == 2, $tavgq2, \
 				    if($driestq == 3, $tavgq3, null())))) \
-		      bio = outpre + '.bio09',
+		      bio = outpre + 'bio09',
 		      driestq = driestq,
@@ -455,7 +455,7 @@
 				    if($driestq == 10, $tavgq10, \
 				    if($driestq == 11, $tavgq11, null())))))))))))) \
 		      driestq = driestq,
@@ -465,34 +465,34 @@
-    grass.run_command('r.support', map = outpre + '.bio09',
+    grass.run_command('r.support', map = outpre + 'bio09',
                       description = 'BIOCLIM09: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio09',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio09',history = os.environ['CMDLINE'])
     # BIO12 = Annual Precipitation
     grass.message(_("BIO12 = Annual Precipitation ..."))
-    output = outpre + '.bio12'
+    output = outpre + 'bio12'
     grass.run_command('r.series', input = prec, output = output, method = 'sum')
-    grass.run_command('r.support', map = outpre + '.bio12',
+    grass.run_command('r.support', map = outpre + 'bio12',
                       description = 'BIOCLIM12: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio12',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio12',history = os.environ['CMDLINE'])
     # BIO13 = Precipitation of Wettest Month
     # BIO14 = Precipitation of Driest Month
     grass.message(_("BIO13 = Precipitation of Wettest Month,"))
     grass.message(_("BIO14 = Precipitation of Driest Month ..."))
-    bio13 = outpre + '.bio13'
-    bio14 = outpre + '.bio14'
+    bio13 = outpre + 'bio13'
+    bio14 = outpre + 'bio14'
                       output = "%s,%s" % (bio13, bio14),
-    grass.run_command('r.support', map = outpre + '.bio13',
+    grass.run_command('r.support', map = outpre + 'bio13',
                       description = 'BIOCLIM13: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio13',history = os.environ['CMDLINE'])
-    grass.run_command('r.support', map = outpre + '.bio14',
+    grass.run_command('r.support', map = outpre + 'bio13',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio14',
                       description = 'BIOCLIM14: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio14',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio14',history = os.environ['CMDLINE'])
     # BIO15 = Precipitation Seasonality (Coefficient of Variation)
@@ -503,29 +503,29 @@
                       output = "%s,%s" % (precavg, precstddev),
                       method = 'average,stddev')
     grass.mapcalc("$bio = if($precavg == 0, 0, round(100.0 * $precstddev / $precavg))",
-                  bio = outpre + '.bio15',
+                  bio = outpre + 'bio15',
                   precstddev = precstddev,
                   precavg = precavg)
-    grass.run_command('r.support', map = outpre + '.bio15',
+    grass.run_command('r.support', map = outpre + 'bio15',
                       description = 'BIOCLIM15: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio15',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio15',history = os.environ['CMDLINE'])
     # BIO16 = Precipitation of Wettest Quarter
     # BIO17 = Precipitation of Driest Quarter
     grass.message(_("BIO16 = Precipitation of Wettest Quarter,"))
     grass.message(_("BIO17 = Precipitation of Driest Quarter ..."))
-    bio16 = outpre + '.bio16'
-    bio17 = outpre + '.bio17'
+    bio16 = outpre + 'bio16'
+    bio17 = outpre + 'bio17'
     grass.run_command('r.series', input = precq,
                       output = "%s,%s" % (bio16, bio17),
-    grass.run_command('r.support', map = outpre + '.bio16',
+    grass.run_command('r.support', map = outpre + 'bio16',
                       description = 'BIOCLIM16: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio16',history = os.environ['CMDLINE'])
-    grass.run_command('r.support', map = outpre + '.bio17',
+    grass.run_command('r.support', map = outpre + 'bio16',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio17',
                       description = 'BIOCLIM17: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio17',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio17',history = os.environ['CMDLINE'])
     precql = precq.split(',')
@@ -537,7 +537,7 @@
 				    if($warmestq == 1, $precq1, \
 				    if($warmestq == 2, $precq2, \
 				    if($warmestq == 3, $precq3, null())))))",
-		      bio = outpre + '.bio18',
+		      bio = outpre + 'bio18',
 		      warmestq = warmestq,
 		      precq0 = precql[0], precq1 = precql[1],
 		      precq2 = precql[2], precq3 = precql[3])
@@ -555,7 +555,7 @@
 				    if($warmestq ==  9, $precq9, \
 				    if($warmestq == 10, $precq10, \
 				    if($warmestq == 11, $precq11, null())))))))))))))",
 		      precq2 = precql[2], precq3 = precql[3],
@@ -564,9 +564,9 @@
 		      precq8 = precql[8], precq9 = precql[9],
 		      precq10 = precql[10], precq11 = precql[11])
-    grass.run_command('r.support', map = outpre + '.bio18',
+    grass.run_command('r.support', map = outpre + 'bio18',
                       description = 'BIOCLIM18: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio18',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio18',history = os.environ['CMDLINE'])
     # BIO19 = Precipitation of Coldest Quarter
     grass.message(_("BIO19 = Precipitation of Coldest Quarter ..."))
@@ -576,7 +576,7 @@
 				    if($coldestq == 1, $precq1, \
 				    if($coldestq == 2, $precq2, \
 				    if($coldestq == 3, $precq3, null())))))",
-		      bio = outpre + '.bio19',
+		      bio = outpre + 'bio19',
 		      coldestq = coldestq,
@@ -594,7 +594,7 @@
 				    if($coldestq ==  9, $precq9, \
 				    if($coldestq == 10, $precq10, \
 				    if($coldestq == 11, $precq11, null())))))))))))))",
@@ -603,9 +603,9 @@
-    grass.run_command('r.support', map = outpre + '.bio19',
+    grass.run_command('r.support', map = outpre + 'bio19',
                       description = 'BIOCLIM19: Generated by r.bioclim')
-    grass.run_command('r.support', map = outpre + '.bio19',history = os.environ['CMDLINE'])
+    grass.run_command('r.support', map = outpre + 'bio19',history = os.environ['CMDLINE'])
                       pattern = tmp_pattern, quiet = True)
