[GRASS-SVN] r67222 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Fri Dec 18 07:21:18 PST 2015
Author: wenzeslaus
Date: 2015-12-18 07:21:18 -0800 (Fri, 18 Dec 2015)
New Revision: 67222
grass/trunk/raster/r.in.lidar/main.c
r.in.lidar: add flag to set region according to the new raster
This is the same as -e flag in v.in.lidar.
Perhaps -e and -n i r.in.lidar and -e in v.in.lidar
should be somehow synchronized.
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2015-12-18 14:42:15 UTC (rev 67221)
+++ grass/trunk/raster/r.in.lidar/main.c 2015-12-18 15:21:18 UTC (rev 67222)
@@ -82,6 +82,7 @@
struct Option *file_list_opt;
struct Option *voutput_opt;
struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag, *intens_flag;
+ struct Flag *set_region_flag;
struct Flag *base_rast_res_flag;
struct Flag *notopo_flag;
@@ -239,6 +240,15 @@
_("Extend region extents based on new dataset");
extents_flag->guisection = _("Output");
+ set_region_flag = G_define_flag();
+ set_region_flag->key = 'n';
+ set_region_flag->label =
+ _("Set computation region to match the new raster map");
+ set_region_flag->description =
+ _("Set computation region to match the 2D extent and resolution"
+ " of the newly created new raster map");
+ set_region_flag->guisection = _("Output");
over_flag = G_define_flag();
over_flag->key = 'o';
over_flag->label =
@@ -273,6 +283,14 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ /* we could use rules but this gives more info and allows continuing */
+ if (set_region_flag->answer && !(extents_flag->answer || res_opt->answer)) {
+ G_warning(_("Flag %c makes sense only with %s option or -%c flag"),
+ set_region_flag->key, res_opt->key, extents_flag->key);
+ /* avoid the call later on */
+ set_region_flag->answer = '\0';
struct StringList infiles;
if (file_list_opt->answer) {
@@ -683,6 +701,11 @@
Vect_destroy_cats_struct(vector_writer.cats);
+ /* set computation region to the new raster map */
+ /* TODO: should be in the done message */
+ if (set_region_flag->answer)
+ G_put_window(®ion);
if (infiles.num_items > 1) {
sprintf(buff, _("Raster map <%s> created."
" %lu points from %d files found in region."),
