[GRASS-SVN] r67232 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Fri Dec 18 13:03:00 PST 2015
Author: martinl
Date: 2015-12-18 13:03:00 -0800 (Fri, 18 Dec 2015)
New Revision: 67232
grass/trunk/gui/wxpython/core/gconsole.py
wxGUI: implement mechanism which allows to pass giface to g.gui.* modules
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py 2015-12-18 20:52:40 UTC (rev 67231)
+++ grass/trunk/gui/wxpython/core/gconsole.py 2015-12-18 21:03:00 UTC (rev 67232)
@@ -491,15 +491,34 @@
'opt': p.get('name', '')})
return
- if len(command) == 1 and hasParams and \
- command[0] != 'v.krige':
- # no arguments given
- try:
- GUI(parent=self._guiparent, giface=self._giface).ParseCommand(command)
- except GException as e:
- print >> sys.stderr, e
- return
+ if len(command) == 1:
+ if command[0].startswith('g.gui.'):
+ import imp
+ import inspect
+ pyFile = command[0]
+ if sys.platform == 'win32':
+ pyFile += '.py'
+ pyPath = os.path.join(os.environ['GISBASE'], 'scripts', pyFile)
+ if not os.path.exists(pyPath):
+ pyPath = os.path.join(os.environ['GRASS_ADDON_BASE'], 'scripts', pyFile)
+ GError(parent=self._guiparent,
+ message=_("Module <%s> not found.") % command[0])
+ pymodule = imp.load_source(command[0].replace('.', '_'), pyPath)
+ pymain = inspect.getargspec(pymodule.main)
+ if pymain and 'giface' in pymain.args:
+ pymodule.main(self._giface)
+ return
+ if hasParams and command[0] != 'v.krige':
+ # no arguments given
+ try:
+ GUI(parent=self._guiparent, giface=self._giface).ParseCommand(command)
+ except GException as e:
+ print >> sys.stderr, e
+ return
# activate computational region (set with g.region)
# for all non-display commands.
if compReg:
