[GRASS-SVN] r67238 - grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser
Fri Dec 18 13:33:55 PST 2015
Author: krejcmat
Date: 2015-12-18 13:33:55 -0800 (Fri, 18 Dec 2015)
New Revision: 67238
   grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py
   grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlRequest.html
   grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlResponse.html
addons g.gui.cswbrowser: add support of web-service layer module
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py	2015-12-18 21:13:57 UTC (rev 67237)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py	2015-12-18 21:33:55 UTC (rev 67238)
@@ -10,25 +10,23 @@
 @author Matej Krejci <matejkrejci gmail.com> (GSoC 2015)
-import sys
-import os
-from grass.pygrass.utils import set_path
 import grass.script as grass
+from grass.pygrass.utils import set_path
 set_path(modulename='wx.metadata', dirname='mdlib')
 import wx
 from cswlib import CSWBrowserPanel, CSWConnectionPanel
 class CswBrowserMainDialog(wx.Frame):
-    def __init__(self):
+    def __init__(self,giface=None):
         wx.Frame.__init__(self, None, title="Metadata browser", size=(1024, 760))
         self.mainNotebook = wx.Notebook(self, wx.ID_ANY)
         self.config = wx.Config("g.gui.cswbrowser")
-        self.BrowserPanel = CSWBrowserPanel(self.mainNotebook, self)
+        self.BrowserPanel = CSWBrowserPanel(self.mainNotebook, self, giface)
         self.connectionPanel = CSWConnectionPanel(self.mainNotebook, self)
         self.mainNotebook.AddPage(self.BrowserPanel, text='Find')
         self.mainNotebook.AddPage(self.connectionPanel, text='Configure')
@@ -39,14 +37,12 @@
         self.mainsizer.Add(self.mainNotebook, 1, wx.EXPAND, )
         self.SetSizer(self.mainsizer)
-def main():
+def main(giface=None):
     app = wx.App()
-    a = CswBrowserMainDialog()
+    a = CswBrowserMainDialog(giface)
     a.Show()
     app.MainLoop()
 if __name__ == '__main__':
     grass.parser()
     main()
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlRequest.html
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlRequest.html	2015-12-18 21:13:57 UTC (rev 67237)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlRequest.html	2015-12-18 21:33:55 UTC (rev 67238)
@@ -13,23 +13,12 @@
 </head>
 <body>
 <div class="highlight"><pre><span class="cp"><?xml version="1.0" ?></span>
-<span class="nt"><csw:GetRecords</span> <span class="na">maxRecords=</span><span
-            class="s">"20"</span> <span class="na">outputFormat=</span><span class="s">"application/xml"</span> <span
-            class="na">outputSchema=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2"</span> <span
-            class="na">resultType=</span><span class="s">"results"</span> <span
-            class="na">service=</span><span class="s">"CSW"</span> <span class="na">version=</span><span
-            class="s">"2.0.2"</span> <span class="na">xmlns:csw=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2"</span> <span
-            class="na">xmlns:xsi=</span><span
-            class="s">"http://www.w3.org/2001/XMLSchema-instance"</span> <span
-            class="na">xsi:schemaLocation=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd"</span><span
-            class="nt">></span>
-	<span class="nt"><csw:Query</span> <span class="na">typeNames=</span><span
-            class="s">"csw:Record"</span><span class="nt">></span>
+<span class="nt"><csw:GetRecords</span> <span class="na">maxRecords=</span><span class="s">"20"</span> <span class="na">outputFormat=</span><span class="s">"application/xml"</span> <span class="na">outputSchema=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2"</span> <span class="na">resultType=</span><span class="s">"results"</span> <span class="na">service=</span><span class="s">"CSW"</span> <span class="na">version=</span><span class="s">"2.0.2"</span> <span class="na">xmlns:csw=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2"</span> <span class="na">xmlns:xsi=</span><span class="s">"http://www.w3.org/2001/XMLSchema-instance"</span> <span class="na">xsi:schemaLocation=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd"</span><span class="nt">></span>
+	<span class="nt"><csw:Query</span> <span class="na">typeNames=</span><span class="s">"csw:Record"</span><span class="nt">></span>
 		<span class="nt"><csw:ElementSetName></span>full<span class="nt"></csw:ElementSetName></span>
 	<span class="nt"></csw:Query></span>
 <span class="nt"></csw:GetRecords></span>
-</pre>
-</div>
+</pre></div>
 </body>
 </html>
\ No newline at end of file
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlResponse.html
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlResponse.html	2015-12-18 21:13:57 UTC (rev 67237)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/htmlResponse.html	2015-12-18 21:33:55 UTC (rev 67238)
@@ -12,573 +12,569 @@
     </style>
 </head>
 <body>
-<div class="highlight">
-<pre><span class="cp"><?xml version="1.0" encoding="utf-8"?></span>
-<span class="nt"><csw:GetRecordsResponse</span> <span class="na">xmlns:csw=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2"</span> <span
-        class="na">xmlns:dc=</span><span class="s">"http://purl.org/dc/elements/1.1/"</span> <span class="na">xmlns:ogc=</span><span
-        class="s">"http://www.opengis.net/ogc"</span> <span class="na">xmlns:dct=</span><span class="s">"http://purl.org/dc/terms/"</span> <span
-        class="na">xmlns:ows=</span><span class="s">"http://www.opengis.net/ows"</span> <span class="na">xmlns:xsi=</span><span
-        class="s">"http://www.w3.org/2001/XMLSchema-instance"</span><span class="nt">></span>
-<span class="nt"><csw:RequestId</span> <span class="nt">/></span>
-<span class="nt"><csw:SearchStatus</span> <span class="nt">/></span>
-<span class="nt"><csw:SearchResults</span> <span class="na">elementSet=</span><span class="s">"full"</span> <span
-        class="na">recordSchema=</span><span
-        class="s">"http://schemas.opengis.net/csw/2.0.2/record.xsd"</span> <span class="na">numberOfRecordsMatched=</span><span
-        class="s">"17527"</span> <span class="na">numberOfRecordsReturned=</span><span class="s">"20"</span> <span
-        class="na">nextRecord=</span><span class="s">"40"</span><span class="nt">></span>
-<span class="nt"><csw:Record</span> <span class="na">xmlns:ns2=</span><span class="s">"http://www.cnipa.gov.it/RNDT/Service"</span> <span
-        class="na">xmlns:srv=</span><span class="s">"http://www.isotc211.org/2005/srv"</span> <span
-        class="na">xmlns:gmd=</span><span class="s">"http://www.isotc211.org/2005/gmd"</span> <span
-        class="na">xmlns:gco=</span><span class="s">"http://www.isotc211.org/2005/gco"</span><span class="nt">></span>
-<span class="nt"><dc:identifier></span>p_AR:00001:20120112:171634<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>PFVP Provincia di Arezzo - Zone di rispetto venatorio<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2005-12-28<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>Istituite dalle Province su richiesta delle ATC sul territorio destinato alla caccia programmata possono essere previste in due tipologie:<span
-        class="ni">&#xd;</span>
-									- zone vaste in cui  prevista la possibilit di prelievo sulle specie non in indirizzo:<span
-									- zone di limitata estensione istituite soprattutto con riguardo alla piccola selvaggina stanziale.<span
-        class="nt"></dct:abstract></span>
-<span class="nt"><dc:type></span>Dataset<span class="nt"></dc:type></span>
-<span class="nt"><dc:subject></span>pianificazione<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>gestione ambientale<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>legislazione regionale<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>zona controllata di caccia<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>Utilizzo del territorio<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>planningCadastre<span class="nt"></dc:subject></span>
-<span class="nt"><dc:language></span>ita<span class="nt"></dc:language></span>
-<span class="nt"><dc:rights></span>Altri vincoli<span class="nt"></dc:rights></span>
-<span class="nt"><ows:WGS84BoundingBox></span>
-<span class="nt"><ows:LowerCorner></span>11.4196653333 43.10020904<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>12.3714 43.513237<span class="nt"></ows:UpperCorner></span>
-<span class="nt"></ows:WGS84BoundingBox></span>
-<span class="nt"><ows:BoundingBox></span>
-<span class="nt"></ows:BoundingBox></span>
-<span class="nt"></csw:Record></span>
-<span class="nt"><dc:identifier></span>r_molise:{E1CCB7E3-AE4F-48E0-A418-A6205DB72B83}<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>MOLISEDB.GIS.W_G_S381114<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2012-04-03<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>La feature class rappresenta un foglio della Carta Tecnica Regionale 1:5000. Il dato  stato ricevuto dalla Regione Molise in formato shapefile.<span
-<span class="nt"><dc:subject></span>map<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>Nomi geografici<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>imageryBaseMapsEarthCover<span class="nt"></dc:subject></span>
-<span class="nt"><dc:format></span>SDE Feature Class<span class="nt"></dc:format></span>
-<span class="nt"><ows:LowerCorner></span>14.832482 41.874003<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>14.874149 41.899003<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>r_molise:{B9315A15-C9C8-4080-A42B-D8998B24DD31}<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>MOLISEDB.GIS.W_G_S394083<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2012-04-06<span class="nt"></dct:modified></span>
-<span class="nt"><ows:LowerCorner></span>14.91582 41.698862<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>14.957496 41.724031<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>r_molise:{677D9AFF-0950-4067-B9A3-AFD8371C5FFA}<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>MOLISEDB.GIS.MO_DBP01G_Centri_Molise<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2012-03-08<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>Feature Class dei centri abitati DBPrior 10k livello 2 per intera Regione Molise. Dato consegnato dalla Regione Molise.<span
-<span class="nt"><dc:subject></span>land use classification<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>boundaries<span class="nt"></dc:subject></span>
-<span class="nt"><ows:LowerCorner></span>14.00283 41.397792<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>15.080393 42.034867<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>r_umbria:00019:20100607:143032<span
-        class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Rete geodetica Regione Umbria<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2010-06-07<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>La rete geodetica planoaltimetrica della Regione Umbria<span class="ni">&#xd;</span>
-Costituisce un raffittimento della rete fondamentale IGM95 e nella sua configurazione definitiva  costituita da 294 nuovi vertici che si aggiungono agli 87 vertici IGM95 esistenti, per un totale di 381 punti uniformemente distribuiti sul territorio regionale.<span
-<span class="nt"><dc:subject></span>Sistemi di coordinate<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>geoscientificInformation<span class="nt"></dc:subject></span>
-							Altri vincoli
-						<span class="nt"></dc:rights></span>
-<span class="nt"><ows:LowerCorner></span>11.8918873189186 42.3644489025728<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>13.2641895503866 43.6173443846477<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>r_molise:{F9F2F9E0-3898-4C3E-AE17-FE276C809F4E}<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>MOLISEDB.GIS.MM_Tmax_Ottobre<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2012-03-14<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>La feature class MM_Tmax_Ottobre,  una feature class poligonale che rappresenta le aree con temperature massime misurate nel mese di Ottobre omogenee. Delle Temperature Massime sono considerati la massima, la media e la minima mensile. Ogni area  stata calcolata per interpolazione a partire dai dati rilevati dalle singole stazioni di misura.<span
-<span class="nt"><dc:subject></span>Condizioni atmosferiche<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>climatologyMeteorologyAtmosphere<span class="nt"></dc:subject></span>
-<span class="nt"><dc:rights></span>Dato a conoscibilit limitata<span class="nt"></dc:rights></span>
-<span class="nt"><ows:LowerCorner></span>13.941193 41.363275<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>15.161064 42.069535<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>r_umbria:00001:20091013:152425<span
-<span class="nt"><dc:title></span>Carta fitoclimatica<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2009-12-01<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>Contiene le unit fitoclimatiche dell'Umbria che rientrano in due Regioni (Temperata Semioceanica di Transizione e Temperata Semioceanica) con l'individuazione sul territorio regionale dei 7 Piani bioclimatici (Collinare Submediterraneo, Basso-Collinare, Alto-Collinare, Collinare Subcontinentale, Basso-Montano, Alto-Montano, Subalpino-Alpino) e delle relative varianti.<span
-<span class="nt"><dc:subject></span>Regioni biogeografiche<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>biota<span class="nt"></dc:subject></span>
-							Altri vincoli
-<span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"WWW:DOWNLOAD-1.0-http--download"</span><span
-        class="nt">></span>http://www.umbriaterritorio.it/CarteTematichePDF/004_.pdf<span
-        class="nt"></dc:URI></span>
-<span class="nt"><dc:identifier></span>agea:403:20091007:081436<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Refresh Provincia Belluno 2009<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2009-07-01<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>copertura del suolo per usi agricoli della Provincia Belluno  rappresentata nella proiezione conforme di Gauss-Boaga<span
-                                       <span class="nt"></dct:abstract></span>
-<span class="nt"><dc:subject></span>copertura del suolo per usi agricoli<span
-        class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>Orto immagini<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>farming<span class="nt"></dc:subject></span>
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>11.66603804 45.88049788<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>12.74959784 46.68037467<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:386:20090911:093825<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Mantova 2008<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2008-07-01<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Mantova alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-<span class="nt"><dc:subject></span>fotografia aerea (immagine)<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>ortofoto<span class="nt"></dc:subject></span>
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>10.30927983 44.90828099<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>11.42766438 45.42804199<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:329:20090911:084441<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Alessandria 2009<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Alessandria alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>8.10847121 44.46487886<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>9.21425034 45.20541861<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:00389:20090911:094023<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Vibo Valentia 2009<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Vibo Valentia alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>15.82719408 38.4289221<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>16.43470805 38.82446257<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>r_campan:16050018:20090527:103952<span
-<span class="nt"><dc:title></span>Parchi Nazionali<span class="nt"></dc:title></span>
-<span class="nt"><dct:modified></span>2009-07-31<span class="nt"></dct:modified></span>
-<span class="nt"><dct:abstract></span>Perimetrazioni dei Parchi Regionali presenti in Regione Campania<span
-<span class="nt"><dc:subject></span>Siti protetti<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>parchi nazionali<span class="nt"></dc:subject></span>
-<span class="nt"><dc:subject></span>environment<span class="nt"></dc:subject></span>
-<span class="nt"><ows:LowerCorner></span>14.364741 39.98938<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>15.698097 40.873218<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:00377:20090911:093144<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Trento 2008<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Trento alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>10.45230853 45.6730803<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>11.96285745 46.53297967<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:00373:20090911:092903<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Terni 2008<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Terni alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>11.89188729 42.36443703<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>12.89633447 42.94310311<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:00342:20090911:090542<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Piacenza 2008<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Piacenza alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>9.19792713 44.55582795<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>10.08347854 45.13907144<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:00330:20090911:084602<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Novara 2008<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Novara alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>8.37667885 39.54914737<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>9.82710733 40.86492774<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:332:20090911:085547<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Asti 2009<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Asti alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>7.88367392 44.51951501<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>8.51258103 45.13293242<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:377:20090911:093146<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Gorizia 2008<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Gorizia alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>13.23754532 45.67415462<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>13.64284038 46.05129914<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:00367:20090911:092454<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Ortofotocarta Salerno 2008<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>Ortofotocarta della Provincia Salerno alla scala 1:10.000 rappresentata nella proiezione conforme di Gauss-Boaga. Una sezione rappresenta la sedicesima parte di un foglio della serie IGM 1:50.000<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>14.42872224 39.9905913<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>15.80638769 40.84875212<span class="nt"></ows:UpperCorner></span>
-<span class="nt"><dc:identifier></span>agea:419:20091012:090325<span class="nt"></dc:identifier></span>
-<span class="nt"><dc:title></span>Refresh Provincia Cuneo 2009<span class="nt"></dc:title></span>
-<span class="nt"><dct:abstract></span>copertura del suolo per usi agricoli della Provincia Cuneo  rappresentata nella proiezione conforme di Gauss-Boaga<span
-							Altri vincoli
-<span class="nt"><ows:LowerCorner></span>6.85344523 44.06006515<span class="nt"></ows:LowerCorner></span>
-<span class="nt"><ows:UpperCorner></span>8.26856826 44.85647935<span class="nt"></ows:UpperCorner></span>
-<span class="nt"></csw:SearchResults></span>
+<div class="highlight"><pre><span class="cp"><?xml version="1.0" encoding="UTF-8"?></span>
+<span class="nt"><csw:GetRecordsResponse</span> <span class="na">xmlns:csw=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2"</span> <span class="na">xmlns:xsi=</span><span class="s">"http://www.w3.org/2001/XMLSchema-instance"</span> <span class="na">xsi:schemaLocation=</span><span class="s">"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd"</span><span class="nt">></span>
+  <span class="nt"><csw:SearchStatus</span> <span class="na">timestamp=</span><span class="s">"2015-12-08T13:25:53"</span> <span class="nt">/></span>
+  <span class="nt"><csw:SearchResults</span> <span class="na">numberOfRecordsMatched=</span><span class="s">"8828"</span> <span class="na">numberOfRecordsReturned=</span><span class="s">"20"</span> <span class="na">elementSet=</span><span class="s">"full"</span> <span class="na">nextRecord=</span><span class="s">"21"</span><span class="nt">></span>
+    <span class="nt"><csw:Record</span> <span class="na">xmlns:ows=</span><span class="s">"http://www.opengis.net/ows"</span> <span class="na">xmlns:geonet=</span><span class="s">"http://www.fao.org/geonetwork"</span> <span class="na">xmlns:dc=</span><span class="s">"http://purl.org/dc/elements/1.1/"</span> <span class="na">xmlns:dct=</span><span class="s">"http://purl.org/dc/terms/"</span><span class="nt">></span>
+      <span class="nt"><dc:identifier></span>7i6iewfy-cyzk-9ll3-aalw-mhiqtu2q92fr<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2015-11-16<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Aanleginrichtingen Waddenzee overig<span class="nt"></dc:title></span>
+      <span class="nt"><dc:type></span>dataset<span class="nt"></dc:type></span>
+      <span class="nt"><dc:subject></span>Aanleginrichting<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Afmeervoorziening<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Scheepvaartvoorzieningen<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>oceans<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:format</span> <span class="nt">/></span>
+      <span class="nt"><dct:abstract></span>Diverse bestanden aanleginrichtingen Waddenzee. Omschrijving: Bestanden rondom de aanleginrichtingen Waddenzee: bodembescherming, bushokjes, funderingen, meterkasten, nautische bebording, palen en masten, strooioppervlakten en verkeersstromen.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Diverse bestanden aanleginrichtingen Waddenzee. Omschrijving: Bestanden rondom de aanleginrichtingen Waddenzee: bodembescherming, bushokjes, funderingen, meterkasten, nautische bebording, palen en masten, strooioppervlakten en verkeersstromen.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:rights></span>otherRestrictions<span class="nt"></dc:rights></span>
+      <span class="nt"><dc:language></span>dut<span class="nt"></dc:language></span>
+      <span class="nt"><dc:source></span>Aangeleverd door district RWS<span class="nt"></dc:source></span>
+      <span class="nt"><dc:relation></span>DC000233<span class="nt"></dc:relation></span>
+      <span class="nt"><ows:BoundingBox</span> <span class="na">crs=</span><span class="s">"urn:ogc:def:crs:EPSG::28992"</span><span class="nt">></span>
+        <span class="nt"><ows:LowerCorner></span>7.210 50.759<span class="nt"></ows:LowerCorner></span>
+        <span class="nt"><ows:UpperCorner></span>3.514 53.428<span class="nt"></ows:UpperCorner></span>
+      <span class="nt"></ows:BoundingBox></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"Dataset"</span> <span class="na">name=</span><span class="s">"Aanleginrichtingen Waddenzee overig - Dataset"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.rijkswaterstaat.nl/apps/geoservices/geodata/regios/projecten/aanleginrichtingen_waddenzee/Aanleginrichtingen_Waddenzee_overig.zip<span class="nt"></dc:URI></span>
+    <span class="nt"></csw:Record></span>
+      <span class="nt"><dc:identifier></span>EII77288-CPVQ-9YNT-F5MD-OH8N7ZTV8L5A<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2014-12-16<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Actuele Wegenlijst<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>Wegen<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Wegennetwerk<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Route<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Wegenkaart<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Rijksweg<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Wegdeel<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject</span> <span class="nt">/></span>
+      <span class="nt"><dc:subject></span>elevation<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>De rijkswegen zijn onderverdeeld naar Planwegen (nrs. 1-99) en Planvervangende wegen (nrs. 200-857 en nr. 915). De informatie (wegnummer, wegdeelbenaming en begin- en eindhectometrering wordt per Regionale Dienst en per wegendistrict weergegeven op rijkswegnummer.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>De rijkswegen zijn onderverdeeld naar Planwegen (nrs. 1-99) en Planvervangende wegen (nrs. 200-857 en nr. 915). De informatie (wegnummer, wegdeelbenaming en begin- en eindhectometrering wordt per Regionale Dienst en per wegendistrict weergegeven op rijkswegnummer.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Aan de basis van de indeling liggen het Tweede Structuurschema Verkeer en Vervoer (SVV-II) en het Meerjarenprogramma Infrastructuur en Transport (MIT 2000-2004).<span class="nt"></dc:source></span>
+      <span class="nt"><dc:relation</span> <span class="nt">/></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"download"</span> <span class="na">name=</span><span class="s">"Actuele Wegenlijst"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.rijkswaterstaat.nl/apps/geoservices/geodata/dmc/actuele_wegenlijst<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>NEBSHNZ6-B8FH-4RTO-UMM9-Q7788LYUVKLA<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2014-12-15<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Binnenvaart Informatie en Communicatie Systeem - Documentatie en Standaarden<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>BICS<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Binnenvaart<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Reisinformatie<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Ladinginformatie<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Schippers<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Beroepsvaart<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Vaarwegbeheerders<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Vaarwegen<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Documentatie<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Standaarden<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>inlandWaters<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Documentatie en standaarden met (achtergrond) informatie, specificaties en technische documentatie voor Binnenvaart Informatie en Communicatie Systeem (BICS). Met BICS worden ((strikt vertrouwelijk) elektronische meldingen gemaakt over reis- en ladinginformatie in de binnenvaart aan de vaarwegbeheerders.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Documentatie en standaarden met (achtergrond) informatie, specificaties en technische documentatie voor Binnenvaart Informatie en Communicatie Systeem (BICS). Met BICS worden ((strikt vertrouwelijk) elektronische meldingen gemaakt over reis- en ladinginformatie in de binnenvaart aan de vaarwegbeheerders.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Weblocatie voor data ontsluiting<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"BICS - Documentatie en Standaarden - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.bics.nl/?q=nl/node/100000018<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"BICS - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.bics.nl<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>9G4HW8E8-G66A-GPFQ-3RSP-W3Z43O0RU22C<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:title></span>Binnenvaart Informatie en Communicatie Systeem - Referentiegegevens<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>Referentiegegevens<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Referentiegegevens Binnenvaart Informatie en Communicatie Systeem (BICS). Met BICS worden (strikt vertrouwelijk)elektronische meldingen gemaakt over reis- en ladinginformatie in de binnenvaart aan de vaarwegbeheerders.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Referentiegegevens Binnenvaart Informatie en Communicatie Systeem (BICS). Met BICS worden (strikt vertrouwelijk)elektronische meldingen gemaakt over reis- en ladinginformatie in de binnenvaart aan de vaarwegbeheerders.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"Binnenvaart Informatie en Communicatie Systeem - Referentiegegevens - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.bics.nl/?q=nl/node/100000073<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"Binnenvaart Informatie en Communicatie Systeem - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.bics.nl<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>G7VINOPN-YJWF-B3SB-78RK-9IIE7BNEOIT7<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:title></span>Binnenvaart Informatie en Communicatie Systeem<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>Met BICS worden elektronische meldingen gemaakt over reis- en ladinginformatie in de binnenvaart aan de vaarwegbeheerders.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Met BICS worden elektronische meldingen gemaakt over reis- en ladinginformatie in de binnenvaart aan de vaarwegbeheerders.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"Binnenvaart Informatie en Communicatie Systeem - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>www.bics.nl<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>CB99CF77-2340-4689-B065-ADAAC9E69837<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2014-08-28<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Boven Merwede diepte grote Merwedesluis voorhaven 08-2014<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>Hoogte<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Vervoersnetwerken<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>aardrijkskunde<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>hoogte<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>landschap<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>water<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Boven Merwede<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>BOVMWDE067<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Bodemhoogte van het watersysteemdeel Boven Merwede, of een deel daarvan. Afhankelijk van de ontwikkelingen in de bodemligging en het belang voor het scheepvaartverkeer is de frequentie van de opname bepaald.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Bodemhoogte van het watersysteemdeel Boven Merwede, of een deel daarvan. Afhankelijk van de ontwikkelingen in de bodemligging en het belang voor het scheepvaartverkeer is de frequentie van de opname bepaald.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>multibeam echoloden: Bodemligging van de toegangsgeul. Opgemeten en vastgelegd in een grid 1x1m en weergeven in diverse productvormen.<span class="nt"></dc:source></span>
+        <span class="nt"><ows:LowerCorner></span>4.969 51.826<span class="nt"></ows:LowerCorner></span>
+        <span class="nt"><ows:UpperCorner></span>4.961 51.83<span class="nt"></ows:UpperCorner></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"dataset"</span> <span class="na">name=</span><span class="s">"Boven Merwede diepte grote Merwedesluis voorhaven 08-2014 - Intranet URL"</span> <span class="na">description=</span><span class="s">"Boven Merwede"</span><span class="nt">></span>\\wnz-ipbw-wss1gd.ad.rws.nl\GenData\GeoData\Projecten\Archief\hoogte\boven_merwede\grids\grote_merwedesluis_voorhaven_067\Bom1405ml0671.txt<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>4djfm8nf-8kug-ve1q-6nrh-mkhpvsrx2003<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2015-06-11<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Databestand Grootschalig Verkeersonderzoek Flevoland 2003<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>wegennetwerk<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>kentekenonderzoek<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>ritkenmerken<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>ritten<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>weggebruik<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>berichten<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>transportation<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Onderzoek naar alle autoverkeer, waarbij onderscheid is gemaakt tussen personenautos en bedrijfsvoertuigen. Onderwerpen zijn herkomsten, bestemmingen, voorkeuren, motieven, percentages van verkeer in Flevoland.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Onderzoek naar alle autoverkeer, waarbij onderscheid is gemaakt tussen personenautos en bedrijfsvoertuigen. Onderwerpen zijn herkomsten, bestemmingen, voorkeuren, motieven, percentages van verkeer in Flevoland.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Het steekproefsgewijs benaderen van eigenaren van voertuigen die een weggedeelte passeren, met een vragenlijst en het analyseren van het databestand en hierover rapporteren.<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"download"</span> <span class="na">name=</span><span class="s">"Databestand Grootschalig Verkeersonderzoek Flevoland 2003 - download"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.rijkswaterstaat.nl/apps/geoservices/geodata/regios/projecten/GVO/GVO_2003_Flevoland.zip<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>4djfm8nf-8kug-ve1q-6nrh-mkhpvflv2008<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2015-11-23<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Databestand Grootschalig Verkeersonderzoek Flevoland 2008<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>In het najaar van 2008 uitgevoerd onderzoek met de belangrijkste resultaten van de enqute onder gebruikers naar herkomsten, bestemmingen, voorkeuren, motieven, percentages van goederenvervoer in Randstad.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>In het najaar van 2008 uitgevoerd onderzoek met de belangrijkste resultaten van de enqute onder gebruikers naar herkomsten, bestemmingen, voorkeuren, motieven, percentages van goederenvervoer in Randstad.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Voor een gedetailleerde beschrijving van het uitvoeren van kentekenenqutes wordt verwezen naar het Handboek Verzamelen Verplaatsingsgegevens (HVV) - Rijkswaterstaat.<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"download"</span> <span class="na">name=</span><span class="s">"Databestand Grootschalig Verkeersonderzoek Flevoland 2008 - download"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.rijkswaterstaat.nl/apps/geoservices/geodata/regios/projecten/GVO/GVO_2008_Flevoland.zip<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>4djfm8nf-8kug-ve1q-6nrh-mkhpvgvr2012<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2015-08-01<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Databestand Grootschalig Verkeersonderzoek Goederenvervoer Randstad 2012<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>Excelbestand op postcode4-niveau van herkomsten, bestemmingen, voorkeuren, motieven, percentages van goederenvervoer in Randstad.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Excelbestand op postcode4-niveau van herkomsten, bestemmingen, voorkeuren, motieven, percentages van goederenvervoer in Randstad.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>In dit onderzoek is op drie dagen in sept/okt 2012 op 44 locaties in de Randstad tussen 5.00 uur en 20.00 uur vrachtverkeer waargenomen en geteld. Dat waren 1,9 miljoen voertuigpassages en 164.000 vrachtautos . Via een steekproef van 46.093 vrachtwagens hebben ruim 12.316 benaderde kentekenhouders van personenautos de enquete goed ingevuld en inzicht gegeven in herkomst, bestemming, motief en andere kenmerken van de waargenomen verplaatsing. Dataset gereed 1 mei 2013. Bewerking uitgevoerd op de set. Kentekens vrachtwagens waargenomen, enquetes verstuurd, ingevulde enquetes verwerkt tot databestand. Kentekenwaarneming sept/okt 2012.<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"download"</span> <span class="na">name=</span><span class="s">"Databestand Grootschalig Verkeersonderzoek Randstad Goederenvervoer 2012 - download"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.rijkswaterstaat.nl/apps/geoservices/geodata/regios/projecten/GVO/GVO_2012_Randstad.zip<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>4djfm8nf-8kug-ve1q-6nrh-mkhpvsrx2014<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:title></span>Databestand Grootschalig Verkeersonderzoek Personenauto's Randstad 2014<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>Excelbestand op postcode4-niveau van herkomsten, bestemmingen, voorkeuren, motieven, percentages van personenverkeer in Randstad.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Excelbestand op postcode4-niveau van herkomsten, bestemmingen, voorkeuren, motieven, percentages van personenverkeer in Randstad.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>In dit onderzoek is op n dag op 34 locaties in de Randstad tussen 5.00 uur en 21.00 uur verkeer geteld. Dat waren 1,38 miljoen passages van 736.000 personenautos . Via een steekproef hebben ruim 160.000 benaderde kentekenhouders van personenautos inzicht gegeven in herkomst, bestemming, motief en andere kenmerken van de waargenomen verplaatsing.<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"download"</span> <span class="na">name=</span><span class="s">"Databestand Grootschalig Verkeersonderzoek Personenauto's Randstad 2014 - download"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.rijkswaterstaat.nl/apps/geoservices/geodata/regios/projecten/GVO/GVO_2014_Randstad.zip<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"download"</span> <span class="na">name=</span><span class="s">"Databestand Grootschalig Verkeersonderzoek Personenauto's Randstad 2014"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://hez10.goudmap.info/gvo/<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>4djfm8nf-8kug-ve1q-6nrh-mkhpvutr2008<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:title></span>Databestand Grootschalig Verkeersonderzoek Utrecht 2008<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>Onderzoek onder de weggebruikers van rijkswegen in Utrecht. Hierbij is onderscheid gemaakt in personenverkeer en goederenvervoer. Onderwerpen zijn herkomsten, bestemmingen, voorkeuren, motieven, percentages van personenverkeer in Randstad.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Onderzoek onder de weggebruikers van rijkswegen in Utrecht. Hierbij is onderscheid gemaakt in personenverkeer en goederenvervoer. Onderwerpen zijn herkomsten, bestemmingen, voorkeuren, motieven, percentages van personenverkeer in Randstad.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Van op dinsdag 15 en dinsdag 22 april 2008 waargenomen Nederlandse voertuigen zijn de eigenaren genquteert. De waarnemenigen en antwoorden zijn vervolgens geannalyseerd.<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"download"</span> <span class="na">name=</span><span class="s">"Databestand Grootschalig Verkeersonderzoek Utrecht 2008 - download"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.rijkswaterstaat.nl/apps/geoservices/geodata/regios/projecten/GVO/GVO_2008_Utrecht.zip<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>Y82RWF5M-LX8L-MYI7-72DA-VWGAEK1SUI3F<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2015-01-26<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Deltaweb - Bestanden deelprogrammas en kennis deltaprogramma<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>Water<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Deltaprogramma<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Bestanden<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Verzamelpagina van alle bestanden over deelprogramma's en kennis van het Deltaprogramma.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Verzamelpagina van alle bestanden over deelprogramma's en kennis van het Deltaprogramma.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"Deltaweb - Bestanden deelprogrammas en kennis deltaprogramma - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>https://deltaprogramma.pleio.nl/file<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>6A7F8D32-CD51-43DF-BA0C-88D3F18C6830<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2010-01-31<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Hartelkanaal diepte Hartelkering 01-2010<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>Hartelkanaal<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>HARKN420<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Bodemhoogte van het watersysteemdeel Hartelkanaal, of een deel daarvan. Afhankelijk van de ontwikkelingen in de bodemligging en het belang voor het scheepvaartverkeer is de frequentie van de opname bepaald.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Bodemhoogte van het watersysteemdeel Hartelkanaal, of een deel daarvan. Afhankelijk van de ontwikkelingen in de bodemligging en het belang voor het scheepvaartverkeer is de frequentie van de opname bepaald.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>multibeam echoloden: Informatie wordt gebruikt door de beheerder. Middels deze informatie volgt hij de ontwikkelingen en de feitelijke toestand van het  onderwater-gedeelte van het betreffende kunstwerk ten einde de functionalitiet van  het kunstwerk te kunnen garanderen.<span class="nt"></dc:source></span>
+        <span class="nt"><ows:LowerCorner></span>4.31 51.864<span class="nt"></ows:LowerCorner></span>
+        <span class="nt"><ows:UpperCorner></span>4.303 51.867<span class="nt"></ows:UpperCorner></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"dataset"</span> <span class="na">name=</span><span class="s">"Hartelkanaal diepte Hartelkering 01-2010 - Intranet URL"</span> <span class="na">description=</span><span class="s">"Hartelkanaal"</span><span class="nt">></span>\\wnz-ipbw-wss1gd.ad.rws.nl\GenData\GeoData\Projecten\Archief\hoogte\hartelkanaal\grids\hartelkering_420\HKL1001ml4201.txt<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>b9dd8575-3c1c-41f4-add5-c4f5f2b67179<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2014-03-04<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>AHN1 5 meter maaiveld raster<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>raster<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>laseraltimetrie<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>ahn<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>LiDAR<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Hoogtegegevens<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Het Actueel Hoogtebestand Nederland (AHN) is een hoogtebestand vervaardigd door middel van laseraltimetrie. Het AHN1 5 meter maaiveldraster is bedoeld als maaiveldbestand, waarbij alle niet-maaiveld objecten (bomen, gebouwen, bruggen en andere objecten) uit de puntenwolk zijn verwijderd. Dit geldt niet voor stedelijke gebieden kleiner dan 1 km2, deze zijn in het bestand ongefilterd gebleven. Vervolgens is herbemonsterd tot een 5 meter raster op basis van een Squared IDW methode.
+Meer informatie vindt u op www.ahn.nl.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Het Actueel Hoogtebestand Nederland (AHN) is een hoogtebestand vervaardigd door middel van laseraltimetrie. Het AHN1 5 meter maaiveldraster is bedoeld als maaiveldbestand, waarbij alle niet-maaiveld objecten (bomen, gebouwen, bruggen en andere objecten) uit de puntenwolk zijn verwijderd. Dit geldt niet voor stedelijke gebieden kleiner dan 1 km2, deze zijn in het bestand ongefilterd gebleven. Vervolgens is herbemonsterd tot een 5 meter raster op basis van een Squared IDW methode.
+Meer informatie vindt u op www.ahn.nl.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Het herbemonsterde 5 meter maaiveld raster.<span class="nt"></dc:source></span>
+      <span class="nt"><ows:BoundingBox</span> <span class="na">crs=</span><span class="s">"urn:ogc:def:crs:EPSG::7415"</span><span class="nt">></span>
+        <span class="nt"><ows:LowerCorner></span>7.28 50.67<span class="nt"></ows:LowerCorner></span>
+        <span class="nt"><ows:UpperCorner></span>3.19 53.61<span class="nt"></ows:UpperCorner></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"atom feed service"</span> <span class="na">name=</span><span class="s">""</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/atom/ahn1_5m.xml<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMTS"</span> <span class="na">name=</span><span class="s">""</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/tiles/service/wmts/ahn1?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WCS"</span> <span class="na">name=</span><span class="s">"ahn1_5m"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wcs?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"ahn1_5m"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wms?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>cf73ef50-d655-4eff-82d3-7b0f4d42ca53<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:title></span>AHN1 25 meter maaiveldraster<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>Het Actueel Hoogtebestand Nederland (AHN) is een hoogtebestand vervaardigd door middel van laseraltimetrie. Het AHN1 25 meter maaiveld raster is bedoeld als maaiveldbestand en is herbemonsterd op basis van het 5 meter raster op basis van een ongewogen gemiddelde methode. Er zijn geen verdere bewerkingen uitgevoerd.
+      <span class="nt"><dc:description></span>Het Actueel Hoogtebestand Nederland (AHN) is een hoogtebestand vervaardigd door middel van laseraltimetrie. Het AHN1 25 meter maaiveld raster is bedoeld als maaiveldbestand en is herbemonsterd op basis van het 5 meter raster op basis van een ongewogen gemiddelde methode. Er zijn geen verdere bewerkingen uitgevoerd.
+      <span class="nt"><dc:source></span>Het herbemonsterde 25 meter maaiveld raster.<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"atom service feed"</span> <span class="na">name=</span><span class="s">""</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn25m/atom/ahn25m.xml<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"atom service feed"</span> <span class="na">name=</span><span class="s">""</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/atom/ahn1_25m.xml<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WCS"</span> <span class="na">name=</span><span class="s">"ahn1_25m"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wcs?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"ahn1_25m"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wms?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"ahn25m:ahn25m"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn25m/wms?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>da237167-7f87-4310-ad64-614233de7a42<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2012-05-30<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Actueel Hoogtebestand Nederland puntdichtheid<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>Overzicht van de gebieden met densiteit gebruikte laser uitgedrukt in aantal punten per 16 vierkante meter<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Overzicht van de gebieden met densiteit gebruikte laser uitgedrukt in aantal punten per 16 vierkante meter<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Dataset is door de DID gemaakt<span class="nt"></dc:source></span>
+        <span class="nt"><ows:LowerCorner></span>7.243 50.735<span class="nt"></ows:LowerCorner></span>
+        <span class="nt"><ows:UpperCorner></span>3.256 53.519<span class="nt"></ows:UpperCorner></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WFS"</span> <span class="na">name=</span><span class="s">"puntdichtheidgebieden"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wfs?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"puntdichtheidgebieden"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wms?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>a68434dd-7cc4-41f6-8d78-b0fc0de0c3b5<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:title></span>Actueel Hoogtebestand Nederland stadspolygonen<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>boundaries<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Contouren van stedelijke gebieden waarin geen filtering van de ahn-data heeft plaats gevonden. Deze grens is meestal door de aannemer op basis van andere bestanden bepaald  en vervolgens is het bestand volgens deze grenzen gefilterd. De AGI heeft vervolgens in de reguliere controles bepaald of deze gebiedsgrens correct was of niet en eventueel de gebiedsgrens aangepast. De aannemer heeft hier vervolgens weer naar gehandeld door respectievelijk data terug te zetten (indien er teveel gefilterd was) of data te filteren (indien er te weinig gefilterd was).<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Contouren van stedelijke gebieden waarin geen filtering van de ahn-data heeft plaats gevonden. Deze grens is meestal door de aannemer op basis van andere bestanden bepaald  en vervolgens is het bestand volgens deze grenzen gefilterd. De AGI heeft vervolgens in de reguliere controles bepaald of deze gebiedsgrens correct was of niet en eventueel de gebiedsgrens aangepast. De aannemer heeft hier vervolgens weer naar gehandeld door respectievelijk data terug te zetten (indien er teveel gefilterd was) of data te filteren (indien er te weinig gefilterd was).<span class="nt"></dc:description></span>
+        <span class="nt"><ows:LowerCorner></span>7.099 50.752<span class="nt"></ows:LowerCorner></span>
+        <span class="nt"><ows:UpperCorner></span>3.387 53.424<span class="nt"></ows:UpperCorner></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WFS"</span> <span class="na">name=</span><span class="s">"stadspolygonen"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wfs?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"stadspolygonen"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wms?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>6dc57d68-cc63-4334-bbca-145263c2c7fc<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:title></span>Actueel Hoogtebestand Nederland vlieglijnen<span class="nt"></dc:title></span>
+      <span class="nt"><dct:abstract></span>Overzicht van de vlieglijnen. Met deze vlieglijnen wordt weergegeven waar het vliegtuig gevolgen heeft tijdens de opname van het AHN. Per vlieglijn is de datum van opname van het AHN opgenomen. De vlieglijnen waren niet meer van heel Nederland te achterhalen. Vooral van die gebieden waar als eerste AHN is gemaakt. Dit zijn Noord-Holland, Drenthe, delen van Overijssel, Zeeland en Noord-Brabant.
+De vlieglijnen zijn berekend op basis van de 4 hoekpunten van de in het terrein opgenomen strook.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Overzicht van de vlieglijnen. Met deze vlieglijnen wordt weergegeven waar het vliegtuig gevolgen heeft tijdens de opname van het AHN. Per vlieglijn is de datum van opname van het AHN opgenomen. De vlieglijnen waren niet meer van heel Nederland te achterhalen. Vooral van die gebieden waar als eerste AHN is gemaakt. Dit zijn Noord-Holland, Drenthe, delen van Overijssel, Zeeland en Noord-Brabant.
+De vlieglijnen zijn berekend op basis van de 4 hoekpunten van de in het terrein opgenomen strook.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Dataset is door de DID gemaakt adv de vluchtgegevens van de vliegmaatschappijen<span class="nt"></dc:source></span>
+        <span class="nt"><ows:LowerCorner></span>7.242 50.736<span class="nt"></ows:LowerCorner></span>
+        <span class="nt"><ows:UpperCorner></span>3.344 53.518<span class="nt"></ows:UpperCorner></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WFS"</span> <span class="na">name=</span><span class="s">"vlieglijnen"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wfs?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"vlieglijnen"</span><span class="nt">></span>http://geodata.nationaalgeoregister.nl/ahn1/wms?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>hrk562h3-4iO6-bnfc-7wpm-wdfcdrdslit4<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2015-05-28<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Informatiehuis Marien - Open data<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>IHM<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Informatiehuis Marien<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Noordzee<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>Open data<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Mariene open data.<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Mariene open data.<span class="nt"></dc:description></span>
+      <span class="nt"><dc:relation></span>YFM3O6G7-2JA7-DHDB-6GEL-TTVIBIQTDAP8<span class="nt"></dc:relation></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"Informatiehuis Marien - Open Data - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>http://www.informatiehuismarien.nl/open-data/<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"website"</span> <span class="na">name=</span><span class="s">"Informatiehuis Marien - website"</span> <span class="na">description=</span><span class="s">""</span><span class="nt">></span>www.informatiehuismarien.nl<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:identifier></span>b9e58aec-aa6c-462d-a733-ed68bda39fe3<span class="nt"></dc:identifier></span>
+      <span class="nt"><dc:date></span>2011-12-31<span class="nt"></dc:date></span>
+      <span class="nt"><dc:title></span>Milieueffectmetingen monitoring shortlist wind op zee<span class="nt"></dc:title></span>
+      <span class="nt"><dc:subject></span>benthos<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>vissen<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>vogels<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>milieu<span class="nt"></dc:subject></span>
+      <span class="nt"><dc:subject></span>environment<span class="nt"></dc:subject></span>
+      <span class="nt"><dct:abstract></span>Betreft monitoringsdata. Bij de start van de bouw van de eerste windparken op zee was nog veel onbekend over de ecologische effecten. Het Shortlist onderzoek richt zich op enerzijds de verspreiding van soorten (vogels, vissen en zeezoogdieren) en anderzijds de effecten op deze soorten in relatie tot de bouw en aanwezigheid van windparken. Het onderzoek is uitgevoerd in de periode 2010-2011. Rapporten zijn te vinden op www.informatiehuismarien.nl<span class="nt"></dct:abstract></span>
+      <span class="nt"><dc:description></span>Betreft monitoringsdata. Bij de start van de bouw van de eerste windparken op zee was nog veel onbekend over de ecologische effecten. Het Shortlist onderzoek richt zich op enerzijds de verspreiding van soorten (vogels, vissen en zeezoogdieren) en anderzijds de effecten op deze soorten in relatie tot de bouw en aanwezigheid van windparken. Het onderzoek is uitgevoerd in de periode 2010-2011. Rapporten zijn te vinden op www.informatiehuismarien.nl<span class="nt"></dc:description></span>
+      <span class="nt"><dc:source></span>Betreft monitoringsdata verkregen in opdracht van het toenmalig ministerie van Economische Zaken, Landbouw en Innovatie en het ministerie van Infrastructuur en Milieu. Het onderzoek is uitgevoerd door een consortium onder leiding van Imares en TNO (bestaande uit Bureau Waardenburg, NIOZ, Seamarco en TNO).<span class="nt"></dc:source></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"Milieueffectmetingen shortlist wind op zee - vogels - OGC:WMS"</span><span class="nt">></span>http://marineproject.openearth.nl/geoserver/ihm_viewer/ows?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WFS"</span> <span class="na">name=</span><span class="s">"Milieueffectmetingen shortlist wind op zee - vogels - OGC:WFS"</span><span class="nt">></span>http://marineproject.openearth.nl/geoserver/ihm_viewer/ows?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"Milieueffectmetingen shortlist wind op zee - vliegroute_mantelmeeuw - OGC:WMS"</span><span class="nt">></span>http://marineproject.openearth.nl/geoserver/ihm_viewer/ows?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WFS"</span> <span class="na">name=</span><span class="s">"Milieueffectmetingen shortlist wind op zee - vliegroute_mantelmeeuw - OGC:WFS"</span><span class="nt">></span>http://marineproject.openearth.nl/geoserver/ihm_viewer/ows?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WMS"</span> <span class="na">name=</span><span class="s">"Milieueffectmetingen shortlist wind op zee - zeezoogdieren - OGC:WMS"</span><span class="nt">></span>http://marineproject.openearth.nl/geoserver/ihm_viewer/ows?<span class="nt"></dc:URI></span>
+      <span class="nt"><dc:URI</span> <span class="na">protocol=</span><span class="s">"OGC:WFS"</span> <span class="na">name=</span><span class="s">"Milieueffectmetingen shortlist wind op zee - zeezoogdieren - OGC:WFS"</span><span class="nt">></span>http://marineproject.openearth.nl/geoserver/ihm_viewer/ows?<span class="nt"></dc:URI></span>
+  <span class="nt"></csw:SearchResults></span>
 <span class="nt"></csw:GetRecordsResponse></span>
-</pre>
-</div>
+</pre></div>
 </body>
 </html>
\ No newline at end of file
