[GRASS-SVN] r67251 - grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid
Sat Dec 19 13:11:31 PST 2015
Author: neteler
Date: 2015-12-19 13:11:31 -0800 (Sat, 19 Dec 2015)
New Revision: 67251
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py
pygrass grid module: fix references to old map type names (trac #2612)
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py	2015-12-19 21:10:49 UTC (rev 67250)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/grid/grid.py	2015-12-19 21:11:31 UTC (rev 67251)
@@ -251,7 +251,7 @@
         mpclc(expression="%s=%s" % (name, rast), overwrite=True, env_=env)
         file_dst = "%s.pack" % os.path.join(path_dst, name)
         rpck(input=name, output=file_dst, overwrite=True, env_=env)
-        remove(flags='f', type='rast', name=name, env_=env)
+        remove(flags='f', type='raster', name=name, env_=env)
         # change gisdbase to dst
         env['GISRC'] = gisrc_dst
         rupck(input=file_dst, output=rast_clean, overwrite=True, env_=env)
@@ -285,7 +285,7 @@
         name = nam % vect
         vpck(input=name, output=file_dst, overwrite=True, env_=env)
-        remove(flags='f', type='vect', name=name, env_=env)
+        remove(flags='f', type='vector', name=name, env_=env)
         vupck(input=file_dst, output=vect, overwrite=True, env_=env)
@@ -472,7 +472,7 @@
                   width=self.width, height=self.height,
                   overlap=self.overlap)
             patt = '%s-*' % inm.value
-            inlist[inm.value] = sorted(self.mset.glist(type='rast',
+            inlist[inm.value] = sorted(self.mset.glist(type='raster',
                                                        pattern=patt))
         self.inlist = inlist
@@ -600,4 +600,4 @@
         if self.inlist:
             grm = Module('g.remove')
             for key in self.inlist:
-                grm(flags='f', type='rast', name=self.inlist[key])
+                grm(flags='f', type='raster', name=self.inlist[key])
