[GRASS-SVN] r67267 - grass-addons/grass7/gui/wxpython/wx.metadata/mdlib
svn_grass at osgeo.org
Sun Dec 20 02:44:47 PST 2015
Author: krejcmat
Date: 2015-12-20 02:44:47 -0800 (Sun, 20 Dec 2015)
New Revision: 67267
grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py
addons wx.metadata: fix issue #2833- g.gui.metadata export to pdf fails
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py 2015-12-20 10:43:02 UTC (rev 67266)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py 2015-12-20 10:44:47 UTC (rev 67267)
@@ -3,8 +3,9 @@
except:
sys.exit('owslib library is missing. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >')
import tempfile, sys, os
-from grass.pygrass.utils import set_path
+from grass.pygrass.utils import set_path,get_lib_path
from grass.script import core as grass
+from core.gcmd import GError, GMessage, GWarning
set_path(modulename='wx.metadata', dirname='mdlib')
@@ -49,14 +50,15 @@
grass.run_command('d.mon', start='cairo', output=f, width=200, height=200, overwrite=True)
grass.run_command('d.erase')
if self.type == 'raster':
+ grass.run_command('g.region', raster=self.map)
grass.run_command('d.rast', map=self.map)
if self.type == 'vector':
+ grass.run_command('g.region', vector=self.map)
grass.run_command('d.vect', map=self.map)
grass.run_command('d.mon', stop='cairo')
grass.run_command('g.region', region='tmpPdf')
return f
def findItem(self, items, name2, idx=-1):
values = []
for i in items:
@@ -134,8 +136,9 @@
self.doc.set_theme(MyTheme)
- logo_path = '/home/matt/Dropbox/GSOC2015/pdfExp/logo.png'
- self.doc.add_image(logo_path, 50, 50, LEFT)
+ logo_path = get_lib_path("wx.metadata",'config')
+ logo_path = os.path.join(logo_path,'logo_variant_bg.png')
+ self.doc.add_image(logo_path, 57, 73, LEFT)
if self.map is None:
self.doc.add_header(self.filename, T1)
@@ -180,9 +183,6 @@
##################### Keywords ################################## TODO
##################### Geographic ##################################
self.doc.add_spacer(25)
self.doc.add_header('Geographic Location', H1)
@@ -198,10 +198,15 @@
mapPath = MapBBFactory([[maxx, minx], [maxy, miny]], )
- gmap = Image(mapPath.link1, 200, 200)
- gmap1 = Image(mapPath.link2, 200, 200)
- self.doc.add(Table([[gmap1, gmap]]))
- self.doc.add(PageBreak())
+ ##################### Add google picture(extend) ##################################
+ try:
+ gmap = Image(mapPath.link1, 200, 200)
+ gmap1 = Image(mapPath.link2, 200, 200)
+ self.doc.add(Table([[gmap1, gmap]]))
+ self.doc.add(PageBreak())
+ except:
+ GWarning("Cannot download metadata picture of extend provided by Google API. Please check internet connection.")
##################### Temporal ##################################
self.doc.add_header('Temporal reference', H1)
@@ -429,7 +434,6 @@
def addValue(self, value):
self.value.append(value)
class Point():
"""Stores a simple (x,y) point. It is used for storing x/y pixels.
