[GRASS-SVN] r67276 - grass/trunk/imagery/i.cluster
svn_grass at osgeo.org
Sun Dec 20 04:51:44 PST 2015
Author: martinl
Date: 2015-12-20 04:51:44 -0800 (Sun, 20 Dec 2015)
New Revision: 67276
grass/trunk/imagery/i.cluster/main.c
grass/trunk/imagery/i.cluster/print1.c
grass/trunk/imagery/i.cluster/print2.c
grass/trunk/imagery/i.cluster/print3.c
grass/trunk/imagery/i.cluster/print4.c
grass/trunk/imagery/i.cluster/print5.c
grass/trunk/imagery/i.cluster/print6.c
i.cluster: use cross-platforn newline character for reports
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c 2015-12-20 12:50:48 UTC (rev 67275)
+++ grass/trunk/imagery/i.cluster/main.c 2015-12-20 12:51:44 UTC (rev 67276)
@@ -232,42 +232,42 @@
fprintf(report,
- _("#################### CLUSTER (%s) ####################\n\n"),
- G_date());
- fprintf(report, _("Location: %s\n"), G_location());
- fprintf(report, _("Mapset: %s\n"), G_mapset());
- fprintf(report, _("Group: %s\n"), group);
- fprintf(report, _("Subgroup: %s\n"), subgroup);
+ _("#################### CLUSTER (%s) ####################%s%s"),
+ G_date(), HOST_NEWLINE, HOST_NEWLINE);
+ fprintf(report, _("Location: %s%s"), G_location(), HOST_NEWLINE);
+ fprintf(report, _("Mapset: %s%s"), G_mapset(), HOST_NEWLINE);
+ fprintf(report, _("Group: %s%s"), group, HOST_NEWLINE);
+ fprintf(report, _("Subgroup: %s%s"), subgroup, HOST_NEWLINE);
for (n = 0; n < ref.nfiles; n++) {
- fprintf(report, _(" %s\n"),
- G_fully_qualified_name(ref.file[n].name, ref.file[n].mapset));
+ fprintf(report, _(" %s%s"),
+ G_fully_qualified_name(ref.file[n].name, ref.file[n].mapset), HOST_NEWLINE);
- fprintf(report, _("Result signature file: %s\n"), outsigfile);
- fprintf(report, "\n");
- fprintf(report, _("Region\n"));
- fprintf(report, _(" North: %12.2f East: %12.2f\n"), window.north,
- window.east);
- fprintf(report, _(" South: %12.2f West: %12.2f\n"), window.south,
- window.west);
- fprintf(report, _(" Res: %12.2f Res: %12.2f\n"), window.ns_res,
- window.ew_res);
- fprintf(report, _(" Rows: %12d Cols: %12d Cells: %d\n"), nrows, ncols,
- nrows * ncols);
- fprintf(report, _("Mask: %s\n"), Rast_mask_info());
- fprintf(report, _("Cluster parameters\n"));
+ fprintf(report, _("Result signature file: %s%s"), outsigfile, HOST_NEWLINE);
+ fprintf(report, "%s", HOST_NEWLINE);
+ fprintf(report, _("Region%s"), HOST_NEWLINE);
+ fprintf(report, _(" North: %12.2f East: %12.2f%s"), window.north,
+ window.east, HOST_NEWLINE);
+ fprintf(report, _(" South: %12.2f West: %12.2f%s"), window.south,
+ window.west, HOST_NEWLINE);
+ fprintf(report, _(" Res: %12.2f Res: %12.2f%s"), window.ns_res,
+ window.ew_res, HOST_NEWLINE);
+ fprintf(report, _(" Rows: %12d Cols: %12d Cells: %d%s"), nrows, ncols,
+ nrows * ncols, HOST_NEWLINE);
+ fprintf(report, _("Mask: %s%s"), Rast_mask_info(), HOST_NEWLINE);
+ fprintf(report, _("Cluster parameters%s"), HOST_NEWLINE);
fprintf(report, _(" Number of initial classes: %d"), maxclass);
if (insigfile)
fprintf(report, _(" [from signature file %s]"), insigfile);
- fprintf(report, _(" Minimum class size: %d\n"), mcs);
- fprintf(report, _(" Minimum class separation: %f\n"), sep);
- fprintf(report, _(" Percent convergence: %f\n"), conv);
- fprintf(report, _(" Maximum number of iterations: %d\n"), iters);
- fprintf(report, _(" Row sampling interval: %d\n"), sample_rows);
- fprintf(report, _(" Col sampling interval: %d\n"), sample_cols);
+ fprintf(report, _(" Minimum class size: %d%s"), mcs, HOST_NEWLINE);
+ fprintf(report, _(" Minimum class separation: %f%s"), sep, HOST_NEWLINE);
+ fprintf(report, _(" Percent convergence: %f%s"), conv, HOST_NEWLINE);
+ fprintf(report, _(" Maximum number of iterations: %d%s"), iters, HOST_NEWLINE);
+ fprintf(report, _(" Row sampling interval: %d%s"), sample_rows, HOST_NEWLINE);
+ fprintf(report, _(" Col sampling interval: %d%s"), sample_cols, HOST_NEWLINE);
fflush(report);
x = (DCELL *) G_malloc(ref.nfiles * sizeof(DCELL));
@@ -291,8 +291,8 @@
G_percent(nrows, nrows, 2);
- fprintf(report, _("Sample size: %d points\n"), C.npoints);
+ fprintf(report, _("Sample size: %d points%s"), C.npoints, HOST_NEWLINE);
if (count < 2)
G_fatal_error(_("Not enough sample points. Please run again and "
"choose a larger sample size."));
@@ -311,9 +311,9 @@
I_cluster_exec(&C, maxclass, iters, conv, sep, mcs, checkpoint,
&interrupted);
- fprintf(report, _("\n########## final results #############\n"));
- fprintf(report, _("%d classes (convergence=%.1f%%)\n"),
- I_cluster_nclasses(&C, mcs), (double)C.percent_stable);
+ fprintf(report, _("%s########## final results #############%s"), HOST_NEWLINE, HOST_NEWLINE);
+ fprintf(report, _("%d classes (convergence=%.1f%%)%s"),
+ I_cluster_nclasses(&C, mcs), (double)C.percent_stable, HOST_NEWLINE);
print_separability(report, &C);
print_class_means(report, &C);
@@ -328,10 +328,11 @@
fprintf(report,
- _("\n\n#################### CLASSES ####################\n"));
- fprintf(report, _("\n%d classes, %.2f%% points stable\n"),
- I_cluster_nclasses(&C, 1), (double)C.percent_stable);
- fprintf(report, _("\n######## CLUSTER END (%s) ########\n"), G_date());
+ _("\n\n#################### CLASSES ####################%s"), HOST_NEWLINE);
+ fprintf(report, _("%s%d classes, %.2f%% points stable%s"),
+ HOST_NEWLINE, I_cluster_nclasses(&C, 1), (double)C.percent_stable, HOST_NEWLINE);
+ fprintf(report, _("%s######## CLUSTER END (%s) ########%s"),
+ HOST_NEWLINE, G_date(), HOST_NEWLINE);
fclose(report);
G_done_msg(_("File <%s> created."),
Modified: grass/trunk/imagery/i.cluster/print1.c
--- grass/trunk/imagery/i.cluster/print1.c 2015-12-20 12:50:48 UTC (rev 67275)
+++ grass/trunk/imagery/i.cluster/print1.c 2015-12-20 12:51:44 UTC (rev 67276)
@@ -8,9 +8,9 @@
int band;
- fprintf(fd, "\n");
- fprintf(fd, _("means and standard deviations for %d band%s\n\n"),
- C->nbands, C->nbands == 1 ? "" : "s");
+ fprintf(fd, "%s", HOST_NEWLINE);
+ fprintf(fd, _("means and standard deviations for %d band%s%s%s"),
+ C->nbands, C->nbands == 1 ? "" : "s", HOST_NEWLINE, HOST_NEWLINE);
fprintf(fd, _(" means "));
for (band = 0; band < C->nbands; band++)
fprintf(fd, " %g", C->band_sum[band] / C->npoints);
@@ -19,7 +19,7 @@
fprintf(fd, " %g",
I_stddev(C->band_sum[band], C->band_sum2[band], C->npoints));
- fprintf(fd, "\n\n");
+ fprintf(fd, "%s%s", HOST_NEWLINE, HOST_NEWLINE);
return 0;
Modified: grass/trunk/imagery/i.cluster/print2.c
--- grass/trunk/imagery/i.cluster/print2.c 2015-12-20 12:50:48 UTC (rev 67275)
+++ grass/trunk/imagery/i.cluster/print2.c 2015-12-20 12:51:44 UTC (rev 67276)
@@ -15,11 +15,12 @@
int c;
int n;
- fprintf(fd, _("\nclass means/stddev for each band\n\n"));
+ fprintf(fd, _("%sclass means/stddev for each band%s%s"),
+ HOST_NEWLINE, HOST_NEWLINE, HOST_NEWLINE);
for (c = 0; c < C->nclasses; c++) {
- fprintf(fd, _("class %d (%d)\n"), c + 1, n = C->count[c]);
+ fprintf(fd, _("class %d (%d)%s"), c + 1, n = C->count[c], HOST_NEWLINE);
if (n > 0)
@@ -30,9 +31,9 @@
fprintf(fd, " %g",
I_stddev(C->sum[band][c], C->sum2[band][c], n));
return 0;
Modified: grass/trunk/imagery/i.cluster/print3.c
--- grass/trunk/imagery/i.cluster/print3.c 2015-12-20 12:50:48 UTC (rev 67275)
+++ grass/trunk/imagery/i.cluster/print3.c 2015-12-20 12:51:44 UTC (rev 67276)
@@ -13,15 +13,16 @@
int band;
int c;
- fprintf(fd, _("\ninitial means for each band\n\n"));
+ fprintf(fd, _("%sinitial means for each band%s%s"),
fprintf(fd, _("class %-3d "), c + 1);
fprintf(fd, " %g", C->mean[band][c]);
return 0;
Modified: grass/trunk/imagery/i.cluster/print4.c
--- grass/trunk/imagery/i.cluster/print4.c 2015-12-20 12:50:48 UTC (rev 67275)
+++ grass/trunk/imagery/i.cluster/print4.c 2015-12-20 12:51:44 UTC (rev 67276)
@@ -13,7 +13,7 @@
int band, cat;
char buf[40];
- fprintf(fd, _("class centroids (sum/count=mean)\n"));
+ fprintf(fd, _("class centroids (sum/count=mean)%s"), HOST_NEWLINE);
for (band = 0; band < C->nbands; band++) {
fprintf(fd, _("band %d"), band + 1);
for (cat = 0; cat < C->nclasses; cat++) {
@@ -24,7 +24,7 @@
sprintf(buf, FMT2, C->sum[band][cat], C->count[cat]);
fprintf(fd, "%s %-18s", cat % 4 ? "" : "\n", buf);
return 0;
Modified: grass/trunk/imagery/i.cluster/print5.c
--- grass/trunk/imagery/i.cluster/print5.c 2015-12-20 12:50:48 UTC (rev 67275)
+++ grass/trunk/imagery/i.cluster/print5.c 2015-12-20 12:51:44 UTC (rev 67276)
@@ -12,15 +12,16 @@
double q;
I_cluster_sum2(C);
- fprintf(fd, _("\nclass separability matrix\n\n"));
+ fprintf(fd, _("%sclass separability matrix%s%s"),
for (first = 0; first < C->nclasses; first = last) {
last = first + 10;
if (last > C->nclasses)
last = C->nclasses;
- fprintf(fd, "\n ");
+ fprintf(fd, "%s ", HOST_NEWLINE);
for (c2 = first; c2 < last; c2++)
fprintf(fd, " %3d", c2 + 1);
for (c1 = first; c1 < C->nclasses; c1++) {
fprintf(fd, "%3d ", c1 + 1);
for (c2 = first; c2 <= c1 && c2 < last; c2++) {
@@ -32,9 +33,9 @@
else
fprintf(fd, " --- ");
return 0;
Modified: grass/trunk/imagery/i.cluster/print6.c
--- grass/trunk/imagery/i.cluster/print6.c 2015-12-20 12:50:48 UTC (rev 67275)
+++ grass/trunk/imagery/i.cluster/print6.c 2015-12-20 12:51:44 UTC (rev 67276)
@@ -10,9 +10,9 @@
fprintf(fd, _("class distribution"));
- fprintf(fd, "%s %10ld", cat % 5 ? "" : "\n", (long)C->count[cat]);
+ fprintf(fd, "%s %10ld", cat % 5 ? "" : HOST_NEWLINE, (long)C->count[cat]);
return 0;
