[GRASS-SVN] r67278 - in grass/trunk: lib/vector/Vlib vector/v.out.ascii
svn_grass at osgeo.org
Sun Dec 20 05:06:38 PST 2015
Author: martinl
Date: 2015-12-20 05:06:38 -0800 (Sun, 20 Dec 2015)
New Revision: 67278
grass/trunk/lib/vector/Vlib/ascii.c
grass/trunk/vector/v.out.ascii/main.c
v.out.ascii + vlib: use cross-platform newline character
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2015-12-20 13:00:07 UTC (rev 67277)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2015-12-20 13:06:38 UTC (rev 67278)
@@ -5,7 +5,7 @@
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009, 2011-2013 by the GRASS Development Team
+ (C) 2001-2015 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -544,7 +544,7 @@
fprintf(ascii, "%s", columns[i]); /* can not happen */
- fprintf(ascii, "\n");
+ fprintf(ascii, "%s", HOST_NEWLINE);
Points = Vect_new_line_struct();
@@ -637,7 +637,7 @@
G_trim_decimal(xstring);
G_rasprintf(&ystring, &ysize, "%.*f", dp, Points->y[0]);
G_trim_decimal(ystring);
- fprintf(att, "A %s %s %d\n", xstring, ystring, cat);
+ fprintf(att, "A %s %s %d%s", xstring, ystring, cat, HOST_NEWLINE);
continue;
@@ -764,15 +764,15 @@
else if (format == GV_ASCII_FORMAT_STD) {
/* FORMAT_STANDARD */
if (ver == 5 && Cats->n_cats > 0)
- fprintf(ascii, "%c %d %d\n", ctype, Points->n_points,
- Cats->n_cats);
+ fprintf(ascii, "%c %d %d%s", ctype, Points->n_points,
+ Cats->n_cats, HOST_NEWLINE);
else
- fprintf(ascii, "%c %d\n", ctype, Points->n_points);
+ fprintf(ascii, "%c %d%s", ctype, Points->n_points, HOST_NEWLINE);
xptr = Points->x;
yptr = Points->y;
@@ -789,22 +789,22 @@
if (Map->head.with_z) {
G_rasprintf(&zstring, &zsize, "%.*f", dp, *zptr++);
G_trim_decimal(zstring);
- fprintf(ascii, " %-12s %-12s %-12s\n", xstring,
- ystring, zstring);
+ fprintf(ascii, " %-12s %-12s %-12s%s", xstring,
+ ystring, zstring, HOST_NEWLINE);
else {
- fprintf(ascii, " %-12s %-12s\n", xstring, ystring);
+ fprintf(ascii, " %-12s %-12s%s", xstring, ystring, HOST_NEWLINE);
} /*Version 4 */
else {
- fprintf(ascii, " %-12s %-12s\n", ystring, xstring);
+ fprintf(ascii, " %-12s %-12s%s", ystring, xstring, HOST_NEWLINE);
if (ver == 5) {
for (i = 0; i < Cats->n_cats; i++) {
- fprintf(ascii, " %-5d %-10d\n", Cats->field[i],
- Cats->cat[i]);
+ fprintf(ascii, " %-5d %-10d%s", Cats->field[i],
+ Cats->cat[i], HOST_NEWLINE);
else {
@@ -814,7 +814,7 @@
- fprintf(att, "P %s %s %d\n", xstring, ystring, cat);
+ fprintf(att, "P %s %s %d%s", xstring, ystring, cat, HOST_NEWLINE);
else {
x = (Points->x[1] + Points->x[0]) / 2;
@@ -824,7 +824,7 @@
G_rasprintf(&ystring, &ysize, "%.*f", dp, y);
- fprintf(att, "L %s %s %d\n", xstring, ystring, cat);
+ fprintf(att, "L %s %s %d%s", xstring, ystring, cat, HOST_NEWLINE);
@@ -879,7 +879,7 @@
/* write inner ring */
Vect_sfa_line_astext(Points, GV_BOUNDARY, 0, dp, ascii); /* boundary is always 2D */
- fprintf(ascii, ")\n");
+ fprintf(ascii, ")%s", HOST_NEWLINE);
count++;
@@ -916,15 +916,24 @@
void Vect_write_ascii_head(FILE *dascii, struct Map_info *Map)
- fprintf(dascii, "ORGANIZATION: %s\n", Vect_get_organization(Map));
- fprintf(dascii, "DIGIT DATE: %s\n", Vect_get_date(Map));
- fprintf(dascii, "DIGIT NAME: %s\n", Vect_get_person(Map));
- fprintf(dascii, "MAP NAME: %s\n", Vect_get_map_name(Map));
- fprintf(dascii, "MAP DATE: %s\n", Vect_get_map_date(Map));
- fprintf(dascii, "MAP SCALE: %d\n", Vect_get_scale(Map));
- fprintf(dascii, "OTHER INFO: %s\n", Vect_get_comment(Map));
- fprintf(dascii, "ZONE: %d\n", Vect_get_zone(Map));
- fprintf(dascii, "MAP THRESH: %f\n", Vect_get_thresh(Map));
+ fprintf(dascii, "ORGANIZATION: %s%s",
+ Vect_get_organization(Map), HOST_NEWLINE);
+ fprintf(dascii, "DIGIT DATE: %s%s",
+ Vect_get_date(Map), HOST_NEWLINE);
+ fprintf(dascii, "DIGIT NAME: %s%s",
+ Vect_get_person(Map), HOST_NEWLINE);
+ fprintf(dascii, "MAP NAME: %s%s",
+ Vect_get_map_name(Map), HOST_NEWLINE);
+ fprintf(dascii, "MAP DATE: %s%s",
+ Vect_get_map_date(Map), HOST_NEWLINE);
+ fprintf(dascii, "MAP SCALE: %d%s",
+ Vect_get_scale(Map), HOST_NEWLINE);
+ fprintf(dascii, "OTHER INFO: %s%s",
+ Vect_get_comment(Map), HOST_NEWLINE);
+ fprintf(dascii, "ZONE: %d%s",
+ Vect_get_zone(Map), HOST_NEWLINE);
+ fprintf(dascii, "MAP THRESH: %f%s",
+ Vect_get_thresh(Map), HOST_NEWLINE);
/* check category */
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2015-12-20 13:00:07 UTC (rev 67277)
+++ grass/trunk/vector/v.out.ascii/main.c 2015-12-20 13:06:38 UTC (rev 67278)
@@ -131,7 +131,7 @@
Vect_write_ascii_head(ascii, &Map);
- fprintf(ascii, "VERTI:\n");
+ fprintf(ascii, "VERTI:%s", HOST_NEWLINE);
/* Open dig_att */
