[GRASS-SVN] r67290 - in grass/trunk/lib/db: dbmi_client dbmi_driver
svn_grass at osgeo.org
Sun Dec 20 14:27:33 PST 2015
Author: martinl
Date: 2015-12-20 14:27:33 -0800 (Sun, 20 Dec 2015)
New Revision: 67290
grass/trunk/lib/db/dbmi_client/shutdown.c
grass/trunk/lib/db/dbmi_client/start.c
grass/trunk/lib/db/dbmi_driver/driver.c
Hangs when closing db drivers (#2775)
Modified: grass/trunk/lib/db/dbmi_client/shutdown.c
--- grass/trunk/lib/db/dbmi_client/shutdown.c 2015-12-20 22:13:07 UTC (rev 67289)
+++ grass/trunk/lib/db/dbmi_client/shutdown.c 2015-12-20 22:27:33 UTC (rev 67290)
@@ -37,10 +37,8 @@
int status;
-#ifdef __MINGW32__
db__set_protocol_fds(driver->send, driver->recv);
DB_START_PROCEDURE_CALL(DB_PROC_SHUTDOWN_DRIVER);
-#endif
/* close the communication FILEs */
fclose(driver->send);
Modified: grass/trunk/lib/db/dbmi_client/start.c
--- grass/trunk/lib/db/dbmi_client/start.c 2015-12-20 22:13:07 UTC (rev 67289)
+++ grass/trunk/lib/db/dbmi_client/start.c 2015-12-20 22:27:33 UTC (rev 67290)
@@ -28,6 +28,13 @@
#define READ 0
#define WRITE 1
+void close_on_exec(int fd)
+#ifndef __MINGW32__
+ int flags = fcntl(fd, F_GETFD);
+ fcntl(fd, F_SETFD, flags | FD_CLOEXEC);
+#endif
\brief Initialize a new dbDriver for db transaction.
@@ -132,6 +139,11 @@
return (dbDriver *) NULL;
+ close_on_exec(p1[READ]);
+ close_on_exec(p1[WRITE]);
+ close_on_exec(p2[READ]);
+ close_on_exec(p2[WRITE]);
pid = G_spawn_ex(startup,
SF_BACKGROUND,
SF_REDIRECT_DESCRIPTOR, 0, p1[READ],
Modified: grass/trunk/lib/db/dbmi_driver/driver.c
--- grass/trunk/lib/db/dbmi_driver/driver.c 2015-12-20 22:13:07 UTC (rev 67289)
+++ grass/trunk/lib/db/dbmi_driver/driver.c 2015-12-20 22:27:33 UTC (rev 67290)
@@ -139,12 +139,10 @@
stat = DB_OK;
/* get the procedure number */
while (db__recv_procnum(&procnum) == DB_OK) {
-#ifdef __MINGW32__
if (procnum == DB_PROC_SHUTDOWN_DRIVER) {
db__send_procedure_ok(procnum);
break;
-#endif
db_clear_error();
/* find this procedure */
