[GRASS-SVN] r67297 - in grass/trunk/raster/r.watershed: ram seg
Mon Dec 21 02:06:25 PST 2015
Author: mmetz
Date: 2015-12-21 02:06:25 -0800 (Mon, 21 Dec 2015)
New Revision: 67297
   grass/trunk/raster/r.watershed/ram/do_astar.c
   grass/trunk/raster/r.watershed/seg/do_astar.c
r.watershed: fix correction for diagonal flow bias
Modified: grass/trunk/raster/r.watershed/ram/do_astar.c
--- grass/trunk/raster/r.watershed/ram/do_astar.c	2015-12-21 08:00:06 UTC (rev 67296)
+++ grass/trunk/raster/r.watershed/ram/do_astar.c	2015-12-21 10:06:25 UTC (rev 67297)
@@ -133,8 +133,8 @@
 			get_slope2(alt_val, alt_nbr[ct_dir],
 				   dist_to_nbr[ct_dir]);
-		if (!is_worked) {
-		    if (ct_dir > 3 && slope[ct_dir] >= 0) {
+		if (!is_in_list || (!is_worked && asp[index_up] < 0)) {
+		    if (ct_dir > 3 && slope[ct_dir] > 0) {
 			if (slope[nbr_ew[ct_dir]] >= 0) {
 			    /* slope to ew nbr > slope to center */
 			    if (slope[ct_dir] <
@@ -154,14 +154,14 @@
 		if (!skip_diag) {
 		    /* add neighbour as new point if not in the list */
-		    if (is_in_list == 0) {
+		    if (!is_in_list) {
 			add_pt(upr, upc, alt_nbr[ct_dir]);
 			/* set flow direction */
 			asp[index_up] = drain[upr - r + 1][upc - c + 1];
-		    else if (is_in_list && is_worked == 0 && slope[ct_dir] > 0) {
+		    else if (!is_worked) {
 			/* neighbour is edge in list, not yet worked */
-			if (asp[index_up] < 0) {
+			if (asp[index_up] < 0 && slope[ct_dir] > 0) {
 			    /* adjust flow direction for edge cell */
Modified: grass/trunk/raster/r.watershed/seg/do_astar.c
--- grass/trunk/raster/r.watershed/seg/do_astar.c	2015-12-21 08:00:06 UTC (rev 67296)
+++ grass/trunk/raster/r.watershed/seg/do_astar.c	2015-12-21 10:06:25 UTC (rev 67297)
@@ -86,8 +86,8 @@
-		if (!is_worked) {
+		if (!is_in_list || (!is_worked && af.asp < 0)) {
 			    if (slope[ct_dir] <
@@ -107,16 +107,16 @@
 		if (!skip_diag) {
 			af.asp = drain[upr - r + 1][upc - c + 1];
 			FLAG_SET(af.flag, INLISTFLAG);
 			seg_put(&aspflag, (char *)&af, upr, upc);
-			if (af.asp < 0) {
+			if (af.asp < 0 && slope[ct_dir] > 0) {
