[GRASS-SVN] r67306 - in grass/trunk: gui/wxpython gui/wxpython/core lib/init
svn_grass at osgeo.org
Mon Dec 21 07:41:08 PST 2015
Author: martinl
Date: 2015-12-21 07:41:08 -0800 (Mon, 21 Dec 2015)
New Revision: 67306
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/wxgui.py
grass/trunk/lib/init/grass.py
Close wxGUI on GRASS CLI exit (#770) - experimental prototype
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2015-12-21 15:05:45 UTC (rev 67305)
+++ grass/trunk/gui/wxpython/core/utils.py 2015-12-21 15:41:08 UTC (rev 67306)
@@ -3,7 +3,7 @@
@brief Misc utilities for wxGUI
-(C) 2007-2013 by the GRASS Development Team
+(C) 2007-2015 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -1125,6 +1125,32 @@
do_doctest_gettext_workaround()
return doctest.testmod().failed
+def registerPid(pid):
+ """Register process id as GUI_PID GRASS variable
+ :param: pid process id
+ env = grass.gisenv()
+ guiPid = []
+ if 'GUI_PID' in env:
+ guiPid = env['GUI_PID'].split(',')
+ guiPid.append(str(pid))
+ grass.run_command('g.gisenv', set='GUI_PID={}'.format(','.join(guiPid)))
+def unregisterPid(pid):
+ """Unregister process id from GUI_PID GRASS variable
+ if 'GUI_PID' not in env:
+ return
+ pid = str(os.getpid())
+ if pid in guiPid:
+ guiPid.remove(pid)
if __name__ == '__main__':
sys.exit(doc_test())
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2015-12-21 15:05:45 UTC (rev 67305)
+++ grass/trunk/gui/wxpython/wxgui.py 2015-12-21 15:41:08 UTC (rev 67306)
@@ -20,9 +20,10 @@
import os
import sys
import getopt
+import atexit
from core import globalvar
-from core.utils import _
+from core.utils import _, registerPid, unregisterPid
from grass.exceptions import Usage
from grass.script.core import set_raise_on_error
@@ -110,7 +111,9 @@
return workspaceFile
+def cleanup():
+ unregisterPid(os.getpid())
def main(argv = None):
if argv is None:
@@ -133,7 +136,11 @@
q = wx.LogNull()
set_raise_on_error(True)
+ # register GUI PID
+ registerPid(os.getpid())
app.MainLoop()
if __name__ == "__main__":
+ atexit.register(cleanup)
sys.exit(main())
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-12-21 15:05:45 UTC (rev 67305)
+++ grass/trunk/lib/init/grass.py 2015-12-21 15:41:08 UTC (rev 67306)
@@ -133,7 +133,7 @@
env_curr = read_gisrc(gisrc)
env_new = {}
for k,v in env_curr.items():
- if k == 'PID' or k.startswith('MONITOR'):
+ if k.endswith('PID') or k.startswith('MONITOR'):
continue
env_new[k] = v
@@ -1352,6 +1352,19 @@
Popen([os.getenv('GRASS_PYTHON'), wxpath("wxgui.py")])
+def close_gui():
+ """Close GUI if running"""
+ if gpath('etc', 'python') not in sys.path:
+ sys.path.append(gpath('etc', 'python'))
+ from grass.script import core as gcore # pylint: disable=E0611
+ env = gcore.gisenv()
+ return
+ import signal
+ for pid in env['GUI_PID'].split(','):
+ debug("Exiting GUI with pid={}".format(pid))
+ os.kill(int(pid), signal.SIGTERM)
def clear_screen():
"""Clear terminal"""
if windows:
@@ -1904,7 +1917,9 @@
exit_val = shell_process.wait()
if exit_val != 0:
warning(_("Failed to start shell '%s'") % os.getenv('SHELL'))
+ # close GUI if running
+ close_gui()
# here we are at the end of grass session
clear_screen()
# TODO: can we just register this atexit?
