[GRASS-SVN] r67313 - in grass/trunk/vector/v.out.lidar: . testsuite
svn_grass at osgeo.org
Mon Dec 21 17:31:02 PST 2015
Author: wenzeslaus
Date: 2015-12-21 17:31:02 -0800 (Mon, 21 Dec 2015)
New Revision: 67313
Added:
grass/trunk/vector/v.out.lidar/testsuite/
grass/trunk/vector/v.out.lidar/testsuite/test_v_out_lidar.py
grass/trunk/vector/v.out.lidar/main.c
grass/trunk/vector/v.out.lidar/v.out.lidar.html
v.out.lidar: scale the data with .01, add basic tests
Modified: grass/trunk/vector/v.out.lidar/main.c
--- grass/trunk/vector/v.out.lidar/main.c 2015-12-22 01:27:47 UTC (rev 67312)
+++ grass/trunk/vector/v.out.lidar/main.c 2015-12-22 01:31:02 UTC (rev 67313)
@@ -471,6 +471,7 @@
struct Option *grass_rgb_column_opt;
struct Option *red_column_opt, *green_column_opt, *blue_column_opt;
struct Option *where_opt;
+ struct Option *las_xyscale_opt, *las_zscale_opt;
struct Flag *region_flag, *no_color_table_flag;
struct Map_info vinput;
@@ -600,6 +601,26 @@
blue_column_opt->required = NO;
blue_column_opt->guisection = _("Columns");
+ las_xyscale_opt = G_define_option();
+ las_xyscale_opt->key = "las_xyscale";
+ las_xyscale_opt->type = TYPE_DOUBLE;
+ las_xyscale_opt->required = YES;
+ las_xyscale_opt->answer = "0.01";
+ las_xyscale_opt->label = _("Internal scale to apply to X and Y values");
+ las_xyscale_opt->description = _("This scale does not change"
+ " the values itself but only how precisely they are stored,"
+ " for example 0.01 will preserve two decimal places");
+ las_zscale_opt = G_define_option();
+ las_zscale_opt->key = "las_zscale";
+ las_zscale_opt->type = TYPE_DOUBLE;
+ las_zscale_opt->required = YES;
+ las_zscale_opt->answer = "0.01";
+ las_zscale_opt->label = _("Internal scale to apply to z values");
+ las_zscale_opt->description = _("This scale does not change"
region_flag = G_define_flag();
region_flag->key = 'r';
region_flag->guisection = _("Selection");
@@ -682,6 +703,8 @@
LASSRS_SetWKT(las_srs, current_wkt);
LASHeader_SetSRS(las_header, las_srs);
+ LASHeader_SetScale(las_header, atof(las_xyscale_opt->answer),
+ atof(las_xyscale_opt->answer), atof(las_zscale_opt->answer));
/* TODO: support append mode */
int write_mode = 1;
Added: grass/trunk/vector/v.out.lidar/testsuite/test_v_out_lidar.py
--- grass/trunk/vector/v.out.lidar/testsuite/test_v_out_lidar.py (rev 0)
+++ grass/trunk/vector/v.out.lidar/testsuite/test_v_out_lidar.py 2015-12-22 01:31:02 UTC (rev 67313)
@@ -0,0 +1,76 @@
+Name: test_v_out_lidar
+Purpose: v.out.lidar export test
+Author: Vaclav Petras
+Copyright: (C) 2015 by Vaclav Petras and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+import os
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class BasicTest(TestCase):
+ """Test case for watershed module
+ This tests expects v.random to work properly.
+ # Setup variables to be used for outputs
+ vector_points = 'v_out_lidar_original'
+ imported_points = 'v_out_lidar_imported'
+ las_file = 'v_out_lidar_points.las'
+ @classmethod
+ def setUpClass(cls):
+ """Ensures expected computational region and generated data"""
+ cls.use_temp_region()
+ cls.runModule('g.region', n=20, s=10, e=25, w=15, res=1)
+ cls.runModule('v.random', flags='zb', output=cls.vector_points,
+ npoints=300, zmin=200, zmax=500, seed=100)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region and generated data"""
+ cls.runModule('g.remove', flags='f', type='vector',
+ name=cls.vector_points)
+ cls.del_temp_region()
+ def tearDown(self):
+ """Remove the outputs created by the export
+ This is executed after each test run.
+ if os.path.isfile(self.las_file):
+ os.remove(self.las_file)
+ self.runModule('g.remove', flags='f', type='vector',
+ name=self.imported_points)
+ def test_module_runs_output_created(self):
+ """Test to see if the standard outputs are created"""
+ self.assertModule('v.out.lidar', input=self.vector_points,
+ output=self.las_file)
+ self.assertFileExists(self.las_file)
+ def test_output_identical(self):
+ This test depends on v.in.lidar working properly.
+ self.assertModule('v.in.lidar', input=self.las_file,
+ output=self.imported_points, flags='bt')
+ self.assertVectorExists(self.imported_points)
+ self.assertVectorEqualsVector(
+ actual=self.imported_points,
+ reference=self.vector_points,
+ digits=2, precision=.01)
+if __name__ == '__main__':
+ test()
Modified: grass/trunk/vector/v.out.lidar/v.out.lidar.html
--- grass/trunk/vector/v.out.lidar/v.out.lidar.html 2015-12-22 01:27:47 UTC (rev 67312)
+++ grass/trunk/vector/v.out.lidar/v.out.lidar.html 2015-12-22 01:31:02 UTC (rev 67313)
@@ -9,7 +9,14 @@
The <b>where</b> option limits the export by attributes (applied only
when the columns are used for export).
+<p>
+LAS format stores the coordinates as integers rounding the decimal places.
+Before that a scale is applied to preserve a certain number of decimal
+places. This scale can be set using <b>las_xyscale</b> and <b>las_xscale</b>
+options. For example, the scale value 0.01 will preserve two decimal
+places while the value 1.0 will preserve none.
<h2>NOTES</h2>
The typical file extensions for the LAS format are .las and .laz (compressed).
