[GRASS-SVN] r67316 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Mon Dec 21 18:02:07 PST 2015
Author: wenzeslaus
Date: 2015-12-21 18:02:07 -0800 (Mon, 21 Dec 2015)
New Revision: 67316
Added:
grass/trunk/vector/v.in.lidar/count_decimation.c
grass/trunk/vector/v.in.lidar/count_decimation.h
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: move out count-based decimation
Files identical with v.decimate.
Copied: grass/trunk/vector/v.in.lidar/count_decimation.c (from rev 67294, grass/trunk/vector/v.decimate/count_decimation.c)
--- grass/trunk/vector/v.in.lidar/count_decimation.c (rev 0)
+++ grass/trunk/vector/v.in.lidar/count_decimation.c 2015-12-22 02:02:07 UTC (rev 67316)
@@ -0,0 +1,134 @@
+ * MODULE: v.decimate
+ * AUTHOR(S): Vaclav Petras
+ * PURPOSE: Reduce the number of points in a vector map
+ * COPYRIGHT: (C) 2015 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the COPYING file that comes with GRASS
+ * for details.
+/* TODO: change int */
+/* TODO: revise names */
+#include "count_decimation.h"
+#include <grass/gis.h>
+#include <stdlib.h>
+void count_decimation_init(struct CountDecimationControl *control,
+ int *skip, int *preserve,
+ int *offset, int *limit)
+ control->skip_every = 0;
+ control->preserve_every = 0;
+ /* counter used by both but that's ok, skip and preserve are exclusive */
+ control->every_counter = 0;
+ control->n_count_filtered = 0;
+ control->offset_n = 0;
+ control->offset_n_counter = 0;
+ control->limit_n = 0;
+ control->limit_n_counter = 0;
+ if (skip)
+ control->skip_every = *skip;
+ if (preserve)
+ control->preserve_every = *preserve;
+ if (offset)
+ control->offset_n = *offset;
+ if (limit)
+ control->limit_n = *limit;
+int count_decimation_is_valid(struct CountDecimationControl *control)
+ if (control->skip_every == 1)
+ return FALSE;
+ if (control->skip_every && control->preserve_every > 1)
+ return FALSE;
+ return TRUE;
+int count_decimation_is_noop(struct CountDecimationControl *control)
+ if (control->skip_every < 2 && control->preserve_every < 2
+ && !control->offset_n && !control->limit_n)
+ return TRUE;
+ return FALSE;
+void count_decimation_init_from_str(struct CountDecimationControl *control,
+ const char *skip, const char *preserve,
+ const char *offset, const char *limit)
+ /* TODO: atoi is probably not appropriate */
+ if (skip)
+ control->skip_every = atoi(skip);
+ if (preserve)
+ control->preserve_every = atoi(preserve);
+ if (offset)
+ control->offset_n = atoi(offset);
+ if (limit)
+ control->limit_n = atoi(limit);
+/* TODO: eliminate noop cases */
+int count_decimation_is_out(struct CountDecimationControl *control)
+ if (control->offset_n) {
+ if (control->offset_n_counter < control->offset_n) {
+ control->offset_n_counter++;
+ return TRUE;
+ else {
+ control->offset_n = 0; /* disable offset check */
+ if (control->skip_every) {
+ control->every_counter++;
+ if (control->every_counter == control->skip_every) {
+ control->n_count_filtered++;
+ return TRUE;
+ else if (control->preserve_every) {
+ if (control->every_counter == control->preserve_every) {
+ else {
+ return TRUE;
+ return FALSE;
+int count_decimation_is_end(struct CountDecimationControl *control)
+ if (control->limit_n) {
+ control->limit_n_counter++;
+ /* this matches the last successfully imported point */
+ if (control->limit_n_counter == control->limit_n)
+ return TRUE;
+ return FALSE;
Copied: grass/trunk/vector/v.in.lidar/count_decimation.h (from rev 67262, grass/trunk/vector/v.decimate/count_decimation.h)
--- grass/trunk/vector/v.in.lidar/count_decimation.h (rev 0)
+++ grass/trunk/vector/v.in.lidar/count_decimation.h 2015-12-22 02:02:07 UTC (rev 67316)
@@ -0,0 +1,43 @@
+ * for details.
+#ifndef GRASS_COUNT_DECIMATION_H
+#define GRASS_COUNT_DECIMATION_H
+/* TODO: change int to ul/ull */
+/* TODO: revise names (now partially on some vars in v.in.lidar code) */
+struct CountDecimationControl {
+ int offset_n;
+ int offset_n_counter;
+ int skip_every;
+ int preserve_every;
+ int every_counter;
+ int n_count_filtered;
+ int limit_n;
+ int limit_n_counter;
+ int *offset, int *limit);
+int count_decimation_is_valid(struct CountDecimationControl *control);
+int count_decimation_is_noop(struct CountDecimationControl *control);
+ const char *offset, const char *limit);
+int count_decimation_is_out(struct CountDecimationControl *control);
+int count_decimation_is_end(struct CountDecimationControl *control);
+#endif /* GRASS_COUNT_DECIMATION_H */
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-12-22 01:50:12 UTC (rev 67315)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-12-22 02:02:07 UTC (rev 67316)
@@ -27,6 +27,8 @@
#include <grass/glocale.h>
#include <liblas/capi/liblas.h>
#ifndef MAX
# define MIN(a,b) ((a<b) ? a : b)
# define MAX(a,b) ((a>b) ? a : b)
@@ -897,32 +899,16 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- /* counters used by both but that's ok, the filters are exclusive */
- int skip_every = 0;
- int preserve_every = 0;
- int every_counter = 0;
+ struct CountDecimationControl count_decimation_control;
+ count_decimation_init_from_str(&count_decimation_control,
+ skip_opt->answer, preserve_opt->answer,
+ offset_opt->answer, limit_opt->answer);
+ if (!count_decimation_is_valid(&count_decimation_control))
+ G_fatal_error(_("Settings for count-based decimation are not valid"));
+ /* we don't check if the decimation is noop */
#ifdef HAVE_LONG_LONG_INT
- unsigned long long n_count_filtered = 0;
- unsigned long long offset_n = 0;
- unsigned long long offset_n_counter = 0;
- unsigned long long limit_n = 0;
- unsigned long long limit_n_counter = 0;
-#else
- unsigned long n_count_filtered = 0;
- unsigned long offset_n = 0;
- unsigned long offset_n_counter = 0;
- unsigned long limit_n = 0;
- unsigned long limit_n_counter = 0;
-#endif
- if (skip_opt->answer)
- skip_every = atoi(skip_opt->answer);
- if (preserve_opt->answer)
- preserve_every = atoi(preserve_opt->answer);
- if (offset_opt->answer)
- offset_n = atoi(offset_opt->answer);
- if (limit_opt->answer)
- limit_n = atoi(limit_opt->answer);
-#ifdef HAVE_LONG_LONG_INT
G_important_message(_("Scanning %llu points..."), n_features);
#else
G_important_message(_("Scanning %lu points..."), n_features);
@@ -1010,33 +996,8 @@
continue;
- if (offset_n) {
- if (offset_n_counter < offset_n) {
- offset_n_counter++;
- continue;
- else {
- offset_n = 0; /* disable offset check */
- if (skip_every) {
- every_counter++;
- if (every_counter == skip_every) {
- n_count_filtered++;
- every_counter = 0;
- continue;
- else if (preserve_every) {
- every_counter++;
- if (every_counter == preserve_every) {
- else {
- continue;
+ if (count_decimation_is_out(&count_decimation_control))
+ continue;
Vect_append_point(Points, x, y, z);
if (id_layer)
@@ -1148,12 +1109,8 @@
- if (limit_n) {
- limit_n_counter++;
- /* this matches the last successfully imported point */
- if (limit_n_counter == limit_n)
- break;
+ if (count_decimation_is_end(&count_decimation_control))
+ break;
if (id_layer && cat == GV_CAT_MAX) {
cat_max_reached = TRUE;
break;
@@ -1183,19 +1140,24 @@
Vect_close(&Map);
/* can be easily determined only when iterated over all points */
- if (!limit_n && !cat_max_reached && points_imported != n_features
+ if (!count_decimation_control.limit_n && !cat_max_reached
+ && points_imported != n_features
- not_valid - n_outside - n_filtered - n_class_filtered
- - n_outside_mask - offset_n_counter - n_count_filtered
- - zrange_filtered)
+ - n_outside_mask - count_decimation_control.offset_n_counter
+ - count_decimation_control.n_count_filtered - zrange_filtered)
G_warning(_("The underlying libLAS library is at its limits."
" Previously reported counts might have been distorted."
" However, the import itself should be unaffected."));
- if (limit_n)
- G_message(_("%llu points imported (limit was %llu)"), limit_n_counter, limit_n);
- else
+ if (count_decimation_control.limit_n) {
+ G_message(_("%llu points imported (limit was %llu)"),
+ count_decimation_control.limit_n_counter,
+ count_decimation_control.limit_n);
+ else {
G_message(_("%llu points imported"), points_imported);
if (not_valid)
G_message(_("%llu input points were not valid"), not_valid);
if (n_outside)
@@ -1208,10 +1170,12 @@
G_message(_("%llu input points were filtered out by class number"), n_class_filtered);
if (zrange_filtered)
G_message(_("%llu input points were filtered outsite the range for z coordinate"), zrange_filtered);
- if (offset_n_counter)
- G_message(_("%llu input points were skipped at the begging using offset"), offset_n_counter);
- if (n_count_filtered)
- G_message(_("%llu input points were skipped by count-based decimation"), n_count_filtered);
+ if (count_decimation_control.offset_n_counter)
+ G_message(_("%llu input points were skipped at the begging using offset"),
+ count_decimation_control.offset_n_counter);
+ if (count_decimation_control.n_count_filtered)
+ G_message(_("%llu input points were skipped by count-based decimation"),
+ count_decimation_control.n_count_filtered);
#else
if (limit_n)
G_message(_("%lu points imported (limit was %d)"), limit_n_counter, limit_n);
@@ -1235,7 +1199,7 @@
G_message(_("%lu input points were skipped by count-based decimation"), n_count_filtered);
G_message(_("Accuracy of the printed point counts might be limited by your computer architecture."));
#endif
- if (limit_n)
G_message(_("The rest of points was ignored"));
if (cat_max_reached)
