[GRASS-SVN] r67321 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Mon Dec 21 20:11:45 PST 2015
Author: wenzeslaus
Date: 2015-12-21 20:11:45 -0800 (Mon, 21 Dec 2015)
New Revision: 67321
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: sync the lu version (fixes r67316 and r67317)
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-12-22 04:01:07 UTC (rev 67320)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-12-22 04:11:45 UTC (rev 67321)
@@ -1082,8 +1082,10 @@
G_message(_("%llu input points were skipped by count-based decimation"),
count_decimation_control.n_count_filtered);
#else
- if (limit_n)
- G_message(_("%lu points imported (limit was %d)"), limit_n_counter, limit_n);
+ if (count_decimation_control.limit_n)
+ G_message(_("%lu points imported (limit was %d)"),
+ count_decimation_control.limit_n_counter,
+ count_decimation_control.limit_n);
else
G_message(_("%lu points imported"), points_imported);
if (not_valid)
@@ -1098,10 +1100,12 @@
G_message(_("%lu input points were filtered out by class number"), n_class_filtered);
if (zrange_filtered)
G_message(_("%lu input points were filtered outsite the range for z coordinate"), zrange_filtered);
- if (offset_n_counter)
- G_message(_("%lu input points were skipped at the begging using offset"), offset_n_counter);
- if (n_count_filtered)
- G_message(_("%lu input points were skipped by count-based decimation"), n_count_filtered);
+ if (count_decimation_control.offset_n_counter)
+ G_message(_("%lu input points were skipped at the begging using offset"),
+ count_decimation_control.offset_n_counter);
+ if (count_decimation_control.n_count_filtered)
+ G_message(_("%lu input points were skipped by count-based decimation"),
+ count_decimation_control.n_count_filtered);
G_message(_("Accuracy of the printed point counts might be limited by your computer architecture."));
#endif
