[GRASS-SVN] r67327 - grass/branches/releasebranch_7_0/vector/v.to.db
svn_grass at osgeo.org
Tue Dec 22 07:05:48 PST 2015
Author: annakrat
Date: 2015-12-22 07:05:48 -0800 (Tue, 22 Dec 2015)
New Revision: 67327
grass/branches/releasebranch_7_0/vector/v.to.db/areas.c
grass/branches/releasebranch_7_0/vector/v.to.db/lines.c
grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html
v.to.db: apply patch from #2658 to fix units inconsistency (merge fom trunk, r67260)
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/areas.c
--- grass/branches/releasebranch_7_0/vector/v.to.db/areas.c 2015-12-22 14:50:09 UTC (rev 67326)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/areas.c 2015-12-22 15:05:48 UTC (rev 67327)
@@ -40,6 +40,8 @@
if ((options.option == O_COMPACT) || (options.option == O_FD) ||
(options.option == O_PERIMETER)) {
perimeter = Vect_get_area_perimeter(Map, area_num);
+ if (G_projection() != PROJECTION_LL)
+ perimeter = perimeter * G_database_units_to_meters_factor();
found = 0;
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/lines.c
--- grass/branches/releasebranch_7_0/vector/v.to.db/lines.c 2015-12-22 14:50:09 UTC (rev 67326)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/lines.c 2015-12-22 15:05:48 UTC (rev 67327)
@@ -123,6 +123,8 @@
else if (options.option == O_LENGTH && (type & GV_LINES)) {
/* Calculate line length */
len = Vect_line_geodesic_length(Points);
+ if (G_projection () != PROJECTION_LL)
+ len = len * G_database_units_to_meters_factor();
Values[idx].d1 += len;
else if (options.option == O_COOR && (type & GV_POINTS)) {
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html
--- grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html 2015-12-22 14:50:09 UTC (rev 67326)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/v.to.db.html 2015-12-22 15:05:48 UTC (rev 67327)
@@ -8,6 +8,8 @@
for closed lines (start equals end).
<h2>NOTES</h2>
+Measures of lengths and areas are always reported in meters, unless the
+<em>unit</em> parameter is set.
The units <em>miles</em>, <em>feet</em>, <em>meters</em> and
<em>kilometers</em> are square for <em>option=area</em>.
<p>Feet and acre units are always reported in their common versions
