[GRASS-SVN] r67330 - in grass/trunk: imagery/i.vi locale/po
svn_grass at osgeo.org
Tue Dec 22 08:10:37 PST 2015
Author: neteler
Date: 2015-12-22 08:10:37 -0800 (Tue, 22 Dec 2015)
New Revision: 67330
grass/trunk/imagery/i.vi/main.c
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fi.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ro.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
fix msg typo
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/imagery/i.vi/main.c 2015-12-22 16:10:37 UTC (rev 67330)
@@ -185,14 +185,14 @@
opt.sl_int->type = TYPE_DOUBLE;
opt.sl_int->required = NO;
opt.sl_int->description = _("Value of the intercept of the soil line (MSAVI2 only)");
- opt.sl_int->guisection = _("MSAVI2 seetings");
+ opt.sl_int->guisection = _("MSAVI2 settings");
opt.sl_red = G_define_option();
opt.sl_red->key = "soil_noise_reduction";
opt.sl_red->type = TYPE_DOUBLE;
opt.sl_red->required = NO;
opt.sl_red->description = _("Value of the factor of reduction of soil noise (MSAVI2 only)");
- opt.sl_red->guisection = _("MSAVI2 seetings");
+ opt.sl_red->guisection = _("MSAVI2 settings");
opt.bits = G_define_option();
opt.bits->key = "storage_bit";
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_ar.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -42793,7 +42793,7 @@
#: ../imagery/i.vi/main.c:181 ../imagery/i.vi/main.c:188
#: ../imagery/i.vi/main.c:195
#, fuzzy
-msgid "MSAVI2 seetings"
+msgid "MSAVI2 settings"
msgstr "طباعة نوع الملف الراسترى فقط"
#: ../imagery/i.vi/main.c:187
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_cs.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43255,7 +43255,7 @@
#, fuzzy
msgstr "Nastavení"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_de.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43469,7 +43469,7 @@
#, fuzzy
msgstr "Einstellungen"
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_el.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -41112,7 +41112,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_es.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43576,7 +43576,7 @@
#, fuzzy
msgstr "Configuraciones"
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_fi.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -39448,7 +39448,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_fr.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -45573,7 +45573,7 @@
#, fuzzy
msgstr "Réglages"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_it.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -42616,7 +42616,7 @@
#, fuzzy
msgstr "Impostazioni"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_ja.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -42663,7 +42663,7 @@
#, fuzzy
msgstr "設定 "
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_ko.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -41343,7 +41343,7 @@
#, fuzzy
msgstr "출력할 격자지도"
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_lv.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -42671,7 +42671,7 @@
#, fuzzy
msgstr "Nevarēja atrast rastra failu %s"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_pl.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -42709,7 +42709,7 @@
#, fuzzy
msgstr "Ustawienia"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_pt.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43970,7 +43970,7 @@
#, fuzzy
msgstr "Fonte"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43895,7 +43895,7 @@
#, fuzzy
msgstr "Fonte"
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_ro.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -40152,7 +40152,7 @@
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_ru.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43446,7 +43446,7 @@
#, fuzzy
msgstr "Параметры"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_sl.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43083,7 +43083,7 @@
#, fuzzy
msgstr "Ne najdem vhodne datoteke %s\n"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_th.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -42936,7 +42936,7 @@
#, fuzzy
msgstr "การกำหนด"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_tr.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -42113,7 +42113,7 @@
#, fuzzy
msgstr "Ayarlar"
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_vi.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43445,7 +43445,7 @@
#, fuzzy
msgstr "Các thiết lập"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2015-12-22 15:50:45 UTC (rev 67329)
+++ grass/trunk/locale/po/grassmods_zh.po 2015-12-22 16:10:37 UTC (rev 67330)
@@ -43016,7 +43016,7 @@
#, fuzzy
msgstr "无法获取栅格行\n"
